[QGIS Commit] r14015 - in docs/trunk/english_us/user_guide: .
working_with_ogc_screenies
svn_qgis at osgeo.org
Fri Aug 6 03:24:34 EDT 2010
Author: sholl
Date: 2010-08-06 07:24:34 +0000 (Fri, 06 Aug 2010)
New Revision: 14015
Added:
docs/trunk/english_us/user_guide/Makefile
docs/trunk/english_us/user_guide/working_with_ogc.tex
docs/trunk/english_us/user_guide/working_with_ogc_screenies/connection_wfs.png
docs/trunk/english_us/user_guide/working_with_ogc_screenies/connection_wms.png
docs/trunk/english_us/user_guide/working_with_ogc_screenies/wms_server-search.png
Updated OGC-chapter for new QGIS 1.5.0
* working_with_ogc.tex, working_with_ogc_screenies/connection_wfs.png,
working_with_ogc_screenies/wms_server-search.png,
working_with_ogc_screenies/connection_wms.png: Updated the OGC-part for
QGIS 1.5.0
* Makefile: Added a basic Makefile for easy building (at least under
linux). just type 'make' inside the folder, everything else will work
automagically.
Added: docs/trunk/english_us/user_guide/Makefile
--- docs/trunk/english_us/user_guide/Makefile (rev 0)
+++ docs/trunk/english_us/user_guide/Makefile 2010-08-06 07:24:34 UTC (rev 14015)
@@ -0,0 +1,80 @@
+# Stephan Holl <stephan at holl-land.de>, 2010
+# Makefile
+.SUFFIXES: .dvi .tex .jpg .eps .ps .fig .pdf .html .tif
+LATEX = latex
+PDFLATEX = pdflatex
+MAKE = make
+APPENDIX = $(wildcard appendices/*.tex)
+INCLUDES = conventions.tex \
+ core_plugins.tex \
+ external_plugins.tex \
+ features_at_a_glance.tex \
+ foreword.tex \
+ getting_started.tex \
+ grass_integration.tex \
+ help_and_support.tex \
+ index.tex \
+ introduction.tex \
+ literature.tex \
+ other_core_plugins.tex \
+ plugins.tex \
+ plugins_coordinate_capture.tex \
+ plugins_decorations.tex \
+ plugins_delimited_text.tex \
+ plugins_dxf2shape_converter.tex \
+ plugins_evis.tex \
+ plugins_ftools.tex \
+ plugins_gdaltools.tex \
+ plugins_georeferencer.tex \
+ plugins_gps.tex \
+ plugins_interpolation.tex \
+ plugins_mapserver_export.tex \
+ plugins_ogr_converter.tex \
+ plugins_openstreetmap.tex \
+ plugins_oracle_raster.tex \
+ plugins_quick_print.tex \
+ plugins_raster_algebra.tex \
+ plugins_raster_terrain.tex \
+ plugins_table_manager.tex \
+ preamble.tex \
+ print_composer.tex \
+ qgis_style.tex \
+ title.tex \
+ toc.tex \
+ working_with_ogc.tex \
+ working_with_projections.tex \
+ working_with_raster.tex \
+ working_with_vector.tex
+TARGET = user_guide.pdf
+IMAGES =
+all: $(INCLUDES) $(APPENDIX)
+ $(MAKE) $(TARGET)
+%.eps: %.jpg
+ convert jpg:$*.jpg eps:$*.eps
+%.eps: %.fig
+ fig2dev -L ps -p dummy_arg -z A4 $*.fig > $*.ps
+%.dvi: %.tex
+ $(LATEX) $*.tex && $(LATEX) $*.tex
+%.ps: %.dvi
+ dvips -R0 -o $*.ps $*.dvi
+%.pdf: %.tex $(INCLUDES) $(APPENDIX)
+ $(PDFLATEX) $*.tex $*.pdf && $(PDFLATEX) $*.tex $*.pdf && $(PDFLATEX) $*.tex $*.pdf
+%.tif: %.pdf
+ gs -sDEVICE=tiffg3 -sPapersize=a4 -dNOPAUSE -q -sOutputFile=$*.tif $*.pdf -c quit
+clean:
+ rm -f *.log *.toc *.aux *.out *.ps WARNINGS
+very-clean: rm
+ rm -f *.dvi *.pdf
Modified: docs/trunk/english_us/user_guide/working_with_ogc.tex
--- docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-08-05 19:26:49 UTC (rev 14014)
+++ docs/trunk/english_us/user_guide/working_with_ogc.tex 2010-08-06 07:24:34 UTC (rev 14015)
@@ -95,7 +95,7 @@
If you need to set up a proxy-server to be able to receive WMS-services
from the internet, you can add your proxy-server in the options.
Choose menu \mainmenuopt{Settings} > \dropmenuopttwo{mActionOptions}{Options}
-and click on the \tab{Proxy} tab. There you can add your proxy-settings
+and click on the \tab{Network \& Proxy} tab. There you can add your proxy-settings
and enable them by setting the \checkbox{Use proxy for web access}.
Make sure that you select the correct proxy-type from the
\dropmenuopt{Proxy type} dropdown menu.
@@ -170,6 +170,20 @@
\index{WMS!image encoding}
\end{Tip}
+\minisec{Options}
+The\tab{Options} section provides a text-field where you can add a name
+for the WMS-layer. This name will be presented in the legend after loading
+the layer.
+If the OnlineRessource-URL from the GetCapabilities-document is different
+from the given URL inside the connection-parameters, QGIS will ask you
+which URL it should use. Depending on your answer QGIS will check the
+checkboxes for yourself based on your answere. This can also be tweaked with a
+\checkbox{Ignore GetMap URL} checkbox and a
+\checkbox{Ignore GetFeatureInfo URL} checkbox separately, also later on.
\minisec{Layers} \label{ogc-wms-layers}
The \tab{Layers} section lists the layers available from the selected
@@ -278,6 +292,25 @@
Basically this option is a frontend to the API of
\url{http://geopole.org}.
+% Tilesets
+\subsection{Tilesets}
+\index{WMS!tileset}
+\index{WMS!WMS-C}
+When using WMS-C (Cached WMS) Services like
+\url{http://labs.metacarta.com/wms-c/Basic.py} you are able to browse
+through the \tab{tiles}-tab given by the server. Additional information like
+tilesize, formats and supported CRS are listed in this table.
+In combination with this feature you can use the tile scale slider from
+the \mainmenuopt{View}>\dropmenuopt{tile scale slider}, which gives you
+the available scales from the tileserver with nice slider docked in.
+% Identify
\subsection{Using the Identify Tool}\label{sec:ogc-wms-identify}
\index{WMS!identify}
\index{identify!WMS}
@@ -420,12 +453,16 @@
\index{WMS!secured layers!}\index{OGC!Authentication}
\end{Tip}
+% WFS-client
\section{WFS Client}\label{sec:ogc-wfs}
In QGIS, a WFS layer behaves pretty much like any other vector layer. You
can identify and select features and view the attribute table. An exception
-is that editing is not supported at this time. To start the WFS plugin you
+is that editing is not supported at this time (at the time of this writing
+there will be support for WFS-T in the near future as well).
+To start the WFS plugin you
need to open \mainmenuopt{Plugins} > \dropmenuopttwo{mActionShowPluginManager}{Plugin Manager...},
activate the \checkbox{WFS plugin} checkbox and click \button{OK}.
@@ -468,6 +505,15 @@
\caption{Adding a WFS layer \nixcaption}\label{fig:wfs_dmsolutions}
\end{figure}
+Without using the checkbox \checkbox{Only request features overlapping the
+current view extent} QGIS fetches all features from the WFS-server. If you
+only want to have a small selection based on your extent, zoom to the area
+of interest, request the WFS-layer again and make sure you have checked
+the checkbox mentioned above. Basically this addes the BBOX-parameter with
+the values from you current extent to the WFS-query. This is extremly
+usefull when you only want to request \textbf{some} features from a huge
+WFS-dataset.
You'll notice the download progress is visualized in the left bottom of the QGIS main window.
Once the layer is loaded, you can identify and select a province or two and view the
attribute table.
Modified: docs/trunk/english_us/user_guide/working_with_ogc_screenies/connection_wfs.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/working_with_ogc_screenies/connection_wms.png
Modified: docs/trunk/english_us/user_guide/working_with_ogc_screenies/wms_server-search.png
