[QGIS Commit] r14059 - in docs/trunk/english_us/user_guide: .
plugins_decorations_images plugins_georeferencer_images
svn_qgis at osgeo.org
Wed Aug 11 08:23:33 EDT 2010
Author: dassau
Date: 2010-08-11 12:23:32 +0000 (Wed, 11 Aug 2010)
New Revision: 14059
docs/trunk/english_us/user_guide/core_plugins.tex
docs/trunk/english_us/user_guide/external_plugins.tex
docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
docs/trunk/english_us/user_guide/plugins_gdaltools.tex
docs/trunk/english_us/user_guide/plugins_georeferencer_images/choose_points.png
docs/trunk/english_us/user_guide/plugins_georeferencer_images/transformation_settings.png
update figures
Modified: docs/trunk/english_us/user_guide/core_plugins.tex
--- docs/trunk/english_us/user_guide/core_plugins.tex 2010-08-11 11:55:13 UTC (rev 14058)
+++ docs/trunk/english_us/user_guide/core_plugins.tex 2010-08-11 12:23:32 UTC (rev 14059)
@@ -9,7 +9,7 @@
{\setlength{\extrarowheight}{15pt}
\small
-\begin{longtable}{|l|l|p{8cm}|}
+\begin{longtable}{|p{1.2cm}|p{3.8cm}|p{10.5cm}|}
\caption{22 QGIS Core Plugins}\label{tab:core_plugins} \\
\hline
\textbf{Icon} & \textbf{Plugin} & \textbf{Description}\\
Modified: docs/trunk/english_us/user_guide/external_plugins.tex
--- docs/trunk/english_us/user_guide/external_plugins.tex 2010-08-11 11:55:13 UTC (rev 14058)
+++ docs/trunk/english_us/user_guide/external_plugins.tex 2010-08-11 12:23:32 UTC (rev 14059)
@@ -23,7 +23,8 @@
You will find an up-to-date list of 'Official' plugins in the Official QGIS
Repository at \url{http://qgis.osgeo.org/download/plugins.html}. This list is
also available automatically from the \filename{Plugins installer}
-via \dropmenuopttwo{plugin_installer}{Fetch Python Plugins...}.
+via \\
+\dropmenuopttwo{plugin_installer}{Fetch Python Plugins...}.
\begin{table}[H]
\centering
Modified: docs/trunk/english_us/user_guide/plugins_decorations_images/scale_bar_dialog.png
(Binary files differ)
Modified: docs/trunk/english_us/user_guide/plugins_gdaltools.tex
--- docs/trunk/english_us/user_guide/plugins_gdaltools.tex 2010-08-11 11:55:13 UTC (rev 14058)
+++ docs/trunk/english_us/user_guide/plugins_gdaltools.tex 2010-08-11 12:23:32 UTC (rev 14059)
@@ -11,11 +11,11 @@
\subsection{The GDAL Library}\label{gdal_lib}
The GDAL library consists of a set of command line programs, each with a large list of options. Users comfortable with running commands from a terminal may prefer the command line, with access to the full set of options. The GDALTools plugin offers an easy interface to the tools, exposing only the most popular options.
-\begin{table}[ht]\index{gdaltools_list}
-\centering
-\caption{List of GDALTools}\medskip
- \begin{tabular}{|l|p{4in}|}
-\hline Build Virtual Raster & This program builds a VRT (Virtual Dataset) that is a mosaic of the list of input gdal datasets. \\
+{\setlength{\extrarowheight}{15pt}
+\begin{longtable}{|p{3cm}|p{13cm}|}
+\caption{List of GDAL tools}\label{tab:gdaltools} \\
+\hline
+Build Virtual Raster & This program builds a VRT (Virtual Dataset) that is a mosaic of the list of input gdal datasets. \\
\hline Contour & This program generates a vector contour file from the input raster elevation model (DEM).\\
\hline Rasterize & This program burns vector geometries (points, lines and polygons) into the raster band(s) of a raster image. Vectors are read from OGR supported vector formats. Note that the vector data must in the same coordinate system as the raster data; on the fly reprojection is not provided.\\
\hline Polygonize & This utility creates vector polygons for all connected regions of pixels in the raster sharing a common pixel value. Each polygon is created with an attribute indicating the pixel value of that polygon. A raster mask may also be provided to determine which pixels are eligible for processing.
@@ -39,10 +39,9 @@
The extents of the output file. If not specified the aggregate extents of all input files will be used. \\
\hline RGB to PCT & This utility will compute an optimal pseudo-color table for a given RGB image using a median cut algorithm on a downsampled RGB histogram. Then it converts the image into a pseudo-colored image using the color table. This conversion utilizes Floyd-Steinberg dithering (error diffusion) to maximize output image visual quality. \\
\hline PCT to RGB & This utility will convert a pseudocolor band on the input file into an output RGB file of the desired format.\\
+\hline
+\end{longtable}
-\end{tabular}
-\end{table}
\begin{figure}[ht]
\centering
\caption{\label{gdaltools_menu}The \emph{GDALTools} menu list \nixcaption}
Modified: docs/trunk/english_us/user_guide/plugins_georeferencer_images/choose_points.png
Modified: docs/trunk/english_us/user_guide/plugins_georeferencer_images/transformation_settings.png
