[QGIS Commit] r14085 - in trunk/qgis/src: app core/raster ui
svn_qgis at osgeo.org
Sun Aug 15 22:37:35 EDT 2010
Author: ersts
Date: 2010-08-16 02:37:35 +0000 (Mon, 16 Aug 2010)
New Revision: 14085
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.cpp
trunk/qgis/src/app/qgsrasterlayerproperties.h
trunk/qgis/src/core/raster/qgscolorrampshader.cpp
trunk/qgis/src/core/raster/qgscolorrampshader.h
trunk/qgis/src/core/raster/qgsrasterlayer.h
trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
-Added ability to interactively select pixels from the canvas to populate the transparency table in the raster layer properties dialog
-Closes ticket #2259
-Updated the color ramp shader to empty the color cache when a new color ramp is set
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-08-16 02:37:35 UTC (rev 14085)
@@ -6815,7 +6815,7 @@
else
- rlp = new QgsRasterLayerProperties( ml );
+ rlp = new QgsRasterLayerProperties( ml, mMapCanvas );
connect( rlp, SIGNAL( refreshLegend( QString, bool ) ), mMapLegend, SLOT( refreshLayerSymbology( QString, bool ) ) );
rlp->exec();
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.cpp
--- trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.cpp 2010-08-16 02:37:35 UTC (rev 14085)
@@ -17,6 +17,8 @@
#include <limits>
+#include "qgsmaptopixel.h"
+#include "qgsmapcanvas.h"
#include "qgslogger.h"
#include "qgsapplication.h"
#include "qgisapp.h"
@@ -46,19 +48,19 @@
#include <QColorDialog>
#include <QList>
#include <QSettings>
+#include <QMouseEvent>
const char * const ident =
"$Id$";
-QgsRasterLayerProperties::QgsRasterLayerProperties( QgsMapLayer *lyr, QWidget *parent, Qt::WFlags fl )
+QgsRasterLayerProperties::QgsRasterLayerProperties( QgsMapLayer* lyr, QgsMapCanvas* theCanvas, QWidget *parent, Qt::WFlags fl )
: QDialog( parent, fl ),
// Constant that signals property not used.
TRSTRING_NOT_SET( tr( "Not Set" ) ),
mRasterLayer( qobject_cast<QgsRasterLayer *>( lyr ) )
ignoreSpinBoxEvent = false; //Short circuit signal loop between min max field and stdDev spin box
mGrayMinimumMaximumEstimated = true;
mRGBMinimumMaximumEstimated = true;
@@ -271,6 +273,19 @@
pbtnExportColorMapToFile->setIcon( QgisApp::getThemeIcon( "/mActionFileSave.png" ) );
pbtnLoadColorMapFromFile->setIcon( QgisApp::getThemeIcon( "/mActionFileOpen.png" ) );
+ mMapCanvas = theCanvas;
+ mPixelSelectorTool = 0;
+ if( mMapCanvas )
+ mPixelSelectorTool = new QgsPixelSelectorTool( theCanvas );
+ connect( mPixelSelectorTool, SIGNAL( pixelSelected( int, int ) ), this, SLOT( pixelSelected( int, int ) ) );
+ else
+ pbnAddValuesFromDisplay->setEnabled( false );
// Only do pyramids if dealing directly with GDAL.
if ( mRasterLayerIsGdal )
@@ -335,6 +350,10 @@
QSettings settings;
settings.setValue( "/Windows/RasterLayerProperties/geometry", saveGeometry() );
settings.setValue( "/Windows/RasterLayerProperties/row", listWidget->currentRow() );
+ if( mPixelSelectorTool )
+ delete mPixelSelectorTool;
@@ -1700,7 +1719,13 @@
void QgsRasterLayerProperties::on_pbnAddValuesFromDisplay_clicked()
- QMessageBox::warning( this, "Function Not Available", "This functionality will be added soon" );
+ if( mMapCanvas && mPixelSelectorTool )
+ mMapCanvas->setMapTool( mPixelSelectorTool );
+ //Need to work around the modality of the dialog but can not just hide() it.
+ setModal( false );
+ lower();
void QgsRasterLayerProperties::on_pbnAddValuesManually_clicked()
@@ -2559,6 +2584,45 @@
sboxThreeBandStdDev->setEnabled( theState );
+void QgsRasterLayerProperties::pixelSelected( int x, int y )
+ //PixelSelectorTool has registered a mouse click on the canvas, so bring the dialog back to the front
+ raise();
+ setModal( true );
+ activateWindow();
+ //Get the pixel values and add a new entry to the transparency table
+ QMap< QString, QString > myPixelMap;
+ mMapCanvas->unsetMapTool( mPixelSelectorTool );
+ mRasterLayer->identify( mMapCanvas->getCoordinateTransform( )->toMapCoordinates( x, y ), myPixelMap );
+ if( tableTransparency->columnCount() == 2 )
+ QString myValue = myPixelMap[ mRasterLayer->grayBandName() ];
+ if( myValue != tr( "out of extent" ) )
+ tableTransparency->insertRow( tableTransparency->rowCount() );
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, tableTransparency->columnCount() - 1, new QTableWidgetItem( "100.0" ) );
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, 0, new QTableWidgetItem( myValue ) );
+ else
+ QString myValue = myPixelMap[ mRasterLayer->redBandName() ];
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, 1, new QTableWidgetItem( myPixelMap[ mRasterLayer->greenBandName() ] ) );
+ tableTransparency->setItem( tableTransparency->rowCount() - 1, 2, new QTableWidgetItem( myPixelMap[ mRasterLayer->blueBandName() ] ) );
void QgsRasterLayerProperties::sboxSingleBandStdDev_valueChanged( double theValue )
if ( !ignoreSpinBoxEvent )
@@ -3289,3 +3353,17 @@
myQSettings.setValue( "style/lastStyleDir", myFileDialog->directory().absolutePath() );
+QgsPixelSelectorTool::QgsPixelSelectorTool( QgsMapCanvas* theCanvas ) : QgsMapTool( theCanvas )
+QgsPixelSelectorTool::~QgsPixelSelectorTool()
+void QgsPixelSelectorTool::canvasReleaseEvent( QMouseEvent* theMouseEvent )
+ emit pixelSelected( theMouseEvent->x( ), theMouseEvent->y( ) );
Modified: trunk/qgis/src/app/qgsrasterlayerproperties.h
--- trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/app/qgsrasterlayerproperties.h 2010-08-16 02:37:35 UTC (rev 14085)
@@ -22,11 +22,15 @@
#include "ui_qgsrasterlayerpropertiesbase.h"
#include "qgisgui.h"
+#include "qgsmaptool.h"
#include "qgscolorrampshader.h"
#include "qgscontexthelp.h"
class QgsMapLayer;
+class QgsMapCanvas;
class QgsRasterLayer;
+class QgsPixelSelectorTool;
/**Property sheet for a raster map layer
@@ -41,7 +45,7 @@
/** \brief Constructor
* @param ml Map layer for which properties will be displayed
- QgsRasterLayerProperties( QgsMapLayer *lyr, QWidget *parent = 0, Qt::WFlags = QgisGui::ModalDialogFlags );
+ QgsRasterLayerProperties( QgsMapLayer *lyr, QgsMapCanvas* theCanvas, QWidget *parent = 0, Qt::WFlags = QgisGui::ModalDialogFlags );
/** \brief Destructor */
~QgsRasterLayerProperties();
@@ -82,6 +86,8 @@
void on_rbtnThreeBandMinMax_toggled( bool );
/** \brief slot executed when the three band standard deviation radio button is pressed. */
void on_rbtnThreeBandStdDev_toggled( bool );
+ void pixelSelected( int x, int y);
/** \brief this slot clears min max values from gui */
void sboxSingleBandStdDev_valueChanged( double );
@@ -208,6 +214,31 @@
QLinearGradient highlightGradient();
qreal mGradientHeight;
qreal mGradientWidth;
+ QgsMapCanvas* mMapCanvas;
+ QgsPixelSelectorTool* mPixelSelectorTool;
+ *Simple map tool for selecting pixels, specific to QgsRasterLayerProperties
+class QgsPixelSelectorTool: public QgsMapTool
+ Q_OBJECT
+ public:
+ QgsPixelSelectorTool( QgsMapCanvas* );
+ ~QgsPixelSelectorTool( );
+ /** \brief Method to handle mouse release, i.e., select, event */
+ void canvasReleaseEvent( QMouseEvent* theMouseEvent );
+ signals:
+ /** \brief Alter the listener ( raster properties dialog ) that a mouse click was registered */
+ private:
+ QgsMapCanvas * mMapCanvas;
#endif
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.cpp
--- trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.cpp 2010-08-16 02:37:35 UTC (rev 14085)
@@ -206,6 +206,13 @@
return false;
+void QgsColorRampShader::setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList )
+ mColorRampItemList = theList;
+ //Clear the cache
+ mColorCache.clear();
void QgsColorRampShader::setColorRampType( QgsColorRampShader::ColorRamp_TYPE theColorRampType )
//When the ramp type changes we need to clear out the cache
Modified: trunk/qgis/src/core/raster/qgscolorrampshader.h
--- trunk/qgis/src/core/raster/qgscolorrampshader.h 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/core/raster/qgscolorrampshader.h 2010-08-16 02:37:35 UTC (rev 14085)
@@ -74,7 +74,7 @@
int maximumColorCacheSize() { return mMaximumColorCacheSize; }
/** \brief Set custom colormap */
- void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList ) { mColorRampItemList = theList; } //TODO: sort on set
+ void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList ); //TODO: sort on set
/** \brief Set the color ramp type*/
void setColorRampType( QgsColorRampShader::ColorRamp_TYPE theColorRampType );
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.h
--- trunk/qgis/src/core/raster/qgsrasterlayer.h 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.h 2010-08-16 02:37:35 UTC (rev 14085)
@@ -59,7 +59,6 @@
class QgsRectangle;
class QgsRasterBandStats;
class QgsRasterPyramid;
-class QgsRasterLayerProperties;
class QImage;
class QPixmap;
class QSlider;
Modified: trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui
--- trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-08-14 23:12:30 UTC (rev 14084)
+++ trunk/qgis/src/ui/qgsrasterlayerpropertiesbase.ui 2010-08-16 02:37:35 UTC (rev 14085)
@@ -1270,7 +1270,7 @@
<item>
<widget class="QToolButton" name="pbnAddValuesFromDisplay">
<property name="enabled">
- <bool>false</bool>
+ <bool>true</bool>
</property>
<property name="toolTip">
<string>Add Values from display</string>
@@ -1888,9 +1888,10 @@
<html><head><meta name="qrichtext" content="1" /><style type="text/css">
p, li { white-space: pre-wrap; }
</style></head><body style=" font-family:'Sans'; font-size:10pt; font-weight:400; font-style:normal;">
-<table style="-qt-table-type: root; margin-top:4px; margin-bottom:4px; margin-left:4px; margin-right:4px;">
+<table border="0" style="-qt-table-type: root; margin-top:4px; margin-bottom:4px; margin-left:4px; margin-right:4px;">
<tr>
<td style="border: none;">
+<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px;"></p>
<p style="-qt-paragraph-type:empty; margin-top:0px; margin-bottom:0px; margin-left:0px; margin-right:0px; -qt-block-indent:0; text-indent:0px; font-family:'Sans Serif'; font-size:9pt;"></p></td></tr></table></body></html></string>
</property>
</widget>
