[QGIS Commit] r14105 - in trunk/qgis/python/plugins/GdalTools: .
tools
svn_qgis at osgeo.org
Wed Aug 18 06:24:34 EDT 2010
Author: brushtyler
Date: 2010-08-18 10:24:34 +0000 (Wed, 18 Aug 2010)
New Revision: 14105
trunk/qgis/python/plugins/GdalTools/__init__.py
trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
applied patch attached to #2932 to improve build overviews (gdaltools).
Thanks to Duarte!
Modified: trunk/qgis/python/plugins/GdalTools/__init__.py
--- trunk/qgis/python/plugins/GdalTools/__init__.py 2010-08-18 09:46:03 UTC (rev 14104)
+++ trunk/qgis/python/plugins/GdalTools/__init__.py 2010-08-18 10:24:34 UTC (rev 14105)
@@ -22,7 +22,7 @@
def description():
return "Integrate gdal tools into qgis"
def version():
- return "Version 1.2.9"
+ return "Version 1.2.10"
def qgisMinimumVersion():
return "1.0"
def classFactory(iface):
Modified: trunk/qgis/python/plugins/GdalTools/tools/doOverview.py
--- trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2010-08-18 09:46:03 UTC (rev 14104)
+++ trunk/qgis/python/plugins/GdalTools/tools/doOverview.py 2010-08-18 10:24:34 UTC (rev 14105)
@@ -32,7 +32,12 @@
(self.inputLayerCombo, [SIGNAL("currentIndexChanged(int)"), SIGNAL("editTextChanged(const QString &)")] ),
( self.algorithmCombo, SIGNAL( "currentIndexChanged( int )" ), self.algorithmCheck ),
( self.levelsEdit, SIGNAL( "textChanged( const QString & )" ) ),
- ( self.roModeCheck, SIGNAL( "stateChanged( int )" ) )
+ ( self.roModeCheck, SIGNAL( "stateChanged( int )" ) ),
+ ( self.rrdCheck, SIGNAL( "stateChanged(int)" ) ),
+ ( self.jpegQualitySpin, SIGNAL( "valueChanged (int)" ) ),
+ ( self.jpegQualityContainer, None, self.tiffjpegCheck),
+ ( self.jpegQualityContainer, None, None, "1.7.0"), #only show for GDAL >=1.7.0
+ ( self.cleanCheck, SIGNAL( "stateChanged(int)" ), None, "1.7.0" ) #only show for GDAL >=1.7.0
@@ -96,6 +101,14 @@
arguments << self.resampling_method[self.algorithmCombo.currentIndex()]
if self.roModeCheck.isChecked():
arguments << "-ro"
+ if self.rrdCheck.isChecked():
+ arguments << "--config" << "USE_RRD" << "YES"
+ if self.tiffjpegCheck.isChecked():
+ arguments << "--config" << "COMPRESS_OVERVIEW" << "JPEG" << "--config" << "PHOTOMETRIC_OVERVIEW" << "YCBCR" << "--config" << "INTERLEAVE_OVERVIEW" << "PIXEL"
+ if self.jpegQualityContainer.isVisible():
+ arguments << "--config" << "JPEG_QUALITY_OVERVIEW" << self.jpegQualitySpin.cleanText()
+ if self.cleanCheck.isChecked():
+ arguments << "-clean"
if self.isBatchEnabled():
return arguments
Modified: trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui
--- trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2010-08-18 09:46:03 UTC (rev 14104)
+++ trunk/qgis/python/plugins/GdalTools/tools/widgetOverview.ui 2010-08-18 10:24:34 UTC (rev 14105)
@@ -7,11 +7,11 @@
<x>0</x>
<y>0</y>
<width>376</width>
- <height>205</height>
+ <height>323</height>
</rect>
</property>
<property name="sizePolicy">
- <sizepolicy hsizetype="Expanding" vsizetype="Preferred">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
<horstretch>0</horstretch>
<verstretch>0</verstretch>
</sizepolicy>
@@ -120,13 +120,112 @@
</layout>
</item>
<item>
+ <widget class="QCheckBox" name="cleanCheck">
+ <property name="toolTip">
+ <string>Remove all overviews.</string>
+ </property>
+ <property name="text">
+ <string>Clean</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QCheckBox" name="roModeCheck">
+ <string>In order to generate external overview (for GeoTIFF especially).</string>
+ </property>
<string>Open in read-only mode</string>
</property>
</widget>
</item>
<item>
+ <widget class="QCheckBox" name="tiffjpegCheck">
+ <string>Create external overviews in TIFF format, compressed using JPEG.</string>
+ </property>
+ <string>Overviews in TIFF format with JPEG compression</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QFrame" name="jpegQualityContainer">
+ <property name="enabled">
+ <bool>true</bool>
+ </property>
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Fixed">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <property name="minimumSize">
+ <size>
+ <width>0</width>
+ <height>25</height>
+ </size>
+ </property>
+ <layout class="QHBoxLayout" name="horizontalLayout_2">
+ <property name="leftMargin">
+ <number>24</number>
+ </property>
+ <property name="topMargin">
+ <number>0</number>
+ </property>
+ <property name="bottomMargin">
+ </property>
+ <item>
+ <widget class="QLabel" name="jpegQualityLabel">
+ <string>For JPEG compressed external overviews,
+the JPEG quality can be set.</string>
+ </property>
+ <string>JPEG Quality (1-100):</string>
+ </property>
+ </widget>
+ </item>
+ <item>
+ <widget class="QSpinBox" name="jpegQualitySpin">
+ <bool>true</bool>
+ </property>
+ <sizepolicy hsizetype="Expanding" vsizetype="Fixed">
+ </sizepolicy>
+ </property>
+ </property>
+ <property name="maximum">
+ <number>100</number>
+ </property>
+ <property name="value">
+ <number>80</number>
+ </property>
+ </widget>
+ </item>
+ </layout>
+ </widget>
+ </item>
+ <item>
+ <widget class="QCheckBox" name="rrdCheck">
+ <string>Alternate overview format using Erdas Imagine format,
+placing the overviews in an associated .aux file
+suitable for direct use with Imagine,ArcGIS, GDAL.</string>
+ </property>
+ <string>Use Imagine format (.aux file)</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QProgressBar" name="progressBar"/>
</item>
</layout>
