[QGIS Commit] r14827 - in trunk/qgis: python/core python/gui src/gui
svn_qgis at osgeo.org
Thu Dec 2 04:55:43 EST 2010
Author: mhugent
Date: 2010-12-02 01:55:42 -0800 (Thu, 02 Dec 2010)
New Revision: 14827
Added:
trunk/qgis/python/core/qgsaddremoveitemcommand.sip
trunk/qgis/python/core/qgscomposeritemcommand.sip
trunk/qgis/python/core/core.sip
trunk/qgis/python/core/qgscomposition.sip
trunk/qgis/python/gui/qgscomposerview.sip
trunk/qgis/src/gui/qgscomposerview.h
Add python bindings for composer command classes
Modified: trunk/qgis/python/core/core.sip
--- trunk/qgis/python/core/core.sip 2010-12-02 08:44:48 UTC (rev 14826)
+++ trunk/qgis/python/core/core.sip 2010-12-02 09:55:42 UTC (rev 14827)
@@ -11,9 +11,11 @@
// TODO: more files to wrap
%Include qgis.sip
+%Include qgsaddremoveitemcommand.sip
%Include qgsapplication.sip
%Include qgscomposerattributetable.sip
%Include qgscomposeritem.sip
+%Include qgscomposeritemcommand.sip
%Include qgscomposerlabel.sip
%Include qgscomposerlegend.sip
%Include qgscomposermap.sip
Added: trunk/qgis/python/core/qgsaddremoveitemcommand.sip
--- trunk/qgis/python/core/qgsaddremoveitemcommand.sip (rev 0)
+++ trunk/qgis/python/core/qgsaddremoveitemcommand.sip 2010-12-02 09:55:42 UTC (rev 14827)
@@ -0,0 +1,25 @@
+/** \ingroup MapComposer
+A composer command class for adding / removing composer items. If mState == Removed, the command owns the item*/
+class QgsAddRemoveItemCommand: QObject, QUndoCommand
+%TypeHeaderCode
+ #include "qgsaddremoveitemcommand.h"
+%End
+ public:
+ enum State
+ Added = 0,
+ Removed
+ QgsAddRemoveItemCommand( State s, QgsComposerItem* item, QgsComposition* c, const QString& text, QUndoCommand* parent = 0 );
+ ~QgsAddRemoveItemCommand();
+ void redo();
+ void undo();
+ signals:
+ void itemAdded( QgsComposerItem* item );
+ void itemRemoved( QgsComposerItem* item );
Added: trunk/qgis/python/core/qgscomposeritemcommand.sip
--- trunk/qgis/python/core/qgscomposeritemcommand.sip (rev 0)
+++ trunk/qgis/python/core/qgscomposeritemcommand.sip 2010-12-02 09:55:42 UTC (rev 14827)
@@ -0,0 +1,85 @@
+/**\ingroup MapComposer
+Undo command to undo/redo all composer item related changes*/
+class QgsComposerItemCommand: QUndoCommand
+%TypeHeaderCode
+ #include "qgscomposeritemcommand.h"
+%End
+ public:
+ QgsComposerItemCommand( QgsComposerItem* item, const QString& text, QUndoCommand* parent = 0 );
+ virtual ~QgsComposerItemCommand();
+ /**Reverses the command*/
+ void undo();
+ /**Replays the command*/
+ void redo();
+ /**Saves current item state as previous state*/
+ void savePreviousState();
+ /**Saves current item state as after state*/
+ void saveAfterState();
+ QDomDocument previousState() const;
+ QDomDocument afterState() const;
+ /**Returns true if previous state and after state are valid and different*/
+ bool containsChange() const;
+A composer command that merges together with other commands having the same context (=id). Keeps the oldest previous state and uses the
+ newest after state. The purpose is to avoid too many micro changes in the history*/
+class QgsComposerMergeCommand: QgsComposerItemCommand
+%TypeHeaderCode
+%End
+ public:
+ enum Context
+ Unknown = 0,
+ //composer label
+ ComposerLabelSetText,
+ //composer map
+ ComposerMapRotation,
+ ComposerMapAnnotationDistance,
+ //composer legend
+ ComposerLegendText,
+ LegendSymbolWidth,
+ LegendSymbolHeight,
+ LegendLayerSpace,
+ LegendSymbolSpace,
+ LegendIconSymbolSpace,
+ LegendBoxSpace,
+ //composer picture
+ ComposerPictureRotation,
+ // composer scalebar
+ ScaleBarLineWidth,
+ ScaleBarHeight,
+ ScaleBarSegmentSize,
+ ScaleBarSegmentsLeft,
+ ScaleBarNSegments,
+ ScaleBarUnitText,
+ ScaleBarMapUnitsSegment,
+ ScaleBarLabelBarSize,
+ ScaleBarBoxContentSpace,
+ // composer table
+ TableMaximumFeatures,
+ TableMargin,
+ TableGridStrokeWidth,
+ //composer shape
+ ShapeRotation,
+ ShapeOutlineWidth,
+ //composer arrow
+ ArrowOutlineWidth,
+ ArrowHeadWidth,
+ //item
+ ItemOutlineWidth
+ QgsComposerMergeCommand( Context c, QgsComposerItem* item, const QString& text );
+ ~QgsComposerMergeCommand();
+ bool mergeWith( const QUndoCommand * command );
+ int id() const;
Modified: trunk/qgis/python/core/qgscomposition.sip
--- trunk/qgis/python/core/qgscomposition.sip 2010-12-02 08:44:48 UTC (rev 14826)
+++ trunk/qgis/python/core/qgscomposition.sip 2010-12-02 09:55:42 UTC (rev 14827)
@@ -57,6 +57,9 @@
void setGridStyle( GridStyle s );
GridStyle gridStyle() const;
+ /**Returns pointer to undo/redo command storage*/
+ QUndoStack* undoStack();
/**Returns the topmose composer item. Ignores mPaperItem*/
QgsComposerItem* composerItemAt( const QPointF & position );
@@ -125,4 +128,15 @@
/**Snaps a scene coordinate point to grid*/
QPointF snapPointToGrid( const QPointF& scenePoint ) const;
+ /**Allocates new item command and saves initial state in it
+ @param item target item
+ @param commandText descriptive command text
+ @param c context for merge commands (unknown for non-mergeable commands)*/
+ void beginCommand( QgsComposerItem* item, const QString& commandText, QgsComposerMergeCommand::Context c = QgsComposerMergeCommand::Unknown );
+ /**Saves end state of item and pushes command to the undo history*/
+ void endCommand();
+ /**Deletes current command*/
+ void cancelCommand();
Modified: trunk/qgis/python/gui/qgscomposerview.sip
--- trunk/qgis/python/gui/qgscomposerview.sip 2010-12-02 08:44:48 UTC (rev 14826)
+++ trunk/qgis/python/gui/qgscomposerview.sip 2010-12-02 09:55:42 UTC (rev 14827)
@@ -68,6 +68,12 @@
/**Returns the composer main window*/
QMainWindow* composerWindow();
+ void setPaintingEnabled( bool enabled );
+ bool paintingEnabled() const;
+ /**Convenience function to create a QgsAddRemoveItemCommand, connect its signals and push it to the undo stack*/
+ void pushAddRemoveCommand( QgsComposerItem* item, const QString& text, QgsAddRemoveItemCommand::State state = QgsAddRemoveItemCommand::Added );
protected:
void mousePressEvent( QMouseEvent* );
void mouseReleaseEvent( QMouseEvent* );
Modified: trunk/qgis/src/gui/qgscomposerview.h
--- trunk/qgis/src/gui/qgscomposerview.h 2010-12-02 08:44:48 UTC (rev 14826)
+++ trunk/qgis/src/gui/qgscomposerview.h 2010-12-02 09:55:42 UTC (rev 14827)
@@ -102,6 +102,9 @@
void setPaintingEnabled( bool enabled ) { mPaintingEnabled = enabled; }
bool paintingEnabled() const { return mPaintingEnabled; }
protected:
@@ -115,10 +118,7 @@
void paintEvent( QPaintEvent* event );
- /**Convenience function to create a QgsAddRemoveItemCommand, connect its signals and push it to the undo stack*/
- void pushAddRemoveCommand( QgsComposerItem* item, const QString& text, QgsAddRemoveItemCommand::State state = QgsAddRemoveItemCommand::Added );
private:
/**Status of shift key (used for multiple selection)*/
bool mShiftKeyPressed;
