[QGIS Commit] r14840 - in branches/threading-branch/src: core
core/composer gui plugins/coordinate_capture
svn_qgis at osgeo.org
Sat Dec 4 15:56:07 EST 2010
Author: wonder
Date: 2010-12-04 12:56:07 -0800 (Sat, 04 Dec 2010)
New Revision: 14840
branches/threading-branch/src/core/composer/qgscomposermap.cpp
branches/threading-branch/src/core/qgsmaprenderer.cpp
branches/threading-branch/src/core/qgsmaprenderer.h
branches/threading-branch/src/gui/qgsmapcanvas.cpp
branches/threading-branch/src/gui/qgsmapoverviewcanvas.cpp
branches/threading-branch/src/plugins/coordinate_capture/coordinatecapturemaptool.cpp
Use QFlags for rendering hints in map renderer
Modified: branches/threading-branch/src/core/composer/qgscomposermap.cpp
--- branches/threading-branch/src/core/composer/qgscomposermap.cpp 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/core/composer/qgscomposermap.cpp 2010-12-04 20:56:07 UTC (rev 14840)
@@ -135,16 +135,8 @@
painter->setRenderHint( QPainter::Antialiasing );
- QgsRenderContext* theRendererContext = theMapRenderer.rendererContext();
- if ( theRendererContext )
- theRendererContext->setDrawEditingInformation( false );
- theRendererContext->setRenderingStopped( false );
+ theMapRenderer.setRenderHint( QgsMapRenderer::ForceVectorOutput );
- // force vector output (no caching of marker images etc.)
- theRendererContext->setForceVectorOutput( true );
//force composer map scale for scale dependent visibility
double bk_scale = theMapRenderer.scale();
theMapRenderer.setScale( scale() );
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-12-04 20:56:07 UTC (rev 14840)
@@ -54,7 +54,7 @@
mThreadingEnabled = false;
mCache = NULL;
- next.overview = false;
+ next.hints = 0;
next.dpi = 96;
next.size = QSize( 0, 0 );
next.projectionsEnabled = false;
@@ -226,7 +226,7 @@
mRenderTime.start();
#endif
- mRenderContext.setDrawEditingInformation( !curr.overview );
+ mRenderContext.setDrawEditingInformation( !curr.hints.testFlag( DrawEditingInformation ) );
mRenderContext.setPainter( painter );
mRenderContext.setCoordinateTransform( 0 );
//this flag is only for stopping during the current rendering progress,
@@ -266,7 +266,7 @@
void QgsMapRenderer::finishRendering()
// render labels for vector layers (not using PAL)
- if ( !curr.overview )
+ if ( !curr.hints.testFlag( NoLabeling ) )
renderLabels();
@@ -362,7 +362,9 @@
//QgsDebugMsg( " Scale dep. visibility enabled? " + QString( "%1" ).arg( ml->hasScaleBasedVisibility() ) );
//QgsDebugMsg( " Input extent: " + ml->extent().toString() );
- if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > curr.scale || ml->maximumScale() < curr.scale ) && ! curr.overview )
+ if ( ! ( curr.hints & IgnoreScaleBasedVisibility ) &&
+ ml->hasScaleBasedVisibility() &&
+ ( ml->minimumScale() > curr.scale || ml->maximumScale() < curr.scale ) )
QgsDebugMsg( "Layer not rendered because it is not within the defined "
"visibility scale range" );
@@ -586,7 +588,7 @@
tctx.ctx = mRenderContext;
QPainter* painter = new QPainter(tctx.img);
- painter->setRenderHint( QPainter::Antialiasing, curr.antialiasingEnabled );
+ painter->setRenderHint( QPainter::Antialiasing, curr.hints.testFlag( Antialiasing ) );
tctx.ctx.setPainter( painter );
// schedule DRAW to a list
@@ -614,7 +616,7 @@
// alter painter
QPainter * mypPainter = new QPainter( &cacheImage );
- mypPainter->setRenderHint( QPainter::Antialiasing, curr.antialiasingEnabled );
+ mypPainter->setRenderHint( QPainter::Antialiasing, curr.hints.testFlag( Antialiasing ) );
mRenderContext.setPainter( mypPainter );
// DRAW!
@@ -1290,7 +1292,8 @@
void QgsMapRenderer::enableOverviewMode( bool isOverview )
- next.overview = isOverview;
+ setRenderHints( NoLabeling | IgnoreScaleBasedVisibility, isOverview );
+ setRenderHints( DrawEditingInformation, !isOverview );
void QgsMapRenderer::setOutputUnits( OutputUnits u )
@@ -1323,11 +1326,6 @@
-void QgsMapRenderer::setAntialiasingEnabled( bool enabled )
- next.antialiasingEnabled = enabled;
double QgsMapRenderer::scale() const
return next.scale;
@@ -1358,11 +1356,6 @@
return next.labelingEngine;
-bool QgsMapRenderer::isAntialiasingEnabled() const
- return next.antialiasingEnabled;
void QgsMapRenderer::clearCache()
if ( mDrawing )
@@ -1388,6 +1381,27 @@
+void QgsMapRenderer::setRenderHint( RenderHint hint, bool on )
+ if ( on )
+ next.hints |= hint;
+ else
+ next.hints &= ~hint;
+void QgsMapRenderer::setRenderHints( RenderHints hints, bool on )
+ if ( on )
+ next.hints |= hints;
+ else
+ next.hints &= ~hints;
+bool QgsMapRenderer::testRenderHint( RenderHint hint ) const
+ return next.hints.testFlag( hint );
QgsMapRendererCache::QgsMapRendererCache()
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/core/qgsmaprenderer.h 2010-12-04 20:56:07 UTC (rev 14840)
@@ -23,6 +23,7 @@
#include <QFutureWatcher>
#include <QTime>
#include <QImage>
+#include <QFlags>
#include "qgis.h"
#include "qgsrectangle.h"
@@ -227,6 +228,22 @@
//! Added in QGIS v1.4
void setLabelingEngine( QgsLabelingEngineInterface* iface );
+ enum RenderHint {
+ Antialiasing = 0x01,
+ ForceVectorOutput = 0x02,
+ DrawEditingInformation = 0x04,
+ NoLabeling = 0x08,
+ IgnoreScaleBasedVisibility = 0x10,
+ MultipleThreads = 0x20
+ // ??? Caching = 0x10,
+ Q_DECLARE_FLAGS(RenderHints, RenderHint)
+ void setRenderHint( RenderHint hint, bool on = true );
+ void setRenderHints( RenderHints hints, bool on = true );
+ bool testRenderHint( RenderHint hint ) const;
//! Enable or disable rendering in multiple threads on multiprocessor computers
//! Added in QGIS v1.6
void setThreadingEnabled( bool use );
@@ -243,12 +260,6 @@
bool isCachingEnabled() const { return mCache != NULL; }
- //! Added in QGIS v1.6
- void setAntialiasingEnabled( bool enabled );
- bool isAntialiasingEnabled() const;
//! Schedule a redraw of the layers.
//! This function returns immediately after starting the asynchronous rendering process.
//! Any previous rendering operations must be finished/canceled first.
@@ -369,9 +380,6 @@
//! current extent to be drawn
QgsRectangle extent;
- //! indicates whether it's map image for overview
- bool overview;
QSize size;
//! detemines whether on the fly projection support is enabled
@@ -389,7 +397,7 @@
//! Labeling engine (NULL by default)
QgsLabelingEngineInterface* labelingEngine;
- bool antialiasingEnabled;
+ RenderHints hints;
} Parameters;
@@ -424,5 +432,7 @@
+Q_DECLARE_OPERATORS_FOR_FLAGS(QgsMapRenderer::RenderHints)
#endif
Modified: branches/threading-branch/src/gui/qgsmapcanvas.cpp
--- branches/threading-branch/src/gui/qgsmapcanvas.cpp 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/gui/qgsmapcanvas.cpp 2010-12-04 20:56:07 UTC (rev 14840)
@@ -102,6 +102,7 @@
setFocusPolicy( Qt::StrongFocus );
mMapRenderer = new QgsMapRenderer;
+ mMapRenderer->setRenderHint( QgsMapRenderer::DrawEditingInformation, true );
// create map canvas item which will show the map
mMap = new QgsMapCanvasMap( this );
@@ -156,7 +157,7 @@
void QgsMapCanvas::enableAntiAliasing( bool theFlag )
- mMapRenderer->setAntialiasingEnabled( theFlag );
+ mMapRenderer->setRenderHint( QgsMapRenderer::Antialiasing, theFlag );
if ( mMapOverview )
mMapOverview->enableAntiAliasing( theFlag );
Modified: branches/threading-branch/src/gui/qgsmapoverviewcanvas.cpp
--- branches/threading-branch/src/gui/qgsmapoverviewcanvas.cpp 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/gui/qgsmapoverviewcanvas.cpp 2010-12-04 20:56:07 UTC (rev 14840)
@@ -253,7 +253,7 @@
painter.begin( &mPixmap );
// antialiasing
- mMapRenderer->setAntialiasingEnabled( mAntiAliasing );
+ mMapRenderer->setRenderHint( QgsMapRenderer::Antialiasing, mAntiAliasing );
// render image
mMapRenderer->render( &painter );
Modified: branches/threading-branch/src/plugins/coordinate_capture/coordinatecapturemaptool.cpp
--- branches/threading-branch/src/plugins/coordinate_capture/coordinatecapturemaptool.cpp 2010-12-04 20:50:02 UTC (rev 14839)
+++ branches/threading-branch/src/plugins/coordinate_capture/coordinatecapturemaptool.cpp 2010-12-04 20:56:07 UTC (rev 14840)
@@ -58,11 +58,6 @@
void CoordinateCaptureMapTool::canvasReleaseEvent( QMouseEvent * thepEvent )
- if ( !mpMapCanvas || mpMapCanvas->isDrawing() )
- return;
QgsPoint myOriginalPoint =
mCanvas->getCoordinateTransform()->toMapCoordinates( thepEvent->x(), thepEvent->y() );
emit mouseClicked( myOriginalPoint );
