[QGIS Commit] r14890 - trunk/qgis/src/providers/delimitedtext
svn_qgis at osgeo.org
Sat Dec 11 14:11:12 EST 2010
Author: gsherman
Date: 2010-12-11 11:11:12 -0800 (Sat, 11 Dec 2010)
New Revision: 14890
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h
Patch for ticket #3320 to fix delimited text plugin crash
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2010-12-11 15:51:25 UTC (rev 14889)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.cpp 2010-12-11 19:11:12 UTC (rev 14890)
@@ -134,6 +134,7 @@
QgsDelimitedTextProvider::QgsDelimitedTextProvider( QString uri )
: QgsVectorDataProvider( uri )
, mHasWktField( false )
+ , mFirstDataLine(0)
, mFieldCount( 0 )
, mXFieldIndex( -1 ), mYFieldIndex( -1 )
, mWktFieldIndex( -1 )
@@ -199,7 +200,7 @@
if ( mFileName.isEmpty() || mDelimiter.isEmpty() )
// uri is invalid so the layer must be too...
- QString( "Data source is invalid" );
+ QgsDebugMsg( "Data source is invalid" );
return;
@@ -238,12 +239,13 @@
lineNumber++;
line = readLine( mStream ); // line of text excluding '\n', default local 8 bit encoding.
- if ( line.isEmpty() )
- continue;
if ( lineNumber < mSkipLines + 1 )
continue;
+ if ( line.isEmpty() )
+ continue;
if ( !hasFields )
// Get the fields from the header row and store them in the
@@ -297,15 +299,14 @@
else // hasFields == true - field names already read
+ if( mFirstDataLine == 0 ) mFirstDataLine = lineNumber;
// split the line on the delimiter
QStringList parts = splitLine( line );
- // Skip malformed lines silently. Report line number with nextFeature()
- if ( parts.size() != mFieldCount )
- continue;
+ // Ensure that the input has at least the required number of fields (mainly to tolerate
+ // missed blank strings at end of row)
+ while( parts.size() < mFieldCount ) parts.append("");
if ( mHasWktField && mWktFieldIndex >= 0 )
@@ -443,6 +444,8 @@
// lex the tokens from the current data line
QStringList tokens = splitLine( line );
+ while( tokens.size() < mFieldCount ) tokens.append("");
QgsGeometry *geom = 0;
@@ -450,6 +453,8 @@
try
QString &sWkt = tokens[mWktFieldIndex];
+ // Remove Z and M coordinates if present, as currently fromWkt doesn't
+ // support these.
if ( mWktHasZM )
sWkt.remove( mWktZMRegexp ).replace( mWktCrdRegexp, "\\1" );
@@ -505,6 +510,7 @@
i != mAttributesToFetch.end();
++i )
QString &value = tokens[attributeColumns[*i]];
QVariant val;
switch ( attributeFields[*i].type() )
@@ -624,11 +630,10 @@
// Reset feature id to 0
mFid = 0;
- // Skip ahead one line since first record is always assumed to be
- // the header record
+ // Skip to first data record
mStream->seek( 0 );
- int n = mSkipLines + 1;
- while ( n-- )
+ int n = mFirstDataLine-1;
+ while ( n-- > 0 )
Modified: trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h
--- trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h 2010-12-11 15:51:25 UTC (rev 14889)
+++ trunk/qgis/src/providers/delimitedtext/qgsdelimitedtextprovider.h 2010-12-11 19:11:12 UTC (rev 14890)
@@ -222,6 +222,7 @@
long mNumberFeatures;
int mSkipLines;
+ int mFirstDataLine; // Actual first line of data (accounting for blank lines)
//! Storage for any lines in the file that couldn't be loaded
QStringList mInvalidLines;
