[QGIS Commit] r14913 - in trunk/qgis: images images/themes/default
images/themes/default/styleicons src/gui/symbology-ng src/ui
svn_qgis at osgeo.org
Tue Dec 14 17:09:39 EST 2010
Author: wonder
Date: 2010-12-14 14:09:39 -0800 (Tue, 14 Dec 2010)
New Revision: 14913
Added:
trunk/qgis/images/themes/default/styleicons/
trunk/qgis/images/themes/default/styleicons/color.png
trunk/qgis/images/themes/default/styleicons/style-line.png
trunk/qgis/images/themes/default/styleicons/style-point.png
trunk/qgis/images/themes/default/styleicons/style-polygon.png
trunk/qgis/images/images.qrc
trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
trunk/qgis/src/ui/qgsstylev2managerdialogbase.ui
Better style manager dialog with icons from Robert Szczepanek.
Modified: trunk/qgis/images/images.qrc
--- trunk/qgis/images/images.qrc 2010-12-14 20:45:46 UTC (rev 14912)
+++ trunk/qgis/images/images.qrc 2010-12-14 22:09:39 UTC (rev 14913)
@@ -279,6 +279,10 @@
<file>themes/default/propertyicons/rendering.png</file>
<file>themes/default/propertyicons/symbology.png</file>
<file>themes/default/propertyicons/transparency.png</file>
+ <file>themes/default/styleicons/color.png</file>
+ <file>themes/default/styleicons/style-point.png</file>
+ <file>themes/default/styleicons/style-line.png</file>
+ <file>themes/default/styleicons/style-polygon.png</file>
<file>icons/qgis-icon-16x16.png</file>
<file>icons/qgis-icon-60x60.png</file>
<file>themes/gis/mActionAddArrow.png</file>
Added: trunk/qgis/images/themes/default/styleicons/color.png
(Binary files differ)
Property changes on: trunk/qgis/images/themes/default/styleicons/color.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: trunk/qgis/images/themes/default/styleicons/style-line.png
Property changes on: trunk/qgis/images/themes/default/styleicons/style-line.png
Added: trunk/qgis/images/themes/default/styleicons/style-point.png
Property changes on: trunk/qgis/images/themes/default/styleicons/style-point.png
Added: trunk/qgis/images/themes/default/styleicons/style-polygon.png
Property changes on: trunk/qgis/images/themes/default/styleicons/style-polygon.png
Modified: trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp
--- trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2010-12-14 20:45:46 UTC (rev 14912)
+++ trunk/qgis/src/gui/symbology-ng/qgsstylev2managerdialog.cpp 2010-12-14 22:09:39 UTC (rev 14913)
@@ -44,7 +44,7 @@
populateTypes();
- connect( cboItemType, SIGNAL( currentIndexChanged( int ) ), this, SLOT( populateList() ) );
+ connect( tabItemType, SIGNAL( currentChanged( int ) ), this, SLOT( populateList() ) );
populateList();
@@ -61,8 +61,10 @@
void QgsStyleV2ManagerDialog::populateTypes()
// save current selection index in types combo
- int current = ( cboItemType->count() > 0 ? cboItemType->currentIndex() : 0 );
+ int current = ( tabItemType->count() > 0 ? tabItemType->currentIndex() : 0 );
+ // no counting of style items
int markerCount = 0, lineCount = 0, fillCount = 0;
QStringList symbolNames = mStyle->symbolNames();
@@ -86,7 +88,7 @@
// update current index to previous selection
cboItemType->setCurrentIndex( current );
void QgsStyleV2ManagerDialog::populateList()
@@ -154,8 +156,14 @@
int QgsStyleV2ManagerDialog::currentItemType()
- int idx = cboItemType->currentIndex();
- return cboItemType->itemData( idx ).toInt();
+ switch ( tabItemType->currentIndex() )
+ case 0: return QgsSymbolV2::Marker;
+ case 1: return QgsSymbolV2::Line;
+ case 2: return QgsSymbolV2::Fill;
+ case 3: return 3;
+ default: return 0;
QString QgsStyleV2ManagerDialog::currentItemName()
Modified: trunk/qgis/src/ui/qgsstylev2managerdialogbase.ui
--- trunk/qgis/src/ui/qgsstylev2managerdialogbase.ui 2010-12-14 20:45:46 UTC (rev 14912)
+++ trunk/qgis/src/ui/qgsstylev2managerdialogbase.ui 2010-12-14 22:09:39 UTC (rev 14913)
@@ -6,29 +6,104 @@
<rect>
<x>0</x>
<y>0</y>
- <width>300</width>
- <height>369</height>
+ <width>625</width>
+ <height>395</height>
</rect>
</property>
<property name="windowTitle">
<string>Style Manager</string>
</property>
- <layout class="QVBoxLayout">
+ <layout class="QVBoxLayout" name="verticalLayout">
<item>
- <widget class="QLabel" name="label">
- <property name="text">
- <string>Style item type</string>
+ <widget class="QTabWidget" name="tabItemType">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Expanding" vsizetype="Expanding">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
</property>
- <property name="buddy">
- <cstring>cboItemType</cstring>
+ <property name="currentIndex">
+ <number>0</number>
</property>
+ <property name="iconSize">
+ <size>
+ <width>22</width>
+ <height>22</height>
+ </size>
+ </property>
+ <property name="documentMode">
+ <bool>true</bool>
+ </property>
+ <widget class="QWidget" name="tabMarker">
+ <sizepolicy hsizetype="Preferred" vsizetype="Ignored">
+ </sizepolicy>
+ </property>
+ <attribute name="icon">
+ <iconset resource="../../images/images.qrc">
+ <normaloff>:/images/themes/default/styleicons/style-point.png</normaloff>:/images/themes/default/styleicons/style-point.png</iconset>
+ </attribute>
+ <attribute name="title">
+ <string>Marker</string>
+ </attribute>
+ </widget>
+ <widget class="QWidget" name="tabLine">
+ </sizepolicy>
+ </property>
+ <normaloff>:/images/themes/default/styleicons/style-line.png</normaloff>:/images/themes/default/styleicons/style-line.png</iconset>
+ </attribute>
+ <string>Line</string>
+ </attribute>
+ </widget>
+ <widget class="QWidget" name="tabFill">
+ </sizepolicy>
+ </property>
+ <normaloff>:/images/themes/default/styleicons/style-polygon.png</normaloff>:/images/themes/default/styleicons/style-polygon.png</iconset>
+ </attribute>
+ <string>Fill</string>
+ </attribute>
+ </widget>
+ <widget class="QWidget" name="tabColorRamp">
+ </sizepolicy>
+ </property>
+ <normaloff>:/images/themes/default/styleicons/color.png</normaloff>:/images/themes/default/styleicons/color.png</iconset>
+ </attribute>
+ <string>Color ramp</string>
+ </attribute>
+ </widget>
</widget>
</item>
<item>
- <widget class="QComboBox" name="cboItemType"/>
- </item>
- <item>
<widget class="QListView" name="listItems">
+ <verstretch>3</verstretch>
+ </sizepolicy>
+ </property>
<property name="editTriggers">
<set>QAbstractItemView::EditKeyPressed|QAbstractItemView::SelectedClicked</set>
</property>
@@ -59,6 +134,9 @@
<property name="toolTip">
<string>Add item</string>
</property>
+ <property name="text">
+ <string>Add</string>
+ </property>
</widget>
</item>
<item>
@@ -66,6 +144,9 @@
<string>Edit item</string>
</property>
+ <string>Edit</string>
+ </property>
</widget>
</item>
<item>
@@ -73,6 +154,9 @@
<string>Remove item</string>
</property>
+ <string>Remove</string>
+ </property>
</widget>
</item>
<item>
@@ -103,14 +187,15 @@
</layout>
</widget>
<tabstops>
- <tabstop>cboItemType</tabstop>
<tabstop>listItems</tabstop>
<tabstop>btnAddItem</tabstop>
<tabstop>btnEditItem</tabstop>
<tabstop>btnRemoveItem</tabstop>
<tabstop>buttonBox</tabstop>
</tabstops>
- <resources/>
+ <resources>
+ <include location="../../images/images.qrc"/>
+ </resources>
<connections>
<connection>
<sender>buttonBox</sender>
