[QGIS Commit] r14930 - in trunk/qgis: i18n src/plugins/sqlanywhere
svn_qgis at osgeo.org
Thu Dec 16 14:22:03 EST 2010
Author: jef
Date: 2010-12-16 11:22:03 -0800 (Thu, 16 Dec 2010)
New Revision: 14930
trunk/qgis/i18n/qgis_de.ts
trunk/qgis/src/plugins/sqlanywhere/sasourceselect.cpp
fix #3344
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts 2010-12-16 16:51:22 UTC (rev 14929)
+++ trunk/qgis/i18n/qgis_de.ts 2010-12-16 19:22:03 UTC (rev 14930)
@@ -9232,7 +9232,7 @@
</message>
<message>
<location filename="../src/app/composer/qgscomposer.cpp" line="769"/>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1542"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1544"/>
<source>Don't show this message again</source>
<translation>Diese Nachricht nicht mehr anzeigen</translation>
</message>
@@ -9298,17 +9298,17 @@
<translation>Einen Dateinamen zum Speichern des Kartenabbilds wählen</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1198"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1200"/>
<source>Composer</source>
<translation>Zusammmenstellung</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1540"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1542"/>
<source>Project contains WMS layers</source>
<translation>Projekt enthält WMS-Layer</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="1541"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="1543"/>
<source>Some WMS servers (e.g. UMN mapserver) have a limit for the WIDTH and HEIGHT parameter. Printing layers from such servers may exceed this limit. If this is the case, the WMS layer will not be printed</source>
<translation>Einige WMS-Server (z.B. UMN-Mapserver) haben Begrenzungen für die WIDTH- und HEIGHT-Parameter. Falls diese Begrenzungen beim Ausdruck überschritten werden, werden diese WMS-Layer nicht gedruckt</translation>
</message>
@@ -9333,38 +9333,38 @@
<translation>Wenn die SVG-Ausgabe nicht zufriedenstellend ist, wird für vektorbasierende QGIS-Ausgabe der Druck in PostScript empfohlen.</p></translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="912"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="914"/>
<source>save template</source>
<translation>Vorlage speichern</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="938"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="940"/>
<source>Save error</source>
<translation>Fehler beim Speichern</translation>
</message>
<message>
<source>Error, could not save file</source>
<translation>Fehler, in Datei konnte nicht gespeichert werden</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="946"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="948"/>
<source>Load template</source>
<translation>Vorlage laden</translation>
</message>
<message>
- <location filename="../src/app/composer/qgscomposer.cpp" line="959"/>
- <location filename="../src/app/composer/qgscomposer.cpp" line="968"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="961"/>
+ <location filename="../src/app/composer/qgscomposer.cpp" line="970"/>
<source>Read error</source>
<translation>Lesefehler</translation>
</message>
<message>
<source>Error, could not read file</source>
<translation>Fehler, Datei konnte nicht gelesen werden</translation>
</message>
<message>
<source>Content of template file is not valid</source>
<translation>Inhalt der Vorlagendatei könnte ungültig sein</translation>
</message>
@@ -24591,8 +24591,8 @@
<message>
<location filename="../src/core/raster/qgsrasterlayer.cpp" line="85"/>
<location filename="../src/core/raster/qgsrasterlayer.cpp" line="2567"/>
- <location filename="../src/core/raster/qgsrasterlayer.cpp" line="3494"/>
- <location filename="../src/core/raster/qgsrasterlayer.cpp" line="3539"/>
+ <location filename="../src/core/raster/qgsrasterlayer.cpp" line="3503"/>
+ <location filename="../src/core/raster/qgsrasterlayer.cpp" line="3548"/>
<source>Not Set</source>
<translation>Nicht gesetzt</translation>
</message>
@@ -24633,7 +24633,7 @@
</message>
<message>
<location filename="../src/core/raster/qgsrasterlayer.cpp" line="2804"/>
- <location filename="../src/core/raster/qgsrasterlayer.cpp" line="5037"/>
+ <location filename="../src/core/raster/qgsrasterlayer.cpp" line="5046"/>
<source>Band</source>
<translation>Kanal</translation>
</message>
@@ -24693,7 +24693,7 @@
<translation>Zellenanzahl</translation>
</message>
<message>
- <location filename="../src/core/raster/qgsrasterlayer.cpp" line="5370"/>
+ <location filename="../src/core/raster/qgsrasterlayer.cpp" line="5379"/>
<source>Specify CRS for layer %1</source>
<translation>KBS für Layer %1 angeben</translation>
</message>
@@ -28068,80 +28068,80 @@
<context>
<name>QgsStyleV2ManagerDialog</name>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="83"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="87"/>
<source>Marker symbol (%1)</source>
<translation>Markierungssymbol (%1)</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="84"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="88"/>
<source>Line symbol (%1)</source>
<translation>Liniensymbol (%1)</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="85"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="89"/>
<source>Fill symbol (%1)</source>
<translation>Füllsymbol (%1)</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="87"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="91"/>
<source>Color ramp (%1)</source>
<translation>Farbverlauf (%1)</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="222"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="226"/>
<source>Symbol name</source>
<translation>Symbolname</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="223"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="227"/>
<source>Please enter name for new symbol:</source>
<translation>Bitte geben Sie einen Name für das neue Symbol ein:</translation>
</message>
<message>
<source>new symbol</source>
<translation>Neues Symbol</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="241"/>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="249"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="245"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="253"/>
<source>Gradient</source>
<translation>Gradiente</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="260"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="264"/>
<source>Random</source>
<translation>Zufällig</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="271"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="275"/>
<source>ColorBrewer</source>
<translation>Farbbrauer</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="243"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="247"/>
<source>Color ramp type</source>
<translation>Farbverlauftyp</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="244"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="248"/>
<source>Please select color ramp type:</source>
<translation>Bitte einen Farbverlauftyp wählen:</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="288"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="292"/>
<source>Color ramp name</source>
<translation>Farbverlaufname</translation>
</message>
<message>
- <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="289"/>
+ <location filename="../src/gui/symbology-ng/qgsstylev2managerdialog.cpp" line="293"/>
<source>Please enter name for new color ramp:</source>
<translation>Bitte einen Name für den Farbverlauf angeben:</translation>
</message>
<message>
<source>new color ramp</source>
<translation>Neuer Farbverlauf</translation>
</message>
@@ -28158,52 +28158,52 @@
<translation type="obsolete">Stilelementtyp</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="49"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="46"/>
<source>Marker</source>
<translation>Markierung</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="64"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="61"/>
<source>Line</source>
<translation>Linie</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="79"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="76"/>
<source>Fill</source>
<translation>Füllung</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="94"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="91"/>
<source>Color ramp</source>
<translation>Farbverlauf</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="135"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="132"/>
<source>Add item</source>
<translation>Element hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="138"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="135"/>
<source>Add</source>
<translation>Hinzufügen</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="145"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="142"/>
<source>Edit item</source>
<translation>Element bearbeiten</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="148"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="145"/>
<source>Edit</source>
<translation>Bearbeiten</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="155"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="152"/>
<source>Remove item</source>
<translation>Element löschen</translation>
</message>
<message>
- <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="158"/>
+ <location filename="../src/ui/qgsstylev2managerdialogbase.ui" line="155"/>
<source>Remove</source>
<translation>Entfernen</translation>
</message>
@@ -30266,122 +30266,122 @@
<context>
<name>QgsWmsProvider</name>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="892"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="904"/>
<source>
Tried URL: %1</source>
<translation>
URL %1 versucht</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="913"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="925"/>
<source>Capabilities request redirected.</source>
<translation>Eigenschaften-Abfrage umgeleitet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="933"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="945"/>
<source>empty of capabilities: %1</source>
<translation>Eigenschaften leer: %1</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="939"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="951"/>
<source>Download of capabilities failed: %1</source>
<translation>Eigenschaften-Abfrage gescheitert: %1</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="951"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="963"/>
<source>%1 of %2 bytes of capabilities downloaded.</source>
<translation>%1 von %2 Bytes der Eigenschaften heruntergeladen.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="956"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="968"/>
<source>%1 of %2 bytes of map downloaded.</source>
<translation>%1 von %2 Bytes der Karte heruntergeladen.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="980"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1003"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1838"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="992"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1015"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1850"/>
<source>Dom Exception</source>
<translation>DOM-Ausnahme</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1900"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1912"/>
<source>Request contains a CRS not offered by the server for one or more of the Layers in the request.</source>
<translation>Anfrage verlangt ein CRS für einen oder mehrere Layer, die der Server nicht anbietet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1904"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1916"/>
<source>Request contains a SRS not offered by the server for one or more of the Layers in the request.</source>
<translation>Anfrage enthält ein SRS für einen oder mehrere Layer, die der Server nicht anbietet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1908"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1920"/>
<source>GetMap request is for a Layer not offered by the server, or GetFeatureInfo request is for a Layer not shown on the map.</source>
<translation>GetMap-Anfrage für einen Layer, den der Server nicht anbietet oder GetFeature-Anfrage für einen Layer, der nicht auf der Karte angezeigt wird.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1913"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1925"/>
<source>Request is for a Layer in a Style not offered by the server.</source>
<translation>Anfrage für einen Layer in einem Stil, den der Server nicht anbietet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1917"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1929"/>
<source>GetFeatureInfo request is applied to a Layer which is not declared queryable.</source>
<translation>GetFeatureInfo-Anfrage wird auf einen Layer bezogen, der nicht als abfragbar deklariert ist.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1921"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1933"/>
<source>GetFeatureInfo request contains invalid X or Y value.</source>
<translation>GetFeatureInfo-Anfrage enthält einen ungültigen X- oder Y-Wert.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1925"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1937"/>
<source>Value of (optional) UpdateSequence parameter in GetCapabilities request is equal to current value of service metadata update sequence number.</source>
<translation>Wert des (optionalen) Aktualisierungssequenenzzählers der GetCapabilities-Anfrage entspricht dem aktuellen Wert des Aktualisierungssequenzzähler in den Dienstmetadaten.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1930"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1942"/>
<source>Value of (optional) UpdateSequence parameter in GetCapabilities request is greater than current value of service metadata update sequence number.</source>
<translation>Wert des (optionalen) Aktualisierungssequenenzzählers der GetCapabilities-Anfrage ist größer als der aktuelle Wert des Aktualisierungssequenzzähler in den Dienstmetadaten.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1935"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1947"/>
<source>Request does not include a sample dimension value, and the server did not declare a default value for that dimension.</source>
<translation>Anfrage enthält keinen beispielhaften Dimensionswert, und der Server selbst definiert auch keinen.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1940"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1952"/>
<source>Request contains an invalid sample dimension value.</source>
<translation>Anfrage enthält einen ungültigen beispielhaften Dimensionswert.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1944"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1956"/>
<source>Request is for an optional operation that is not supported by the server.</source>
<translation>Anfrage ist für eine optionale Operation, die der Server nicht unterstützt.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1955"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1967"/>
<source>The WMS vendor also reported: </source>
<translation>Der WMS-Betreiber meldete folgendes: </translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2167"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2363"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2543"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2606"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2179"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2375"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2555"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2618"/>
<source>Property</source>
<translation>Eigenschaft</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2170"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2366"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2546"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2609"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2182"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2378"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2558"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2621"/>
<source>Value</source>
<translation>Wert</translation>
</message>
<message numerus="yes">
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2270"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2282"/>
<source>(and %n more)</source>
<comment>crs</comment>
<translation>
@@ -30390,188 +30390,188 @@
</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2332"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2344"/>
<source>Selected Layers</source>
<translation>Gewählte Layer</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2334"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2346"/>
<source>Other Layers</source>
<translation>Andere Layer</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2371"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2383"/>
<source>WMS Version</source>
<translation>WMS-Version</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2183"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2295"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2379"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2195"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2307"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2391"/>
<source>Title</source>
<translation>Titel</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2191"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2303"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2387"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2203"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2315"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2399"/>
<source>Abstract</source>
<translation>Zusammenfassung</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2395"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2407"/>
<source>Keywords</source>
<translation>Schlüsselworte</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2403"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2415"/>
<source>Online Resource</source>
<translation>Online-Quelle</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2411"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2423"/>
<source>Contact Person</source>
<translation>Kontaktperson</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2423"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2435"/>
<source>Fees</source>
<translation>Kosten</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2431"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2443"/>
<source>Access Constraints</source>
<translation>Zugriffsbeschränkungen</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2439"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2451"/>
<source>Image Formats</source>
<translation>Bildformate</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2447"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2459"/>
<source>Identify Formats</source>
<translation>Abfrageformate</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2455"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2467"/>
<source>Layer Count</source>
<translation>Layeranzahl</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2465"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2477"/>
<source>Tileset Count</source>
<translation>Tileset-Anzahl</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2550"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2562"/>
<source>Selected</source>
<translation>Ausgewählt</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2202"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2210"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2218"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2553"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2214"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2222"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2230"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2565"/>
<source>Yes</source>
<translation>Ja</translation>
</message>
<message>
<source>No</source>
<translation>Nein</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2175"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2187"/>
<source>Visibility</source>
<translation>Sichtbarkeit</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2178"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2190"/>
<source>Visible</source>
<translation>Sichtbar</translation>
</message>
<message>
<source>Hidden</source>
<translation>Versteckt</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2199"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2211"/>
<source>Can Identify</source>
<translation>Kann abgefragt werden</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2207"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2219"/>
<source>Can be Transparent</source>
<translation>Kann transparent sein</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2223"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2235"/>
<source>Cascade Count</source>
<translation>Kaskadiere Anzahl</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2231"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2243"/>
<source>Fixed Width</source>
<translation>Feste Breite</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2239"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2251"/>
<source>Fixed Height</source>
<translation>Feste Höhe</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2247"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2259"/>
<source>WGS 84 Bounding Box</source>
<translation>WGS84-Ausdehnung</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2257"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2267"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2269"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2279"/>
<source>Available in CRS</source>
<translation>Verfügbar in KBS</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2278"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2290"/>
<source>Available in style</source>
<translation>Verfügbar im Stil</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2287"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2299"/>
<source>Name</source>
<translation>Name</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2598"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2610"/>
<source>Cache stats</source>
<translation>Cache-Statistik</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2559"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2571"/>
<source>Styles</source>
<translation>Stile</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="521"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="528"/>
<source>Getting map via WMS.</source>
<translation>Lade Karte über WMS.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="651"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="658"/>
<source>Getting tiles via WMS.</source>
<translation>Lade Kacheln über WMS.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="870"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="881"/>
<source>empty capabilities document</source>
<translation>Leeres Capabilities-Dokument</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="982"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="994"/>
<source>Could not get WMS capabilities: %1 at line %2 column %3
This is probably due to an incorrect WMS Server URL.
Response was:
@@ -30584,7 +30584,7 @@
%4</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1005"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1017"/>
<source>Could not get WMS capabilities in the expected format (DTD): no %1 or %2 found.
This might be due to an incorrect WMS Server URL.
Tag:%3
@@ -30598,7 +30598,7 @@
%4</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1840"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1852"/>
<source>Could not get WMS Service Exception at %1: %2 at line %3 column %4
Response was:
@@ -30611,89 +30611,89 @@
%5</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1896"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1908"/>
<source>Request contains a format not offered by the server.</source>
<translation>Anfrage enthält ein Format, dass der Server nicht anbietet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2474"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2486"/>
<source>GetCapabilitiesUrl</source>
<translation>GetCapabilities-URL</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2481"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2493"/>
<source>GetMapUrl</source>
<translation>GetMap-URL</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2484"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2491"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2496"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2503"/>
<source>&nbsp;<font color="red">(advertised but ignored)</font></source>
<translation>&nbsp;<font color="red">(gemeldet, aber ignoriert)</font></translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2500"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2512"/>
<source>Selected Layers:</source>
<translation>Gewählte Layer:</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2513"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2525"/>
<source>Other layers:</source>
<translation>Andere Layer:</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2567"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2579"/>
<source>CRS</source>
<translation>KBS</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2574"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2586"/>
<source>Bounding Box</source>
<translation>Ausdehnung</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2581"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2593"/>
<source>Available in Resolutions</source>
<translation>Verfügbare Auflösungen</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2613"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2625"/>
<source>Hits</source>
<translation>Treffer</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2619"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2631"/>
<source>Misses</source>
<translation>Fehlgriffe</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2625"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2637"/>
<source>Errors</source>
<translation>Fehler</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2697"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2709"/>
<source>Layer cannot be queried in plain text.</source>
<translation>Layer kann in Klartext abgefragt werden.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2703"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2715"/>
<source>Layer cannot be queried.</source>
<translation>Layer kann nicht abgefragt werden.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2747"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2759"/>
<source>identify request redirected.</source>
<translation>Identify-Anfrage umgeleitet.</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2215"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2227"/>
<source>Can Zoom In</source>
<translation>Kann herangezoomt werden</translation>
</message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="668"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="784"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="675"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="791"/>
<source>%n tile requests in background</source>
<comment>tile request count</comment>
<translation>
@@ -30702,8 +30702,8 @@
</translation>
</message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="669"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="785"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="676"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="792"/>
<source>, %n cache hits</source>
<comment>tile cache hits</comment>
<translation>
@@ -30712,8 +30712,8 @@
</translation>
</message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="670"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="786"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="677"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="793"/>
<source>, %n cache misses.</source>
<comment>tile cache missed</comment>
<translation>
@@ -30722,8 +30722,8 @@
</translation>
</message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="671"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="787"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="678"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="794"/>
<source>, %n errors.</source>
<comment>errors</comment>
<translation>
@@ -30732,45 +30732,45 @@
</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="730"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="737"/>
<source>tile request err %1: %2</source>
<translation>Tile-Anfragefehler %1: %2</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="812"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2763"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="819"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2775"/>
<source>map request error %1: %2</source>
<translation>Kartenanfragefehler %1: %2</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2328"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2354"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2340"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2366"/>
<source>Server Properties</source>
<translation>Server-Eigenschaften</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2340"/>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2528"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2352"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2540"/>
<source>Tileset Properties</source>
<translation>Tileset-Eigenschaften</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2345"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2357"/>
<source>Cache Stats</source>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2488"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2500"/>
<source>GetFeatureInfoUrl</source>
<translation>GetFeatureInfoUrl</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1948"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1960"/>
<source>(No error code was reported)</source>
<translation>(Kein Fehlercode zurückgegeben)</translation>
</message>
<message>
- <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1952"/>
+ <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1964"/>
<source>(Unknown error code)</source>
<translation>(Unbekannter Fehlercode)</translation>
</message>
@@ -31274,8 +31274,18 @@
<message>
<location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="563"/>
<source>Database connection was successful, but no tables containing geometry columns were %1.</source>
- <translation>Die Datenbankverbindung war erfolgreich, jedoch keine Tabelle mit Geometriespalten wurden %1.</translation>
+ <translation>Die Datenbankverbindung war erfolgreich, jedoch wurde keine Tabelle mit Geometriespalten %1.</translation>
</message>
+ <message>
+ <location filename="../src/plugins/sqlanywhere/sasourceselect.cpp" line="566"/>
+ <source>found</source>
+ <translation>gefunden</translation>
+ </message>
+ <message>
+ <source>found in your schema</source>
+ <translation>in Ihrem Schema gefunden</translation>
+ </message>
</context>
<context>
<name>SaSourceSelectBase</name>
Modified: trunk/qgis/src/plugins/sqlanywhere/sasourceselect.cpp
--- trunk/qgis/src/plugins/sqlanywhere/sasourceselect.cpp 2010-12-16 16:51:22 UTC (rev 14929)
+++ trunk/qgis/src/plugins/sqlanywhere/sasourceselect.cpp 2010-12-16 19:22:03 UTC (rev 14930)
@@ -563,7 +563,7 @@
tr( "Database connection was successful, but no tables "
"containing geometry columns were %1." )
.arg( searchOtherSchemas ?
- "found" : "found in your schema" )
+ tr( "found" ) : tr( "found in your schema" ) )
