[QGIS Commit] r12856 - trunk/qgis/python/core
svn_qgis at osgeo.org
Mon Feb 1 04:28:17 EST 2010
Author: wonder
Date: 2010-02-01 04:28:14 -0500 (Mon, 01 Feb 2010)
New Revision: 12856
trunk/qgis/python/core/qgsrastershader.sip
trunk/qgis/python/core/qgsrastershaderfunction.sip
PyQGIS: wrapped raster shaders (color ramp, freak out, pseudocolor)
Modified: trunk/qgis/python/core/qgsrastershader.sip
--- trunk/qgis/python/core/qgsrastershader.sip 2010-02-01 09:01:41 UTC (rev 12855)
+++ trunk/qgis/python/core/qgsrastershader.sip 2010-02-01 09:28:14 UTC (rev 12856)
@@ -28,13 +28,13 @@
/** \brief generates and new RGB value based on one input value */
- bool shade(double, int*, int*, int*);
+ bool shade(double, int* /Out/, int* /Out/, int* /Out/);
/** \brief generates and new RGB value based on original RGB value */
- bool shade(double, double, double, int*, int*, int*);
+ bool shade(double, double, double, int* /Out/, int* /Out/, int* /Out/);
/** \brief A public method that allows the user to set their own shader function */
void setRasterShaderFunction(QgsRasterShaderFunction*);
/** \brief Set the maximum value */
void setMaximumValue(double);
/** \brief Return the minimum value */
void setMinimumValue(double);
\ No newline at end of file
Modified: trunk/qgis/python/core/qgsrastershaderfunction.sip
--- trunk/qgis/python/core/qgsrastershaderfunction.sip 2010-02-01 09:01:41 UTC (rev 12855)
+++ trunk/qgis/python/core/qgsrastershaderfunction.sip 2010-02-01 09:28:14 UTC (rev 12856)
@@ -10,12 +10,125 @@
virtual ~QgsRasterShaderFunction();
- virtual bool shade(double, int*, int*, int*);
+ virtual bool shade(double, int* /Out/, int* /Out/, int* /Out/);
- virtual bool shade(double, double, double, int*, int*, int*);
+ virtual bool shade(double, double, double, int* /Out/, int* /Out/, int* /Out/);
virtual void setMaximumValue(double);
virtual void setMinimumValue(double);
+class QgsColorRampShader : QgsRasterShaderFunction
+%TypeHeaderCode
+#include <qgscolorrampshader.h>
+%End
+ public:
+ QgsColorRampShader( double theMinimumValue = 0.0, double theMaximumValue = 255.0 );
+ //An entry for classification based upon value.
+ //Such a classification is typically used for
+ //single band layers where a pixel value represents
+ //not a color but a quantity, e.g. temperature or elevation
+ struct ColorRampItem
+ QString label;
+ double value;
+ QColor color;
+ // compare operator for sorting
+ //bool operator<( const ColorRampItem& other ) const;
+ enum ColorRamp_TYPE
+ INTERPOLATED,
+ DISCRETE,
+ EXACT
+ /** \brief Get the custom colormap*/
+ QList<QgsColorRampShader::ColorRampItem> colorRampItemList() const;
+ /** \brief Get the color ramp type */
+ QgsColorRampShader::ColorRamp_TYPE colorRampType();
+ /** \brief Get the color ramp type as a string */
+ QString colorRampTypeAsQString();
+ /** \brief Get the maximum size the color cache can be*/
+ int maximumColorCacheSize();
+ /** \brief Set custom colormap */
+ void setColorRampItemList( const QList<QgsColorRampShader::ColorRampItem>& theList );
+ /** \brief Set the color ramp type*/
+ void setColorRampType( QgsColorRampShader::ColorRamp_TYPE theColorRampType );
+ void setColorRampType( QString );
+ /** \brief Set the maximum size the color cache can be */
+ void setMaximumColorCacheSize( int theSize );
+ /** \brief Generates and new RGB value based on one input value */
+ bool shade( double, int* /Out/, int* /Out/, int* /Out/);
+ /** \brief Generates and new RGB value based on original RGB value */
+ bool shade( double, double, double, int* /Out/, int* /Out/, int* /Out/);
+class QgsFreakOutShader : QgsRasterShaderFunction
+%TypeHeaderCode
+#include <qgsfreakoutshader.h>
+%End
+ public:
+ QgsFreakOutShader( double theMinimumValue = 0.0, double theMaximumValue = 255.0 );
+ /** \brief generates and new RGB value based on one input value */
+ /** \brief generates and new RGB value based on original RGB value */
+ /** \brief Set the maximum value */
+ void setMaximumValue( double );
+ /** \brief Return the minimum value */
+ void setMinimumValue( double );
+class QgsPseudoColorShader : QgsRasterShaderFunction
+%TypeHeaderCode
+#include <qgspseudocolorshader.h>
+%End
+ public:
+ QgsPseudoColorShader( double theMinimumValue = 0.0, double theMaximumValue = 255.0 );
