[QGIS Commit] r12863 - in docs/trunk/english_us/user_guide: .
features_at_a_glance_screenies
svn_qgis at osgeo.org
Wed Feb 3 05:42:17 EST 2010
Author: dassau
Date: 2010-02-03 05:42:16 -0500 (Wed, 03 Feb 2010)
New Revision: 12863
Added:
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/shortcuts.png
docs/trunk/english_us/user_guide/features_at_a_glance.tex
docs/trunk/english_us/user_guide/features_at_a_glance_screenies/Makefile
docs/trunk/english_us/user_guide/foreword.tex
added shortcut configuration tool
Modified: docs/trunk/english_us/user_guide/features_at_a_glance.tex
--- docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-02-03 10:09:31 UTC (rev 12862)
+++ docs/trunk/english_us/user_guide/features_at_a_glance.tex 2010-02-03 10:42:16 UTC (rev 12863)
@@ -134,6 +134,27 @@
These six components of the QGIS interface are described in more detail in
the following sections.
+\subsubsection{Keyboard shortcuts}\label{shortcuts}
+\index{Keyboard shortcuts}
+QGIS provides default keyboard shortcuts for many features. You find them in
+Section \ref{label_menubar} below. Additionally the menu option \mainmenuopt{Settings} >
+\dropmenuopt{Configure Shortcuts} allows to change the default keyboard
+shortcuts and to add new keyboard shortcuts to QGIS features.
+\begin{figure}[ht]
+ \begin{center}
+ \caption{Define shortcut options \nixcaption (KDE)}
+ \label{fig:shortcuts}
+ \includegraphics[clip=true, width=8cm]{shortcuts}
+\end{center}
+\end{figure}
+Configuration is very simple. Just select a feature from the list and click
+on \button{Change}, \button{Set none} or \button{Set default}. Once you have
+found your configuration, you can save it as XML file and load it to another
+QGIS installation.
\subsubsection{Menu Bar}\label{label_menubar}
\index{menus}
@@ -899,11 +920,11 @@
\end{itemize}
\subsection{GUI Options}\label{subsec:gui_options}
-\includegraphics[width=0.7cm,clip=true]{mActionOptions}
-Some basic options for QGIS
-can be selected using the \dialog{Options} dialog. Select the
+\includegraphics[width=0.7cm,clip=true]{mActionOptions} Some basic options
+for QGIS can be selected using the \dialog{Options} dialog. Select the
- \dropmenuopttwo{mActionOptions}{Options}. The tabs where you can
+\dropmenuopttwo{mActionOptions}{Options}. The tabs where you can
optmize your options are:
\minisec{General Tab}
Modified: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/Makefile
--- docs/trunk/english_us/user_guide/features_at_a_glance_screenies/Makefile 2010-02-03 10:09:31 UTC (rev 12862)
+++ docs/trunk/english_us/user_guide/features_at_a_glance_screenies/Makefile 2010-02-03 10:42:16 UTC (rev 12863)
@@ -14,6 +14,7 @@
measure_area.eps\
measure_line.eps\
proxy-settings.eps\
+ shortcuts.eps\
##### TARGETS #####
Added: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/shortcuts.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/features_at_a_glance_screenies/shortcuts.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Modified: docs/trunk/english_us/user_guide/foreword.tex
--- docs/trunk/english_us/user_guide/foreword.tex 2010-02-03 10:09:31 UTC (rev 12862)
+++ docs/trunk/english_us/user_guide/foreword.tex 2010-02-03 10:42:16 UTC (rev 12863)
@@ -176,6 +176,7 @@
\item Added 'Configure shortcuts' dialog
\item Added 'Export to PDF' feature to map composer menu
\item Added support to user-specific SVG path in the map composer
+ \item Added 'newgis' icon theme, a revision of the original 'gis' theme
\item Possibility to add/remove attributes also in attribute table. Small modification to attribute table such that adding / removing columns is visible
\item Field Calculator
\item New analysis tools: Zonal statistics, TIN interpolation and Overlay analyzer
