[QGIS Commit] r12875 - in docs/trunk/english_us/user_guide: .
print_composer_screenies
svn_qgis at osgeo.org
Thu Feb 4 11:28:56 EST 2010
Author: dassau
Date: 2010-02-04 11:28:51 -0500 (Thu, 04 Feb 2010)
New Revision: 12875
Added:
docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map1.png
docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map2.png
docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map3.png
docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map4.png
Removed:
docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_label_item.png
docs/trunk/english_us/user_guide/print_composer.tex
docs/trunk/english_us/user_guide/print_composer_screenies/Makefile
print composer image update
Modified: docs/trunk/english_us/user_guide/print_composer.tex
--- docs/trunk/english_us/user_guide/print_composer.tex 2010-02-04 16:15:56 UTC (rev 12874)
+++ docs/trunk/english_us/user_guide/print_composer.tex 2010-02-04 16:28:51 UTC (rev 12875)
@@ -172,8 +172,8 @@
\begin{figure}[ht]
\centering
\caption{Print Composer map item tab - Map and Extents dialog \nixcaption}\label{fig:mapdialog}
-\subfigure[Map dialog]{\label{subfig:map_dialog1}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map_item1}}\goodgap
-\subfigure[Extents dialog]{\label{subfig:map_dialog2}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map_item2}}
+\subfigure[Map dialog]{\label{subfig:map_dialog1}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map1}}\goodgap
+\subfigure[Extents dialog]{\label{subfig:map_dialog2}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map2}}
\end{figure}
\minisec{Map dialog}
@@ -217,8 +217,8 @@
\begin{figure}[ht]
\centering
\caption{Print Composer map item tab - Grid and General options dialog \nixcaption}\label{fig:sec_map_dialog}
- \subfigure[Grid dialog]{\label{subfig:map_dialog3}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map_item3}}\goodgap
- \subfigure[General options dialog]{\label{subfig:map_dialog4}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map_item4}}
+ \subfigure[Grid dialog]{\label{subfig:map_dialog3}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map3}}\goodgap
+ \subfigure[General options dialog]{\label{subfig:map_dialog4}\includegraphics[clip=true, width=0.4\textwidth]{print_composer_map4}}
\end{figure}
\minisec{Grid dialog}
Modified: docs/trunk/english_us/user_guide/print_composer_screenies/Makefile
--- docs/trunk/english_us/user_guide/print_composer_screenies/Makefile 2010-02-04 16:15:56 UTC (rev 12874)
+++ docs/trunk/english_us/user_guide/print_composer_screenies/Makefile 2010-02-04 16:28:51 UTC (rev 12875)
@@ -13,6 +13,10 @@
PNG=print_composer_blank.eps\
print_composer_complete.eps\
+ print_composer_map1.eps\
+ print_composer_map2.eps\
+ print_composer_map3.eps\
+ print_composer_map4.eps\
print_composer_label1.eps\
print_composer_label2.eps\
print_composer_image1.eps\
Deleted: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_label_item.png
(Binary files differ)
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map1.png
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map1.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map2.png
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map2.png
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map3.png
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map3.png
Added: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map4.png
Property changes on: docs/trunk/english_us/user_guide/print_composer_screenies/print_composer_map4.png
