[QGIS Commit] r12879 - in trunk/qgis/src/core: . raster
svn_qgis at osgeo.org svn_qgis at osgeo.org
Thu Feb 4 16:23:13 EST 2010
Author: rblazek
Date: 2010-02-04 16:23:12 -0500 (Thu, 04 Feb 2010)
New Revision: 12879
   trunk/qgis/src/core/qgsrasterdataprovider.cpp
   trunk/qgis/src/core/qgsrasterdataprovider.h
   trunk/qgis/src/core/raster/qgsrasterlayer.cpp
prepare for GRASS raster provider
Modified: trunk/qgis/src/core/qgsrasterdataprovider.cpp
--- trunk/qgis/src/core/qgsrasterdataprovider.cpp	2010-02-04 21:08:33 UTC (rev 12878)
+++ trunk/qgis/src/core/qgsrasterdataprovider.cpp	2010-02-04 21:23:12 UTC (rev 12879)
@@ -19,6 +19,8 @@
 #include "qgsrasterdataprovider.h"
 #include "qgslogger.h"
+#include <QMap>
 QgsRasterDataProvider::QgsRasterDataProvider(): mDpi( -1 )
@@ -45,5 +47,10 @@
   return abilitiesList.join( ", " );
+bool QgsRasterDataProvider::identify( const QgsPoint& thePoint, QMap<QString, QString>& theResults )
+  theResults.clear();
+  return false;
 // ENDS
Modified: trunk/qgis/src/core/qgsrasterdataprovider.h
--- trunk/qgis/src/core/qgsrasterdataprovider.h	2010-02-04 21:08:33 UTC (rev 12878)
+++ trunk/qgis/src/core/qgsrasterdataprovider.h	2010-02-04 21:23:12 UTC (rev 12879)
@@ -115,6 +115,9 @@
     virtual QString metadata() = 0;
+    /** \brief Identify raster value(s) found on the point position */
+    virtual bool identify( const QgsPoint & point, QMap<QString, QString>& results );
      * \brief Identify details from a server (e.g. WMS) from the last screen update
Modified: trunk/qgis/src/core/raster/qgsrasterlayer.cpp
--- trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2010-02-04 21:08:33 UTC (rev 12878)
+++ trunk/qgis/src/core/raster/qgsrasterlayer.cpp	2010-02-04 21:23:12 UTC (rev 12879)
@@ -490,58 +490,6 @@
   t = fi.lastModified();
-  // Check also color table for GRASS
-  if ( name.contains( "cellhd" ) > 0 )
-  { // most probably GRASS
-    QString dir = fi.path();
-    QString map = fi.fileName();
-    fi.setFile( dir + "/../colr/" + map );
-    if ( fi.exists() )
-      if ( fi.lastModified() > t ) t = fi.lastModified();
-  // Check GRASS group members (bands)
-  if ( name.contains( "group" ) > 0 )
-  { // probably GRASS group
-    fi.setFile( name + "/REF" );
-    {  // most probably GRASS group
-      QFile f( name + "/REF" );
-      if ( f.open( QIODevice::ReadOnly ) )
-        QString dir = fi.path() + "/../../../";
-        char buf[101];
-        while ( f.readLine( buf, 100 ) != -1 )
-          QString ln = QString( buf );
-          QStringList sl = ln.trimmed().split( ' ', QString::SkipEmptyParts );
-          QString map = sl.first();
-          sl.pop_front();
-          QString mapset = sl.first();
-          // header
-          fi.setFile( dir + mapset + "/cellhd/" +  map );
-          // color
-          fi.setFile( dir + mapset + "/colr/" +  map );
   QgsDebugMsg( "last modified = " + t.toString() );
   return t;
@@ -1170,6 +1118,9 @@
   int myWidth = mWidth;
   int myHeight = mHeight;
   int myDivisor = 2;
+  if ( mDataProvider ) return mPyramidList;
   GDALRasterBandH myGDALBand = GDALGetRasterBand( mGdalDataset, 1 ); //just use the first band
   mPyramidList.clear();
@@ -1928,6 +1879,12 @@
   QgsDebugMsg( thePoint.toString() );
+  if ( !mProviderKey.isEmpty() )
+    QgsDebugMsg( "identify provider : " + mProviderKey ) ;
+    return ( mDataProvider->identify( thePoint, theResults ) );
   if ( !mLayerExtent.contains( thePoint ) )
     // Outside the raster
@@ -3270,8 +3227,15 @@
           mDrawingStyle = MultiBandColor;  //sensible default
           // Setup source CRS
-          *mCRS = QgsCoordinateReferenceSystem();
-          mCRS->createFromOgcWmsCrs( crs );
+          if ( mProviderKey == "wms" )
+            *mCRS = QgsCoordinateReferenceSystem();
+            mCRS->createFromOgcWmsCrs( crs );
+          else
+            *mCRS = QgsCoordinateReferenceSystem( mDataProvider->crs() );
       else
@@ -5453,9 +5417,11 @@
   if ( mLastModified < QgsRasterLayer::lastModified( source() ) )
-    QgsDebugMsg( "Outdated -> reload" );
-    closeDataset();
-    return readFile( source() );
+    if ( !usesProvider() ) {
+      QgsDebugMsg( "Outdated -> reload" );
+      closeDataset();
+      return readFile( source() );
   return true;
More information about the QGIS-commit mailing list
