[QGIS Commit] r12893 - trunk/qgis/python/plugins/fTools/tools
    svn_qgis at osgeo.org
    Sun Feb  7 07:43:35 EST 2010
Author: cfarmer
Date: 2010-02-07 07:43:33 -0500 (Sun, 07 Feb 2010)
New Revision: 12893
   trunk/qgis/python/plugins/fTools/tools/frmRegPoints.ui
   trunk/qgis/python/plugins/fTools/tools/frmVectorGrid.ui
update maximum grid spacing for regular points tool (fixes #2404).
Modified: trunk/qgis/python/plugins/fTools/tools/frmRegPoints.ui
--- trunk/qgis/python/plugins/fTools/tools/frmRegPoints.ui	2010-02-07 12:27:37 UTC (rev 12892)
+++ trunk/qgis/python/plugins/fTools/tools/frmRegPoints.ui	2010-02-07 12:43:33 UTC (rev 12893)
@@ -1,10 +1,11 @@
-<ui version="4.0" >
+<?xml version="1.0" encoding="UTF-8"?>
+<ui version="4.0">
  <class>Dialog</class>
- <widget class="QDialog" name="Dialog" >
-  <property name="windowModality" >
+ <widget class="QDialog" name="Dialog">
+  <property name="windowModality">
    <enum>Qt::NonModal</enum>
   </property>
-  <property name="geometry" >
+  <property name="geometry">
    <rect>
     <x>0</x>
     <y>0</y>
@@ -12,169 +13,169 @@
     <height>451</height>
    </rect>
   </property>
-  <property name="windowTitle" >
+  <property name="windowTitle">
    <string>Generate Regular Points</string>
   </property>
-  <property name="sizeGripEnabled" >
+  <property name="sizeGripEnabled">
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" name="gridLayout" >
-   <item row="0" column="0" >
-    <widget class="QRadioButton" name="rdoBoundary" >
-     <property name="text" >
+  <layout class="QGridLayout" name="gridLayout">
+   <item row="0" column="0">
+    <widget class="QRadioButton" name="rdoBoundary">
+     <property name="text">
       <string>Input Boundary Layer</string>
      </property>
-     <property name="checked" >
+     <property name="checked">
       <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="1" column="0" colspan="2" >
-    <widget class="QComboBox" name="inShape" />
+   <item row="1" column="0" colspan="2">
+    <widget class="QComboBox" name="inShape"/>
    </item>
-   <item row="2" column="0" >
-    <widget class="QRadioButton" name="rdoCoordinates" >
+   <item row="2" column="0">
+    <widget class="QRadioButton" name="rdoCoordinates">
       <string>Input Coordinates</string>
      </property>
     </widget>
    </item>
-   <item row="3" column="0" >
-    <layout class="QHBoxLayout" >
+   <item row="3" column="0">
+    <layout class="QHBoxLayout">
      <item>
-      <widget class="QLabel" name="label" >
+      <widget class="QLabel" name="label">
         <string>X Min</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QLineEdit" name="xMin" />
+      <widget class="QLineEdit" name="xMin"/>
      </item>
     </layout>
    </item>
-   <item row="3" column="1" >
+   <item row="3" column="1">
      <item>
-      <widget class="QLabel" name="label_4" >
+      <widget class="QLabel" name="label_4">
         <string>Y Min</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QLineEdit" name="yMin" />
+      <widget class="QLineEdit" name="yMin"/>
      </item>
     </layout>
    </item>
-   <item row="4" column="0" >
+   <item row="4" column="0">
      <item>
-      <widget class="QLabel" name="label_3" >
+      <widget class="QLabel" name="label_3">
         <string>X Max</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QLineEdit" name="xMax" />
+      <widget class="QLineEdit" name="xMax"/>
      </item>
     </layout>
    </item>
-   <item row="4" column="1" >
+   <item row="4" column="1">
      <item>
-      <widget class="QLabel" name="label_5" >
+      <widget class="QLabel" name="label_5">
         <string>Y Max</string>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QLineEdit" name="yMax" />
+      <widget class="QLineEdit" name="yMax"/>
      </item>
     </layout>
    </item>
-   <item row="5" column="0" colspan="2" >
-    <widget class="QGroupBox" name="gridBox" >
-     <property name="title" >
+   <item row="5" column="0" colspan="2">
+    <widget class="QGroupBox" name="gridBox">
+     <property name="title">
       <string>Grid Spacing</string>
      </property>
-     <layout class="QGridLayout" >
-      <item row="0" column="0" colspan="2" >
+     <layout class="QGridLayout">
+      <item row="0" column="0" colspan="2">
         <item>
-         <widget class="QRadioButton" name="rdoSpacing" >
+         <widget class="QRadioButton" name="rdoSpacing">
            <string>Use this point spacing</string>
           </property>
            <bool>true</bool>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QDoubleSpinBox" name="spnSpacing" >
-          <property name="decimals" >
+         <widget class="QDoubleSpinBox" name="spnSpacing">
+          <property name="decimals">
            <number>4</number>
           </property>
-          <property name="minimum" >
+          <property name="minimum">
            <double>0.000100000000000</double>
           </property>
-          <property name="maximum" >
-           <double>9999.000000000000000</double>
+          <property name="maximum">
+           <double>1000000000.000000000000000</double>
           </property>
-          <property name="singleStep" >
+          <property name="singleStep">
           </property>
          </widget>
         </item>
        </layout>
       </item>
         <item>
-         <widget class="QRadioButton" name="rdoNumber" >
+         <widget class="QRadioButton" name="rdoNumber">
            <string>Use this number of points</string>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QSpinBox" name="spnNumber" >
+         <widget class="QSpinBox" name="spnNumber">
            <number>1</number>
           </property>
            <number>9999</number>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="2" column="0" colspan="2" >
-       <widget class="QCheckBox" name="chkRandom" >
+      <item row="2" column="0" colspan="2">
+       <widget class="QCheckBox" name="chkRandom">
          <string>Apply random offset to point spacing</string>
         </property>
        </widget>
       </item>
-       <widget class="QDoubleSpinBox" name="spnInset" >
+       <widget class="QDoubleSpinBox" name="spnInset">
          <number>4</number>
         </property>
         </property>
         </property>
        </widget>
       </item>
-       <widget class="QLabel" name="label_6" >
+       <widget class="QLabel" name="label_6">
          <string>Initial inset from corner (LH side)</string>
         </property>
        </widget>
@@ -182,56 +183,56 @@
      </layout>
     </widget>
    </item>
-   <item row="6" column="0" >
-    <widget class="QLabel" name="label_2" >
-     <property name="sizePolicy" >
-      <sizepolicy vsizetype="Fixed" hsizetype="Fixed" >
+   <item row="6" column="0">
+    <widget class="QLabel" name="label_2">
+     <property name="sizePolicy">
+      <sizepolicy hsizetype="Fixed" vsizetype="Fixed">
        <horstretch>0</horstretch>
        <verstretch>0</verstretch>
       </sizepolicy>
      </property>
       <string>Output Shapefile</string>
      </property>
     </widget>
    </item>
-   <item row="7" column="0" colspan="2" >
+   <item row="7" column="0" colspan="2">
      <item>
-      <widget class="QLineEdit" name="outShape" >
-       <property name="readOnly" >
+      <widget class="QLineEdit" name="outShape">
+       <property name="readOnly">
         <bool>true</bool>
        </property>
       </widget>
      </item>
      <item>
-      <widget class="QToolButton" name="toolOut" >
+      <widget class="QToolButton" name="toolOut">
         <string>Browse</string>
        </property>
       </widget>
      </item>
     </layout>
    </item>
-   <item row="8" column="0" >
-    <widget class="QProgressBar" name="progressBar" >
-     <property name="value" >
+   <item row="8" column="0">
+    <widget class="QProgressBar" name="progressBar">
+     <property name="value">
       <number>0</number>
      </property>
-     <property name="alignment" >
+     <property name="alignment">
       <set>Qt::AlignCenter</set>
      </property>
-     <property name="textVisible" >
+     <property name="textVisible">
       <bool>true</bool>
      </property>
     </widget>
    </item>
-   <item row="8" column="1" >
-    <widget class="QDialogButtonBox" name="buttonBox_2" >
-     <property name="orientation" >
+   <item row="8" column="1">
+    <widget class="QDialogButtonBox" name="buttonBox_2">
+     <property name="orientation">
       <enum>Qt::Horizontal</enum>
      </property>
-     <property name="standardButtons" >
+     <property name="standardButtons">
       <set>QDialogButtonBox::Close|QDialogButtonBox::Ok</set>
      </property>
     </widget>
@@ -246,11 +247,11 @@
    <receiver>Dialog</receiver>
    <slot>accept()</slot>
    <hints>
-    <hint type="sourcelabel" >
+    <hint type="sourcelabel">
      <x>142</x>
      <y>444</y>
     </hint>
-    <hint type="destinationlabel" >
+    <hint type="destinationlabel">
      <x>215</x>
      <y>290</y>
     </hint>
@@ -262,11 +263,11 @@
    <slot>close()</slot>
    <hints>
      <x>68</x>
      <y>444</y>
     </hint>
      <x>132</x>
      <y>239</y>
     </hint>
@@ -278,11 +279,11 @@
    <receiver>inShape</receiver>
    <slot>setEnabled(bool)</slot>
    <hints>
      <x>105</x>
      <y>26</y>
     </hint>
      <x>103</x>
      <y>51</y>
     </hint>
@@ -294,11 +295,11 @@
    <receiver>xMin</receiver>
    <hints>
      <x>37</x>
      <y>84</y>
     </hint>
      <x>58</x>
      <y>115</y>
     </hint>
@@ -310,11 +311,11 @@
    <receiver>xMax</receiver>
    <hints>
      <x>19</x>
      <y>82</y>
     </hint>
      <x>69</x>
      <y>146</y>
     </hint>
@@ -326,11 +327,11 @@
    <receiver>yMin</receiver>
    <hints>
      <x>82</x>
      <y>83</y>
     </hint>
      <x>238</x>
      <y>110</y>
     </hint>
@@ -342,11 +343,11 @@
    <receiver>yMax</receiver>
    <hints>
      <x>58</x>
      <y>88</y>
     </hint>
      <x>239</x>
      <y>149</y>
     </hint>
@@ -358,11 +359,11 @@
    <receiver>spnSpacing</receiver>
    <hints>
      <x>107</x>
      <y>207</y>
     </hint>
      <x>213</x>
      <y>210</y>
     </hint>
@@ -374,11 +375,11 @@
    <receiver>spnNumber</receiver>
    <hints>
      <x>100</x>
      <y>244</y>
     </hint>
      <x>209</x>
      <y>243</y>
     </hint>
Modified: trunk/qgis/python/plugins/fTools/tools/frmVectorGrid.ui
--- trunk/qgis/python/plugins/fTools/tools/frmVectorGrid.ui	2010-02-07 12:27:37 UTC (rev 12892)
+++ trunk/qgis/python/plugins/fTools/tools/frmVectorGrid.ui	2010-02-07 12:43:33 UTC (rev 12893)
@@ -1,161 +1,162 @@
+<ui version="4.0">
   </property>
    <rect>
     <x>0</x>
     <y>0</y>
-    <width>369</width>
+    <width>377</width>
     <height>459</height>
    </rect>
   </property>
-   <string>Generate Regular Points</string>
+   <string>Generate Vector Grid</string>
   </property>
    <bool>true</bool>
   </property>
-  <layout class="QGridLayout" name="gridLayout_2" >
-    <widget class="QGroupBox" name="groupBox" >
+  <layout class="QGridLayout" name="gridLayout_2">
+    <widget class="QGroupBox" name="groupBox">
       <string>Grid extent</string>
      </property>
       </item>
-      <item row="1" column="0" >
-       <widget class="QToolButton" name="btnUpdate" >
-        <property name="minimumSize" >
+      <item row="1" column="0">
+       <widget class="QToolButton" name="btnUpdate">
+        <property name="minimumSize">
          <size>
           <width>0</width>
           <height>30</height>
          </size>
         </property>
          <string>Update extents from layer</string>
         </property>
        </widget>
       </item>
-      <item row="1" column="1" >
-       <widget class="QToolButton" name="btnCanvas" >
+      <item row="1" column="1">
+       <widget class="QToolButton" name="btnCanvas">
          <size>
           <width>0</width>
           <height>30</height>
          </size>
         </property>
          <string>Update extents from canvas</string>
         </property>
        </widget>
       </item>
         <item>
-          <property name="enabled" >
+          <property name="enabled">
            <bool>true</bool>
           </property>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="xMin" >
+         <widget class="QLineEdit" name="xMin">
            <bool>true</bool>
           </property>
-          <property name="inputMask" >
+          <property name="inputMask">
            <string/>
           </property>
            <string/>
           </property>
          </widget>
         </item>
        </layout>
       </item>
-      <item row="2" column="1" >
+      <item row="2" column="1">
         <item>
            <bool>true</bool>
           </property>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="yMin" >
+         <widget class="QLineEdit" name="yMin">
            <bool>true</bool>
           </property>
            <string/>
           </property>
            <string/>
           </property>
          </widget>
         </item>
        </layout>
       </item>
         <item>
            <bool>true</bool>
           </property>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="xMax" >
+         <widget class="QLineEdit" name="xMax">
            <bool>true</bool>
           </property>
            <string/>
           </property>
            <string/>
           </property>
          </widget>
         </item>
        </layout>
       </item>
         <item>
            <bool>true</bool>
           </property>
           </property>
          </widget>
         </item>
         <item>
-         <widget class="QLineEdit" name="yMax" >
+         <widget class="QLineEdit" name="yMax">
            <bool>true</bool>
           </property>
            <string/>
           </property>
            <string/>
           </property>
          </widget>
@@ -165,18 +166,18 @@
      </layout>
     </widget>
    </item>
       <string>Parameters</string>
      </property>
        <spacer>
         </property>
-        <property name="sizeHint" stdset="0" >
+        <property name="sizeHint" stdset="0">
          <size>
           <width>40</width>
           <height>20</height>
@@ -184,45 +185,45 @@
         </property>
        </spacer>
       </item>
-      <item row="0" column="1" >
-       <widget class="QLabel" name="label_7" >
+      <item row="0" column="1">
+       <widget class="QLabel" name="label_7">
          <string>X</string>
         </property>
        </widget>
       </item>
-      <item row="0" column="2" >
-       <widget class="QDoubleSpinBox" name="spnX" >
+      <item row="0" column="2">
+       <widget class="QDoubleSpinBox" name="spnX">
          <number>4</number>
         </property>
         </property>
-         <double>999999999.000000000000000</double>
         </property>
         </property>
        </widget>
       </item>
-      <item rowspan="2" row="0" column="3" >
-       <widget class="QCheckBox" name="chkLock" >
+      <item row="0" column="3" rowspan="2">
+       <widget class="QCheckBox" name="chkLock">
          <string>Lock 1:1 ratio</string>
         </property>
          <bool>true</bool>
         </property>
        </widget>
       </item>
-      <item row="0" column="4" >
+      <item row="0" column="4">
        <spacer>
         </property>
          <size>
           <width>40</width>
           <height>20</height>
@@ -230,12 +231,12 @@
         </property>
        </spacer>
       </item>
        <spacer>
         </property>
          <size>
           <width>40</width>
           <height>20</height>
@@ -243,48 +244,48 @@
         </property>
        </spacer>
       </item>
-       <widget class="QLabel" name="label_8" >
+       <widget class="QLabel" name="label_8">
          <bool>false</bool>
         </property>
          <string>Y</string>
         </property>
        </widget>
       </item>
-      <item row="1" column="2" >
-       <widget class="QDoubleSpinBox" name="spnY" >
+      <item row="1" column="2">
+       <widget class="QDoubleSpinBox" name="spnY">
          <bool>false</bool>
         </property>
          <number>4</number>
         </property>
         </property>
         </property>
         </property>
        </widget>
       </item>
-      <item row="2" column="0" colspan="3" >
-       <widget class="QRadioButton" name="rdoPolygons" >
+      <item row="2" column="0" colspan="3">
+       <widget class="QRadioButton" name="rdoPolygons">
          <string>Output grid as polygons</string>
         </property>
          <bool>true</bool>
         </property>
        </widget>
       </item>
-      <item row="3" column="0" colspan="3" >
-       <widget class="QRadioButton" name="rdoLines" >
+      <item row="3" column="0" colspan="3">
+       <widget class="QRadioButton" name="rdoLines">
          <string>Output grid as lines</string>
         </property>
        </widget>
@@ -292,56 +293,56 @@
      </layout>
     </widget>
    </item>
       </sizepolicy>
      </property>
       <string>Output shapefile</string>
      </property>
     </widget>
    </item>
-   <item row="3" column="0" colspan="2" >
+   <item row="3" column="0" colspan="2">
      <item>
         <bool>true</bool>
        </property>
       </widget>
      </item>
      <item>
        </property>
       </widget>
      </item>
     </layout>
    </item>
       <number>0</number>
      </property>
      </property>
       <bool>true</bool>
      </property>
     </widget>
    </item>
      </property>
      </property>
     </widget>
@@ -356,11 +357,11 @@
    <hints>
      <x>330</x>
      <y>449</y>
     </hint>
      <x>215</x>
      <y>290</y>
     </hint>
@@ -372,11 +373,11 @@
    <hints>
      <x>256</x>
      <y>449</y>
     </hint>
      <x>132</x>
      <y>239</y>
     </hint>
@@ -388,11 +389,11 @@
    <receiver>spnY</receiver>
    <slot>setDisabled(bool)</slot>
    <hints>
      <x>279</x>
      <y>244</y>
     </hint>
      <x>164</x>
      <y>280</y>
     </hint>
@@ -404,11 +405,11 @@
    <receiver>label_8</receiver>
    <hints>
      <x>302</x>
      <y>261</y>
     </hint>
      <x>73</x>
      <y>280</y>
     </hint>
