[QGIS Commit] r12895 - in docs/trunk/english_us/user_guide:
appendices working_with_raster_screenies
svn_qgis at osgeo.org
Sun Feb 7 13:57:38 EST 2010
Author: micha
Date: 2010-02-07 13:57:36 -0500 (Sun, 07 Feb 2010)
New Revision: 12895
docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
docs/trunk/english_us/user_guide/working_with_raster_screenies/rasterPropertiesDialog.png
GRASS appendix - module list; new raster properties screen shot
Modified: docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex
--- docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex 2010-02-07 15:58:56 UTC (rev 12894)
+++ docs/trunk/english_us/user_guide/appendices/grass_toolbox_modules.tex 2010-02-07 18:57:36 UTC (rev 12895)
@@ -27,6 +27,7 @@
raster map layer \\
\hline r.in.aster & Georeferencing, rectification, and import of
Terra-ASTER imagery and relative DEM's using gdalwarp \\
+ \hline r.in.bin & Import binary raster \\
\hline r.in.gdal & Import GDAL supported raster file into a GRASS binary
raster map layer \\
\hline r.in.gdal.loc & Import GDAL supported raster file into a GRASS
@@ -42,10 +43,56 @@
in the current directory \\
\hline r.in.srtm & Import SRTM HGT files into GRASS \\
\hline i.in.spotvgt & Import of SPOT VGT NDVI file into a raster map \\
+ \hline r.in.wms & Download and import data from WMS server \\
+ \hline r.external & Link GDAL supported raster to binary raster \\
+ \hline r.external.qgis & Link GDAL supported raster to binary raster map layer \\
+ \hline r.external & Link all GDAL supported rasters in a directory to binary rasters \\
+ \hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Vector data import modules}\medskip
+ \begin{tabular}{|p{4cm}|p{12cm}|}
+ \hline \multicolumn{2}{|c|}{\textbf{Vector data import modules in the GRASS
+Toolbox}} \\
+ \hline \textbf{Module name} & \textbf{Purpose} \\
+ \hline v.in.db & Import vector points from database containing coordinates \\
+ \hline v.in.dxf & Import DXF vector layer \\
+ \hline v.in.e00 & Import ESRI E00 file in a vector map \\
+ \hline v.in.garmin & Import vector from gps using gpstrans \\
+ \hline v.in.gpsbabel & Import vector from gps using gpsbabel \\
+ \hline v.in.geonames & Import geonames.org country files \\
+ \hline v.in.gns & Import USNGS Geonet Names Server (GNS) country file \\
+ \hline v.in.mapgen & Import MapGen or MatLab vectors in GRASS \\
+ \hline v.in.ogr & Import OGR/PostGIS vector layers \\
+ \hline v.in.ogr.qgis & Import loaded vector layers into GRASS binary
+ vector map \\
+ \hline v.in.ogr.loc & Import OGR/PostGIS vector layers and create a fitted
+ location \\
+ \hline v.in.ogr.qgis.loc & Import loaded vector layers into GRASS binary
+ vector map and create a fitted location \\
+ \hline v.in.ogr.all & Import all the OGR/PostGIS vector layers in a given
+ data source \\
+ \hline v.in.ogr.all.loc & Import all the OGR/PostGIS vector layers in a
+ given data source and create a fitted location \\
\hline
\end{tabular}
\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Database import modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Database import modules in the GRASS
+Toolbox}} \\
+ \hline db.in.ogr & Import attribute tables in various formats \\
+\hline
+\end{tabular}
+\end{table}
\newpage
\begin{table}[ht]
@@ -56,12 +103,16 @@
the GRASS
Toolbox}} \\
+ \hline r.out.gdal & Export raster to various formats (GDAL library) \\
\hline r.out.gdal.gtiff & Export raster layer to Geo TIFF \\
+ \hline r.out.ascii & Export raster to ASCII text file \\
\hline r.out.arc & Converts a raster map layer into an ESRI ARCGRID file \\
+ \hline r.out.xyz & Export raster to text file as x,y,z values based on cell centers \\
\hline r.gridatb & Exports GRASS raster map to GRIDATB.FOR map file
(TOPMODEL) \\
\hline r.out.mat & Exports a GRASS raster to a binary MAT-File \\
\hline r.out.bin & Exports a GRASS raster to a binary array \\
+ \hline r.out.mpeg & Export raster series to MPEG movie \\
\hline r.out.png & Export GRASS raster as non-georeferenced PNG image
format \\
\hline r.out.ppm & Converts a GRASS raster map to a PPM image file at the
@@ -74,38 +125,13 @@
at the pixel resolution of the currently defined region\\
\hline r.out.vrml & Export a raster map to the Virtual Reality Modeling
Language (VRML)\\
+ \hline r.out.vtk & Export raster layer to VTK-ASCII \\
\hline
\end{tabular}
\end{table}
\newpage
-\begin{table}[ht]
-\centering
-\caption{GRASS Toolbox: Vector data import modules}\medskip
- \begin{tabular}{|p{4cm}|p{12cm}|}
- \hline \multicolumn{2}{|c|}{\textbf{Vector data import modules in the GRASS
-Toolbox}} \\
- \hline \textbf{Module name} & \textbf{Purpose} \\
- \hline v.in.dxf & Import DXF vector layer \\
- \hline v.in.e00 & Import ESRI E00 file in a vector map \\
- \hline v.in.garmin & Import vector from gps using gpstrans \\
- \hline v.in.gpsbabel & Import vector from gps using gpsbabel \\
- \hline v.in.mapgen & Import MapGen or MatLab vectors in GRASS \\
- \hline v.in.ogr & Import OGR/PostGIS vector layers \\
- \hline v.in.ogr.qgis & Import loaded vector layers into GRASS binary
- vector map \\
- \hline v.in.ogr.loc & Import OGR/PostGIS vector layers and create a fitted
- location \\
- \hline v.in.ogr.qgis.loc & Import loaded vector layers into GRASS binary
- vector map and create a fitted location \\
- \hline v.in.ogr.all & Import all the OGR/PostGIS vector layers in a given
- data source \\
- \hline v.in.ogr.all.loc & Import all the OGR/PostGIS vector layers in a
- given data source and create a fitted location \\
-\hline
-\end{tabular}
-\end{table}
\begin{table}[ht]
\centering
@@ -116,16 +142,29 @@
\hline v.out.ogr & Export vector layer to various formats (OGR library) \\
\hline v.out.ogr.gml & Export vector layer to GML \\
- \hline v.out.ogr.postgis & Export vector layer to various formats (OGR
- library) \\
+ \hline v.out.ogr.pg & Export vector layer to PostGIS database table \\
\hline v.out.ogr.mapinfo & Mapinfo export of vector layer \\
\hline v.out.ascii & Convert a GRASS binary vector map to a GRASS ASCII
vector map \\
\hline v.out.dxf & converts a GRASS vector map to DXF \\
+ \hline v.out.pov & Export vector layer to POV-Ray \\
+ \hline v.out.svg & Export vector layer to SVG \\
+ \hline v.out.vtk & Export vector layer to VTK-ASCII \\
\hline
\end{tabular}
\end{table}
+begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Vector data table}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Vector table export modules in the GRASS
+Toolbox}} \\
+ \hline dbout.ogr & Export attribute table to various formats \\
+\hline
+\end{tabular}
+\end{table}
\newpage
\subsection{GRASS Toolbox data type conversion modules}
@@ -243,6 +282,7 @@
\hline r.colors.table & Set raster color table from setted tables \\
\hline r.colors.rules & Set raster color table from setted rules \\
\hline r.colors.rast & Set raster color table from existing raster \\
+ \hline r.colors.stddev & Set color rules based on standard deviation frommap's mean value \\
\hline r.blend & Blend color components for two raster maps by given ratio \\
\hline r.composite & Blend red, green, raster layers to obtain one color
raster \\
@@ -272,6 +312,8 @@
to the corresponding cells in the output raster map layers\\
\hline r.patch & Create a new raster map by combining other raster maps \\
\hline r.statistics & Category or object oriented statistics \\
+ \hline r.sunmask.position & Calculate shadow maps from exact sun position \\
+ \hline r.sunmask.date.time & Calculate shadow maps from sun position determined by date/time\\
\hline r.cost & Outputs a raster map layer showing the cumulative cost of
moving between different geographic locations on an input raster map layer
whose cell category values represent cost\\
@@ -288,6 +330,7 @@
\hline r.texture.bis & Generate images with textural features from a raster
map (second serie of indices)\\
\hline r.los & Line-of-sigth raster analysis \\
+ \hline r.grow.distance & Create raster of distance to features in input layer \\
\hline r.clump & Recategorizes into unique categories contiguous cells \\
\hline r.grow & Generates a raster map layer with contiguous areas grown by
one cell\\
@@ -298,11 +341,54 @@
\begin{table}[ht]
\centering
+\caption{GRASS Toolbox: Hydrologic modelling modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Hydrologic modelling modules in the GRASS
+ Toolbox}} \\
+ \hline r.watershed & Watershed Analysis \\
+ \hline r.carve & Takes vector stream data, transforms it to raster, and
+ subtracts depth from the output DEM \\
+ \hline r.fill.dir & Filters and generates a depressionless elevation map
+ and a flow direction map from a given elevation layer \\
+ \hline r.lake.xy & Fills lake from seed point at given level \\
+ \hline r.lake.seed & Fills lake from seed at given level \\
+ \hline r.topidx & Creates a 3D volume map based on 2D elevation and value
+ raster maps \\
+ \hline r.basins.fill & Generates a raster map layer showing watershed
+ subbasins \\
+ \hline r.water.outlet & Watershed basin creation program \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
+\caption{GRASS Toolbox: Change raster category values and labels modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Raster category and label modules in the GRASS Toolbox}} \\
+ \hline r.reclass.area.greater & Reclasses a raster map greater than user
+ specified area size (in hectares) \\
+ \hline r.reclass.area.lesser & Reclasses a raster map less than user
+ \hline r.reclass & Reclass a raster using a reclassification rules file \\
+ \hline r.recode & Recode raster maps\\
+ \hline r.rescale & Rescales the range of category values in a raster map
+ layer \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
\caption{GRASS Toolbox: Surface management modules}\medskip
\hline \multicolumn{2}{|c|}{\textbf{Surface management modules in the GRASS
Toolbox}} \\
+ \hline r.circle & Create a map containing concentric circles \\
\hline r.random & Creates a random vector point map contained in a raster \\
\hline r.random.cells & Generates random cell values with spatial
dependence \\
@@ -318,6 +404,7 @@
user \\
\hline r.surf.random & Produces a raster map layer of uniform random
deviates whose range can be expressed by the user \\
+ \hline r.plane & Create a raster plane \\
\hline r.bilinear & Bilinear interpolation utility for raster map layers \\
\hline v.surf.bispline & Bicubic or bilinear spline interpolation with
Tykhonov regularization\\
@@ -332,46 +419,10 @@
\end{tabular}
\end{table}
-\begin{table}[ht]
-\centering
-\caption{GRASS Toolbox: Change raster category values and labels modules}\medskip
- \hline \multicolumn{2}{|c|}{\textbf{Raster category and label modules in the GRASS Toolbox}} \\
- \hline r.reclass.area.greater & Reclasses a raster map greater than user
- specified area size (in hectares) \\
- \hline r.reclass.area.lesser & Reclasses a raster map less than user
- \hline r.reclass & Reclass a raster using a reclassification rules file \\
- \hline r.recode & Recode raster maps\\
- \hline r.rescale & Rescales the range of category values in a raster map
- layer \\
-\hline
-\end{tabular}
-\end{table}
-\begin{table}[ht]
-\centering
-\caption{GRASS Toolbox: Hydrologic modelling modules}\medskip
- \hline \multicolumn{2}{|c|}{\textbf{Hydrologic modelling modules in the GRASS
- Toolbox}} \\
- \hline r.carve & Takes vector stream data, transforms it to raster, and
- subtracts depth from the output DEM \\
- \hline r.fill.dir & Filters and generates a depressionless elevation map
- and a flow direction map from a given elevation layer \\
- \hline r.lake.xy & Fills lake from seed point at given level \\
- \hline r.lake.seed & Fills lake from seed at given level \\
- \hline r.topidx & Creates a 3D volume map based on 2D elevation and value
- raster maps \\
- \hline r.basins.fill & Generates a raster map layer showing watershed
- subbasins \\
- \hline r.water.outlet & Watershed basin creation program \\
-\hline
-\end{tabular}
-\end{table}
\begin{table}[ht]
\centering
\caption{GRASS Toolbox: Reports and statistic analysis modules}\medskip
@@ -477,6 +528,38 @@
\begin{table}[ht]
\centering
+\caption{GRASS Toolbox: Spatial vector and network analysis modules}\medskip
+ \hline \multicolumn{2}{|c|}{\textbf{Spatial vector and network analysis modules in the GRASS
+ Toolbox}} \\
+ \hline v.extract.where & Select features by attributes \\
+ \hline v.extract.list & Extract selected features \\
+ \hline v.select.overlap & Select features overlapped by features in another
+ map\\
+ \hline v.buffer & Vector buffer \\
+ \hline v.distance & Find the nearest element in vector 'to' for elements in
+ vector 'from'. \\
+ \hline v.net & Network maintenance \\
+ \hline v.net.nodes & Create nodes on network \\
+ \hline v.net.alloc & Allocate network\\
+ \hline v.net.iso & Cut network by cost isolines \\
+ \hline v.net.salesman & Connect nodes by shortest route (traveling
+ salesman) \\
+ \hline v.net.steiner & Connect selected nodes by shortest tree (Steiner
+ tree) \\
+ \hline v.patch & Create a new vector map by combining other vector maps \\
+ \hline v.overlay.or & Vector union \\
+ \hline v.overlay.and & Vector intersection \\
+ \hline v.overlay.not & Vector subtraction \\
+ \hline v.overlay.xor & Vector non-intersection \\
+\hline
+\end{tabular}
+\end{table}
+\begin{table}[ht]
+\centering
\caption{GRASS Toolbox: Change vector field modules}\medskip
\hline \multicolumn{2}{|c|}{\textbf{Change vector field modules in the GRASS
@@ -493,6 +576,7 @@
\end{tabular}
\end{table}
\begin{table}[ht]
\centering
\caption{GRASS Toolbox: Working with vector points modules}\medskip
@@ -504,6 +588,7 @@
\hline v.in.db & Import vector points from a database table containing
coordinates \\
\hline v.random & Randomly generate a 2D/3D GRASS vector point map \\
+ \hline v.perturb & Random location of perturbation of vector points \\
\hline v.kcv & Randomly partition points into test/train sets \\
\hline v.outlier & Romove outliers from vector point data \\
\hline v.hull & Create a convex hull \\
@@ -517,36 +602,6 @@
\begin{table}[ht]
\centering
-\caption{GRASS Toolbox: Spatial vector and network analysis modules}\medskip
- \hline \multicolumn{2}{|c|}{\textbf{Spatial vector and network analysis modules in the GRASS
- Toolbox}} \\
- \hline v.extract.where & Select features by attributes \\
- \hline v.extract.list & Extract selected features \\
- \hline v.select.overlap & Select features overlapped by features in another
- map\\
- \hline v.buffer & Vector buffer \\
- \hline v.distance & Find the nearest element in vector 'to' for elements in
- vector 'from'. \\
- \hline v.net.nodes & Create nodes on network \\
- \hline v.net.alloc & Allocate network\\
- \hline v.net.iso & Cut network by cost isolines \\
- \hline v.net.salesman & Connect nodes by shortest route (traveling
- salesman) \\
- \hline v.net.steiner & Connect selected nodes by shortest tree (Steiner
- tree) \\
- \hline v.patch & Create a new vector map by combining other vector maps \\
- \hline v.overlay.or & Vector union \\
- \hline v.overlay.and & Vector intersection \\
- \hline v.overlay.not & Vector subtraction \\
- \hline v.overlay.xor & Vector non-intersection \\
-\hline
-\end{tabular}
-\end{table}
-\begin{table}[ht]
-\centering
\caption{GRASS Toolbox: Vector update by other maps modules}\medskip
\hline \multicolumn{2}{|c|}{\textbf{Vector update by other maps modules in the GRASS
@@ -592,7 +647,7 @@
\hline \multicolumn{2}{|c|}{\textbf{Imagery analysis modules in the GRASS
Toolbox}} \\
- \hline i.image.mosaik & Mosaic up to 4 images \\
+ \hline i.image.mosaic & Mosaic up to 4 images \\
\hline i.rgb.his & Red Green Blue (RGB) to Hue Intensity Saturation (HIS)
raster map color transformation function \\
\hline i.his.rgb & Hue Intensity Saturation (HIS) to Red Green Blue (RGB)
@@ -602,7 +657,7 @@
high-res pancromatic channels \\
\hline i.zc & Zero-crossing edge detection raster function for image
processing \\
- \hline i.mfilter & \\
+ \hline r.mfilter & Raster file matrix filter\\
\hline i.tasscap4 & Tasseled Cap (Kauth Thomas) transformation for
LANDSAT-TM 4 data \\
\hline i.tasscap5 & Tasseled Cap (Kauth Thomas) transformation for
@@ -638,10 +693,11 @@
\hline db.connect & Sets general DB connection mapset \\
\hline db.connect.schema & Sets general DB connection mapset with a schema \\
+ \hline db.connect-login.pg & Set Postgresql DB connection \\
\hline v.db.reconnect.all & Reconnect vector to a new database \\
\hline db.login & Set user/password for driver/database \\
- \hline db.in.ogr & Imports attribute tables in various formats \\
\hline v.db.addtable & Create and add a new table to a vector \\
+ \hline v.db.droptable & Remove existing attribute table of a vector \\
\hline v.db.addcol & Adds one or more columns to the attribute table
connected to a given vector map \\
\hline v.db.dropcol & Drops a column from the attribute table connected to
Modified: docs/trunk/english_us/user_guide/working_with_raster_screenies/rasterPropertiesDialog.png
(Binary files differ)
