[QGIS Commit] r12900 - in trunk/qgis/src: core plugins/labeling
svn_qgis at osgeo.org
Mon Feb 8 06:08:48 EST 2010
Author: wonder
Date: 2010-02-08 06:08:45 -0500 (Mon, 08 Feb 2010)
New Revision: 12900
trunk/qgis/src/core/qgsmaprenderer.h
trunk/qgis/src/core/qgsvectorlayer.cpp
trunk/qgis/src/plugins/labeling/pallabeling.cpp
trunk/qgis/src/plugins/labeling/pallabeling.h
Uhm... fixing compilation error, take #2.
Hopefully also with better label size scaling in composer (labeling plugin)
Modified: trunk/qgis/src/core/qgsmaprenderer.h
--- trunk/qgis/src/core/qgsmaprenderer.h 2010-02-08 09:33:23 UTC (rev 12899)
+++ trunk/qgis/src/core/qgsmaprenderer.h 2010-02-08 11:08:45 UTC (rev 12900)
@@ -51,7 +51,7 @@
//! called to find out whether the layer is used for labeling
virtual bool willUseLayer( QgsVectorLayer* layer ) = 0;
//! called when starting rendering of a layer
- virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex ) = 0;
+ virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex, QgsRenderContext& ctx ) = 0;
//! called for every feature
virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat ) = 0;
//! called when the map is drawn and labels should be placed
Modified: trunk/qgis/src/core/qgsvectorlayer.cpp
--- trunk/qgis/src/core/qgsvectorlayer.cpp 2010-02-08 09:33:23 UTC (rev 12899)
+++ trunk/qgis/src/core/qgsvectorlayer.cpp 2010-02-08 11:08:45 UTC (rev 12900)
@@ -898,7 +898,7 @@
if ( rendererContext.labelingEngine() )
int attrIndex;
- if ( rendererContext.labelingEngine()->prepareLayer( this, attrIndex ) )
+ if ( rendererContext.labelingEngine()->prepareLayer( this, attrIndex, rendererContext ) )
if ( !attributes.contains( attrIndex ) )
attributes << attrIndex;
@@ -958,7 +958,7 @@
int attrIndex;
Modified: trunk/qgis/src/plugins/labeling/pallabeling.cpp
--- trunk/qgis/src/plugins/labeling/pallabeling.cpp 2010-02-08 09:33:23 UTC (rev 12899)
+++ trunk/qgis/src/plugins/labeling/pallabeling.cpp 2010-02-08 11:08:45 UTC (rev 12900)
@@ -28,6 +28,7 @@
#include <qgsgeometry.h>
#include <qgsmaprenderer.h>
using namespace pal;
@@ -296,7 +297,7 @@
-int PalLabeling::prepareLayer( QgsVectorLayer* layer, int& attrIndex )
+int PalLabeling::prepareLayer( QgsVectorLayer* layer, int& attrIndex, QgsRenderContext& ctx )
Q_ASSERT( mMapRenderer != NULL );
@@ -353,6 +354,10 @@
// set whether adjacent lines should be merged
l->setMergeConnectedLines( lyr.mergeLines );
+ // set font size from points to output size
+ double size = 0.3527 * lyr.textFont.pointSizeF() * ctx.scaleFactor(); //* ctx.rasterScaleFactor();
+ lyr.textFont.setPixelSize((int)size);
// save the pal layer to our layer context (with some additional info)
lyr.palLayer = l;
lyr.fieldIndex = fldIndex;
@@ -620,5 +625,8 @@
QgsLabelingEngineInterface* PalLabeling::clone()
- return new PalLabeling();
+ PalLabeling* lbl = new PalLabeling();
+ lbl->mShowingAllLabels = mShowingAllLabels;
+ lbl->mShowingCandidates = mShowingCandidates;
+ return lbl;
Modified: trunk/qgis/src/plugins/labeling/pallabeling.h
--- trunk/qgis/src/plugins/labeling/pallabeling.h 2010-02-08 09:33:23 UTC (rev 12899)
+++ trunk/qgis/src/plugins/labeling/pallabeling.h 2010-02-08 11:08:45 UTC (rev 12900)
@@ -126,7 +126,7 @@
virtual bool willUseLayer( QgsVectorLayer* layer );
//! hook called when drawing layer before issuing select()
- virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex );
+ virtual int prepareLayer( QgsVectorLayer* layer, int& attrIndex, QgsRenderContext& ctx );
//! hook called when drawing for every feature in a layer
virtual void registerFeature( QgsVectorLayer* layer, QgsFeature& feat );
