[QGIS Commit] r12912 - trunk/qgis/src/plugins/grass/modules-common
svn_qgis at osgeo.org
Wed Feb 10 04:39:17 EST 2010
Author: pcav
Date: 2010-02-10 04:39:11 -0500 (Wed, 10 Feb 2010)
New Revision: 12912
trunk/qgis/src/plugins/grass/modules-common/v.dissolve.qgm
Fix in v.dissolve GRASS module - closes #2351. Thanks Giovanni Manghi
Modified: trunk/qgis/src/plugins/grass/modules-common/v.dissolve.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.dissolve.qgm 2010-02-09 20:28:36 UTC (rev 12911)
+++ trunk/qgis/src/plugins/grass/modules-common/v.dissolve.qgm 2010-02-10 09:39:11 UTC (rev 12912)
@@ -3,6 +3,6 @@
<qgisgrassmodule label="Dissolves boundaries between adjacent areas sharing a common category number or attribute" module="v.dissolve">
<option key="input" layeroption="layer"/>
- <field key="column" layer="map" type="integer,string" label="Attribute field" />
+ <field key="column" layer="input" type="integer,string" label="Attribute field" />
<option key="output" />
</qgisgrassmodule>
