[QGIS Commit] r12923 - in trunk/qgis/src: plugins/grass
providers/grass
svn_qgis at osgeo.org
Thu Feb 11 02:41:38 EST 2010
Author: jef
Date: 2010-02-11 02:41:35 -0500 (Thu, 11 Feb 2010)
New Revision: 12923
trunk/qgis/src/plugins/grass/qgis.g.browser.cpp
trunk/qgis/src/providers/grass/qgsgrass.h
fix windows build errors
Modified: trunk/qgis/src/plugins/grass/qgis.g.browser.cpp
--- trunk/qgis/src/plugins/grass/qgis.g.browser.cpp 2010-02-10 20:17:49 UTC (rev 12922)
+++ trunk/qgis/src/plugins/grass/qgis.g.browser.cpp 2010-02-11 07:41:35 UTC (rev 12923)
@@ -4,15 +4,23 @@
#include <QUrl>
#include <QDesktopServices>
+#ifdef Q_OS_WIN
+#include <windows.h>
+#endif
// Open a URL by default browser
-int main(int argc, char **argv)
+int main( int argc, char **argv )
- if ( argc < 2 )
- fprintf ( stderr, "URL argument missing\n" );
- exit (1);
+ if ( argc < 2 )
+ fprintf( stderr, "URL argument missing\n" );
+ exit( 1 );
- QDesktopServices::openUrl ( QUrl ( argv[1] ) );
- sleep(1); // not nice but if it exits immediately the page sometimes does not open
- exit ( 0 );
+ QDesktopServices::openUrl( QUrl( argv[1] ) );
+#ifdef Q_OS_WIN
+ Sleep( 1000 );
+#else
+ sleep( 1 ); // not nice but if it exits immediately the page sometimes does not open
+#endif
+ exit( 0 );
Modified: trunk/qgis/src/providers/grass/qgsgrass.h
--- trunk/qgis/src/providers/grass/qgsgrass.h 2010-02-10 20:17:49 UTC (rev 12922)
+++ trunk/qgis/src/providers/grass/qgsgrass.h 2010-02-11 07:41:35 UTC (rev 12923)
@@ -161,25 +161,25 @@
static GRASS_EXPORT QString lockFilePath();
// ! Get current gisrc path
- static QString gisrcFilePath();
+ static GRASS_EXPORT QString gisrcFilePath();
// ! Run a GRASS module in any gisdbase/location
static GRASS_EXPORT QByteArray runModule( QString gisdbase, QString location, QString module, QStringList arguments );
// ! Get info string from qgis.g.info module
- static GRASS_EXPORT QString getInfo( QString info, QString gisdbase,
- QString location, QString mapset=0, QString map=0, MapType type = None, double x=0, double y=0 );
+ static GRASS_EXPORT QString getInfo( QString info, QString gisdbase,
+ QString location, QString mapset = 0, QString map = 0, MapType type = None, double x = 0, double y = 0 );
- // ! Get location projection
- static GRASS_EXPORT QgsCoordinateReferenceSystem crs( QString gisdbase, QString location);
+ // ! Get location projection
+ static GRASS_EXPORT QgsCoordinateReferenceSystem crs( QString gisdbase, QString location );
// ! Get map extent
- static GRASS_EXPORT QgsRectangle extent( QString gisdbase, QString location,
- QString mapset, QString map, MapType type = None );
+ static GRASS_EXPORT QgsRectangle extent( QString gisdbase, QString location,
+ QString mapset, QString map, MapType type = None );
// ! Get map value / feautre info
- static GRASS_EXPORT QMap<QString, QString> query( QString gisdbase, QString location,
- QString mapset, QString map, MapType type, double x, double y);
+ static GRASS_EXPORT QMap<QString, QString> query( QString gisdbase, QString location,
+ QString mapset, QString map, MapType type, double x, double y );
//! Library version
static GRASS_EXPORT int versionMajor();
