[QGIS Commit] r12953 - trunk/qgis/src/analysis/vector
svn_qgis at osgeo.org
Wed Feb 17 06:22:54 EST 2010
Author: mhugent
Date: 2010-02-17 06:22:52 -0500 (Wed, 17 Feb 2010)
New Revision: 12953
trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
trunk/qgis/src/analysis/vector/qgszonalstatistics.h
Improve zonal statistics function in analysis lib
Modified: trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp 2010-02-16 22:31:03 UTC (rev 12952)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.cpp 2010-02-17 11:22:52 UTC (rev 12953)
@@ -97,7 +97,7 @@
//add the new count, sum, mean fields to the provider
QList<QgsField> newFieldList;
- QgsField countField( mAttributePrefix + "count", QVariant::Int );
+ QgsField countField( mAttributePrefix + "count", QVariant::Double );
QgsField sumField( mAttributePrefix + "sum", QVariant::Double );
QgsField meanField( mAttributePrefix + "mean", QVariant::Double );
newFieldList.push_back( countField );
@@ -133,12 +133,7 @@
double count = 0;
double sum = 0;
double mean = 0;
- float* scanLine;
int featureCounter = 0;
- //x- and y- coordinate of current cell
- double cellCenterX = 0;
- double cellCenterY = 0;
- QgsPoint currentCellCenter;
while ( vectorProvider->nextFeature( f ) )
@@ -166,31 +161,17 @@
continue;
- scanLine = ( float * ) CPLMalloc( sizeof( float ) * nCellsX );
- cellCenterY = rasterBBox.yMaximum() - offsetY * cellsizeY - cellsizeY / 2;
- count = 0;
- sum = 0;
+ statisticsFromMiddlePointTest( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY, \
+ rasterBBox, sum, count );
- for ( int i = 0; i < nCellsY; ++i )
+ if ( count <= 1 )
- GDALRasterIO( rasterBand, GF_Read, offsetX, offsetY + i, nCellsX, 1, scanLine, nCellsX, 1, GDT_Float32, 0, 0 );
- cellCenterX = rasterBBox.xMinimum() + offsetX * cellsizeX + cellsizeX / 2;
- for ( int j = 0; j < nCellsX; ++j )
- currentCellCenter = QgsPoint( cellCenterX, cellCenterY );
- if ( featureGeometry->contains( ¤tCellCenter ) )
- if ( scanLine[j] != mInputNodataValue ) //don't consider nodata values
- sum += scanLine[j];
- ++count;
- cellCenterX += cellsizeX;
- cellCenterY -= cellsizeY;
+ //the cell resolution is probably larger than the polygon area. We switch to precise pixel - polygon intersection in this case
+ statisticsFromPreciseIntersection( rasterBand, featureGeometry, offsetX, offsetY, nCellsX, nCellsY, cellsizeX, cellsizeY, \
if ( count == 0 )
mean = 0;
@@ -200,7 +181,7 @@
mean = sum / count;
- //write the new AEY value to the vector data provider
+ //write the statistics value to the vector data provider
QgsChangedAttributesMap changeMap;
QgsAttributeMap changeAttributeMap;
changeAttributeMap.insert( countIndex, QVariant( count ) );
@@ -209,7 +190,6 @@
changeMap.insert( f.id(), changeAttributeMap );
vectorProvider->changeAttributeValues( changeMap );
- CPLFree( scanLine );
++featureCounter;
@@ -246,6 +226,84 @@
return 0;
+void QgsZonalStatistics::statisticsFromMiddlePointTest( void* band, QgsGeometry* poly, int pixelOffsetX, \
+ int pixelOffsetY, int nCellsX, int nCellsY, double cellSizeX, double cellSizeY, const QgsRectangle& rasterBBox, double& sum, double& count )
+ double cellCenterX, cellCenterY;
+ QgsPoint currentCellCenter;
+ float* scanLine = ( float * ) CPLMalloc( sizeof( float ) * nCellsX );
+ cellCenterY = rasterBBox.yMaximum() - pixelOffsetY * cellSizeY - cellSizeY / 2;
+ count = 0;
+ sum = 0;
+ for ( int i = 0; i < nCellsY; ++i )
+ GDALRasterIO( band, GF_Read, pixelOffsetX, pixelOffsetY + i, nCellsX, 1, scanLine, nCellsX, 1, GDT_Float32, 0, 0 );
+ cellCenterX = rasterBBox.xMinimum() + pixelOffsetX * cellSizeX + cellSizeX / 2;
+ for ( int j = 0; j < nCellsX; ++j )
+ currentCellCenter = QgsPoint( cellCenterX, cellCenterY );
+ if ( poly->contains( ¤tCellCenter ) )
+ if ( scanLine[j] != mInputNodataValue ) //don't consider nodata values
+ sum += scanLine[j];
+ ++count;
+ cellCenterX += cellSizeX;
+ cellCenterY -= cellSizeY;
+ CPLFree( scanLine );
+void QgsZonalStatistics::statisticsFromPreciseIntersection( void* band, QgsGeometry* poly, int pixelOffsetX, \
+ sum = 0;
+ count = 0;
+ double currentY = rasterBBox.yMaximum() - pixelOffsetY * cellSizeY - cellSizeY / 2;
+ float* pixelData = ( float * ) CPLMalloc( sizeof( float ) );
+ QgsGeometry* pixelRectGeometry = 0;
+ QgsGeometry* intersectGeometry = 0;
+ double hCellSizeX = cellSizeX / 2.0;
+ double hCellSizeY = cellSizeY / 2.0;
+ double pixelArea = cellSizeX * cellSizeY;
+ double intersectionArea = 0;
+ double weight = 0;
+ for ( int row = 0; row < nCellsY; ++row )
+ double currentX = rasterBBox.xMinimum() + cellSizeX / 2.0 + pixelOffsetX * cellSizeX;
+ for ( int col = 0; col < nCellsX; ++col )
+ GDALRasterIO( band, GF_Read, pixelOffsetX + col, pixelOffsetY + row, nCellsX, 1, pixelData, 1, 1, GDT_Float32, 0, 0 );
+ pixelRectGeometry = QgsGeometry::fromRect( QgsRectangle( currentX - hCellSizeX, currentY - hCellSizeY, currentX + hCellSizeX, currentY + hCellSizeY ) );
+ if ( pixelRectGeometry )
+ //intersecton
+ intersectGeometry = pixelRectGeometry->intersection( poly );
+ if ( intersectGeometry )
+ if ( GEOSArea( intersectGeometry->asGeos(), &intersectionArea ) )
+ weight = intersectionArea / pixelArea;
+ count += weight;
+ sum += *pixelData * weight;
+ delete intersectGeometry;
+ currentX += cellSizeX;
+ currentY -= cellSizeY;
+ CPLFree( pixelData );
Modified: trunk/qgis/src/analysis/vector/qgszonalstatistics.h
--- trunk/qgis/src/analysis/vector/qgszonalstatistics.h 2010-02-16 22:31:03 UTC (rev 12952)
+++ trunk/qgis/src/analysis/vector/qgszonalstatistics.h 2010-02-17 11:22:52 UTC (rev 12953)
@@ -21,6 +21,7 @@
#include "qgsrectangle.h"
#include <QString>
+class QgsGeometry;
class QgsVectorLayer;
class QProgressDialog;
@@ -42,6 +43,15 @@
int cellInfoForBBox( const QgsRectangle& rasterBBox, const QgsRectangle& featureBBox, double cellSizeX, double cellSizeY,
int& offsetX, int& offsetY, int& nCellsX, int& nCellsY ) const;
+ /**Returns statistics by considering the pixels where the center point is within the polygon (fast)*/
+ void statisticsFromMiddlePointTest( void* band, QgsGeometry* poly, int pixelOffsetX, int pixelOffsetY, int nCellsX, int nCellsY, \
+ double cellSizeX, double cellSizeY, const QgsRectangle& rasterBBox, double& sum, double& count );
+ /**Returns statistics with precise pixel - polygon intersection test (slow) */
+ void statisticsFromPreciseIntersection( void* band, QgsGeometry* poly, int pixelOffsetX, int pixelOffsetY, int nCellsX, int nCellsY, \
QString mRasterFilePath;
/**Raster band to calculate statistics from (defaults to 1)*/
int mRasterBand;
