[QGIS Commit] r13880 - in trunk/qgis/mac/xcode: . Qgis.xcodeproj
svn_qgis at osgeo.org
Fri Jul 2 16:55:44 EDT 2010
Author: kyngchaos
Date: 2010-07-02 20:55:44 +0000 (Fri, 02 Jul 2010)
New Revision: 13880
trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
trunk/qgis/mac/xcode/qgis_settings.xcconfig
fix qgis.g.browser linking
Modified: trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj
--- trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-07-02 19:19:28 UTC (rev 13879)
+++ trunk/qgis/mac/xcode/Qgis.xcodeproj/project.pbxproj 2010-07-02 20:55:44 UTC (rev 13880)
@@ -15552,8 +15552,7 @@
runOnlyForDeploymentPostprocessing = 0;
shellPath = /bin/sh;
- shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\necho \"Copying Qt frameworks...\"\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] && [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/V
ersions/$QT_FWVER/Resources\" ] ; then\n\t\t\tcp -Rfp \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/Resources\" \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\t\tln -sfh Versions/Current/Resources \"$FWDIR/$q.framework/Resources\"\n\t\tfi\n\t\t# debug variants\n\t\tqd=$q\"_debug\"\n\t\tif [ \"$CONFIGURATION\" = \"Debug\" ] && [ -f \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" ] ; then\n\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/Versions/$QT_FWVER/$qd\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$qd\"\n\t\t\tln -sf Versions/Current/$qd \"$FWDIR/$q.framework/$qd\"\n\t\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" ] ; then\n\t\t\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$qd.dSYM\" \"$FWDIR/$q.framework\"\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n\n# copy Qt plugins\nmkdir -p \"$APPDIRC/PlugIns/imageformats\"\nif [ ! -f \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\" ] ; then\n\tditto -X $QARCHS \"$QT_PLUGINS_DIR/imageformats/libqjpeg.dylib\" \"$APPDIRC/PlugIn
s/imageformats/libqjpeg.dylib\"\nfi\nmkdir -p \"$APPDIRC/PlugIns/codecs\"\nfor c in cn jp kr tw\ndo\n\tif [ ! -f \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\" ] ; then\n\t\tditto -X $QARCHS \"$QT_PLUGINS_DIR/codecs/libq$c\"\"codecs.dylib\" \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\tfi\ndone\n\n# Qwt\n\necho \"Copying Qwt and updating library paths...\"\nQWTROOT=\"$QWT_PREFIX/lib\"\nif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\tditto -X $QARCHS \"$QWTROOT/libqwt.dylib\" \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\tqlib=`otool -L \"$QWTROOT/libqwt.dylib\" | grep -E -m 1 \"libqwt.+ \" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\tQWT_CHG=\"-change $qlib @executable_path/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\techo \"install_name_tool $QWT_CHG \\\"$APPDIR/Qgis\\\"\"\n\tinstall_name_tool $QWT_CHG \"$APPDIR/Qgis\"\nfi\n\n# PyQt path based on PYTHON_FORM\n\nif [ \"$PYSITE\" ] ; then\n\techo \"Copying PyQt library paths...\"\n\t
mkdir -p \"$QGISPYDIR/PyQt$QT_FWVER\"\n\tif [ ! -f \"$QGISPYDIR/sip.so\" ] ; then\n\t\tditto -X $QARCHS \"$PYSITE/sip.so\" \"$QGISPYDIR/\"\n\t\tcp -fp \"$PYSITE/sipconfig.py\" \"$QGISPYDIR/\"\n\tfi\n\tfor q in $PYQTLIST\n\tdo\n\t\tif [ ! -f \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\" ] ; then\n\t\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/$q.so\" \"$QGISPYDIR/PyQt$QT_FWVER/$q.so\"\n\t\tfi\n\tdone\n\tcp -fp \"$PYSITE/PyQt$QT_FWVER/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/\"\n\t# PyQwt\n\tif [ -d \"$PYSITE/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\techo \"Copying PyQwt and updating library paths...\"\n\t\tmkdir -p \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/_iqt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tditto -X $QARCHS \"$PYSITE/PyQt$QT_FWVER/Qwt5/Qwt.so\" \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -fp \"$PYSITE/PyQt$QT_FWVER/Qwt5/\"*.py \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/\"\n\t\tcp -Rfp \"$PYSITE/PyQt$QT_FWVER/uic\" \"$QGISPYDIR/PyQt$QT_FWVER\"\n\t\techo \
"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls libqgis*.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\necho \"Updating Qt library paths...\"\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tif [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\tqq=`otool -L \"$QT_PREFIX_FW/$q.framework/$q\" | grep -E -m 1 \"$q.framework.*\\(\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tq_chg=\"-change $qq @executable_path/
$QGIS_FW_SUBDIR/$q.framework/$q\"\n\t\t# app\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/Qgis\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/Qgis\"\n\t\t# qgis_help qt linking done with symlinks\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t\t# libs\n\t\tfor ql in $qgliblist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIB_SUBDIR/$ql\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\t\tdone\n\t\t# plugins\n\t\tfor qp in $pluglist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\t\tdone\n\t\t# qt fw\n\t\tfor qf in $QTLISTQG\n\t\tdo\n\t\t\tif [ -d \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework\" ] ; then\n\t\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_FW_S
UBDIR/$qf.framework/Versions/$QT_FWVER/$qf\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\t\t\tfi\n\t\tdone\n\t\t# qt plugs\n\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t\tfor c in cn jp kr tw\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/codecs/libq$c\\\"\\\"codecs.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\t\tdone\n\t\t# Qwt\n\t\tif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t\tfi\n\t\t# PyQt\n\t\tif [ \"$PYSITE\" ] ; then\n\t\t\tfor pq in $PYQTLIST\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER
/$pq.so\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\t\tdone\n\t\t\tfor pg in $qgpylist\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/qgis/$pg\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/qgis/$pg\"\n\t\t\tdone\n\t\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\t\tfor pw in _iqt Qwt\n\t\t\t\tdo\n\t\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\\\"\"\n\t\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\"\n\t\t\t\tdone\n\t\t\tfi\n\t\tfi\n\tfi\ndone\n";
- showEnvVarsInLog = 0;
+ shellScript = "# Note: assumes default Qt binary framework install\n\nAPPDIRC=\"$QGIS_BUILD_PATH\" # app contents\nAPPDIR=\"$APPDIRC/MacOS\"\nFWDIR=\"$APPDIR/$QGIS_FW_SUBDIR\"\nLIBDIR=\"$APPDIR/$QGIS_LIB_SUBDIR\"\nQGISPYDIR=\"$APPDIR/$QGIS_DATA_SUBDIR/python\"\n\n# qt arches\nQARCHS=\"\"\nfor a in $ARCHS\ndo\n\tQARCHS=\"$QARCHS -arch $a\"\ndone\n\n# copy Qt frameworks\necho \"Copying Qt frameworks...\"\nmkdir -p \"$FWDIR\"\nfor q in $QTLISTQG\ndo\n\tif [ ! -d \"$FWDIR/$q.framework\" ] && [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; then\n\t\t# reconstruct framework to avoid excessive copying, then deleting\n\t\t# especially when debug variants are present\n\t\tmkdir -p \"$FWDIR/$q.framework/Versions/$QT_FWVER\"\n\t\tln -sfh $QT_FWVER \"$FWDIR/$q.framework/Versions/Current\"\n\t\tditto -X $QARCHS \"$QT_PREFIX_FW/$q.framework/$q\" \"$FWDIR/$q.framework/Versions/$QT_FWVER/$q\"\n\t\tln -sf Versions/Current/$q \"$FWDIR/$q.framework/$q\"\n\t\tif [ -d \"$QT_PREFIX_FW/$q.framework/V
"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/_iqt.so\"\n\t\techo \"install_name_tool $QWT_CHG \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\\\"\"\n\t\tinstall_name_tool $QWT_CHG \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/Qwt.so\"\n\tfi\nfi\n\n# GRASS plugin libexec stuff may link Qt\nif [ -d \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin\" ] ; then\n\tln -s ../$QGIS_LIBEXEC_REL/$QGIS_FW_SUBDIR \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/Frameworks\"\nfi\n\n# just in case no plugins were compiled\nmkdir -p \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\n# list plugins & libs\ncd \"$APPDIR/$QGIS_PLUGIN_SUBDIR\"\npluglist=`ls`\ncd \"$APPDIR/$QGIS_LIB_SUBDIR\"\nqgliblist=`ls libqgis*.dylib`\nif [ \"$PYSITE\" ] ; then\n\tcd \"$QGISPYDIR/qgis\"\n\tqgpylist=`ls *.so`\nfi\n\n# main Qt framework loop\n\necho \"Updating Qt library paths...\"\n\ncd \"$APPDIR\"\n\nfor q in $QTLISTQG\ndo\n\tif [ -d \"$QT_PREFIX_FW/$q.framework\" ] ; the
n\n\t\tqq=`otool -L \"$QT_PREFIX_FW/$q.framework/$q\" | grep -E -m 1 \"$q.framework.*\\(\" | cut -d \\( -f 1 | sed -E -e 's/^[[:space:]]//' -e 's/[[:space:]]$//'`\n\t\tq_chg=\"-change $qq @executable_path/$QGIS_FW_SUBDIR/$q.framework/$q\"\n\t\t# app\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/Qgis\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/Qgis\"\n\t\t# qgis_help qt linking done with symlinks\n\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_BIN_SUBDIR/qgis_help.app/Contents/MacOS/qgis_help\"\n\t\t# libs\n\t\tfor ql in $qgliblist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIB_SUBDIR/$ql\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIB_SUBDIR/$ql\"\n\t\tdone\n\t\t# GRASS libexec stuff\n\t\tif [ -f \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_LIBEXEC_SUBDI
R/grass/bin/qgis.g.browser\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_LIBEXEC_SUBDIR/grass/bin/qgis.g.browser\"\n\t\tfi\n\t\t# plugins\n\t\tfor qp in $pluglist\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_PLUGIN_SUBDIR/$qp\"\n\t\tdone\n\t\t# qt fw\n\t\tfor qf in $QTLISTQG\n\t\tdo\n\t\t\tif [ -d \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework\" ] ; then\n\t\t\t\techo \"install_name_tool $q_chg \\\"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$APPDIR/$QGIS_FW_SUBDIR/$qf.framework/Versions/$QT_FWVER/$qf\"\n\t\t\tfi\n\t\tdone\n\t\t# qt plugs\n\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\\\"\"\n\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/imageformats/libqjpeg.dylib\"\n\t\tfor c in cn jp kr tw\n\t\tdo\n\t\t\techo \"install_name_tool $q_chg \\\"$APPDIRC/PlugIns/codecs/libq$c\\\"\\\"codecs
.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$APPDIRC/PlugIns/codecs/libq$c\"\"codecs.dylib\"\n\t\tdone\n\t\t# Qwt\n\t\tif [ -f \"$QWTROOT/libqwt.dylib\" ] ; then\n\t\t\techo \"install_name_tool $q_chg \\\"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\\\"\"\n\t\t\tinstall_name_tool $q_chg \"$QGIS_BUILD_PATH/MacOS/$QGIS_LIB_SUBDIR/libqwt.dylib\"\n\t\tfi\n\t\t# PyQt\n\t\tif [ \"$PYSITE\" ] ; then\n\t\t\tfor pq in $PYQTLIST\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/PyQt$QT_FWVER/$pq.so\"\n\t\t\tdone\n\t\t\tfor pg in $qgpylist\n\t\t\tdo\n\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/qgis/$pg\\\"\"\n\t\t\t\tinstall_name_tool $q_chg \"$QGISPYDIR/qgis/$pg\"\n\t\t\tdone\n\t\t\tif [ -d \"$QGISPYDIR/PyQt$QT_FWVER/Qwt5\" ] ; then\n\t\t\t\tfor pw in _iqt Qwt\n\t\t\t\tdo\n\t\t\t\t\techo \"install_name_tool $q_chg \\\"$QGISPYDIR/PyQt$QT_FWVER/Qwt5/$pw.so\\\"\"\n\t\t\t\t\tins
72F3DABA11D70D4900FFA738 /* Script - svnver plist */ = {
isa = PBXShellScriptBuildPhase;
Modified: trunk/qgis/mac/xcode/qgis_settings.xcconfig
--- trunk/qgis/mac/xcode/qgis_settings.xcconfig 2010-07-02 19:19:28 UTC (rev 13879)
+++ trunk/qgis/mac/xcode/qgis_settings.xcconfig 2010-07-02 20:55:44 UTC (rev 13880)
@@ -183,6 +183,7 @@
QGIS_DATA_SUBDIR = ../Resources
QGIS_PLUGIN_SUBDIR = ../PlugIns/qgis
QGIS_LIBEXEC_SUBDIR = lib/gqis
+QGIS_LIBEXEC_REL = ../.. // for backing out in relative paths, match depth of _SUBDIR above
QGIS_HEADER_SEARCH_BASE = $(SYMROOT)/$(CONFIGURATION)$(EFFECTIVE_PLATFORM_NAME)/include
HEADER_SEARCH_PATHS = $(QGIS_HEADER_SEARCH_BASE)
ALWAYS_SEARCH_USER_PATHS = NO
