[QGIS Commit] r13904 - in trunk/qgis/src: app app/legend ui
svn_qgis at osgeo.org
Sun Jul 11 06:05:41 EDT 2010
Author: mhugent
Date: 2010-07-11 10:05:41 +0000 (Sun, 11 Jul 2010)
New Revision: 13904
trunk/qgis/src/app/legend/qgslegendlayer.cpp
trunk/qgis/src/app/qgsoptions.cpp
trunk/qgis/src/ui/qgsoptionsbase.ui
Option for raster icon in legend
Modified: trunk/qgis/src/app/legend/qgslegendlayer.cpp
--- trunk/qgis/src/app/legend/qgslegendlayer.cpp 2010-07-09 12:29:18 UTC (rev 13903)
+++ trunk/qgis/src/app/legend/qgslegendlayer.cpp 2010-07-11 10:05:41 UTC (rev 13904)
@@ -365,13 +365,18 @@
else if ( theLayer->type() == QgsMapLayer::RasterLayer )
-#if 0 //MH100708: disabled for 1.5 release because of performance problems
- QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>( theLayer );
- QPixmap myPixmap( 32, 32 );
- rlayer->thumbnailAsPixmap( &myPixmap );
- return myPixmap;
-#endif //0
- return QPixmap();
+ QSettings s;
+ if( s.value( "/qgis/createRasterLegendIcons", true ).toBool() )
+ QgsRasterLayer* rlayer = qobject_cast<QgsRasterLayer *>( theLayer );
+ QPixmap myPixmap( 32, 32 );
+ rlayer->thumbnailAsPixmap( &myPixmap );
+ return myPixmap;
+ else
+ return QPixmap();
Modified: trunk/qgis/src/app/qgsoptions.cpp
--- trunk/qgis/src/app/qgsoptions.cpp 2010-07-09 12:29:18 UTC (rev 13903)
+++ trunk/qgis/src/app/qgsoptions.cpp 2010-07-11 10:05:41 UTC (rev 13904)
@@ -235,6 +235,7 @@
cbxIdentifyResultsDocked->setChecked( settings.value( "/qgis/dockIdentifyResults", false ).toBool() );
cbxAddPostgisDC->setChecked( settings.value( "/qgis/addPostgisDC", false ).toBool() );
cbxAddNewLayersToCurrentGroup->setChecked( settings.value( "/qgis/addNewLayersToCurrentGroup", false ).toBool() );
+ cbxCreateRasterLegendIcons->setChecked( settings.value( "/qgis/createRasterLegendIcons", true ).toBool() );
//set the color for selections
int myRed = settings.value( "/qgis/default_selection_color_red", 255 ).toInt();
@@ -489,6 +490,7 @@
settings.setValue( "/qgis/dockIdentifyResults", cbxIdentifyResultsDocked->isChecked() );
settings.setValue( "/qgis/addPostgisDC", cbxAddPostgisDC->isChecked() );
settings.setValue( "/qgis/addNewLayersToCurrentGroup", cbxAddNewLayersToCurrentGroup->isChecked() );
+ settings.setValue( "/qgis/createRasterLegendIcons", cbxCreateRasterLegendIcons->isChecked() );
settings.setValue( "/qgis/new_layers_visible", chkAddedVisibility->isChecked() );
settings.setValue( "/qgis/enable_anti_aliasing", chkAntiAliasing->isChecked() );
settings.setValue( "/qgis/enable_render_caching", chkUseRenderCaching->isChecked() );
Modified: trunk/qgis/src/ui/qgsoptionsbase.ui
--- trunk/qgis/src/ui/qgsoptionsbase.ui 2010-07-09 12:29:18 UTC (rev 13903)
+++ trunk/qgis/src/ui/qgsoptionsbase.ui 2010-07-11 10:05:41 UTC (rev 13904)
@@ -380,6 +380,13 @@
</widget>
</item>
<item>
+ <widget class="QCheckBox" name="cbxCreateRasterLegendIcons">
+ <property name="text">
+ <string>Create raster icons in legend</string>
+ </property>
+ </widget>
+ </item>
+ <item>
<widget class="QCheckBox" name="cbxHideSplash">
<string>Hide splash screen at startup</string>
