[QGIS Commit] r13948 - trunk/qgis/src/plugins/interpolation
svn_qgis at osgeo.org
Tue Jul 20 13:22:27 EDT 2010
Author: mhugent
Date: 2010-07-20 17:22:27 +0000 (Tue, 20 Jul 2010)
New Revision: 13948
Removed:
trunk/qgis/src/plugins/interpolation/qgisinterpolator.h
Remove legacy file from interpolation plugin
Deleted: trunk/qgis/src/plugins/interpolation/qgisinterpolator.h
--- trunk/qgis/src/plugins/interpolation/qgisinterpolator.h 2010-07-20 14:02:49 UTC (rev 13947)
+++ trunk/qgis/src/plugins/interpolation/qgisinterpolator.h 2010-07-20 17:22:27 UTC (rev 13948)
@@ -1,71 +0,0 @@
- qgsinterpolator.h
- begin : March 10, 2008
- copyright : (C) 2008 by Marco Hugentobler
- email : marco dot hugentobler at karto dot baug dot ethz dot ch
- * This program is free software; you can redistribute it and/or modify *
- * it under the terms of the GNU General Public License as published by *
- * the Free Software Foundation; either version 2 of the License, or *
- * (at your option) any later version. *
-#ifndef QGSINTERPOLATOR_H
-#define QGSINTERPOLATOR_H
-#include <QVector>
-class QgsVectorLayer;
-struct vertexData
- double x;
- double y;
- double z;
-/**Interface class for interpolations. Interpolators take
-the vertices of a vector layer as base data. The z-Value
-can be an attribute or the z-coordinates in case of 25D types*/
-class QgsInterpolator
- public:
- QgsInterpolator( QgsVectorLayer* vlayer );
- virtual ~QgsInterpolator();
- /**Calculates interpolation value for map coordinates x, y
- @param x x-coordinate (in map units)
- @param y y-coordinate (in map units)
- @param result out: interpolation result
- @return 0 in case of success*/
- virtual int interpolatePoint( double x, double y, double& result ) = 0;
- /**Use the z-coord of 25D for interpolation*/
- void enableZCoordInterpolation() {useZCoord = true;}
- /**Use a vector attribute as interpolation value*/
- void enableAttributeValueInterpolation( int attribute );
- protected:
- /**Caches the vertex and value data from the provider. All the vertex data
- will be held in virtual memory
- int cacheBaseData();
- QVector<vertexData> mCachedBaseData;
- private:
- QgsInterpolator(); //forbidden
- QgsVectorLayer* mVectorLayer;
- bool zCoordInterpolation;
- int mValueAttribute;
-#endif
