[QGIS Commit] r13951 - in trunk/qgis: python/core src/app src/core
svn_qgis at osgeo.org
Wed Jul 21 09:12:48 EDT 2010
Author: wonder
Date: 2010-07-21 13:12:47 +0000 (Wed, 21 Jul 2010)
New Revision: 13951
trunk/qgis/python/core/qgsapplication.sip
trunk/qgis/src/app/main.cpp
trunk/qgis/src/core/qgsapplication.cpp
trunk/qgis/src/core/qgsapplication.h
[FEATURE] Added --configpath option that overrides the default path (~/.qgis) for user configuration and forces QSettings to use this directory, too.\
This allows users to e.g. carry QGIS installation on a flash drive together with all plugins and settings.
Developed for Faunalia (http://www.faunalia.it) with funding from Regione Toscana - Sistema Informativo per la Gestione del Territorio e dell' Ambiente [RT-SIGTA].
For the project: "Sviluppo di prodotti software GIS open-source basati sui prodotti QuantumGIS e Postgis (CIG 037728516E)"
Modified: trunk/qgis/python/core/qgsapplication.sip
--- trunk/qgis/python/core/qgsapplication.sip 2010-07-21 10:10:43 UTC (rev 13950)
+++ trunk/qgis/python/core/qgsapplication.sip 2010-07-21 13:12:47 UTC (rev 13951)
@@ -58,7 +58,7 @@
public:
//QgsApplication(int argc, char ** argv, bool GUIenabled);
- QgsApplication(SIP_PYLIST argv, bool GUIenabled) /PostHook=__pyQtQAppHook__/ [(int &argc, char **argv, bool GUIenabled)];
+ QgsApplication(SIP_PYLIST argv, bool GUIenabled, QString customConfigPath = QString() ) /PostHook=__pyQtQAppHook__/ [(int &argc, char **argv, bool GUIenabled, QString customConfigPath = QString() )];
%MethodCode
// The Python interface is a list of argument strings that is modified.
@@ -73,7 +73,7 @@
// Create it now the arguments are right.
static int nargc = argc;
- sipCpp = new sipQgsApplication(nargc, argv, a1);
+ sipCpp = new sipQgsApplication(nargc, argv, a1, *a2);
// Now modify the original list.
qtgui_UpdatePyArgv(a0, argc, argv);
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2010-07-21 10:10:43 UTC (rev 13950)
+++ trunk/qgis/src/app/main.cpp 2010-07-21 13:12:47 UTC (rev 13951)
@@ -100,6 +100,7 @@
<< "\t[--nologo]\thide splash screen\n"
<< "\t[--noplugins]\tdon't restore plugins on startup\n"
<< "\t[--optionspath path]\tuse the given QSettings path\n"
+ << "\t[--configpath path]\tuse the given path for all user configuration\n"
<< "\t[--help]\t\tthis text\n\n"
<< " FILES:\n"
<< " Files specified on the command line can include rasters,\n"
@@ -288,6 +289,10 @@
// which is useful for testing
QString myTranslationCode;
+ // The user can specify a path which will override the default path of custom
+ // user settings (~/.qgis) and it will be used for QSettings INI file
+ QString configpath;
#ifndef WIN32
if ( !bundleclicked( argc, argv ) )
@@ -314,13 +319,14 @@
{"project", required_argument, 0, 'p'},
{"extent", required_argument, 0, 'e'},
{"optionspath", required_argument, 0, 'o'},
+ {"configpath", required_argument, 0, 'c'},
{0, 0, 0, 0}
/* getopt_long stores the option index here. */
int option_index = 0;
- optionChar = getopt_long( argc, argv, "swhlpeo",
+ optionChar = getopt_long( argc, argv, "swhlpeoc",
long_options, &option_index );
/* Detect the end of the options. */
@@ -372,9 +378,13 @@
break;
case 'o':
- QSettings::setPath( QSettings::NativeFormat, QSettings::UserScope, optarg );
+ QSettings::setPath( QSettings::IniFormat, QSettings::UserScope, optarg );
break;
+ case 'c':
+ configpath = optarg;
+ break;
case '?':
usage( argv[0] );
return 2; // XXX need standard exit codes
@@ -445,8 +455,13 @@
else if ( i + 1 < argc && ( arg == "--optionspath" || arg == "-o" ) )
- QSettings::setPath( QSettings::NativeFormat, QSettings::UserScope, argv[++i] );
+ QSettings::setPath( QSettings::IniFormat, QSettings::UserScope, argv[++i] );
+ else if ( i + 1 < argc && ( arg == "--configpath" || arg == "-c" ) )
+ configpath = argv[++i];
+ QSettings::setPath( QSettings::IniFormat, QSettings::UserScope, configpath );
else
myFileList.append( QDir::convertSeparators( QFileInfo( QFile::decodeName( argv[i] ) ).absoluteFilePath() ) );
@@ -476,8 +491,15 @@
).toUtf8().constData();
exit( 1 ); //exit for now until a version of qgis is capabable of running non interactive
- QgsApplication myApp( argc, argv, myUseGuiFlag );
+ if ( !configpath.isEmpty() )
+ // tell QSettings to use INI format and save the file in custom config path
+ QgsApplication myApp( argc, argv, myUseGuiFlag, configpath );
// (if Windows/Mac, use icon from resource)
#if ! defined(Q_WS_WIN) && ! defined(Q_WS_MAC)
myApp.setWindowIcon( QPixmap( qgis_xpm ) ); // Linux
Modified: trunk/qgis/src/core/qgsapplication.cpp
--- trunk/qgis/src/core/qgsapplication.cpp 2010-07-21 10:10:43 UTC (rev 13950)
+++ trunk/qgis/src/core/qgsapplication.cpp 2010-07-21 13:12:47 UTC (rev 13951)
@@ -39,6 +39,7 @@
QString QgsApplication::mPkgDataPath;
QString QgsApplication::mThemeName;
QStringList QgsApplication::mDefaultSvgPaths;
+QString QgsApplication::mConfigPath = QDir::homePath() + QString( "/.qgis/" );
\class QgsApplication
@@ -53,7 +54,7 @@
so that platform-conditional code is minimized and paths are easier
to change due to centralization.
-QgsApplication::QgsApplication( int & argc, char ** argv, bool GUIenabled )
+QgsApplication::QgsApplication( int & argc, char ** argv, bool GUIenabled, QString customConfigPath )
: QApplication( argc, argv, GUIenabled )
#if defined(Q_WS_MACX) || defined(Q_WS_WIN32) || defined(WIN32)
@@ -65,6 +66,11 @@
setPrefixPath( myPrefix, true );
#endif
+ if ( !customConfigPath.isEmpty() )
+ mConfigPath = customConfigPath + "/"; // make sure trailing slash is included
mDefaultSvgPaths << mPkgDataPath + QString( "/svg/" );
mDefaultSvgPaths << qgisSettingsDirPath() + QString( "svg/" );
@@ -284,7 +290,7 @@
const QString QgsApplication::qgisSettingsDirPath()
- return QDir::homePath() + QString( "/.qgis/" );
+ return mConfigPath;
Modified: trunk/qgis/src/core/qgsapplication.h
--- trunk/qgis/src/core/qgsapplication.h 2010-07-21 10:10:43 UTC (rev 13950)
+++ trunk/qgis/src/core/qgsapplication.h 2010-07-21 13:12:47 UTC (rev 13951)
@@ -26,7 +26,8 @@
Q_OBJECT
public:
- QgsApplication( int & argc, char ** argv, bool GUIenabled );
+ //! @note customConfigDir parameter added in v1.6
+ QgsApplication( int & argc, char ** argv, bool GUIenabled, QString customConfigPath = QString() );
virtual ~QgsApplication();
//! Catch exceptions when sending event to receiver.
@@ -197,6 +198,8 @@
static QString mPkgDataPath;
static QString mThemeName;
static QStringList mDefaultSvgPaths;
+ static QString mConfigPath;
#endif
