[QGIS Commit] r13962 - trunk/qgis/src/plugins/georeferencer
svn_qgis at osgeo.org
Sun Jul 25 11:20:16 EDT 2010
Author: mmassing
Date: 2010-07-25 15:20:16 +0000 (Sun, 25 Jul 2010)
New Revision: 13962
trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.h
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp
trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h
Patch by Luiz Motta: adds the ability to move GCPs in the qgis canvas (partial commit of #2890). Thanks.
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.cpp 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.cpp 2010-07-25 15:20:16 UTC (rev 13962)
@@ -122,15 +122,33 @@
-bool QgsGeorefDataPoint::contains( const QPoint &p )
+bool QgsGeorefDataPoint::contains( const QPoint &p, bool isMapPlugin )
- QPointF pnt = mGCPSourceItem->mapFromScene( p );
- return mGCPSourceItem->shape().contains( pnt );
+ if ( isMapPlugin )
+ QPointF pnt = mGCPSourceItem->mapFromScene( p );
+ return mGCPSourceItem->shape().contains( pnt );
+ else
+ QPointF pnt = mGCPDestinationItem->mapFromScene( p );
+ return mGCPDestinationItem->shape().contains( pnt );
-void QgsGeorefDataPoint::moveTo( const QPoint &p )
+void QgsGeorefDataPoint::moveTo( const QPoint &p, bool isMapPlugin )
- QgsPoint pnt = mGCPSourceItem->toMapCoordinates( p );
- setPixelCoords( pnt );
+ QgsPoint pnt = mGCPSourceItem->toMapCoordinates( p );
+ mPixelCoords = pnt;
+ else
+ QgsPoint pnt = mGCPDestinationItem->toMapCoordinates( p );
+ mMapCoords = pnt;
+ mGCPSourceItem->update();
+ mGCPDestinationItem->update();
updateCoords();
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.h 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefdatapoint.h 2010-07-25 15:20:16 UTC (rev 13962)
@@ -46,7 +46,7 @@
int id() const { return mId; }
void setId( int id );
- bool contains( const QPoint &p );
+ bool contains( const QPoint &p, bool isMapPlugin );
QgsMapCanvas *srcCanvas() const { return mSrcCanvas; }
QgsMapCanvas *dstCanvas() const { return mDstCanvas; }
@@ -55,7 +55,7 @@
void setResidual( const QPointF& r );
public slots:
- void moveTo( const QPoint & );
+ void moveTo( const QPoint &, bool isMapPlugin );
void updateCoords();
private:
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.cpp 2010-07-25 15:20:16 UTC (rev 13962)
@@ -86,6 +86,7 @@
, mLayer( 0 )
, mAgainAddRaster ( false )
, mMovingPoint( 0 )
+ , mMovingPointQgis ( 0 )
, mMapCoordsDialog( 0 )
, mUseZeroForTrans( false )
, mLoadInQgis( false )
@@ -153,6 +154,7 @@
delete mToolAddPoint;
delete mToolDeletePoint;
delete mToolMovePoint;
+ delete mToolMovePointQgis;
@@ -382,6 +384,7 @@
void QgsGeorefPluginGui::setMovePointTool()
mCanvas->setMapTool( mToolMovePoint );
+ mIface->mapCanvas()->setMapTool( mToolMovePointQgis );
// View slots
@@ -478,7 +481,7 @@
for ( QgsGCPList::iterator it = mPoints.begin(); it != mPoints.end(); ++it )
QgsGeorefDataPoint* pt = *it;
- if ( /*pt->pixelCoords() == coords ||*/ pt->contains( coords ) ) // first operand for removing from GCP table
+ if ( /*pt->pixelCoords() == coords ||*/ pt->contains( coords, true ) ) // first operand for removing from GCP table
int row = mPoints.indexOf( *it );
mGCPListWidget->model()->removeRow( row );
@@ -507,28 +510,54 @@
void QgsGeorefPluginGui::selectPoint( const QPoint &p )
+ // Get Map Sender
+ QObject *tool = sender();
+ if ( tool == 0)
+ return;
+ bool isMapPlugin = ( (void *)tool == (void *)mToolMovePoint ) ? true : false;
- if (( *it )->contains( p ) )
+ if ( ( *it )->contains( p, isMapPlugin ) )
- mMovingPoint = *it;
+ isMapPlugin ? mMovingPoint = *it : mMovingPointQgis = *it;
break;
void QgsGeorefPluginGui::movePoint( const QPoint &p )
- if ( mMovingPoint )
+ // Get Map Sender
+ if ( tool == 0)
- mMovingPoint->moveTo( p );
+ return;
+ QgsGeorefDataPoint *mvPoint = (isMapPlugin ? mMovingPoint : mMovingPointQgis);
+ if ( mvPoint )
+ mvPoint->moveTo( p, isMapPlugin );
mGCPListWidget->updateGCPList();
void QgsGeorefPluginGui::releasePoint( const QPoint &p )
- mMovingPoint = 0;
+ // Get Map Sender
+ if ( tool == 0)
+ return;
+ isMapPlugin ? mMovingPoint = 0 : mMovingPointQgis = 0;
void QgsGeorefPluginGui::showCoordDialog( const QgsPoint &pixelCoords )
@@ -894,6 +923,16 @@
connect( mToolMovePoint, SIGNAL( pointReleased( const QPoint & ) ),
this, SLOT( releasePoint( const QPoint & ) ) );
+ // Point in Qgis Map
+ mToolMovePointQgis = new QgsGeorefToolMovePoint( mIface->mapCanvas() );
+ mToolMovePointQgis->setAction( mActionMoveGCPPoint );
+ connect( mToolMovePointQgis, SIGNAL( pointPressed( const QPoint & ) ),
+ this, SLOT( selectPoint( const QPoint & ) ) );
+ connect( mToolMovePointQgis, SIGNAL( pointMoved( const QPoint & ) ),
+ this, SLOT( movePoint( const QPoint & ) ) );
+ connect( mToolMovePointQgis, SIGNAL( pointReleased( const QPoint & ) ),
+ this, SLOT( releasePoint( const QPoint & ) ) );
QSettings s;
int action = s.value( "/qgis/wheel_action", 0 ).toInt();
double zoomFactor = s.value( "/qgis/zoom_factor", 2 ).toDouble();
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeorefplugingui.h 2010-07-25 15:20:16 UTC (rev 13962)
@@ -222,8 +222,10 @@
QgsMapTool *mToolAddPoint;
QgsMapTool *mToolDeletePoint;
QgsMapTool *mToolMovePoint;
+ QgsMapTool *mToolMovePointQgis;
QgsGeorefDataPoint *mMovingPoint;
+ QgsGeorefDataPoint *mMovingPointQgis;
QPointer<QgsMapCoordsDialog> mMapCoordsDialog;
bool mUseZeroForTrans;
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.cpp 2010-07-25 15:20:16 UTC (rev 13962)
@@ -12,7 +12,7 @@
* (at your option) any later version. *
-/* $Id$ */
+/* $Id: qgsgeoreftoolmovepoint.cpp 13187 2010-03-28 22:14:44Z jef $ */
#include "qgsmapcanvas.h"
@@ -33,6 +33,11 @@
+bool QgsGeorefToolMovePoint::isCanvas(QgsMapCanvas *canvas)
+ return (mCanvas == canvas);
void QgsGeorefToolMovePoint::canvasMoveEvent( QMouseEvent *e )
emit pointMoved( e->pos() );
Modified: trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h
--- trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h 2010-07-25 15:20:10 UTC (rev 13961)
+++ trunk/qgis/src/plugins/georeferencer/qgsgeoreftoolmovepoint.h 2010-07-25 15:20:16 UTC (rev 13962)
@@ -12,7 +12,7 @@
-/* $Id$ */
+/* $Id: qgsgeoreftoolmovepoint.h 13187 2010-03-28 22:14:44Z jef $ */
#ifndef QGSGEOREFTOOLMOVEPOINT_H
#define QGSGEOREFTOOLMOVEPOINT_H
@@ -34,6 +34,8 @@
void canvasMoveEvent( QMouseEvent *e );
void canvasReleaseEvent( QMouseEvent *e );
+ bool isCanvas(QgsMapCanvas *);
signals:
void pointPressed( const QPoint &p );
void pointMoved( const QPoint &p );
