[QGIS Commit] r13972 - in trunk/qgis: i18n
src/plugins/grass/modules-common
svn_qgis at osgeo.org
Tue Jul 27 08:41:20 EDT 2010
Author: pcav
Date: 2010-07-27 12:41:20 +0000 (Tue, 27 Jul 2010)
New Revision: 13972
trunk/qgis/i18n/qgis_it.ts
trunk/qgis/src/plugins/grass/modules-common/v.univar.qgm
Fixed v.univar GRASS module
Modified: trunk/qgis/i18n/qgis_it.ts
--- trunk/qgis/i18n/qgis_it.ts 2010-07-27 11:13:55 UTC (rev 13971)
+++ trunk/qgis/i18n/qgis_it.ts 2010-07-27 12:41:20 UTC (rev 13972)
@@ -660,7 +660,7 @@
<message>
<location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="26"/>
<source>Area</source>
- <translation type="unfinished">Area</translation>
+ <translation>Area</translation>
</message>
<message>
<location filename="../python/plugins/fTools/tools/frmRegPoints.ui" line="45"/>
Modified: trunk/qgis/src/plugins/grass/modules-common/v.univar.qgm
--- trunk/qgis/src/plugins/grass/modules-common/v.univar.qgm 2010-07-27 11:13:55 UTC (rev 13971)
+++ trunk/qgis/src/plugins/grass/modules-common/v.univar.qgm 2010-07-27 12:41:20 UTC (rev 13972)
@@ -3,5 +3,5 @@
<qgisgrassmodule label="Calculate univariate statistics of vector map features" module="v.univar">
<option key="map" typeoption="type"/>
- <field key="column" layer="input" type="integer,double" label="Attribute field" />
+ <field key="column" layer="map" type="integer,double" label="Attribute field" />
</qgisgrassmodule>
