[QGIS Commit] r13982 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org
Thu Jul 29 05:46:19 EDT 2010
Author: dassau
Date: 2010-07-29 09:46:19 +0000 (Thu, 29 Jul 2010)
New Revision: 13982
Removed:
docs/trunk/english_us/user_guide/plugins_labeling.tex
removed labeling plugin is now part of vector section
Deleted: docs/trunk/english_us/user_guide/plugins_labeling.tex
--- docs/trunk/english_us/user_guide/plugins_labeling.tex 2010-07-29 09:41:03 UTC (rev 13981)
+++ docs/trunk/english_us/user_guide/plugins_labeling.tex 2010-07-29 09:46:19 UTC (rev 13982)
@@ -1,77 +0,0 @@
-% !TeX root = user_guide.tex
-\section{New Labeling}
-% when the revision of a section has been finalized,
-% comment out the following line:
-%\updatedisclaimer
-The new \toolbtntwo{labeling}{Labeling} core application provides smart labeling
-for vector point, line and polygon layers and only requires a few parameters.
-This new application will replace the current QGIS labeling and also supports
-on-the-fly transformated layers.
-\begin{enumerate}
- \item Start QGIS and load a vector point, line or polygon layer.
- \item Activate the layer in the legend and click on the
- \toolbtntwo{labeling}{Labeling} icon in the QGIS toolbar menu.
-\end{enumerate}
-\minisec{Labeling point layers}
-First step is to activate the \checkbox{Label this layer} checkbox and select an attribute
-column to use for labeling. After that you can define the label placement and text style,
-labeling priority, scale-based visibility, if every part of multipart feature is to be
-labeled and if features act as obstacles for labels or not (see Figure \ref{fig:pointlabel}).
-\begin{figure}[ht]
-\centering
- \includegraphics[clip=true, width=12cm]{label_points}
- \caption{Smart labeling of vector point layers \nixcaption}\label{fig:pointlabel}
-\end{figure}
-\minisec{Labeling line layers}
-column to use for labeling. After that you can define the label placement, orientation,
-distance to feature, text style, labeling priority, scale-based visibility, if every part
-of a multipart line is to be labeled, if lines shall be merged to avoid duplicate labels
-and if features act as obstacles for labels or not (see Figure \ref{fig:linelabel}).
-\begin{figure}[ht]
-\centering
- \includegraphics[clip=true, width=12cm]{label_line}
- \caption{Smart labeling of vector line layers \nixcaption}\label{fig:linelabel}
-\end{figure}
-\minisec{Labeling polygon layers}
-column to use for labeling. After that you can define the label placement, distance and text
-style, labeling priority, scale-based visibility, if every part of multipart feature is to be
-labeled and if features act as obstacles for labels or not (see Figure \ref{fig:arealabel}).
-\begin{figure}[ht]
-\centering
- \includegraphics[clip=true, width=12cm]{label_area}
- \caption{Smart labeling of vector polygon layers \nixcaption}\label{fig:arealabel}
-\end{figure}
-\minisec{Change engine settings}
-Additionally you can click the \button{Engine settings} button and select the search method,
-used to find the best label placement. Available is Chain, Popmusic Tabu, Popmusic Chain,
-Popmusic Tabu Chain and FALP.
-\begin{figure}[ht]
-\centering
- \includegraphics[clip=true, width=7cm]{label_engine}
- \caption{Dialog to change label engine settings \nixcaption}\label{fig:labelengine}
-\end{figure}
-Furthermore the number of candidates can be defined for point, line and polygon features,
-and you can define whether to show all labels (including colliding labels) and label
-candidates for debugging.
-\FloatBarrier
