[QGIS Commit] r13627 - trunk/qgis/src/python
svn_qgis at osgeo.org
Wed Jun 2 09:38:38 EDT 2010
Author: jef
Date: 2010-06-02 09:38:36 -0400 (Wed, 02 Jun 2010)
New Revision: 13627
trunk/qgis/src/python/qgspythonutilsimpl.cpp
fix python runtime error when no HOME is set
Modified: trunk/qgis/src/python/qgspythonutilsimpl.cpp
--- trunk/qgis/src/python/qgspythonutilsimpl.cpp 2010-06-02 10:52:41 UTC (rev 13626)
+++ trunk/qgis/src/python/qgspythonutilsimpl.cpp 2010-06-02 13:38:36 UTC (rev 13627)
@@ -62,12 +62,13 @@
// expect that bindings are installed locally, so add the path to modules
// also add path to plugins
#ifdef Q_OS_WIN
+ runString( "oldhome=None\n" );
runString( "if os.environ.has_key('HOME'): oldhome=os.environ['HOME']\n" );
runString( "os.environ['HOME']=os.environ['USERPROFILE']" );
#endif
runString( "sys.path = [\"" + pythonPath() + "\", os.path.expanduser(\"~/.qgis/python\"), os.path.expanduser(\"~/.qgis/python/plugins\"), \"" + pluginsPath() + "\" ] + sys.path" );
#ifdef Q_OS_WIN
- runString( "if os.environ.has_key('HOME'): os.environ['HOME']=oldhome\n" );
+ runString( "if oldhome: os.environ['HOME']=oldhome\n" );
#endif
// import SIP
