[QGIS Commit] r13657 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Jun 4 23:01:36 EDT 2010
Author: jef
Date: 2010-06-04 23:01:36 -0400 (Fri, 04 Jun 2010)
New Revision: 13657
   trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2010-06-05 02:58:58 UTC (rev 13656)
+++ trunk/qgis/i18n/qgis_de.ts	2010-06-05 03:01:36 UTC (rev 13657)
@@ -12229,10 +12229,6 @@
         <source>Use map units if possible</source>
         <translation>möglichst Karteneinheiten</translation>
     </message>
-    <message>
-        <source>Map units</source>
-        <translation type="obsolete">Karteneinheiten</translation>
-    </message>
 </context>
 <context>
     <name>QgsGeorefDescriptionDialogBase</name>
@@ -28191,12 +28187,11 @@
 <context>
     <name>dxf2shpConverterGui</name>
     <message>
-        <location filename="../src/plugins/dxf2shp_converter/dxf2shpconvertergui.cpp" line="121"/>
         <source>Fields description:
 * Input DXF file: path to the DXF file to be converted
 * Output Shp file: desired name of the shape file to be created
 * Shp output file type: specifies the type of the output shape file
-* Export text labels checkbox: if checked, an additional shp points layer will be created,   and the associated dbf table will contain informations about the &quot;TEXT&quot; fields found in the dxf file, and the text strings themselves
+* Export text labels checkbox: if checked, an additional shp points layer will be created,   and the associated dbf table will contain information about the &quot;TEXT&quot; fields found in the dxf file, and the text strings themselves
 Developed by Paolo L. Scala, Barbara Rita Barricelli, Marco Padula
More information about the QGIS-commit mailing list
