[QGIS Commit] r13675 - in branches/threading-branch/src: app core
core/composer providers/wms
svn_qgis at osgeo.org
Mon Jun 7 06:43:20 EDT 2010
Author: wonder
Date: 2010-06-07 06:43:18 -0400 (Mon, 07 Jun 2010)
New Revision: 13675
branches/threading-branch/src/app/qgisapp.cpp
branches/threading-branch/src/core/composer/qgscomposermap.cpp
branches/threading-branch/src/core/qgsmaprenderer.cpp
branches/threading-branch/src/core/qgsmaprenderer.h
branches/threading-branch/src/providers/wms/qgswmsprovider.cpp
More housekeeping: determine whether to use render caching from renderer properties, not from global QSettings
Modified: branches/threading-branch/src/app/qgisapp.cpp
--- branches/threading-branch/src/app/qgisapp.cpp 2010-06-07 08:39:17 UTC (rev 13674)
+++ branches/threading-branch/src/app/qgisapp.cpp 2010-06-07 10:43:18 UTC (rev 13675)
@@ -2102,6 +2102,7 @@
QSettings mySettings;
mMapCanvas->enableAntiAliasing( mySettings.value( "/qgis/enable_anti_aliasing", false ).toBool() );
mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render", false ).toBool() );
+ mMapCanvas->mapRenderer()->setCachingEnabled( mySettings.value( "/qgis/enable_render_caching", false ).toBool() );
int action = mySettings.value( "/qgis/wheel_action", 0 ).toInt();
double zoomFactor = mySettings.value( "/qgis/zoom_factor", 2 ).toDouble();
@@ -5083,6 +5084,7 @@
mMapCanvas->enableAntiAliasing( mySettings.value( "/qgis/enable_anti_aliasing" ).toBool() );
mMapCanvas->useImageToRender( mySettings.value( "/qgis/use_qimage_to_render" ).toBool() );
Modified: branches/threading-branch/src/core/composer/qgscomposermap.cpp
--- branches/threading-branch/src/core/composer/qgscomposermap.cpp 2010-06-07 08:39:17 UTC (rev 13674)
+++ branches/threading-branch/src/core/composer/qgscomposermap.cpp 2010-06-07 10:43:18 UTC (rev 13675)
@@ -149,13 +149,7 @@
double bk_scale = theMapRenderer.scale();
theMapRenderer.setScale( scale() );
- //layer caching (as QImages) cannot be done for composer prints
- QSettings s;
- bool bkLayerCaching = s.value( "/qgis/enable_render_caching", false ).toBool();
- s.setValue( "/qgis/enable_render_caching", false );
theMapRenderer.render( painter );
- s.setValue( "/qgis/enable_render_caching", bkLayerCaching );
theMapRenderer.setScale( bk_scale );
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-07 08:39:17 UTC (rev 13674)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-07 10:43:18 UTC (rev 13675)
@@ -48,6 +48,8 @@
mDrawing = false;
mOverview = false;
+ mThreadingEnabled = false;
+ mCachingEnabled = false;
// set default map units - we use WGS 84 thus use degrees
setMapUnits( QGis::Degrees );
@@ -285,8 +287,7 @@
if ( !mySameAsLastFlag )
//clear the cache pixmap if we changed resolution / extent
- QSettings mySettings;
- if ( mySettings.value( "/qgis/enable_render_caching", false ).toBool() )
+ if ( mCachingEnabled )
QgsMapLayerRegistry::instance()->clearAllLayerCaches();
@@ -436,35 +437,31 @@
- if ( ! split )//render caching does not yet cater for split extents
+ if ( !mySameAsLastFlag || ml->cacheImage() == 0 )
- if ( !mySameAsLastFlag || ml->cacheImage() == 0 )
+ QgsDebugMsg( "\n\n\nCaching enabled but layer redraw forced by extent change or empty cache\n\n\n" );
+ QImage * mypImage = new QImage( mRenderContext.painter()->device()->width(),
+ mRenderContext.painter()->device()->height(), QImage::Format_ARGB32 );
+ mypImage->fill( 0 );
+ ml->setCacheImage( mypImage ); //no need to delete the old one, maplayer does it for you
+ QPainter * mypPainter = new QPainter( ml->cacheImage() );
+ if ( mypContextPainter->testRenderHint( QPainter::Antialiasing ) )
- QgsDebugMsg( "\n\n\nCaching enabled but layer redraw forced by extent change or empty cache\n\n\n" );
- QImage * mypImage = new QImage( mRenderContext.painter()->device()->width(),
- mRenderContext.painter()->device()->height(), QImage::Format_ARGB32 );
- mypImage->fill( 0 );
- ml->setCacheImage( mypImage ); //no need to delete the old one, maplayer does it for you
- QPainter * mypPainter = new QPainter( ml->cacheImage() );
- if ( mySettings.value( "/qgis/enable_anti_aliasing", false ).toBool() )
- mypPainter->setRenderHint( QPainter::Antialiasing );
- mRenderContext.setPainter( mypPainter );
+ mypPainter->setRenderHint( QPainter::Antialiasing );
- else if ( mySameAsLastFlag )
- //draw from cached image
- QgsDebugMsg( "\n\n\nCaching enabled --- drawing layer from cached image\n\n\n" );
- mypContextPainter->drawImage( 0, 0, *( ml->cacheImage() ) );
- disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
- //short circuit as there is nothing else to do...
- return;
+ mRenderContext.setPainter( mypPainter );
+ else if ( mySameAsLastFlag )
+ //draw from cached image
+ QgsDebugMsg( "\n\n\nCaching enabled --- drawing layer from cached image\n\n\n" );
+ mypContextPainter->drawImage( 0, 0, *( ml->cacheImage() ) );
+ disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
+ //short circuit as there is nothing else to do...
+ return;
if ( scaleRaster )
@@ -495,6 +492,7 @@
emit drawError( ml );
+ mRenderContext.setExtent( mExtent ); // return back to the original extent
if ( scaleRaster )
@@ -503,17 +501,14 @@
mRenderContext.painter()->restore();
- if ( !split )
- // composite the cached image into our view and then clean up from caching
- // by reinstating the painter as it was swapped out for caching renders
- delete mRenderContext.painter();
- mRenderContext.setPainter( mypContextPainter );
- //draw from cached image that we created further up
+ // composite the cached image into our view and then clean up from caching
+ // by reinstating the painter as it was swapped out for caching renders
+ delete mRenderContext.painter();
+ mRenderContext.setPainter( mypContextPainter );
+ //draw from cached image that we created further up
@@ -1047,3 +1042,4 @@
mLabelingEngine = iface;
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-07 08:39:17 UTC (rev 13674)
+++ branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-07 10:43:18 UTC (rev 13675)
@@ -64,7 +64,6 @@
/** \ingroup core
* A non GUI class for rendering a map layer set onto a QPainter.
@@ -187,12 +186,20 @@
//! Enable or disable rendering in multiple threads on multiprocessor computers
//! Added in QGIS v1.6
- void setUsingThreadedRendering( bool use ) { mUsingThreadedRendering = use; }
+ void setThreadingEnabled( bool use ) { mThreadingEnabled = use; }
//! Determine whether we are using threaded rendering
- bool isUsingThreadedRendering() const { return mUsingThreadedRendering; }
+ bool isThreadingEnabled() const { return mThreadingEnabled; }
+ //! Enable or disable caching of rendered layers
+ //! Added in QGIS v1.6
+ void setCachingEnabled( bool enabled ) { mCachingEnabled = enabled; }
+ //! Determine whether the rendered layers are cached
+ bool isCachingEnabled() const { return mCachingEnabled; }
signals:
void drawingProgress( int current, int total );
@@ -290,7 +297,10 @@
QgsLabelingEngineInterface* mLabelingEngine;
//! Multithreaded rendering
- bool mUsingThreadedRendering;
+ bool mThreadingEnabled;
+ //! Render caching
+ bool mCachingEnabled;
#endif
Modified: branches/threading-branch/src/providers/wms/qgswmsprovider.cpp
--- branches/threading-branch/src/providers/wms/qgswmsprovider.cpp 2010-06-07 08:39:17 UTC (rev 13674)
+++ branches/threading-branch/src/providers/wms/qgswmsprovider.cpp 2010-06-07 10:43:18 UTC (rev 13675)
@@ -422,7 +422,7 @@
cachedViewHeight = pixelHeight;
QSettings s;
+ bool bkLayerCaching = s.value( "/qgis/enable_render_caching", false ).toBool(); // TODO: move this into render context
if ( !mTiled )
