[QGIS Commit] r13677 - branches/threading-branch/src/core
svn_qgis at osgeo.org svn_qgis at osgeo.org
Mon Jun 7 08:53:19 EDT 2010
Author: wonder
Date: 2010-06-07 08:53:18 -0400 (Mon, 07 Jun 2010)
New Revision: 13677
   branches/threading-branch/src/core/qgsmaprenderer.cpp
   branches/threading-branch/src/core/qgsmaprenderer.h
More housekeeping in QgsMapRenderer
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp	2010-06-07 11:18:24 UTC (rev 13676)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp	2010-06-07 12:53:18 UTC (rev 13677)
@@ -213,6 +213,8 @@
   QgsDebugMsg( "========== Rendering ==========" );
+  QgsDebugMsg( "caching enabled? " + QString::number(mCachingEnabled) );
   if ( mExtent.isEmpty() )
     QgsDebugMsg( "empty extent... not rendering" );
@@ -295,20 +297,9 @@
   QgsOverlayObjectPositionManager* overlayManager = overlayManagerFromSettings();
-  // render all layers in the stack, starting at the base
-  QListIterator<QString> li( mLayerSet );
-  li.toBack();
-  while ( li.hasPrevious() )
-    if ( mRenderContext.renderingStopped() )
-      break;
+  // do the rendering of all layers
+  renderLayers( overlayManager );
-    QString layerId = li.previous();
-    renderLayer( layerId, mySameAsLastFlag, overlayManager );
   QgsDebugMsg( "Done rendering map layers" );
   // render labels for vector layers (not using PAL)
@@ -344,106 +335,99 @@
-void QgsMapRenderer::renderLayer( QString layerId, bool mySameAsLastFlag, QgsOverlayObjectPositionManager* overlayManager )
+void QgsMapRenderer::renderLayers( QgsOverlayObjectPositionManager* overlayManager )
+  // render all layers in the stack, starting at the base
+  QListIterator<QString> li( mLayerSet );
+  li.toBack();
+  while ( li.hasPrevious() )
+    if ( mRenderContext.renderingStopped() )
+      break;
-  // Store the painter in case we need to swap it out for the
-  // cache painter
-  QPainter * mypContextPainter = mRenderContext.painter();
+    QString layerId = li.previous();
-  QgsDebugMsg( "Rendering at layer item " + layerId );
+    QgsDebugMsg( "Rendering at layer item " + layerId );
-  //emit drawingProgress(myRenderCounter++, mLayerSet.size());
-  QgsMapLayer *ml = QgsMapLayerRegistry::instance()->mapLayer( layerId );
+    //emit drawingProgress(myRenderCounter++, mLayerSet.size());
+    QgsMapLayer *ml = QgsMapLayerRegistry::instance()->mapLayer( layerId );
-  if ( !ml )
-    QgsDebugMsg( "Layer not found in registry!" );
-    return;
+    if ( !ml )
+      QgsDebugMsg( "Layer not found in registry!" );
+      return;
-  QgsDebugMsg( "Rendering layer " + ml->name() );
-  QgsDebugMsg( "  Layer minscale " + QString( "%1" ).arg( ml->minimumScale() ) );
-  QgsDebugMsg( "  Layer maxscale " + QString( "%1" ).arg( ml->maximumScale() ) );
-  QgsDebugMsg( "  Scale dep. visibility enabled? " + QString( "%1" ).arg( ml->hasScaleBasedVisibility() ) );
-  QgsDebugMsg( "  Input extent: " + ml->extent().toString() );
+    //QgsDebugMsg( "  Layer minscale " + QString( "%1" ).arg( ml->minimumScale() ) );
+    //QgsDebugMsg( "  Layer maxscale " + QString( "%1" ).arg( ml->maximumScale() ) );
+    //QgsDebugMsg( "  Scale dep. visibility enabled? " + QString( "%1" ).arg( ml->hasScaleBasedVisibility() ) );
+    //QgsDebugMsg( "  Input extent: " + ml->extent().toString() );
-  if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > mScale || ml->maximumScale() < mScale ) && ! mOverview )
-    QgsDebugMsg( "Layer not rendered because it is not within the defined "
-                 "visibility scale range" );
-    return;
+    if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > mScale || ml->maximumScale() < mScale ) && ! mOverview )
+      QgsDebugMsg( "Layer not rendered because it is not within the defined "
+                   "visibility scale range" );
+      return;
-  connect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
+    QgsCoordinateTransform* ct = NULL;
+    if ( hasCrsTransformEnabled() )
+      ct = new QgsCoordinateTransform( ml->srs(), *mDestCRS );
+    mRenderContext.setCoordinateTransform( ct );
-  // Now do the call to the layer that actually does
-  // the rendering work!
+    //create overlay objects for features within the view extent
+    if ( ml->type() == QgsMapLayer::VectorLayer && overlayManager )
+      QgsVectorLayer* vl = qobject_cast<QgsVectorLayer *>( ml );
+      if ( vl )
+        overlayManager->addOverlaysForLayer( vl, mRenderContext );
-  bool split = false;
-  QgsRectangle r1, r2;
-  QgsCoordinateTransform* ct;
+    // Force render of layers that are being edited
+    // or if there's a labeling engine that needs the layer to register features
+    if ( ml->type() == QgsMapLayer::VectorLayer )
+      if ( vl->isEditable() ||
+           ( mRenderContext.labelingEngine() && mRenderContext.labelingEngine()->willUseLayer( vl ) ) )
+        ml->setCacheImage( 0 );
-  if ( hasCrsTransformEnabled() )
-    r1 = mExtent;
-    split = splitLayersExtent( ml, r1, r2 );
-    ct = new QgsCoordinateTransform( ml->srs(), *mDestCRS );
-    mRenderContext.setExtent( r1 );
-  else
-    ct = NULL;
+    // Now do the call to the layer that actually does
+    // the rendering work!
+    connect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
-  mRenderContext.setCoordinateTransform( ct );
+    renderLayer( ml );
-  //decide if we have to scale the raster
-  //this is necessary in case QGraphicsScene is used
-  bool scaleRaster = false;
-  double rasterScaleFactor = mRenderContext.rasterScaleFactor();
-  QgsMapToPixel rasterMapToPixel;
-  QgsMapToPixel bk_mapToPixel;
-  if ( ml->type() == QgsMapLayer::RasterLayer && fabs( rasterScaleFactor - 1.0 ) > 0.000001 )
-    scaleRaster = true;
+    disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
-  //create overlay objects for features within the view extent
-  if ( ml->type() == QgsMapLayer::VectorLayer && overlayManager )
-    QgsVectorLayer* vl = qobject_cast<QgsVectorLayer *>( ml );
-    if ( vl )
-      overlayManager->addOverlaysForLayer( vl, mRenderContext );
-  // Force render of layers that are being edited
-  // or if there's a labeling engine that needs the layer to register features
-  if ( ml->type() == QgsMapLayer::VectorLayer )
-    if ( vl->isEditable() ||
-         ( mRenderContext.labelingEngine() && mRenderContext.labelingEngine()->willUseLayer( vl ) ) )
-      ml->setCacheImage( 0 );
+void QgsMapRenderer::renderLayer( QgsMapLayer* ml )
+  // Store the painter in case we need to swap it out for the
+  // cache painter
+  QPainter * mypContextPainter = mRenderContext.painter();
   if ( mCachingEnabled )
-    if ( !mySameAsLastFlag || ml->cacheImage() == 0 )
+    if ( ml->cacheImage() == 0 )
-      QgsDebugMsg( "\n\n\nCaching enabled but layer redraw forced by extent change or empty cache\n\n\n" );
-      QImage * mypImage = new QImage( mRenderContext.painter()->device()->width(),
-                                      mRenderContext.painter()->device()->height(), QImage::Format_ARGB32 );
+      QgsDebugMsg( "\n\n\nCaching enabled --- redraw forced by extent change or empty cache\n\n\n" );
+      QPaintDevice* device = mRenderContext.painter()->device();
+      QImage * mypImage = new QImage( device->width(), device->height(), QImage::Format_ARGB32_Premultiplied );
       mypImage->fill( 0 );
       ml->setCacheImage( mypImage ); //no need to delete the old one, maplayer does it for you
       QPainter * mypPainter = new QPainter( ml->cacheImage() );
@@ -453,17 +437,28 @@
       mRenderContext.setPainter( mypPainter );
-    else if ( mySameAsLastFlag )
+    else
       //draw from cached image
       QgsDebugMsg( "\n\n\nCaching enabled --- drawing layer from cached image\n\n\n" );
       mypContextPainter->drawImage( 0, 0, *( ml->cacheImage() ) );
-      disconnect( ml, SIGNAL( drawingProgress( int, int ) ), this, SLOT( onDrawingProgress( int, int ) ) );
       //short circuit as there is nothing else to do...
       return;
+  //decide if we have to scale the raster
+  //this is necessary in case QGraphicsScene is used
+  bool scaleRaster = false;
+  double rasterScaleFactor = mRenderContext.rasterScaleFactor();
+  QgsMapToPixel rasterMapToPixel;
+  QgsMapToPixel bk_mapToPixel;
+  if ( ml->type() == QgsMapLayer::RasterLayer && fabs( rasterScaleFactor - 1.0 ) > 0.000001 )
+    scaleRaster = true;
   if ( scaleRaster )
     bk_mapToPixel = mRenderContext.mapToPixel();
@@ -475,15 +470,21 @@
     mRenderContext.painter()->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
+  // split the rendering into two parts if necessary
+  bool split = false;
+  QgsRectangle r1, r2;
+    r1 = mExtent;
+    split = splitLayersExtent( ml, r1, r2 );
+    mRenderContext.setExtent( r1 );
+  // draw the layer
   if ( !ml->draw( mRenderContext ) )
     emit drawError( ml );
-  else
-    QgsDebugMsg( "Layer rendered without issues" );
   if ( split )
@@ -510,7 +511,6 @@
     //draw from cached image that we created further up
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h	2010-06-07 11:18:24 UTC (rev 13676)
+++ branches/threading-branch/src/core/qgsmaprenderer.h	2010-06-07 12:53:18 UTC (rev 13677)
@@ -233,8 +233,11 @@
     bool splitLayersExtent( QgsMapLayer* layer, QgsRectangle& extent, QgsRectangle& r2 );
+    //! render the whole layer set
+    void renderLayers( QgsOverlayObjectPositionManager* overlayManager );
     //! render one layer
-    void renderLayer( QString layerId, bool mySameAsLastFlag, QgsOverlayObjectPositionManager* overlayManager );
+    void renderLayer( QgsMapLayer* ml );
     //! render labels for vector layers (not using PAL)
     void renderLabels();
More information about the QGIS-commit mailing list
