[QGIS Commit] r13684 - in trunk/qgis/python/plugins/GdalTools: .
tools
svn_qgis at osgeo.org
Mon Jun 7 17:55:06 EDT 2010
Author: brushtyler
Date: 2010-06-07 17:55:03 -0400 (Mon, 07 Jun 2010)
New Revision: 13684
trunk/qgis/python/plugins/GdalTools/GdalTools.py
trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
import the modules without use the path
Modified: trunk/qgis/python/plugins/GdalTools/GdalTools.py
--- trunk/qgis/python/plugins/GdalTools/GdalTools.py 2010-06-07 19:59:53 UTC (rev 13683)
+++ trunk/qgis/python/plugins/GdalTools/GdalTools.py 2010-06-07 21:55:03 UTC (rev 13684)
@@ -29,20 +29,11 @@
req_mods = { "osgeo": "osgeo [python-gdal]" }
try:
- # Set up current path, so that we know where to look for modules
- import os.path, sys
- currentPath = os.path.dirname( __file__ )
- modulesPath = os.path.abspath( currentPath + '/tools' )
- sys.path.append( modulesPath )
+ from tools import GdalTools_utils as Utils
- import GdalTools_utils as Utils
- import doBuildVRT, doContour, doRasterize, doPolygonize, doMerge, doSieve, doProximity, doNearBlack
- import doWarp, doGrid, doTranslate, doClipper, doInfo, doProjection, doOverview, doRgbPct, doPctRgb
- import doSettings, doAbout
- sys.path.remove( modulesPath )
+ from tools import ( doBuildVRT, doContour, doRasterize, doPolygonize, doMerge, doSieve, doProximity, doNearBlack )
+ from tools import ( doWarp, doGrid, doTranslate, doClipper, doInfo, doProjection, doOverview, doRgbPct, doPctRgb )
+ from tools import ( doSettings, doAbout )
except ImportError, e:
error_str = str(e)
error_mod = error_str.replace( "No module named ", "" )
Modified: trunk/qgis/python/plugins/GdalTools/tools/doAbout.py
--- trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2010-06-07 19:59:53 UTC (rev 13683)
+++ trunk/qgis/python/plugins/GdalTools/tools/doAbout.py 2010-06-07 21:55:03 UTC (rev 13684)
@@ -6,19 +6,8 @@
from qgis.gui import *
from ui_dialogAbout import Ui_GdalToolsAboutDialog as Ui_Dialog
+from GdalTools import version
-# Set up current path, so that we know where to look for version
-import os.path, sys
-currentPath = os.path.dirname( __file__ )
-pluginPath = os.path.abspath( currentPath + "/.." )
-sys.path.append( pluginPath )
-# prepended the module name, to avoid conflicts with other __init__ modules in search path
-from GdalTools.__init__ import version
-sys.path.remove( pluginPath )
class GdalToolsAboutDialog(QDialog, Ui_Dialog):
def __init__(self, iface):
