[QGIS Commit] r13695 - trunk/qgis/i18n
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 8 16:11:32 EDT 2010
Author: jef
Date: 2010-06-08 16:11:32 -0400 (Tue, 08 Jun 2010)
New Revision: 13695
   trunk/qgis/i18n/qgis_de.ts
german translation update
Modified: trunk/qgis/i18n/qgis_de.ts
--- trunk/qgis/i18n/qgis_de.ts	2010-06-08 20:06:04 UTC (rev 13694)
+++ trunk/qgis/i18n/qgis_de.ts	2010-06-08 20:11:32 UTC (rev 13695)
@@ -4930,6 +4930,15 @@
         <source>SQLite DB (*.sqlite *.db);;All files (*)</source>
         <translation>SQLite DB (*.sqlite *.db);;Alle Dateien (*)</translation>
     </message>
+    <message>
+        <location filename="../src/app/main.cpp" line="472"/>
+        <source>QGIS starting in non-interactive mode not supported.
+You are seeing this message most likely because you have no DISPLAY environment variable set.
+</source>
+        <translation>QGIS im nicht interaktiven Modus zu starten wird nicht unterstützt.
+Diese Meldung erscheint höchstwahrscheinlich, weil die Umgebungsvariable DISPLAY nicht gesetzt ist.
+</translation>
+    </message>
 </context>
 <context>
     <name>QextSerialPort</name>
@@ -14212,17 +14221,17 @@
 <context>
     <name>QgsGrassModuleField</name>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2958"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2955"/>
         <source>Attribute field</source>
         <translation>Attributfeld</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2971"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2968"/>
         <source>Warning</source>
         <translation>Warnung</translation>
     </message>
     <message>
         <source>&apos;layer&apos; attribute in field tag with key= %1 is missing.</source>
         <translation>&apos;layer&apos;-Attribut im Feldtag mit key= %1 fehlt.</translation>
     </message>
@@ -14230,17 +14239,17 @@
 <context>
     <name>QgsGrassModuleFile</name>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3148"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3145"/>
         <source>File</source>
         <translation>Datei</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3277"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3274"/>
         <source>%1:&amp;nbsp;missing value</source>
         <translation>%1:&amp;nbsp;Fehlender Wert</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3284"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3281"/>
         <source>%1:&amp;nbsp;directory does not exist</source>
         <translation>%1&amp;nbsp;Verzeichnis existiert nicht</translation>
     </message>
@@ -14248,39 +14257,39 @@
 <context>
     <name>QgsGrassModuleGdalInput</name>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2714"/>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2729"/>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2910"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2712"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2727"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2907"/>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2911"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2908"/>
         <source>PostGIS driver in OGR does not support schemas!&lt;br&gt;Only the table name will be used.&lt;br&gt;It can result in wrong input if more tables of the same name&lt;br&gt;are present in the database.</source>
         <translation>Der PostGIS-Treiber in OGR unterstützt keine Schemata!&lt;br&gt;Nur der Tabellenname wird benutzt.&lt;br&gt;Die kann zu falschen Eingaben führen, wenn mehrere Tabellen gleichen Namens&lt;br&gt;in der Datenbank vorkommen.</translation>
     </message>
     <message>
         <source>Cannot find layeroption %1</source>
         <translation>Kann Layeroption %1 nicht finden</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2694"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2692"/>
         <source>OGR/PostGIS/GDAL Input</source>
         <translation>OGR/PostGIS/GDAL-Quelle</translation>
     </message>
     <message>
         <source>Cannot find whereoption %1</source>
         <translation>Kann Where-Option %1 nicht finden</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2775"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2773"/>
         <source>Select a layer</source>
         <translation>Einen Layer wählen</translation>
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2938"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2935"/>
         <source>%1:&amp;nbsp;no input</source>
         <translation>%1&amp;nbsp;keine Eingabe</translation>
     </message>
@@ -14326,7 +14335,7 @@
     </message>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2570"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="2568"/>
         <translation>%1:&amp;nbsp;keine Eingabe</translation>
     </message>
@@ -14347,7 +14356,7 @@
 <context>
     <name>QgsGrassModuleSelection</name>
     <message>
-        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3044"/>
+        <location filename="../src/plugins/grass/qgsgrassmodule.cpp" line="3041"/>
         <source>Selected categories</source>
         <translation>Gewählte Kategorien</translation>
     </message>
@@ -27094,152 +27103,152 @@
 <context>
     <name>QgsWmsProvider</name>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="878"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="882"/>
         <source>
 Tried URL: %1</source>
         <translation>
 URL %1 versucht</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="899"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="903"/>
         <source>Capabilities request redirected.</source>
         <translation>Capabilities-Abfrage umgeleitet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="918"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="922"/>
         <source>empty of capabilities: %1</source>
         <translation>Capabilities leer: %1</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="923"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="927"/>
         <source>Download of capabilities failed: %1</source>
         <translation>Capabilities-Abfrage gescheitert: %1</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="935"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="939"/>
         <source>%1 of %2 bytes of capabilities downloaded.</source>
         <translation>%1 von %2 Bytes der Capabilities heruntergeladen.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="940"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="944"/>
         <source>%1 of %2 bytes of map downloaded.</source>
         <translation>%1 von %2 Bytes der Karte heruntergeladen.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="964"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="984"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1817"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="968"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="988"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1821"/>
         <source>Dom Exception</source>
         <translation>DOM-Ausnahme</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="965"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="969"/>
         <source>Could not get WMS capabilities: %1 at line %2 column %3
 </source>
         <translation>Konnte WMS-Eigenschaften nicht bestimmen: %1 in Zeile %2, Spalte %3
 </translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="967"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="988"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="971"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="992"/>
         <source>This is probably due to an incorrect WMS Server URL.</source>
         <translation>Dies liegt wahrscheinlich an einer falschen WMS-Server-URL.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="985"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="989"/>
         <source>Could not get WMS capabilities in the expected format (DTD): no %1 or %2 found
 </source>
         <translation>WMS-Eigenschaften nicht im erwarteten Format (DTD): kein %1 oder %2 gefunden
 </translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1818"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1822"/>
         <source>Could not get WMS Service Exception at %1: %2 at line %3 column %4</source>
         <translation>Konnte WMS-Diensteigenschaften in %1 nicht bestimmen: %2 in Zeile %3, Spalte %4</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1871"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1875"/>
         <source>Request contains a Format not offered by the server.</source>
         <translation>Anfrage verlangt ein Format, dass der Servern nicht anbietet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1875"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1879"/>
         <source>Request contains a CRS not offered by the server for one or more of the Layers in the request.</source>
         <translation>Anfrage verlangt ein CRS für einen oder mehrere Layer, die der Server nicht anbietet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1879"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1883"/>
         <source>Request contains a SRS not offered by the server for one or more of the Layers in the request.</source>
         <translation>Anfrage enthält ein SRS für einen oder mehrere Layer, die der Server nicht anbietet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1883"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1887"/>
         <source>GetMap request is for a Layer not offered by the server, or GetFeatureInfo request is for a Layer not shown on the map.</source>
         <translation>GetMap-Anfrage für einen Layer, den der Server nicht anbietet oder GetFeature-Anfrage für einen Layer, der nicht auf der Karte angezeigt wird.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1888"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1892"/>
         <source>Request is for a Layer in a Style not offered by the server.</source>
         <translation>Anfrage für einen Layer in einem Stil, den der Server nicht anbietet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1892"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1896"/>
         <source>GetFeatureInfo request is applied to a Layer which is not declared queryable.</source>
         <translation>GetFeatureInfo-Anfrage wird auf einen Layer bezogen, der nicht als abfragbar deklariert ist.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1896"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1900"/>
         <source>GetFeatureInfo request contains invalid X or Y value.</source>
         <translation>GetFeatureInfo-Anfrage enthält einen ungültigen X- oder Y-Wert.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1900"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1904"/>
         <source>Value of (optional) UpdateSequence parameter in GetCapabilities request is equal to current value of service metadata update sequence number.</source>
         <translation>Wert des (optionalen) Aktualisierungssequenenzzählers der GetCapabilities-Anfrage entspricht dem aktuellen Wert des Aktualisierungssequenzzähler in den Dienstmetadaten.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1905"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1909"/>
         <source>Value of (optional) UpdateSequence parameter in GetCapabilities request is greater than current value of service metadata update sequence number.</source>
         <translation>Wert des (optionalen) Aktualisierungssequenenzzählers der GetCapabilities-Anfrage ist größer als der aktuelle Wert des Aktualisierungssequenzzähler in den Dienstmetadaten.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1910"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1914"/>
         <source>Request does not include a sample dimension value, and the server did not declare a default value for that dimension.</source>
         <translation>Anfrage enthält keinen beispielhaften Dimensionswert, und der Server selbst definiert auch keinen.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1915"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1919"/>
         <source>Request contains an invalid sample dimension value.</source>
         <translation>Anfrage enthält einen ungültigen beispielhaften Dimensionswert.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1919"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1923"/>
         <source>Request is for an optional operation that is not supported by the server.</source>
         <translation>Anfrage ist für eine optionale Operation, die der Server nicht unterstützt.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1930"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1934"/>
         <source>The WMS vendor also reported: </source>
         <translation>Der WMS-Betreiber meldete folgendes: </translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2142"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2338"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2518"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2581"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2146"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2342"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2522"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2585"/>
         <source>Property</source>
         <translation>Eigenschaft</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2145"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2341"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2521"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2584"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2149"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2345"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2525"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2588"/>
         <source>Value</source>
         <translation>Wert</translation>
     </message>
     <message numerus="yes">
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2245"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2249"/>
         <source>(and %n more)</source>
         <comment>crs</comment>
         <translation>
@@ -27248,250 +27257,260 @@
         </translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2307"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2311"/>
         <source>Selected Layers</source>
         <translation>Gewählte Layer</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2309"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2313"/>
         <source>Other Layers</source>
         <translation>Andere Layer</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2346"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2350"/>
         <source>WMS Version</source>
         <translation>WMS-Version</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2158"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2270"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2354"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2162"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2274"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2358"/>
         <source>Title</source>
         <translation>Titel</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2166"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2278"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2362"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2170"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2282"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2366"/>
         <source>Abstract</source>
         <translation>Zusammenfassung</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2370"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2374"/>
         <source>Keywords</source>
         <translation>Schlüsselworte</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2378"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2382"/>
         <source>Online Resource</source>
         <translation>Online-Quelle</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2386"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2390"/>
         <source>Contact Person</source>
         <translation>Kontaktperson</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2398"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2402"/>
         <source>Fees</source>
         <translation>Kosten</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2406"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2410"/>
         <source>Access Constraints</source>
         <translation>Zugriffsbeschränkungen</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2414"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2418"/>
         <source>Image Formats</source>
         <translation>Bildformate</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2422"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2426"/>
         <source>Identify Formats</source>
         <translation>Abfrageformate</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2430"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2434"/>
         <source>Layer Count</source>
         <translation>Layeranzahl</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2440"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2444"/>
         <source>Tileset Count</source>
         <translation>Tileset-Anzahl</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2525"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2529"/>
         <source>Selected</source>
         <translation>Ausgewählt</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2177"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2185"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2193"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2528"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2181"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2189"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2197"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2532"/>
         <source>Yes</source>
         <translation>Ja</translation>
     </message>
     <message>
         <source>No</source>
         <translation>Nein</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2150"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2154"/>
         <source>Visibility</source>
         <translation>Sichtbarkeit</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2153"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2157"/>
         <source>Visible</source>
         <translation>Sichtbar</translation>
     </message>
     <message>
         <source>Hidden</source>
         <translation>Versteckt</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2174"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2178"/>
         <source>Can Identify</source>
         <translation>Kann abgefragt werden</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2182"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2186"/>
         <source>Can be Transparent</source>
         <translation>Kann transparent sein</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2198"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2202"/>
         <source>Cascade Count</source>
         <translation>Kaskadiere Anzahl</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2206"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2210"/>
         <source>Fixed Width</source>
         <translation>Feste Breite</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2214"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2218"/>
         <source>Fixed Height</source>
         <translation>Feste Höhe</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2222"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2226"/>
         <source>WGS 84 Bounding Box</source>
         <translation>WGS84-Ausdehnung</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2232"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2242"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2236"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2246"/>
         <source>Available in CRS</source>
         <translation>Verfügbar in KBS</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2253"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2257"/>
         <source>Available in style</source>
         <translation>Verfügbar im Stil</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2262"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2266"/>
         <source>Name</source>
         <translation>Name</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2573"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2577"/>
         <source>Cache stats</source>
         <translation>Cache-Statistik</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2534"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2538"/>
         <source>Styles</source>
         <translation>Stile</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2449"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="521"/>
+        <source>Getting map via WMS.</source>
+        <translation>Lade Karte über WMS.</translation>
+    </message>
+    <message>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="651"/>
+        <source>Getting tiles via WMS.</source>
+        <translation>Lade Kacheln über WMS.</translation>
+    </message>
+    <message>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2453"/>
         <source>GetCapabilitiesUrl</source>
         <translation>GetCapabilities-URL</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2456"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2460"/>
         <source>GetMapUrl</source>
         <translation>GetMap-URL</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2459"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2466"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2463"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2470"/>
         <source>&amp;nbsp;&lt;font color=&quot;red&quot;&gt;(advertised but ignored)&lt;/font&gt;</source>
         <translation>&amp;nbsp;&lt;font color=&quot;red&quot;&gt;(gemeldet, aber ignoriert)&lt;/font&gt;</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2475"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2479"/>
         <source>Selected Layers:</source>
         <translation>Gewählte Layer:</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2488"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2492"/>
         <source>Other layers:</source>
         <translation>Andere Layer:</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2542"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2546"/>
         <source>CRS</source>
         <translation>KBS</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2549"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2553"/>
         <source>Bounding Box</source>
         <translation>Ausdehnung</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2556"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2560"/>
         <source>Available in Resolutions</source>
         <translation>Verfügbare Auflösungen</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2588"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2592"/>
         <source>Hits</source>
         <translation>Treffer</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2594"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2598"/>
         <source>Misses</source>
         <translation>Fehlgriffe</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2600"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2604"/>
         <source>Errors</source>
         <translation>Fehler</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2673"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2677"/>
         <source>Layer cannot be queried in plain text.</source>
         <translation>Layer kann in Klartext abgefragt werden.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2679"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2683"/>
         <source>Layer cannot be queried.</source>
         <translation>Layer kann nicht abgefragt werden.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2723"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2727"/>
         <source>identify request redirected.</source>
         <translation>Identify-Anfrage umgeleitet.</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2190"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2194"/>
         <source>Can Zoom In</source>
         <translation>Kann herangezoomt werden</translation>
     </message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="664"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="780"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="668"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="784"/>
         <source>%n tile requests in background</source>
         <comment>tile request count</comment>
         <translation>
@@ -27500,8 +27519,8 @@
         </translation>
     </message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="665"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="781"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="669"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="785"/>
         <source>, %n cache hits</source>
         <comment>tile cache hits</comment>
         <translation>
@@ -27510,8 +27529,8 @@
         </translation>
     </message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="666"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="782"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="670"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="786"/>
         <source>, %n cache misses.</source>
         <comment>tile cache missed</comment>
         <translation>
@@ -27520,8 +27539,8 @@
         </translation>
     </message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="667"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="783"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="671"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="787"/>
         <source>, %n errors.</source>
         <comment>errors</comment>
         <translation>
@@ -27530,45 +27549,45 @@
         </translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="726"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="730"/>
         <source>tile request err %1: %2</source>
         <translation>Tile-Anfragefehler %1: %2</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="807"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2738"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="811"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2742"/>
         <source>map request error %1: %2</source>
         <translation>Kartenanfragefehler %1: %2</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2303"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2329"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2307"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2333"/>
         <source>Server Properties</source>
         <translation>Server-Eigenschaften</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2315"/>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2503"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2319"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2507"/>
         <source>Tileset Properties</source>
         <translation>Tileset-Eigenschaften</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2320"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2324"/>
         <source>Cache Stats</source>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2463"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="2467"/>
         <source>GetFeatureInfoUrl</source>
         <translation>GetFeatureInfoUrl</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1923"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1927"/>
         <source>(No error code was reported)</source>
         <translation>(Kein Fehlercode zurückgegeben)</translation>
     </message>
     <message>
-        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1927"/>
+        <location filename="../src/providers/wms/qgswmsprovider.cpp" line="1931"/>
         <source>(Unknown error code)</source>
         <translation>(Unbekannter Fehlercode)</translation>
     </message>
@@ -27784,19 +27803,16 @@
 <context>
     <name>UndoWidget</name>
     <message>
-        <location filename="../src/app/qgsgeomerrorswidget.cpp" line="161"/>
         <location filename="../src/app/qgsundowidget.cpp" line="161"/>
         <source>Undo/Redo</source>
         <translation>Rücknahme/Wiederholung</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsgeomerrorswidget.cpp" line="162"/>
         <location filename="../src/app/qgsundowidget.cpp" line="162"/>
         <source>Undo</source>
         <translation>Zurücknehmen</translation>
     </message>
     <message>
-        <location filename="../src/app/qgsgeomerrorswidget.cpp" line="163"/>
         <location filename="../src/app/qgsundowidget.cpp" line="163"/>
         <source>Redo</source>
         <translation>Wiederholen</translation>
More information about the QGIS-commit mailing list
