[QGIS Commit] r13738 - in trunk/qgis: . doc
svn_qgis at osgeo.org svn_qgis at osgeo.org
Wed Jun 16 16:05:32 EDT 2010
Author: jef
Date: 2010-06-16 20:05:32 +0000 (Wed, 16 Jun 2010)
New Revision: 13738
   trunk/qgis/INSTALL
   trunk/qgis/doc/INSTALL.t2t
add dch reference to INSTALL
Modified: trunk/qgis/INSTALL
--- trunk/qgis/INSTALL	2010-06-16 11:31:39 UTC (rev 13737)
+++ trunk/qgis/INSTALL	2010-06-16 20:05:32 UTC (rev 13738)
@@ -1324,6 +1324,12 @@
   apt-get install build-essential
+First you need to create an changelog entry for your distribution. For example for Ubuntu Lucid:
+  dch -l ~lucid  --force-distribution --distribution lucid "lucid build"
 The QGIS packages will be created with:
@@ -1337,7 +1343,7 @@
 using dpkg -r libqgis1-dev.  Otherwise dpkg-buildpackage will complain about a
 build conflict.
-The the packages are created in the parent directory (ie. one level up).
+The packages are created in the parent directory (ie. one level up).
 Install them using dpkg.  E.g.:
Modified: trunk/qgis/doc/INSTALL.t2t
--- trunk/qgis/doc/INSTALL.t2t	2010-06-16 11:31:39 UTC (rev 13737)
+++ trunk/qgis/doc/INSTALL.t2t	2010-06-16 20:05:32 UTC (rev 13738)
@@ -1173,6 +1173,12 @@
+dch -l ~lucid  --force-distribution --distribution lucid "lucid build"
@@ -1186,7 +1192,7 @@
 using ``dpkg -r libqgis1-dev``.  Otherwise ``dpkg-buildpackage`` will complain about a
 build conflict.
More information about the QGIS-commit mailing list
