[QGIS Commit] r13775 - in branches/threading-branch/src: app app/legend core core/raster gui
svn_qgis at osgeo.org svn_qgis at osgeo.org
Tue Jun 22 04:29:49 EDT 2010
Author: wonder
Date: 2010-06-22 08:29:49 +0000 (Tue, 22 Jun 2010)
New Revision: 13775
   branches/threading-branch/src/app/legend/qgslegend.cpp
   branches/threading-branch/src/app/qgisapp.cpp
   branches/threading-branch/src/app/qgsrasterlayerproperties.cpp
   branches/threading-branch/src/app/qgsvectorlayerproperties.cpp
   branches/threading-branch/src/core/qgsmaplayer.cpp
   branches/threading-branch/src/core/qgsmaplayer.h
   branches/threading-branch/src/core/qgsmaplayerregistry.cpp
   branches/threading-branch/src/core/qgsmaplayerregistry.h
   branches/threading-branch/src/core/qgsmaprenderer.cpp
   branches/threading-branch/src/core/qgsmaprenderer.h
   branches/threading-branch/src/core/qgsvectorlayer.cpp
   branches/threading-branch/src/core/raster/qgsrasterlayer.cpp
   branches/threading-branch/src/gui/qgsmapcanvas.cpp
Render caching done with QgsMapRendererCache, deprecated methods of QgsMapLayer for caching
Modified: branches/threading-branch/src/app/legend/qgslegend.cpp
--- branches/threading-branch/src/app/legend/qgslegend.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/app/legend/qgslegend.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -1332,6 +1332,7 @@
 void QgsLegend::updateMapCanvasLayerSet()
+  QgsDebugMsg("updating layer set");
   QList<QgsMapCanvasLayer> layers;
   // create list of the layers
@@ -1463,8 +1464,6 @@
     return;
-  bool renderFlagState = mMapCanvas->renderFlag();
   //if the text of a QgsLegendLayer has changed, change the display names of all its maplayers
   // TODO: is this still necessary?
   QgsLegendLayer* theLegendLayer = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
@@ -1477,13 +1476,13 @@
   if ( item->data( 0, Qt::UserRole ).toInt() == item->checkState( 0 ) )
     return;
+  mMapCanvas->freeze( true );
   QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item ); //item is a legend group
   if ( lg )
     //set all the child layer files to the new check state
     std::list<QgsLegendLayer*> subfiles = lg->legendLayers();
-    mMapCanvas->setRenderFlag( false );
     for ( std::list<QgsLegendLayer*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
 #ifdef QGISDEBUG
@@ -1510,10 +1509,6 @@
-    // If it was on, turn it back on, otherwise leave it
-    // off, as turning it on causes a refresh.
-    if ( renderFlagState )
-      mMapCanvas->setRenderFlag( true );
     item->setData( 0, Qt::UserRole, item->checkState( 0 ) );
@@ -1534,17 +1529,13 @@
       static_cast<QgsLegendGroup*>( ll->parent() )->updateCheckState();
       ll->parent()->setData( 0, Qt::UserRole, ll->parent()->checkState( 0 ) );
-    mMapCanvas->freeze( false );
     //update check state of the legend group
+  mMapCanvas->freeze( false );
   // update layer set
   updateMapCanvasLayerSet();
Modified: branches/threading-branch/src/app/qgisapp.cpp
--- branches/threading-branch/src/app/qgisapp.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/app/qgisapp.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -4488,7 +4488,7 @@
 void QgisApp::refreshMapCanvas()
   //clear all caches first
-  QgsMapLayerRegistry::instance()->clearAllLayerCaches();
+  mMapCanvas->mapRenderer()->clearCache();
   //then refresh
   mMapCanvas->refresh();
Modified: branches/threading-branch/src/app/qgsrasterlayerproperties.cpp
--- branches/threading-branch/src/app/qgsrasterlayerproperties.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/app/qgsrasterlayerproperties.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -1471,9 +1471,6 @@
   // update symbology
   emit refreshLegend( mRasterLayer->getLayerID(), false );
-  //no need to delete the old one, maplayer will do it if needed
-  mRasterLayer->setCacheImage( 0 );
   //make sure the layer is redrawn
   mRasterLayer->triggerRepaint();
Modified: branches/threading-branch/src/app/qgsvectorlayerproperties.cpp
--- branches/threading-branch/src/app/qgsvectorlayerproperties.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/app/qgsvectorlayerproperties.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -665,9 +665,6 @@
   // update symbology
   emit refreshLegend( layer->getLayerID(), false );
-  layer->setCacheImage( 0 );
   layer->triggerRepaint();
   // notify the project we've made a change
   QgsProject::instance()->dirty( true );
Modified: branches/threading-branch/src/core/qgsmaplayer.cpp
--- branches/threading-branch/src/core/qgsmaplayer.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaplayer.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -842,12 +842,7 @@
 void QgsMapLayer::setCacheImage( QImage * thepImage )
-  QgsDebugMsg( "cache Image set!" );
-  if ( mpCacheImage )
-    delete mpCacheImage;
-  mpCacheImage = thepImage;
+  QgsDebugMsg( "warning: deprecated, does nothing." );
 bool QgsMapLayer::isEditable() const
@@ -860,7 +855,8 @@
   mValid = valid;
 void QgsMapLayer::clearCacheImage()
-  setCacheImage( 0 );
Modified: branches/threading-branch/src/core/qgsmaplayer.h
--- branches/threading-branch/src/core/qgsmaplayer.h	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaplayer.h	2010-06-22 08:29:49 UTC (rev 13775)
@@ -290,10 +290,10 @@
     /** Return pointer to layer's undo stack */
     QUndoStack* undoStack();
-    /** Get the QImage used for caching render operations
+    /** @deprecated Caching is done now in QgsMapRendererCache. Returns always 0.
      * @note This method was added in QGIS 1.4 **/
-    QImage * cacheImage() { return mpCacheImage; }
-    /** Set the QImage used for caching render operations
+    QImage * cacheImage() { return 0; }
+    /** @deprecated Caching is done now in QgsMapRendererCache. Does nothing.
     void setCacheImage( QImage * thepImage );
@@ -314,7 +314,7 @@
     void toggleScaleBasedVisibility( bool theVisibilityFlag );
     bool hasScaleBasedVisibility();
-    /** Clear cached image
+    /** @deprecated Caching is done now in QgsMapRendererCache. Clear cache by emitting dataChanged() signal.
      * added in 1.5 */
     void clearCacheImage();
Modified: branches/threading-branch/src/core/qgsmaplayerregistry.cpp
--- branches/threading-branch/src/core/qgsmaplayerregistry.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaplayerregistry.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -117,16 +117,9 @@
 } // QgsMapLayerRegistry::removeAllMapLayers()
-//Added in QGIS 1.4
 void QgsMapLayerRegistry::clearAllLayerCaches()
-  QMap<QString, QgsMapLayer *>::iterator it;
-  for ( it = mMapLayers.begin(); it != mMapLayers.end() ; ++it )
-    //the map layer will take care of deleting the QImage
-    it.value()->setCacheImage( 0 );
-} // QgsMapLayerRegistry::clearAllLayerCaches()
 QMap<QString, QgsMapLayer*> & QgsMapLayerRegistry::mapLayers()
Modified: branches/threading-branch/src/core/qgsmaplayerregistry.h
--- branches/threading-branch/src/core/qgsmaplayerregistry.h	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaplayerregistry.h	2010-06-22 08:29:49 UTC (rev 13775)
@@ -82,10 +82,8 @@
     void removeAllMapLayers();
-    /* Clears all layer caches, resetting them to zero and
-     * freeing up any memory they may have been using. Layer
-     * caches are used to speed up rendering in certain situations
-     * see ticket #1974 for more details.
+    /** Does nothing.
+     * @deprecated clearing of caches is now done with QgsMapRenderer::clearCache()
      * @note this method was added in QGIS 1.4
     void clearAllLayerCaches();
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -54,7 +54,7 @@
   mDrawing = false;
   mOverview = false;
   mThreadingEnabled = false;
-  mCachingEnabled = false;
+  mCache = NULL;
   // set default map units - we use WGS 84 thus use degrees
   setMapUnits( QGis::Degrees );
@@ -83,6 +83,7 @@
   delete mDistArea;
   delete mDestCRS;
   delete mLabelingEngine;
+  delete mCache;
@@ -104,9 +105,6 @@
     return false; // do not allow changes while rendering
-  //remember the previous extent
-  mLastExtent = mExtent;
   // Don't allow zooms where the current extent is so small that it
   // can't be accurately represented using a double (which is what
   // currentExtent uses). Excluding 0 avoids a divide by zero and an
@@ -233,15 +231,9 @@
   mDrawing = true;
-  //flag to see if the render context has changed
-  //since the last time we rendered. If it hasnt changed we can
-  //take some shortcuts with rendering
-  bool mySameAsLastFlag = true;
   QgsDebugMsg( "========== Rendering ==========" );
+  QgsDebugMsg( "caching enabled? " + QString::number(mCache != NULL) );
-  QgsDebugMsg( "caching enabled? " + QString::number(mCachingEnabled) );
 #ifdef QGISDEBUG
   QgsDebugMsg( "Starting to render layer stack." );
   mRenderTime.start();
@@ -264,41 +256,21 @@
     scaleFactor = sceneDpi / 25.4;
   double rasterScaleFactor = deviceDpi / sceneDpi;
-  if ( mRenderContext.rasterScaleFactor() != rasterScaleFactor )
-    mRenderContext.setRasterScaleFactor( rasterScaleFactor );
-    mySameAsLastFlag = false;
-  if ( mRenderContext.scaleFactor() != scaleFactor )
-    mRenderContext.setScaleFactor( scaleFactor );
-  if ( mRenderContext.rendererScale() != mScale )
-    //add map scale to render context
-    mRenderContext.setRendererScale( mScale );
-  if ( mLastExtent != mExtent )
+  // initialize render context scaling
+  mRenderContext.setRasterScaleFactor( rasterScaleFactor );
+  mRenderContext.setScaleFactor( scaleFactor );
+  mRenderContext.setRendererScale( mScale );
   mRenderContext.setLabelingEngine( mLabelingEngine );
   if ( mLabelingEngine )
     mLabelingEngine->init( this );
-  // know we know if this render is just a repeat of the last time, we
-  // can clear caches if it has changed
-  if ( !mySameAsLastFlag )
+  if (mCache)
-    //clear the cache pixmap if we changed resolution / extent
-    if ( mCachingEnabled )
+    // initialize cache: if the parameters are not the same as the last time,
+    // the cached images are removed
+    mCache->init(mExtent, mScale, scaleFactor, rasterScaleFactor);
   mOverlayManager = overlayManagerFromSettings();
@@ -429,13 +401,13 @@
     // Force render of layers that are being edited
     // or if there's a labeling engine that needs the layer to register features
-    if ( ml->type() == QgsMapLayer::VectorLayer )
+    if ( mCache && ml->type() == QgsMapLayer::VectorLayer )
       QgsVectorLayer* vl = qobject_cast<QgsVectorLayer *>( ml );
       if ( vl->isEditable() ||
            ( mRenderContext.labelingEngine() && mRenderContext.labelingEngine()->willUseLayer( vl ) ) )
-        ml->setCacheImage( 0 );
+        mCache->setCacheImage(ml->getLayerID(), QImage());
@@ -564,61 +536,79 @@
 void _renderLayerThreading( ThreadedRenderContext& tctx )
-  QgsDebugMsg("threaded rendering start: "+tctx.ml->getLayerID());
-  // TODO: error handling
-  tctx.mr->renderLayer( tctx.ml, tctx.ctx );
+  QString layerId = tctx.ml->getLayerID();
+  if (tctx.cached)
+    QgsDebugMsg("threaded cached (doing nothing): "+layerId);
+  else
+    QgsDebugMsg("threaded rendering start: "+layerId);
+    // TODO: error handling
+    tctx.mr->renderLayer( tctx.ml, tctx.ctx );
-  QgsDebugMsg("threaded rendering end  : "+tctx.ml->getLayerID());
+    if (tctx.mr->mCache)
+      // save cache image
+      tctx.mr->mCache->setCacheImage( layerId, *tctx.img );
+    QgsDebugMsg("threaded rendering end  : "+layerId);
 void QgsMapRenderer::renderLayerThreading( QgsMapLayer* ml )
-  if ( mCachingEnabled && ml->cacheImage() != 0 )
+  ThreadedRenderContext tctx;
+  tctx.ml = ml;
+  if ( mCache && ! mCache->cacheImage(ml->getLayerID()).isNull() )
-    // do nothing - cached image will be used
-    // TODO: resolve caching
+    // cached image will be used
+    tctx.img = new QImage( mCache->cacheImage(ml->getLayerID()));
+    tctx.cached = true;
   else
-    ThreadedRenderContext tctx;
-    tctx.ml = ml;
     // create image
     tctx.img = new QImage( mSize, QImage::Format_ARGB32_Premultiplied );
     tctx.img->fill( 0 );
+    tctx.cached = false;
-    // create private context
-    tctx.mr = this;
-    tctx.ctx = mRenderContext;
+  // create private context
+  tctx.mr = this;
+  tctx.ctx = mRenderContext;
-    QPainter* painter = new QPainter(tctx.img);
-    painter->setRenderHint( QPainter::Antialiasing, mAntialiasingEnabled );
-    tctx.ctx.setPainter( painter );
+  QPainter* painter = new QPainter(tctx.img);
+  painter->setRenderHint( QPainter::Antialiasing, mAntialiasingEnabled );
+  tctx.ctx.setPainter( painter );
-    // schedule DRAW to a list
-    mThreadedJobs.append(tctx);
+  // schedule DRAW to a list
+  mThreadedJobs.append(tctx);
 void QgsMapRenderer::renderLayerNoThreading( QgsMapLayer* ml )
+  if ( mCache )
     // Store the painter in case we need to swap it out for the
     // cache painter
     QPainter * mypContextPainter = mRenderContext.painter();
-    if ( ml->cacheImage() == 0 )
+    // retrieve cached image for the layer (will be null if not valid)
+    QImage cacheImage = mCache->cacheImage(ml->getLayerID());
+    if ( cacheImage.isNull() )
       // create cached image
       QgsDebugMsg( "\n\n\nCaching enabled --- redraw forced by extent change or empty cache\n\n\n" );
       QPaintDevice* device = mRenderContext.painter()->device();
-      QImage * mypImage = new QImage( device->width(), device->height(), QImage::Format_ARGB32_Premultiplied );
-      mypImage->fill( 0 );
-      ml->setCacheImage( mypImage ); //no need to delete the old one, maplayer does it for you
+      cacheImage = QImage( device->width(), device->height(), QImage::Format_ARGB32_Premultiplied );
+      cacheImage.fill( 0 );
       // alter painter
-      QPainter * mypPainter = new QPainter( ml->cacheImage() );
+      QPainter * mypPainter = new QPainter( &cacheImage );
       mypPainter->setRenderHint( QPainter::Antialiasing, mAntialiasingEnabled );
       mRenderContext.setPainter( mypPainter );
@@ -630,10 +620,13 @@
       // by reinstating the painter as it was swapped out for caching renders
       delete mRenderContext.painter();
       mRenderContext.setPainter( mypContextPainter );
+      // set cache image to the newly rendered image
+      mCache->setCacheImage( ml->getLayerID(), cacheImage );
     // draw cached image
-    mypContextPainter->drawImage( 0, 0, *( ml->cacheImage() ) );
+    mypContextPainter->drawImage( 0, 0, cacheImage );
   else
@@ -1063,7 +1056,30 @@
     return; // do not allow changes while rendering
+  foreach (QString layerId, mLayerSet)
+    QgsMapLayer* ml = QgsMapLayerRegistry::instance()->mapLayer(layerId);
+    if (ml)
+      disconnect(ml, SIGNAL(selectionChanged()), this, SLOT(clearLayerCache()));
+      disconnect(ml, SIGNAL(editingStopped()), this, SLOT(clearLayerCache()));
+      disconnect(ml, SIGNAL(dataChanged()), this, SLOT(clearLayerCache()));
   mLayerSet = layers;
+    if (ml)
+      connect(ml, SIGNAL(selectionChanged()), this, SLOT(clearLayerCache()));
+      connect(ml, SIGNAL(editingStopped()), this, SLOT(clearLayerCache()));
+      connect(ml, SIGNAL(dataChanged()), this, SLOT(clearLayerCache()));
   updateFullExtent();
@@ -1072,6 +1088,27 @@
   return mLayerSet;
+void QgsMapRenderer::clearLayerCache()
+  QgsMapLayer* ml = qobject_cast<QgsMapLayer*>(sender());
+  if (mCache)
+    if (ml)
+      QgsDebugMsg("clearing cache for: "+ml->getLayerID());
+    else
+      QgsDebugMsg("clearing cache - FOR WHOM ?????\n\n\n\n\n\n");
+  else
+    QgsDebugMsg("not caching -> not clearing cache");
 QgsOverlayObjectPositionManager* QgsMapRenderer::overlayManagerFromSettings()
   QSettings settings;
@@ -1316,7 +1353,16 @@
-  mCachingEnabled = enabled;
+  if ( mCache && !enabled )
+    delete mCache;
+    mCache = NULL;
+  else if ( !mCache && enabled )
+    mCache = new QgsMapRendererCache();
 void QgsMapRenderer::setAntialiasingEnabled( bool enabled )
@@ -1329,3 +1375,64 @@
   mAntialiasingEnabled = enabled;
+void QgsMapRenderer::clearCache()
+  if ( mDrawing )
+    QgsDebugMsg("Ignored --- drawing now!");
+    return; // do not allow changes while rendering
+  if (mCache)
+    mCache->clear();
+QgsMapRendererCache::QgsMapRendererCache()
+  clear();
+void QgsMapRendererCache::clear()
+  mExtent.setMinimal();
+  mScale = 0;
+  mScaleFactor = 0;
+  mRasterScaleFactor = 0;
+  mCachedImages.clear();
+bool QgsMapRendererCache::init(QgsRectangle extent, double scale, double scaleFactor, double rasterScaleFactor)
+  // check whether the params are the same
+  if (extent == mExtent &&
+      scale == mScale &&
+      scaleFactor == mScaleFactor &&
+      rasterScaleFactor == mRasterScaleFactor )
+    return true;
+  // set new params
+  mExtent = extent;
+  mScale = scale;
+  mScaleFactor = scaleFactor;
+  mRasterScaleFactor = rasterScaleFactor;
+  // invalidate cache
+  return false;
+void QgsMapRendererCache::setCacheImage(QString layerId, const QImage& img)
+  mCachedImages[layerId] = img;
+QImage QgsMapRendererCache::cacheImage(QString layerId)
+  return mCachedImages.value(layerId);
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsmaprenderer.h	2010-06-22 08:29:49 UTC (rev 13775)
@@ -49,6 +49,7 @@
   QgsMapLayer* ml; // source map layer
   QImage* img; // destination image
   QgsRenderContext ctx; // private render context
+  bool cached; // whether the image is retrieved from cache (= rendering not necessary)
 } ThreadedRenderContext;
@@ -78,6 +79,35 @@
+class CORE_EXPORT QgsMapRendererCache
+  public:
+    QgsMapRendererCache();
+    //! invalidate the cache contents
+    void clear();
+    //! initialize cache: set new parameters and erase cache if parameters have changed
+    //! @return flag whether the extent and other factors are the same as last time
+    bool init(QgsRectangle extent, double scale, double scaleFactor, double rasterScaleFactor);
+    //! set cached image for the specified layer ID
+    void setCacheImage(QString layerId, const QImage& img);
+    //! get cached image for the specified layer ID. Returns null image if it is not cached.
+    QImage cacheImage(QString layerId);
+  protected:
+    QgsRectangle mExtent;
+    double mScale;
+    double mScaleFactor, mRasterScaleFactor;
+    QMap<QString, QImage> mCachedImages;
 /** \ingroup core
  * A non GUI class for rendering a map layer set onto a QPainter.
@@ -212,7 +242,7 @@
     //! Determine whether the rendered layers are cached
     //! Added in QGIS v1.6
-    bool isCachingEnabled() const { return mCachingEnabled; }
+    bool isCachingEnabled() const { return mCache != NULL; }
     void setAntialiasingEnabled( bool enabled );
@@ -241,6 +271,10 @@
     bool isDrawing() const { return mDrawing; }
+    //! if caching is enabled, invalidate the renderer cache
+    //! Added in QGIS v1.6
+    void clearCache();
   signals:
     //! emitted when asynchronous rendering is finished (or canceled).
@@ -268,6 +302,8 @@
     void futureFinished();
+    void clearLayerCache();
   protected:
     //! adjust extent to fit the pixmap size
@@ -324,13 +360,6 @@
     //! current extent to be drawn
-    /** Last extent to we drew so we know if we can
-        used layer render caching or not. Note there are no
-        accessors for this as it is intended to internal
-        use only.
-        @note added in QGIS 1.4 */
-    QgsRectangle mLastExtent;
     //! indicates whether it's map image for overview
     bool mOverview;
@@ -362,7 +391,7 @@
     bool mThreadingEnabled;
     //! Render caching
-    bool mCachingEnabled;
+    QgsMapRendererCache* mCache;
     bool mAntialiasingEnabled;
Modified: branches/threading-branch/src/core/qgsvectorlayer.cpp
--- branches/threading-branch/src/core/qgsvectorlayer.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/qgsvectorlayer.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -1046,9 +1046,6 @@
   if ( emitSignal )
-    // invalidate cache
     emit selectionChanged();
@@ -1059,9 +1056,6 @@
   if ( emitSignal )
@@ -1085,9 +1079,6 @@
     select( f.id(), false ); // don't emit signal (not to redraw it everytime)
   emit selectionChanged(); // now emit signal to redraw layer
@@ -1111,9 +1102,6 @@
     mSelectedFeatureIds.remove( *iter );
@@ -1137,9 +1125,6 @@
@@ -1152,15 +1137,13 @@
   if ( emitSignal )
 void QgsVectorLayer::triggerRepaint()
+  emit dataChanged(); // invalidates caches of map renderers
   emit repaintRequested();
@@ -1384,7 +1367,7 @@
   updateExtents();
   if ( res )
   return res;
@@ -1839,9 +1822,6 @@
     deleteFeature( fid );  // removes from selection
   triggerRepaint();
@@ -2449,6 +2429,8 @@
       // TODO: Check if the provider has the capability to send fullExtentCalculated
       connect( mDataProvider, SIGNAL( fullExtentCalculated() ), this, SLOT( updateExtents() ) );
+      connect( mDataProvider, SIGNAL(dataChanged()), this, SIGNAL(dataChanged()) );
       // get the extent
       QgsRectangle mbr = mDataProvider->extent();
@@ -3113,9 +3095,6 @@
   bool success = true;
-  //clear the cache image so markers don't appear anymore on next draw
   mCommitErrors.clear();
   if ( !mDataProvider )
@@ -3443,9 +3422,6 @@
   emit editingStopped();
   setModified( false );
-  // invalidate the cache so the layer updates properly to show its original
-  // after the rollback
   triggerRepaint();
   return true;
@@ -3456,9 +3432,6 @@
   // TODO: check whether features with these ID exist
   mSelectedFeatureIds = ids;
@@ -3552,9 +3525,6 @@
   if ( makeSelected )
Modified: branches/threading-branch/src/core/raster/qgsrasterlayer.cpp
--- branches/threading-branch/src/core/raster/qgsrasterlayer.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/core/raster/qgsrasterlayer.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -228,6 +228,7 @@
     mDataProvider, SIGNAL( statusChanged( QString ) ),
     this,           SLOT( showStatusMessage( QString ) )
   QgsDebugMsg( "(8 arguments) exiting." );
   emit statusChanged( tr( "QgsRasterLayer created" ) );
@@ -3612,6 +3613,7 @@
 void QgsRasterLayer::triggerRepaint()
Modified: branches/threading-branch/src/gui/qgsmapcanvas.cpp
--- branches/threading-branch/src/gui/qgsmapcanvas.cpp	2010-06-22 07:22:40 UTC (rev 13774)
+++ branches/threading-branch/src/gui/qgsmapcanvas.cpp	2010-06-22 08:29:49 UTC (rev 13775)
@@ -229,6 +229,7 @@
   if ( isDrawing() )
+    QgsDebugMsg("ignored - drawing!" );
     return;
@@ -246,6 +247,7 @@
     if ( lyr.isVisible() )
+      QgsDebugMsg("pushing layer "+ lyr.layer()->getLayerID() );
       layerSet.push_back( lyr.layer()->getLayerID() );
     if ( lyr.isInOverview() )
More information about the QGIS-commit mailing list
