[QGIS Commit] r13796 - in branches/threading-branch/src: app
app/legend gui
svn_qgis at osgeo.org
Thu Jun 24 07:27:54 EDT 2010
Author: wonder
Date: 2010-06-24 11:27:54 +0000 (Thu, 24 Jun 2010)
New Revision: 13796
branches/threading-branch/src/app/legend/qgslegend.cpp
branches/threading-branch/src/app/legend/qgslegend.h
branches/threading-branch/src/app/legend/qgslegendgroup.cpp
branches/threading-branch/src/app/legend/qgslegendgroup.h
branches/threading-branch/src/app/legend/qgslegendlayer.cpp
branches/threading-branch/src/app/legend/qgslegendlayer.h
branches/threading-branch/src/app/qgisapp.cpp
branches/threading-branch/src/gui/qgsmapcanvas.cpp
Fixed handling of layer/group visibility in legend
Modified: branches/threading-branch/src/app/legend/qgslegend.cpp
--- branches/threading-branch/src/app/legend/qgslegend.cpp 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegend.cpp 2010-06-24 11:27:54 UTC (rev 13796)
@@ -147,29 +147,18 @@
void QgsLegend::selectAll( bool select )
- if ( !mMapCanvas || mMapCanvas->isDrawing() )
- return;
- // Turn off rendering to improve speed.
- bool renderFlagState = mMapCanvas->renderFlag();
- mMapCanvas->setRenderFlag( false );
for ( QTreeWidgetItem* theItem = firstItem(); theItem; theItem = nextItem( theItem ) )
- QgsLegendItem* litem = dynamic_cast<QgsLegendItem *>( theItem );
- if ( litem && litem->type() == QgsLegendItem::LEGEND_LAYER )
+ QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( theItem );
+ if ( ll )
- theItem->setCheckState( 0, ( select ? Qt::Checked : Qt::Unchecked ) );
- handleItemChange( theItem, 0 );
+ ll->handleCheckStateChange( select ? Qt::Checked : Qt::Unchecked, true );
- // Turn on rendering (if it was on previously)
- mMapCanvas->setRenderFlag( renderFlagState );
QgsProject::instance()->dirty( true );
+ updateMapCanvasLayerSet();
void QgsLegend::removeGroup( int groupIndex )
@@ -1457,17 +1446,16 @@
-void QgsLegend::handleItemChange( QTreeWidgetItem* item, int row )
+void QgsLegend::handleItemChange( QTreeWidgetItem* item, int column )
if ( !item )
return;
- //if the text of a QgsLegendLayer has changed, change the display names of all its maplayers
- // TODO: is this still necessary?
+ // if the text of a QgsLegendLayer has changed, change the display names of its maplayer
QgsLegendLayer* theLegendLayer = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
- if ( theLegendLayer )
+ if ( theLegendLayer && theLegendLayer->layer()->name() != theLegendLayer->text( 0 ) )
theLegendLayer->layer()->setLayerName( theLegendLayer->text( 0 ) );
@@ -1476,66 +1464,22 @@
if ( item->data( 0, Qt::UserRole ).toInt() == item->checkState( 0 ) )
return;
- mMapCanvas->freeze( true );
+ mMapCanvas->cancelRendering();
QgsLegendGroup* lg = dynamic_cast<QgsLegendGroup *>( item ); //item is a legend group
if ( lg )
- //set all the child layer files to the new check state
- std::list<QgsLegendLayer*> subfiles = lg->legendLayers();
- for ( std::list<QgsLegendLayer*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
-#ifdef QGISDEBUG
- if ( item->checkState( 0 ) == Qt::Checked )
- QgsDebugMsg( "item checked" );
- else if ( item->checkState( 0 ) == Qt::Unchecked )
- QgsDebugMsg( "item unchecked" );
- else if ( item->checkState( 0 ) == Qt::PartiallyChecked )
- QgsDebugMsg( "item partially checked" );
-#endif
- blockSignals( true );
- ( *iter )->setCheckState( 0, item->checkState( 0 ) );
- blockSignals( false );
- item->setData( 0, Qt::UserRole, item->checkState( 0 ) );
- if (( *iter )->layer() )
- ( *iter )->setVisible( item->checkState( 0 ) == Qt::Checked );
+ // update the group + all its children layers
+ lg->handleCheckStateChange( item->checkState( 0 ) );
QgsLegendLayer* ll = dynamic_cast<QgsLegendLayer *>( item ); //item is a legend layer
if ( ll )
- ll->setCheckState( 0, item->checkState( 0 ) );
- ll->setData( 0, Qt::UserRole, ll->checkState( 0 ) );
- if ( ll->layer() )
- ll->setVisible( item->checkState( 0 ) == Qt::Checked );
- if ( ll->parent() )
- static_cast<QgsLegendGroup*>( ll->parent() )->updateCheckState();
- ll->parent()->setData( 0, Qt::UserRole, ll->parent()->checkState( 0 ) );
- //update check state of the legend group
+ // update the visibility + update parent's check state
+ ll->handleCheckStateChange( item->checkState( 0 ), true );
- mMapCanvas->freeze( false );
// update layer set
Modified: branches/threading-branch/src/app/legend/qgslegend.h
--- branches/threading-branch/src/app/legend/qgslegend.h 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegend.h 2010-06-24 11:27:54 UTC (rev 13796)
@@ -364,7 +364,7 @@
/**Sets all listview items to closed*/
void collapseAll();
/**Just for a test*/
- void handleItemChange( QTreeWidgetItem* item, int row );
+ void handleItemChange( QTreeWidgetItem* item, int column );
/** delegates current layer to map canvas */
void handleCurrentItemChanged( QTreeWidgetItem* current, QTreeWidgetItem* previous );
/**Calls openPersistentEditor for the current item*/
Modified: branches/threading-branch/src/app/legend/qgslegendgroup.cpp
--- branches/threading-branch/src/app/legend/qgslegendgroup.cpp 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegendgroup.cpp 2010-06-24 11:27:54 UTC (rev 13796)
@@ -145,5 +145,20 @@
treeWidget()->blockSignals( true );
setCheckState( 0, theState );
treeWidget()->blockSignals( false );
+ setData( 0, Qt::UserRole, theState );
+void QgsLegendGroup::handleCheckStateChange( Qt::CheckState state )
+ //set all the child layer files to the new check state
+ std::list<QgsLegendLayer*> subfiles = legendLayers();
+ for ( std::list<QgsLegendLayer*>::iterator iter = subfiles.begin(); iter != subfiles.end(); ++iter )
+ // update the children (but don't let them update the parent)
+ ( *iter )->handleCheckStateChange( state, false );
+ setData( 0, Qt::UserRole, state );
Modified: branches/threading-branch/src/app/legend/qgslegendgroup.h
--- branches/threading-branch/src/app/legend/qgslegendgroup.h 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegendgroup.h 2010-06-24 11:27:54 UTC (rev 13796)
@@ -45,6 +45,9 @@
std::list<QgsLegendLayer*> legendLayers();
/**Goes through all the legendlayers and sets check state to checked/partially checked/unchecked*/
void updateCheckState();
+ /** called when the legend group gets checked/unchecked to check/uncheck also its children */
+ void handleCheckStateChange( Qt::CheckState state );
#endif
Modified: branches/threading-branch/src/app/legend/qgslegendlayer.cpp
--- branches/threading-branch/src/app/legend/qgslegendlayer.cpp 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegendlayer.cpp 2010-06-24 11:27:54 UTC (rev 13796)
@@ -22,6 +22,7 @@
#include "qgisapp.h"
#include "qgslegend.h"
#include "qgslegendlayer.h"
+#include "qgslegendgroup.h"
#include "qgslegendsymbologyitem.h"
#include "qgslogger.h"
@@ -499,3 +500,21 @@
QString name = mLyr.layer()->name();
setText( 0, name );
+void QgsLegendLayer::handleCheckStateChange( Qt::CheckState state, bool updateParentGroup )
+ treeWidget()->blockSignals( true );
+ setCheckState( 0, state );
+ treeWidget()->blockSignals( false );
+ if ( layer() )
+ setVisible( state == Qt::Checked );
+ if ( updateParentGroup && parent() )
+ static_cast<QgsLegendGroup*>( parent() )->updateCheckState();
Modified: branches/threading-branch/src/app/legend/qgslegendlayer.h
--- branches/threading-branch/src/app/legend/qgslegendlayer.h 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/legend/qgslegendlayer.h 2010-06-24 11:27:54 UTC (rev 13796)
@@ -54,8 +54,6 @@
/**Returns the map layer associated the item*/
QgsMapLayer* layer();
QgsMapCanvasLayer& canvasLayer();
- /**Goes through all the legendlayerfiles and sets check state to checked/partially checked/unchecked*/
- //void updateCheckState();
/**Updates symbology of the layer and copies symbology to other layer files in the group*/
void refreshSymbology( const QString& key, double widthScale = 1.0 );
@@ -72,6 +70,9 @@
/**Determines whether there are layers in overview*/
bool isInOverview();
+ /** called when the legend layer gets checked/unchecked */
+ void handleCheckStateChange( Qt::CheckState state, bool updateParentGroup );
/**Returns a label for a layer. Is static such that
the name can be passed to the constructor of QgsLegendLayer*/
static QString nameFromLayer( QgsMapLayer* layer );
Modified: branches/threading-branch/src/app/qgisapp.cpp
--- branches/threading-branch/src/app/qgisapp.cpp 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/app/qgisapp.cpp 2010-06-24 11:27:54 UTC (rev 13796)
@@ -3507,11 +3507,11 @@
// showMaxmized() is a work-around. Turn off rendering for this as it
// would otherwise cause two re-renders of the map, which can take a
// long time.
- bool renderFlag = mapCanvas()->renderFlag();
- mapCanvas()->setRenderFlag( false );
+ mapCanvas()->freeze();
showNormal();
showMaximized();
- mapCanvas()->setRenderFlag( renderFlag );
+ mapCanvas()->freeze(false);
+ mapCanvas()->refresh();
mPrevScreenModeMaximized = false;
else
Modified: branches/threading-branch/src/gui/qgsmapcanvas.cpp
--- branches/threading-branch/src/gui/qgsmapcanvas.cpp 2010-06-24 10:21:11 UTC (rev 13795)
+++ branches/threading-branch/src/gui/qgsmapcanvas.cpp 2010-06-24 11:27:54 UTC (rev 13796)
@@ -227,11 +227,8 @@
void QgsMapCanvas::setLayerSet( QList<QgsMapCanvasLayer> &layers )
- if ( isDrawing() )
- QgsDebugMsg("ignored - drawing!" );
- return;
+ // make sure we're not rendering
+ cancelRendering();
// create layer set
QStringList layerSet, layerSetOverview;
@@ -363,7 +360,10 @@
void QgsMapCanvas::refresh()
if ( !mRenderFlag || mFrozen )
+ QgsDebugMsg("REFRESH ignored: canvas frozen");
return;
cancelRendering();
