[QGIS Commit] r13830 - trunk/qgis/python/plugins/plugin_installer
svn_qgis at osgeo.org
Mon Jun 28 15:18:40 EDT 2010
Author: borysiasty
Date: 2010-06-28 19:18:40 +0000 (Mon, 28 Jun 2010)
New Revision: 13830
trunk/qgis/python/plugins/plugin_installer/__init__.py
trunk/qgis/python/plugins/plugin_installer/installer_data.py
trunk/qgis/python/plugins/plugin_installer/installer_gui.py
trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
trunk/qgis/python/plugins/plugin_installer/qgsplugininstalleroldreposbase.ui
Plugin installer fixes: fix error when uninstalling installer itself, support for <disabled> repo tag, remove my repository
Modified: trunk/qgis/python/plugins/plugin_installer/__init__.py
--- trunk/qgis/python/plugins/plugin_installer/__init__.py 2010-06-28 18:44:01 UTC (rev 13829)
+++ trunk/qgis/python/plugins/plugin_installer/__init__.py 2010-06-28 19:18:40 UTC (rev 13830)
@@ -1,7 +1,7 @@
# -*- coding: utf-8 -*-
Copyright (C) 2007-2008 Matthew Perry
-Copyright (C) 2008-2009 Borys Jurgiel
+Copyright (C) 2008-2010 Borys Jurgiel
* This program is free software; you can redistribute it and/or modify *
@@ -15,7 +15,7 @@
return "Plugin Installer"
def version():
- return "Version 1.0.11"
+ return "Version 1.0.12"
def description():
return "Downloads and installs QGIS python plugins"
Modified: trunk/qgis/python/plugins/plugin_installer/installer_data.py
--- trunk/qgis/python/plugins/plugin_installer/installer_data.py 2010-06-28 18:44:01 UTC (rev 13829)
+++ trunk/qgis/python/plugins/plugin_installer/installer_data.py 2010-06-28 19:18:40 UTC (rev 13830)
@@ -1,7 +1,7 @@
@@ -83,7 +83,7 @@
officialRepo = ("QGIS Official Repository", "http://pyqgis.org/repo/official","")
contribRepo = ("QGIS Contributed Repository", "http://pyqgis.org/repo/contributed","")
authorRepos = [("Carson Farmer's Repository", "http://www.ftools.ca/cfarmerQgisRepo.xml", "http://www.ftools.ca/cfarmerQgisRepo_0.xx.xml"),
- ("Borys Jurgiel's Repository", "http://bwj.aster.net.pl/qgis/plugins.xml", "http://bwj.aster.net.pl/qgis-oldapi/plugins.xml"),
+ # depreciated: ("Borys Jurgiel's Repository", "http://bwj.aster.net.pl/qgis/plugins.xml", "http://bwj.aster.net.pl/qgis-oldapi/plugins.xml"),
("Faunalia Repository", "http://www.faunalia.it/qgis/plugins.xml", "http://faunalia.it/qgis/plugins.xml"),
("Martin Dobias' Sandbox", "http://mapserver.sk/~wonder/qgis/plugins-sandbox.xml", ""),
("Aaron Racicot's Repository", "http://qgisplugins.z-pulley.com", ""),
@@ -456,7 +456,8 @@
qgisMaximumVersion = pluginNodes.item(i).firstChildElement("qgis_maximum_version").text().simplified()
if not qgisMaximumVersion: qgisMaximumVersion = "2"
#if compatible, add the plugin to the list
- if compareVersions(QGIS_VER, qgisMinimumVersion) < 2 and compareVersions(qgisMaximumVersion, QGIS_VER) < 2:
+ if not pluginNodes.item(i).firstChildElement("disabled").text().simplified().toUpper() in ["TRUE","YES"]:
+ if compareVersions(QGIS_VER, qgisMinimumVersion) < 2 and compareVersions(qgisMaximumVersion, QGIS_VER) < 2:
if QGIS_VER[0]==qgisMinimumVersion[0] or name=="plugin_installer" or (qgisMinimumVersion!="0" and qgisMaximumVersion!="2"):
#add the plugin to the cache
plugins.addFromRepository(plugin)
Modified: trunk/qgis/python/plugins/plugin_installer/installer_gui.py
--- trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2010-06-28 18:44:01 UTC (rev 13829)
+++ trunk/qgis/python/plugins/plugin_installer/installer_gui.py 2010-06-28 19:18:40 UTC (rev 13830)
@@ -1,7 +1,7 @@
@@ -27,7 +27,7 @@
try:
from qgis.utils import startPlugin, unloadPlugin, loadPlugin # QGIS >= 1.4
- from qgis.utils import updateAvailablePlugins # QGIS >= 1.5
+ from qgis.utils import reloadPlugin, updateAvailablePlugins # QGIS >= 1.5
except Exception:
pass
@@ -676,11 +676,24 @@
warning += "\n\n"+self.tr("Warning: this plugin isn't available in any accessible repository!")
if QMessageBox.warning(self, self.tr("QGIS Python Plugin Installer"), warning , QMessageBox.Yes, QMessageBox.No) == QMessageBox.No:
return
+ # unload the plugin if it's not plugin_installer itself (otherwise, do it after removing its directory):
+ if key != "plugin_installer":
+ try:
+ unloadPlugin(key)
+ except:
+ pass
pluginDir = QFileInfo(QgsApplication.qgisUserDbFilePath()).path() + "/python/plugins/" + plugin["localdir"]
result = removeDir(pluginDir)
if result:
QMessageBox.warning(self, self.tr("Plugin uninstall failed"), result)
else:
+ # if the uninstalled plugin is the installer itself, reload it and quit
+ if key == "plugin_installer":
+ try:
+ reloadPlugin(key)
+ return
+ except:
+ pass
# safe remove
try:
unloadPlugin(plugin["localdir"])
Modified: trunk/qgis/python/plugins/plugin_installer/installer_plugin.py
--- trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2010-06-28 18:44:01 UTC (rev 13829)
+++ trunk/qgis/python/plugins/plugin_installer/installer_plugin.py 2010-06-28 19:18:40 UTC (rev 13830)
@@ -1,7 +1,7 @@
@@ -128,6 +128,7 @@
self.mainWindow().menuBar().actions()[4].menu().removeAction(self.action)
if self.statusLabel:
self.mainWindow().statusBar().removeWidget(self.statusLabel)
+ self.guiDlg.close()
Modified: trunk/qgis/python/plugins/plugin_installer/qgsplugininstalleroldreposbase.ui
--- trunk/qgis/python/plugins/plugin_installer/qgsplugininstalleroldreposbase.ui 2010-06-28 18:44:01 UTC (rev 13829)
+++ trunk/qgis/python/plugins/plugin_installer/qgsplugininstalleroldreposbase.ui 2010-06-28 19:18:40 UTC (rev 13830)
@@ -14,7 +14,7 @@
<property name="minimumSize">
<size>
<width>480</width>
- <height>150</height>
+ <height>182</height>
</size>
</property>
<property name="windowTitle">
