[QGIS Commit] r13843 - branches/threading-branch/src/core
svn_qgis at osgeo.org
Tue Jun 29 10:26:33 EDT 2010
Author: wonder
Date: 2010-06-29 14:26:33 +0000 (Tue, 29 Jun 2010)
New Revision: 13843
branches/threading-branch/src/core/qgsmaprenderer.cpp
branches/threading-branch/src/core/qgsmaprenderer.h
Map renderer now can be altered while it is still drawing.
There are two sets of parameters: "next" used for following rendering operations, "curr" for active rendering operation.
All changes are done only within "next" parameters, when starting rendering, "next" is copied to "curr", so that rendering can safely use the parameters
even if they get changed in meanwhile.
Modified: branches/threading-branch/src/core/qgsmaprenderer.cpp
--- branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-29 14:04:34 UTC (rev 13842)
+++ branches/threading-branch/src/core/qgsmaprenderer.cpp 2010-06-29 14:26:33 UTC (rev 13843)
@@ -51,27 +51,21 @@
mDistArea = new QgsDistanceArea;
mDrawing = false;
- mOverview = false;
mThreadingEnabled = false;
mCache = NULL;
- mDpi = 96;
+ next.overview = false;
+ next.dpi = 96;
+ next.size = QSize( 0, 0 );
+ next.projectionsEnabled = false;
+ next.destCRS = QgsCoordinateReferenceSystem( GEOCRS_ID, QgsCoordinateReferenceSystem::InternalCrsId ); //WGS 84
+ next.outputUnits = QgsMapRenderer::Millimeters;
+ next.labelingEngine = NULL;
// set default map units - we use WGS 84 thus use degrees
setMapUnits( QGis::Degrees );
- mSize = QSize( 0, 0 );
- mProjectionsEnabled = false;
- mDestCRS = new QgsCoordinateReferenceSystem( GEOCRS_ID, QgsCoordinateReferenceSystem::InternalCrsId ); //WGS 84
- mOutputUnits = QgsMapRenderer::Millimeters;
- mLabelingEngine = NULL;
connect(QgsMapLayerRegistry::instance(), SIGNAL(layerWillBeRemoved(QString)), this, SLOT(handleLayerRemoval(QString)));
- //connect(&mFW, SIGNAL(finished()), SLOT(futureFinished()));
QgsMapRenderer::~QgsMapRenderer()
@@ -83,31 +77,24 @@
delete mDistArea;
- delete mDestCRS;
- delete mLabelingEngine;
+ delete next.labelingEngine;
delete mCache;
QgsRectangle QgsMapRenderer::extent() const
- return mExtent;
+ return next.extent;
void QgsMapRenderer::updateScale()
- QgsScaleCalculator calc(mDpi, mMapUnits);
- mScale = calc.calculate( mExtent, mSize.width() );
+ QgsScaleCalculator calc(next.dpi, next.mapUnits);
+ next.scale = calc.calculate( next.extent, next.size.width() );
bool QgsMapRenderer::setExtent( const QgsRectangle& extent )
- if ( mDrawing )
- QgsDebugMsg("Ignored --- drawing now!");
- return false; // do not allow changes while rendering
// Don't allow zooms where the current extent is so small that it
// can't be accurately represented using a double (which is what
// currentExtent uses). Excluding 0 avoids a divide by zero and an
@@ -137,7 +124,7 @@
return false;
- mExtent = extent;
+ next.extent = extent;
if ( !extent.isEmpty() )
adjustExtentToSize();
return true;
@@ -147,86 +134,80 @@
void QgsMapRenderer::setOutputSize( QSize size, int dpi )
- if ( mDrawing )
- return; // do not allow changes while rendering
- mSize = size;
- mDpi = dpi;
+ next.size = size;
+ next.dpi = dpi;
int QgsMapRenderer::outputDpi()
- return mDpi;
+ return next.dpi;
QSize QgsMapRenderer::outputSize()
- return mSize;
+ return next.size;
void QgsMapRenderer::adjustExtentToSize()
- int myHeight = mSize.height();
- int myWidth = mSize.width();
+ int myHeight = next.size.height();
+ int myWidth = next.size.width();
QgsMapToPixel newCoordXForm;
if ( !myWidth || !myHeight )
- mScale = 1;
+ next.scale = 1;
newCoordXForm.setParameters( 0, 0, 0, 0 );
return;
// calculate the translation and scaling parameters
// mapUnitsPerPixel = map units per pixel
- double mapUnitsPerPixelY = static_cast<double>( mExtent.height() )
+ double mapUnitsPerPixelY = static_cast<double>( next.extent.height() )
/ static_cast<double>( myHeight );
- double mapUnitsPerPixelX = static_cast<double>( mExtent.width() )
+ double mapUnitsPerPixelX = static_cast<double>( next.extent.width() )
/ static_cast<double>( myWidth );
- mMapUnitsPerPixel = mapUnitsPerPixelY > mapUnitsPerPixelX ? mapUnitsPerPixelY : mapUnitsPerPixelX;
+ next.mapUnitsPerPixel = mapUnitsPerPixelY > mapUnitsPerPixelX ? mapUnitsPerPixelY : mapUnitsPerPixelX;
// calculate the actual extent of the mapCanvas
double dxmin, dxmax, dymin, dymax, whitespace;
if ( mapUnitsPerPixelY > mapUnitsPerPixelX )
- dymin = mExtent.yMinimum();
- dymax = mExtent.yMaximum();
- whitespace = (( myWidth * mMapUnitsPerPixel ) - mExtent.width() ) * 0.5;
- dxmin = mExtent.xMinimum() - whitespace;
- dxmax = mExtent.xMaximum() + whitespace;
+ dymin = next.extent.yMinimum();
+ dymax = next.extent.yMaximum();
+ whitespace = (( myWidth * next.mapUnitsPerPixel ) - next.extent.width() ) * 0.5;
+ dxmin = next.extent.xMinimum() - whitespace;
+ dxmax = next.extent.xMaximum() + whitespace;
else
- dxmin = mExtent.xMinimum();
- dxmax = mExtent.xMaximum();
- whitespace = (( myHeight * mMapUnitsPerPixel ) - mExtent.height() ) * 0.5;
- dymin = mExtent.yMinimum() - whitespace;
- dymax = mExtent.yMaximum() + whitespace;
+ dxmin = next.extent.xMinimum();
+ dxmax = next.extent.xMaximum();
+ whitespace = (( myHeight * next.mapUnitsPerPixel ) - next.extent.height() ) * 0.5;
+ dymin = next.extent.yMinimum() - whitespace;
+ dymax = next.extent.yMaximum() + whitespace;
QgsDebugMsg( QString( "Map units per pixel (x,y) : %1, %2" ).arg( mapUnitsPerPixelX ).arg( mapUnitsPerPixelY ) );
QgsDebugMsg( QString( "Pixmap dimensions (x,y) : %1, %2" ).arg( myWidth ).arg( myHeight ) );
- QgsDebugMsg( QString( "Extent dimensions (x,y) : %1, %2" ).arg( mExtent.width() ).arg( mExtent.height() ) );
- QgsDebugMsg( mExtent.toString() );
+ QgsDebugMsg( QString( "Extent dimensions (x,y) : %1, %2" ).arg( next.extent.width() ).arg( next.extent.height() ) );
+ QgsDebugMsg( next.extent.toString() );
// update extent
- mExtent.setXMinimum( dxmin );
- mExtent.setXMaximum( dxmax );
- mExtent.setYMinimum( dymin );
- mExtent.setYMaximum( dymax );
+ next.extent.setXMinimum( dxmin );
+ next.extent.setXMaximum( dxmax );
+ next.extent.setYMinimum( dymin );
+ next.extent.setYMaximum( dymax );
// update the scale
updateScale();
- QgsDebugMsg( QString( "Scale (assuming meters as map units) = 1:%1" ).arg( mScale ) );
+ QgsDebugMsg( QString( "Scale (assuming meters as map units) = 1:%1" ).arg( next.scale ) );
- newCoordXForm.setParameters( mMapUnitsPerPixel, dxmin, dymin, myHeight );
+ newCoordXForm.setParameters( next.mapUnitsPerPixel, dxmin, dymin, myHeight );
mRenderContext.setMapToPixel( newCoordXForm );
- mRenderContext.setExtent( mExtent );
+ mRenderContext.setExtent( next.extent );
@@ -234,6 +215,9 @@
mDrawing = true;
+ // copy the parameters for the current rendering
+ curr = next;
QgsDebugMsg( "========== Rendering ==========" );
QgsDebugMsg( "caching enabled? " + QString::number(mCache != NULL) );
@@ -242,7 +226,7 @@
mRenderTime.start();
#endif
- mRenderContext.setDrawEditingInformation( !mOverview );
+ mRenderContext.setDrawEditingInformation( !curr.overview );
mRenderContext.setPainter( painter );
mRenderContext.setCoordinateTransform( 0 );
//this flag is only for stopping during the current rendering progress,
@@ -252,9 +236,9 @@
//calculate scale factor
//use the specified dpi and not those from the paint device
//because sometimes QPainter units are in a local coord sys (e.g. in case of QGraphicsScene)
- double sceneDpi = mDpi;
+ double sceneDpi = curr.dpi;
double scaleFactor = 1.0;
- if ( mOutputUnits == QgsMapRenderer::Millimeters )
+ if ( curr.outputUnits == QgsMapRenderer::Millimeters )
scaleFactor = sceneDpi / 25.4;
@@ -263,17 +247,17 @@
// initialize render context scaling
mRenderContext.setRasterScaleFactor( rasterScaleFactor );
mRenderContext.setScaleFactor( scaleFactor );
- mRenderContext.setRendererScale( mScale );
+ mRenderContext.setRendererScale( curr.scale );
- mRenderContext.setLabelingEngine( mLabelingEngine );
- if ( mLabelingEngine )
- mLabelingEngine->init( this );
+ mRenderContext.setLabelingEngine( curr.labelingEngine );
+ if ( curr.labelingEngine )
+ curr.labelingEngine->init( this );
if (mCache)
// initialize cache: if the parameters are not the same as the last time,
// the cached images are removed
- mCache->init(mExtent, mScale, scaleFactor, rasterScaleFactor);
+ mCache->init(curr.extent, curr.scale, scaleFactor, rasterScaleFactor);
mOverlayManager = overlayManagerFromSettings();
@@ -282,7 +266,7 @@
void QgsMapRenderer::finishRendering()
// render labels for vector layers (not using PAL)
- if ( !mOverview )
+ if ( !curr.overview )
renderLabels();
@@ -290,7 +274,7 @@
//find overlay positions and draw the vector overlays
if ( mOverlayManager )
- mOverlayManager->drawOverlays( mRenderContext, mMapUnits );
+ mOverlayManager->drawOverlays( mRenderContext, curr.mapUnits );
delete mOverlayManager;
mOverlayManager = NULL;
@@ -298,14 +282,14 @@
// make sure progress bar arrives at 100%!
emit drawingProgress( 1, 1 );
// set correct extent
+ mRenderContext.setExtent( curr.extent );
mRenderContext.setCoordinateTransform( NULL );
- mLabelingEngine->drawLabeling( mRenderContext );
- mLabelingEngine->exit();
+ curr.labelingEngine->drawLabeling( mRenderContext );
+ curr.labelingEngine->exit();
QgsDebugMsg( "Rendering completed in (seconds): " + QString( "%1" ).arg( mRenderTime.elapsed() / 1000.0 ) );
@@ -321,7 +305,7 @@
return;
- if ( mExtent.isEmpty() )
+ if ( next.extent.isEmpty() )
QgsDebugMsg( "empty extent... not rendering" );
return;
@@ -351,7 +335,7 @@
mThreadedJobs.clear();
// render all layers in the stack, starting at the base
- QListIterator<QString> li( mLayerSet );
+ QListIterator<QString> li( curr.layerSet );
li.toBack();
while ( li.hasPrevious() )
@@ -378,7 +362,7 @@
//QgsDebugMsg( " Scale dep. visibility enabled? " + QString( "%1" ).arg( ml->hasScaleBasedVisibility() ) );
//QgsDebugMsg( " Input extent: " + ml->extent().toString() );
- if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > mScale || ml->maximumScale() < mScale ) && ! mOverview )
+ if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > curr.scale || ml->maximumScale() < curr.scale ) && ! curr.overview )
QgsDebugMsg( "Layer not rendered because it is not within the defined "
"visibility scale range" );
@@ -388,7 +372,7 @@
QgsCoordinateTransform* ct = NULL;
if ( hasCrsTransformEnabled() )
- ct = new QgsCoordinateTransform( ml->srs(), *mDestCRS );
+ ct = new QgsCoordinateTransform( ml->srs(), curr.destCRS );
mRenderContext.setCoordinateTransform( ct );
@@ -447,7 +431,7 @@
QImage QgsMapRenderer::threadedRenderingOutput()
- QImage i( mSize, QImage::Format_ARGB32_Premultiplied );
+ QImage i( curr.size, QImage::Format_ARGB32_Premultiplied );
i.fill(0);
QPainter p;
p.begin(&i);
@@ -509,7 +493,7 @@
return;
@@ -592,7 +576,7 @@
else
// create image
- tctx.img = new QImage( mSize, QImage::Format_ARGB32_Premultiplied );
+ tctx.img = new QImage( curr.size, QImage::Format_ARGB32_Premultiplied );
tctx.img->fill( 0 );
tctx.cached = false;
@@ -602,7 +586,7 @@
tctx.ctx = mRenderContext;
QPainter* painter = new QPainter(tctx.img);
- painter->setRenderHint( QPainter::Antialiasing, mAntialiasingEnabled );
+ painter->setRenderHint( QPainter::Antialiasing, curr.antialiasingEnabled );
tctx.ctx.setPainter( painter );
// schedule DRAW to a list
@@ -630,7 +614,7 @@
// alter painter
QPainter * mypPainter = new QPainter( &cacheImage );
- mypPainter->setRenderHint( QPainter::Antialiasing, mAntialiasingEnabled );
+ mypPainter->setRenderHint( QPainter::Antialiasing, curr.antialiasingEnabled );
mRenderContext.setPainter( mypPainter );
// DRAW!
@@ -677,7 +661,7 @@
bk_mapToPixel = ctx.mapToPixel();
rasterMapToPixel = ctx.mapToPixel();
rasterMapToPixel.setMapUnitsPerPixel( ctx.mapToPixel().mapUnitsPerPixel() / rasterScaleFactor );
- rasterMapToPixel.setYMaximum( mSize.height() * rasterScaleFactor );
+ rasterMapToPixel.setYMaximum( curr.size.height() * rasterScaleFactor );
ctx.setMapToPixel( rasterMapToPixel );
ctx.painter()->save();
ctx.painter()->scale( 1.0 / rasterScaleFactor, 1.0 / rasterScaleFactor );
@@ -688,7 +672,7 @@
QgsRectangle r1, r2;
if ( ctx.coordinateTransform() )
- r1 = mExtent;
+ r1 = curr.extent;
split = splitLayersExtent( ml, r1, r2 );
ctx.setExtent( r1 );
@@ -706,7 +690,7 @@
return false;
- ctx.setExtent( mExtent ); // return back to the original extent
+ ctx.setExtent( curr.extent ); // return back to the original extent
if ( scaleRaster )
@@ -721,7 +705,7 @@
void QgsMapRenderer::renderLabels()
QgsCoordinateTransform* ct;
@@ -744,16 +728,16 @@
// only make labels if the layer is visible
// after scale dep viewing settings are checked
- if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > mScale || mScale > ml->maximumScale() ) )
+ if ( ml->hasScaleBasedVisibility() && ( ml->minimumScale() > curr.scale || curr.scale > ml->maximumScale() ) )
continue;
bool split = false;
- r1 = mExtent;
+ r1 = curr.extent;
mRenderContext.setExtent( r1 );
else
@@ -777,14 +761,8 @@
void QgsMapRenderer::setMapUnits( QGis::UnitType u )
- if ( mDrawing )
+ next.mapUnits = u;
- mMapUnits = u;
// Since the map units have changed, force a recalculation of the scale.
updateScale();
@@ -793,7 +771,7 @@
QGis::UnitType QgsMapRenderer::mapUnits() const
- return mMapUnits;
+ return next.mapUnits;
void QgsMapRenderer::onDrawingProgress( int current, int total )
@@ -807,43 +785,29 @@
void QgsMapRenderer::setProjectionsEnabled( bool enabled )
- if ( mDrawing )
+ if ( next.projectionsEnabled != enabled )
- if ( mProjectionsEnabled != enabled )
- mProjectionsEnabled = enabled;
+ next.projectionsEnabled = enabled;
QgsDebugMsg( "Adjusting DistArea projection on/off" );
mDistArea->setProjectionsEnabled( enabled );
- updateFullExtent();
emit hasCrsTransformEnabled( enabled );
bool QgsMapRenderer::hasCrsTransformEnabled()
- return mProjectionsEnabled;
+ return next.projectionsEnabled;
void QgsMapRenderer::setDestinationSrs( const QgsCoordinateReferenceSystem& srs )
- if ( mDrawing )
QgsDebugMsg( "* Setting destCRS : = " + srs.toProj4() );
QgsDebugMsg( "* DestCRS.srsid() = " + QString::number( srs.srsid() ) );
- if ( *mDestCRS != srs )
+ if ( next.destCRS != srs )
QgsDebugMsg( "Setting DistArea CRS to " + QString::number( srs.srsid() ) );
mDistArea->setSourceCrs( srs.srsid() );
- *mDestCRS = srs;
+ next.destCRS = srs;
emit destinationSrsChanged();
@@ -851,21 +815,23 @@
const QgsCoordinateReferenceSystem& QgsMapRenderer::destinationSrs()
QgsDebugMsgLevel( "* Returning destCRS", 3 );
- QgsDebugMsgLevel( "* DestCRS.srsid() = " + QString::number( mDestCRS->srsid() ), 3 );
- QgsDebugMsgLevel( "* DestCRS.proj4() = " + mDestCRS->toProj4(), 3 );
- return *mDestCRS;
+ QgsDebugMsgLevel( "* DestCRS.srsid() = " + QString::number( next.destCRS.srsid() ), 3 );
+ QgsDebugMsgLevel( "* DestCRS.proj4() = " + next.destCRS.toProj4(), 3 );
+ return next.destCRS;
bool QgsMapRenderer::splitLayersExtent( QgsMapLayer* layer, QgsRectangle& extent, QgsRectangle& r2 )
+ // this method operates on "current" parameters - called only from rendering routines
bool split = false;
try
- QgsCoordinateTransform tr( layer->srs(), *mDestCRS );
+ QgsCoordinateTransform tr( layer->srs(), curr.destCRS );
#ifdef QGISDEBUG
// QgsLogger::debug<QgsRectangle>("Getting extent of canvas in layers CS. Canvas is ", extent, __FILE__, __FUNCTION__, __LINE__);
@@ -921,7 +887,7 @@
try
- QgsCoordinateTransform tr( theLayer->srs(), *mDestCRS );
+ QgsCoordinateTransform tr( theLayer->srs(), next.destCRS );
extent = tr.transformBoundingBox( extent );
catch ( QgsCsException &cse )
@@ -944,7 +910,7 @@
try
point = tr.transform( point, QgsCoordinateTransform::ForwardTransform );
@@ -966,7 +932,7 @@
try
point = tr.transform( point, QgsCoordinateTransform::ReverseTransform );
@@ -988,7 +954,7 @@
try
rect = tr.transform( rect, QgsCoordinateTransform::ReverseTransform );
@@ -1003,17 +969,24 @@
void QgsMapRenderer::updateFullExtent()
+ // legacy
+QgsRectangle QgsMapRenderer::fullExtent()
QgsDebugMsg( "called." );
QgsMapLayerRegistry* registry = QgsMapLayerRegistry::instance();
+ QgsRectangle fullExtent;
// reset the map canvas extent since the extent may now be smaller
// We can't use a constructor since QgsRectangle normalizes the rectangle upon construction
- mFullExtent.setMinimal();
+ fullExtent.setMinimal();
// iterate through the map layers and test each layers extent
// against the current min and max values
- QStringList::iterator it = mLayerSet.begin();
- while ( it != mLayerSet.end() )
+ QStringList::iterator it = next.layerSet.begin();
+ while ( it != next.layerSet.end() )
QgsMapLayer * lyr = registry->mapLayer( *it );
if ( lyr == NULL )
@@ -1030,55 +1003,44 @@
QgsRectangle extent = layerExtentToOutputExtent( lyr, lyr->extent() );
QgsDebugMsg( "Output extent: " + extent.toString() );
- mFullExtent.unionRect( extent );
+ fullExtent.unionRect( extent );
it++;
- if ( mFullExtent.width() == 0.0 || mFullExtent.height() == 0.0 )
+ if ( fullExtent.width() == 0.0 || fullExtent.height() == 0.0 )
// If all of the features are at the one point, buffer the
// rectangle a bit. If they are all at zero, do something a bit
// more crude.
- if ( mFullExtent.xMinimum() == 0.0 && mFullExtent.xMaximum() == 0.0 &&
- mFullExtent.yMinimum() == 0.0 && mFullExtent.yMaximum() == 0.0 )
+ if ( fullExtent.xMinimum() == 0.0 && fullExtent.xMaximum() == 0.0 &&
+ fullExtent.yMinimum() == 0.0 && fullExtent.yMaximum() == 0.0 )
- mFullExtent.set( -1.0, -1.0, 1.0, 1.0 );
+ fullExtent.set( -1.0, -1.0, 1.0, 1.0 );
else
const double padFactor = 1e-8;
- double widthPad = mFullExtent.xMinimum() * padFactor;
- double heightPad = mFullExtent.yMinimum() * padFactor;
- double xmin = mFullExtent.xMinimum() - widthPad;
- double xmax = mFullExtent.xMaximum() + widthPad;
- double ymin = mFullExtent.yMinimum() - heightPad;
- double ymax = mFullExtent.yMaximum() + heightPad;
- mFullExtent.set( xmin, ymin, xmax, ymax );
+ double widthPad = fullExtent.xMinimum() * padFactor;
+ double heightPad = fullExtent.yMinimum() * padFactor;
+ double xmin = fullExtent.xMinimum() - widthPad;
+ double xmax = fullExtent.xMaximum() + widthPad;
+ double ymin = fullExtent.yMinimum() - heightPad;
+ double ymax = fullExtent.yMaximum() + heightPad;
+ fullExtent.set( xmin, ymin, xmax, ymax );
- QgsDebugMsg( "Full extent: " + mFullExtent.toString() );
+ QgsDebugMsg( "Full extent: " + fullExtent.toString() );
+ return fullExtent;
-QgsRectangle QgsMapRenderer::fullExtent()
- return mFullExtent;
void QgsMapRenderer::setLayerSet( const QStringList& layers )
- if ( mDrawing )
+ foreach (QString layerId, next.layerSet)
- foreach (QString layerId, mLayerSet)
QgsMapLayer* ml = QgsMapLayerRegistry::instance()->mapLayer(layerId);
if (ml)
@@ -1088,9 +1050,9 @@
- mLayerSet = layers;
+ next.layerSet = layers;
if (ml)
@@ -1101,12 +1063,11 @@
QStringList& QgsMapRenderer::layerSet()
- return mLayerSet;
+ return next.layerSet;
void QgsMapRenderer::clearLayerCache()
@@ -1315,55 +1276,31 @@
+ if ( next.labelingEngine )
- mLabelingEngine = iface;
+ next.labelingEngine = iface;
void QgsMapRenderer::setScale( double scale )
- if ( mDrawing )
- mScale = scale;
+ next.scale = scale;
void QgsMapRenderer::enableOverviewMode( bool isOverview )
- if ( mDrawing )
- mOverview = isOverview;
+ next.overview = isOverview;
void QgsMapRenderer::setOutputUnits( OutputUnits u )
- if ( mDrawing )
- mOutputUnits = u;
+ next.outputUnits = u;
void QgsMapRenderer::setThreadingEnabled( bool use )
- if ( mDrawing )
- mThreadingEnabled = use;
+ // currently does nothing
void QgsMapRenderer::setCachingEnabled( bool enabled )
@@ -1388,15 +1325,44 @@
void QgsMapRenderer::setAntialiasingEnabled( bool enabled )
- if ( mDrawing )
+ next.antialiasingEnabled = enabled;
- mAntialiasingEnabled = enabled;
+double QgsMapRenderer::scale() const
+ return next.scale;
+double QgsMapRenderer::mapUnitsPerPixel() const
+ return next.mapUnitsPerPixel;
+int QgsMapRenderer::width() const
+ return next.size.width();
+int QgsMapRenderer::height() const
+ return next.size.height();
+QgsMapRenderer::OutputUnits QgsMapRenderer::outputUnits() const
+ return next.outputUnits;
+QgsLabelingEngineInterface* QgsMapRenderer::labelingEngine()
+ return next.labelingEngine;
+bool QgsMapRenderer::isAntialiasingEnabled() const
+ return next.antialiasingEnabled;
void QgsMapRenderer::clearCache()
if ( mDrawing )
@@ -1414,7 +1380,7 @@
void QgsMapRenderer::handleLayerRemoval(QString layerId)
- if (mLayerSet.contains(layerId))
+ if (next.layerSet.contains(layerId))
// make sure that the layer won't be used in further rendering
if (isDrawing())
Modified: branches/threading-branch/src/core/qgsmaprenderer.h
--- branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-29 14:04:34 UTC (rev 13842)
+++ branches/threading-branch/src/core/qgsmaprenderer.h 2010-06-29 14:26:33 UTC (rev 13843)
@@ -27,6 +27,7 @@
#include "qgis.h"
#include "qgsrectangle.h"
#include "qgsrendercontext.h"
+#include "qgscoordinatereferencesystem.h"
class QDomDocument;
class QDomNode;
@@ -35,7 +36,6 @@
class QgsMapToPixel;
class QgsMapLayer;
class QgsMapRenderer;
-class QgsCoordinateReferenceSystem;
class QgsDistanceArea;
class QgsOverlayObjectPositionManager;
class QgsVectorLayer;
@@ -142,14 +142,14 @@
const QgsMapToPixel* coordinateTransform() { return &( mRenderContext.mapToPixel() ); }
- double scale() const { return mScale; }
+ double scale() const;
/**Sets scale for scale based visibility. Normally, the scale is calculated automatically. This
function is only used to force a preview scale (e.g. for print composer)*/
void setScale( double scale );
- double mapUnitsPerPixel() const { return mMapUnitsPerPixel; }
+ double mapUnitsPerPixel() const;
- int width() const { return mSize.width(); };
- int height() const { return mSize.height(); };
+ int width() const;
+ int height() const;
//! Recalculate the map scale
void updateScale();
@@ -195,7 +195,7 @@
void setOutputUnits( OutputUnits u );
- OutputUnits outputUnits() const {return mOutputUnits;}
+ OutputUnits outputUnits() const;
//! returns current extent of layer set
QgsRectangle fullExtent();
@@ -206,7 +206,7 @@
//! change current layer set
void setLayerSet( const QStringList& layers );
- //! updates extent of the layer set
+ //! @deprecated does nothing. Just use fullExtent()
void updateFullExtent();
//! read settings
@@ -220,7 +220,7 @@
//! Labeling engine (NULL if there's no custom engine)
//! \note Added in QGIS v1.4
- QgsLabelingEngineInterface* labelingEngine() { return mLabelingEngine; }
+ QgsLabelingEngineInterface* labelingEngine();
//! Set labeling engine. Previous engine (if any) is deleted.
//! Takes ownership of the engine.
@@ -247,7 +247,7 @@
void setAntialiasingEnabled( bool enabled );
//! Added in QGIS v1.6
- bool isAntialiasingEnabled() const { return mAntialiasingEnabled; }
+ bool isAntialiasingEnabled() const;
//! Schedule a redraw of the layers.
//! This function returns immediately after starting the asynchronous rendering process.
@@ -352,57 +352,65 @@
protected:
- //! indicates drawing in progress
- bool mDrawing;
+ typedef struct
+ //! map units per pixel
+ double mapUnitsPerPixel;
- //! map units per pixel
- double mMapUnitsPerPixel;
+ //! Map scale at its current zool level
+ double scale;
- //! Map scale at its current zool level
- double mScale;
+ //! Scene DPI
+ double dpi;
- //! Scene DPI
- double mDpi;
+ //! map unit type
+ QGis::UnitType mapUnits;
- //! map unit type
- QGis::UnitType mMapUnits;
+ //! current extent to be drawn
+ QgsRectangle extent;
- //! current extent to be drawn
- QgsRectangle mExtent;
+ //! indicates whether it's map image for overview
+ bool overview;
- //! indicates whether it's map image for overview
- bool mOverview;
+ QSize size;
- QSize mSize;
+ //! detemines whether on the fly projection support is enabled
+ bool projectionsEnabled;
- //! detemines whether on the fly projection support is enabled
- bool mProjectionsEnabled;
+ //! destination spatial reference system of the projection
+ QgsCoordinateReferenceSystem destCRS;
- //! destination spatial reference system of the projection
- QgsCoordinateReferenceSystem* mDestCRS;
+ //! stores array of layers to be rendered (identified by string)
+ QStringList layerSet;
- //! stores array of layers to be rendered (identified by string)
- QStringList mLayerSet;
+ //! Output units
+ OutputUnits outputUnits;
- //! full extent of the layer set
- QgsRectangle mFullExtent;
+ //! Labeling engine (NULL by default)
+ QgsLabelingEngineInterface* labelingEngine;
+ bool antialiasingEnabled;
+ } Parameters;
+ //! parameters for the next rendering process
+ Parameters next;
+ //! parameters for the current rendering process
+ Parameters curr;
+ //! indicates drawing in progress
+ bool mDrawing;
//! tool for measuring
QgsDistanceArea* mDistArea;
- //!Output units
- OutputUnits mOutputUnits;
- //! Labeling engine (NULL by default)
- QgsLabelingEngineInterface* mLabelingEngine;
//! Multithreaded rendering
bool mThreadingEnabled;
//! Render caching
QgsMapRendererCache* mCache;
- bool mAntialiasingEnabled;
QFuture<void> mFuture;
QFutureWatcher<void> mFW;
