[QGIS Commit] r13004 - trunk/qgis/src/core
svn_qgis at osgeo.org
Fri Mar 5 07:14:43 EST 2010
Author: mhugent
Date: 2010-03-05 07:14:41 -0500 (Fri, 05 Mar 2010)
New Revision: 13004
trunk/qgis/src/core/qgsgeometry.cpp
trunk/qgis/src/core/qgsgeometry.h
trunk/qgis/src/core/qgspoint.cpp
trunk/qgis/src/core/qgspoint.h
Move distanceSquaredPointToSegment(...) from QgsGeometry to QgsPoint
Modified: trunk/qgis/src/core/qgsgeometry.cpp
--- trunk/qgis/src/core/qgsgeometry.cpp 2010-03-05 12:08:32 UTC (rev 13003)
+++ trunk/qgis/src/core/qgsgeometry.cpp 2010-03-05 12:14:41 UTC (rev 13004)
@@ -2453,7 +2453,7 @@
if ( index > 0 )
- if (( testdist = distanceSquaredPointToSegment( point, prevx, prevy, thisx, thisy, distPoint ) ) < sqrDist )
+ if (( testdist = point.sqrDistToSegment( *prevx, *prevy, *thisx, *thisy, distPoint ) ) < sqrDist )
closestSegmentIndex = index;
sqrDist = testdist;
@@ -2497,7 +2497,7 @@
if ( prevx && prevy )
closestSegmentIndex = pointindex;
sqrDist = testdist;
@@ -2539,7 +2539,7 @@
sqrDist = testdist;
@@ -2587,7 +2587,7 @@
sqrDist = testdist;
@@ -4679,102 +4679,6 @@
return FALSE;
-double QgsGeometry::distanceSquaredPointToSegment(
- const QgsPoint& point,
- double *x1, double *y1,
- double *x2, double *y2,
- QgsPoint& minDistPoint )
- double nx, ny; //normal vector
- nx = *y2 - *y1;
- ny = -( *x2 - *x1 );
- double t;
- t = ( point.x() * ny - point.y() * nx - *x1 * ny + *y1 * nx ) / (( *x2 - *x1 ) * ny - ( *y2 - *y1 ) * nx );
- if ( t < 0.0 )
- minDistPoint.setX( *x1 );
- minDistPoint.setY( *y1 );
- else if ( t > 1.0 )
- minDistPoint.setX( *x2 );
- minDistPoint.setY( *y2 );
- else
- minDistPoint.setX( *x1 + t *( *x2 - *x1 ) );
- minDistPoint.setY( *y1 + t *( *y2 - *y1 ) );
- return ( minDistPoint.sqrDist( point ) );
-#if 0
- double d;
- // Proportion along segment (0 to 1) the perpendicular of the point falls upon
- double t;
- // Projection of point on the segment
- double xn;
- double yn;
- double segmentsqrdist = ( *x2 - *x1 ) * ( *x2 - *x1 ) +
- ( *y2 - *y1 ) * ( *y2 - *y1 );
- // QgsDebugMsg(QString("Entered with (%1, %2) (%3, %4) %5.").arg(*x1).arg(*y1).arg(*x2).arg(*y2).arg(segmentsqrdist));
- if ( segmentsqrdist == 0.0 )
- // segment is a point
- xn = *x1;
- yn = *y1;
- else
- d =
- ( point.x() - *x1 ) * ( *x2 - *x1 )
- + ( point.y() - *y1 ) * ( *y2 - *y1 );
- t = d / segmentsqrdist;
- // Do not go beyond end of line
- // (otherwise this would be a comparison to an infinite line)
- if ( t < 0.0 )
- xn = *x1;
- yn = *y1;
- xn = *x2;
- yn = *y2;
- else
- xn = *x1 + t * ( *x2 - *x1 );
- yn = *y1 + t * ( *y2 - *y1 );
- minDistPoint.set( xn, yn );
- return (
- ( xn - point.x() ) *( xn - point.x() ) +
- ( yn - point.y() ) *( yn - point.y() )
-#endif //0
bool QgsGeometry::convertToMultiType()
if ( !mGeometry )
Modified: trunk/qgis/src/core/qgsgeometry.h
--- trunk/qgis/src/core/qgsgeometry.h 2010-03-05 12:08:32 UTC (rev 13003)
+++ trunk/qgis/src/core/qgsgeometry.h 2010-03-05 12:14:41 UTC (rev 13004)
@@ -419,14 +419,6 @@
// Private functions
- /** Squared distance from point to the given line segment
- * TODO: Perhaps move this to QgsPoint
- double distanceSquaredPointToSegment( const QgsPoint& point,
- QgsPoint& minDistPoint );
/** Converts from the WKB geometry to the GEOS geometry.
@return true in case of success and false else
Modified: trunk/qgis/src/core/qgspoint.cpp
--- trunk/qgis/src/core/qgspoint.cpp 2010-03-05 12:08:32 UTC (rev 13003)
+++ trunk/qgis/src/core/qgspoint.cpp 2010-03-05 12:14:41 UTC (rev 13004)
@@ -238,3 +238,32 @@
return 2;
+double QgsPoint::sqrDistToSegment( double x1, double y1, double x2, double y2, QgsPoint& minDistPoint ) const
+ double nx, ny; //normal vector
+ nx = y2 - y1;
+ ny = -( x2 - x1 );
+ double t;
+ t = ( m_x * ny - m_y * nx - x1 * ny + y1 * nx ) / (( x2 - x1 ) * ny - ( y2 - y1 ) * nx );
+ if ( t < 0.0 )
+ minDistPoint.setX( x1 );
+ minDistPoint.setY( y1 );
+ else if ( t > 1.0 )
+ minDistPoint.setX( x2 );
+ minDistPoint.setY( y2 );
+ else
+ minDistPoint.setX( x1 + t *( x2 - x1 ) );
+ minDistPoint.setY( y1 + t *( y2 - y1 ) );
+ return ( sqrDist( minDistPoint ) );
Modified: trunk/qgis/src/core/qgspoint.h
--- trunk/qgis/src/core/qgspoint.h 2010-03-05 12:08:32 UTC (rev 13003)
+++ trunk/qgis/src/core/qgspoint.h 2010-03-05 12:14:41 UTC (rev 13004)
@@ -144,6 +144,8 @@
/**Returns the squared distance between this and other point*/
double sqrDist( const QgsPoint& other ) const;
+ double sqrDistToSegment( double x1, double y1, double x2, double y2, QgsPoint& minDistPoint ) const;
//! equality operator
bool operator==( const QgsPoint &other );
