[QGIS Commit] r13017 - in trunk/qgis/src: app/postgres ui
svn_qgis at osgeo.org
Sun Mar 7 16:37:38 EST 2010
Author: jef
Date: 2010-03-07 16:37:34 -0500 (Sun, 07 Mar 2010)
New Revision: 13017
trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
trunk/qgis/src/app/postgres/qgspgsourceselect.h
trunk/qgis/src/ui/qgspgsourceselectbase.ui
fix #2526
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.cpp
--- trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2010-03-07 18:14:35 UTC (rev 13016)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.cpp 2010-03-07 21:37:34 UTC (rev 13017)
@@ -50,6 +50,16 @@
buttonBox->addButton( mAddButton, QDialogButtonBox::ActionRole );
connect( mAddButton, SIGNAL( clicked() ), this, SLOT( addTables() ) );
+ QPushButton *pb = new QPushButton( tr( "&Save" ) );
+ pb->setToolTip( tr( "Save connections" ) );
+ buttonBox->addButton( pb, QDialogButtonBox::ActionRole );
+ connect( pb, SIGNAL( clicked() ), this, SLOT( saveClicked() ) );
+ pb = new QPushButton( tr( "&Load" ) );
+ pb->setToolTip( tr( "Load connections" ) );
+ connect( pb, SIGNAL( clicked() ), this, SLOT( loadClicked() ) );
mAddButton->setEnabled( false );
populateConnectionList();
@@ -94,7 +104,7 @@
//hide the search options by default
- //they will be shown when the user ticks
+ //they will be shown when the user ticks
//the search options group box
mSearchLabel->setVisible( false );
mSearchColumnComboBox->setVisible( false );
@@ -139,13 +149,13 @@
-void QgsPgSourceSelect::on_btnSave_clicked()
+void QgsPgSourceSelect::saveClicked()
QgsManageConnectionsDialog dlg( this, QgsManageConnectionsDialog::Save, QgsManageConnectionsDialog::PostGIS );
dlg.exec();
-void QgsPgSourceSelect::on_btnLoad_clicked()
+void QgsPgSourceSelect::loadClicked()
QgsManageConnectionsDialog dlg( this, QgsManageConnectionsDialog::Load, QgsManageConnectionsDialog::PostGIS );
dlg.exec();
@@ -840,7 +850,6 @@
// Now tell the layer list dialog box...
emit setLayerType( schemas[i], tables[i], columns[i], type );
PQfinish( pd );
Modified: trunk/qgis/src/app/postgres/qgspgsourceselect.h
--- trunk/qgis/src/app/postgres/qgspgsourceselect.h 2010-03-07 18:14:35 UTC (rev 13016)
+++ trunk/qgis/src/app/postgres/qgspgsourceselect.h 2010-03-07 21:37:34 UTC (rev 13017)
@@ -132,9 +132,9 @@
//! Deletes the selected connection
void on_btnDelete_clicked();
//! Saves the selected connections to the file
- void on_btnSave_clicked();
+ void saveClicked();
//! Loads the selected connections from the file
- void on_btnLoad_clicked();
+ void loadClicked();
void on_mSearchTableEdit_textChanged( const QString & text );
void on_mSearchColumnComboBox_currentIndexChanged( const QString & text );
void on_mSearchModeComboBox_currentIndexChanged( const QString & text );
Modified: trunk/qgis/src/ui/qgspgsourceselectbase.ui
--- trunk/qgis/src/ui/qgspgsourceselectbase.ui 2010-03-07 18:14:35 UTC (rev 13016)
+++ trunk/qgis/src/ui/qgspgsourceselectbase.ui 2010-03-07 21:37:34 UTC (rev 13017)
@@ -6,8 +6,8 @@
<rect>
<x>0</x>
<y>0</y>
- <width>406</width>
- <height>500</height>
+ <width>362</width>
+ <height>476</height>
</rect>
</property>
<property name="windowTitle">
@@ -72,24 +72,6 @@
</widget>
</item>
<item>
- <layout class="QHBoxLayout" name="horizontalLayout">
- <item>
- <widget class="QPushButton" name="btnSave">
- <property name="text">
- <string>Save connections</string>
- </property>
- </widget>
- </item>
- <item>
- <widget class="QPushButton" name="btnLoad">
- <string>Load connections</string>
- </property>
- </widget>
- </item>
- </layout>
- </item>
- <item>
<widget class="QTreeView" name="mTablesTreeView">
<property name="selectionMode">
<enum>QAbstractItemView::ExtendedSelection</enum>
@@ -107,29 +89,18 @@
</widget>
</item>
<item>
- <spacer>
- <property name="orientation">
- <enum>Qt::Horizontal</enum>
+ <widget class="QGroupBox" name="mSearchGroupBox">
+ <property name="title">
+ <string>Search options</string>
</property>
- <property name="sizeHint" stdset="0">
- <size>
- <width>271</width>
- <height>20</height>
- </size>
+ <property name="flat">
+ <bool>true</bool>
</property>
- </spacer>
- </item>
- <item>
- <widget class="QPushButton" name="mSearchOptionsButton">
- <string>Search options...</string>
+ <property name="checkable">
+ <bool>true</bool>
</property>
- </widget>
- </item>
- <item>
- <widget class="QGroupBox" name="mSearchGroupBox">
- <property name="title">
- <string/>
+ <property name="checked">
+ <bool>false</bool>
</property>
<layout class="QGridLayout">
<property name="margin">
@@ -140,6 +111,9 @@
</property>
<item row="0" column="0">
<widget class="QLabel" name="mSearchLabel">
+ <property name="enabled">
+ <bool>true</bool>
+ </property>
<string>Search:</string>
</property>
@@ -150,6 +124,9 @@
</item>
<item row="2" column="0" colspan="2">
<widget class="QLabel" name="mSearchModeLabel">
+ <bool>true</bool>
+ </property>
<string>Search mode:</string>
</property>
@@ -159,10 +136,17 @@
</widget>
</item>
<item row="2" column="2">
- <widget class="QComboBox" name="mSearchModeComboBox"/>
+ <widget class="QComboBox" name="mSearchModeComboBox">
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
<item row="1" column="0" colspan="2">
<widget class="QLabel" name="mSearchColumnsLabel">
+ <bool>true</bool>
+ </property>
<string>Search in columns:</string>
</property>
@@ -172,10 +156,18 @@
</widget>
</item>
<item row="1" column="2">
- <widget class="QComboBox" name="mSearchColumnComboBox"/>
+ <widget class="QComboBox" name="mSearchColumnComboBox">
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
<item row="0" column="1" colspan="2">
- <widget class="QLineEdit" name="mSearchTableEdit"/>
+ <widget class="QLineEdit" name="mSearchTableEdit">
+ <bool>true</bool>
+ </property>
+ </widget>
</item>
</layout>
</widget>
@@ -198,7 +190,6 @@
<tabstop>btnDelete</tabstop>
<tabstop>mTablesTreeView</tabstop>
<tabstop>btnBuildQuery</tabstop>
- <tabstop>mSearchOptionsButton</tabstop>
<tabstop>mSearchTableEdit</tabstop>
<tabstop>mSearchColumnComboBox</tabstop>
<tabstop>mSearchModeComboBox</tabstop>
@@ -213,14 +204,110 @@
<slot>reject()</slot>
<hints>
<hint type="sourcelabel">
- <x>353</x>
- <y>446</y>
+ <x>352</x>
+ <y>466</y>
</hint>
<hint type="destinationlabel">
- <x>404</x>
+ <x>361</x>
<y>421</y>
</hint>
</hints>
</connection>
+ <connection>
+ <sender>mSearchGroupBox</sender>
+ <signal>toggled(bool)</signal>
+ <receiver>mSearchTableEdit</receiver>
+ <slot>setVisible(bool)</slot>
+ <hints>
+ <hint type="sourcelabel">
+ <x>85</x>
+ <y>324</y>
+ </hint>
+ <hint type="destinationlabel">
+ <x>177</x>
+ <y>360</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>mSearchColumnComboBox</receiver>
+ <hints>
+ <x>88</x>
+ <y>325</y>
+ </hint>
+ <x>254</x>
+ <y>381</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>mSearchModeComboBox</receiver>
+ <hints>
+ <x>106</x>
+ <y>333</y>
+ </hint>
+ <x>281</x>
+ <y>410</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>mSearchLabel</receiver>
+ <hints>
+ <x>124</x>
+ <y>327</y>
+ </hint>
+ <x>58</x>
+ <y>360</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>mSearchColumnsLabel</receiver>
+ <hints>
+ <x>42</x>
+ <y>327</y>
+ </hint>
+ <x>39</x>
+ <y>379</y>
+ </hint>
+ </hints>
+ </connection>
+ <connection>
+ <receiver>mSearchModeLabel</receiver>
+ <hints>
+ <x>73</x>
+ <y>322</y>
+ </hint>
+ <x>68</x>
+ <y>411</y>
+ </hint>
+ </hints>
+ </connection>
</connections>
</ui>
