[QGIS Commit] r13034 - trunk/qgis/python/plugins/fTools/tools
svn_qgis at osgeo.org
Mon Mar 8 19:52:40 EST 2010
Author: cfarmer
Date: 2010-03-08 19:52:39 -0500 (Mon, 08 Mar 2010)
New Revision: 13034
trunk/qgis/python/plugins/fTools/tools/doDefineProj.py
trunk/qgis/python/plugins/fTools/tools/doGeometry.py
trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
Uses Qt functions to determine output file name and path correctly (all? ftools output files should now be loaded with correct layer name). Fixes #2498.
Modified: trunk/qgis/python/plugins/fTools/tools/doDefineProj.py
--- trunk/qgis/python/plugins/fTools/tools/doDefineProj.py 2010-03-09 00:22:34 UTC (rev 13033)
+++ trunk/qgis/python/plugins/fTools/tools/doDefineProj.py 2010-03-09 00:52:39 UTC (rev 13034)
@@ -109,14 +109,4 @@
self.txtProjection.clear()
self.txtProjection.insert(projString)
else:
- return
-#Gets map layer by layername in canvas
-#Return: QgsMapLayer
- def getMapLayerByName(self,myName):
- mc = self.iface.mapCanvas()
- nLayers = mc.layerCount()
- for l in range(nLayers):
- layer = mc.layer(l)
- if layer.name() == unicode(myName):
- return layer
+ return
\ No newline at end of file
Modified: trunk/qgis/python/plugins/fTools/tools/doGeometry.py
--- trunk/qgis/python/plugins/fTools/tools/doGeometry.py 2010-03-09 00:22:34 UTC (rev 13033)
+++ trunk/qgis/python/plugins/fTools/tools/doGeometry.py 2010-03-09 00:52:39 UTC (rev 13034)
@@ -175,7 +175,8 @@
if success:
addToTOC = QMessageBox.question( self, self.tr("Geometry"), self.tr( "Created output shapefile:\n%1\n\nWould you like to add the new layer to the TOC?" ).arg( unicode( self.shapefileName ) ), QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
if addToTOC == QMessageBox.Yes:
- ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) )
+ if not ftools_utils.addShapeToCanvas( unicode( self.shapefileName ) ):
+ QMessageBox.warning( self, self.tr("Geoprocessing"), self.tr( "Error loading output shapefile:\n%1" ).arg( unicode( self.shapefileName ) ))
else:
QMessageBox.warning( self, self.tr("Geometry"), self.tr( "Error writing output shapefile." ) )
Modified: trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py
--- trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2010-03-09 00:22:34 UTC (rev 13033)
+++ trunk/qgis/python/plugins/fTools/tools/doGeoprocessing.py 2010-03-09 00:52:39 UTC (rev 13034)
@@ -212,7 +212,8 @@
out_text = ""
addToTOC = QMessageBox.question( self, self.tr("Geoprocessing"), self.tr( "Created output shapefile:\n%1\n\n%2%3" ).arg( unicode( self.shapefileName ) ).arg( out_text ).arg( end_text ), QMessageBox.Yes, QMessageBox.No, QMessageBox.NoButton )
def runStatusFromThread( self, status ):
self.progressBar.setValue( status )
Modified: trunk/qgis/python/plugins/fTools/tools/ftools_utils.py
--- trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2010-03-09 00:22:34 UTC (rev 13033)
+++ trunk/qgis/python/plugins/fTools/tools/ftools_utils.py 2010-03-09 00:52:39 UTC (rev 13034)
@@ -1,3 +1,4 @@
+# -*- coding: utf-8 -*-
# Utility functions
@@ -31,261 +32,262 @@
# From two input attribute maps, create single attribute map
def combineVectorAttributes( atMapA, atMapB ):
- attribA = atMapA.values()
- lengthA = len(attribA)
- attribB = atMapB.values()
- lengthB = len(attribB)
- attribA.extend( attribB )
- return dict( zip( range( 0, lengthB + lengthA ), attribA ) )
+ attribA = atMapA.values()
+ lengthA = len(attribA)
+ attribB = atMapB.values()
+ lengthB = len(attribB)
+ attribA.extend( attribB )
+ return dict( zip( range( 0, lengthB + lengthA ), attribA ) )
# For use with memory provider/layer, converts full field type to simple string
def convertFieldNameType( inName ):
- if inName == "Integer":
- return "int"
- elif inName == "Real":
- return "double"
- else:
- return "string"
+ if inName == "Integer":
+ return "int"
+ elif inName == "Real":
+ return "double"
+ else:
+ return "string"
# From two input field maps, create single field map
def combineVectorFields( layerA, layerB ):
- fieldsA = layerA.dataProvider().fields().values()
- fieldsB = layerB.dataProvider().fields().values()
- fieldsB = testForUniqueness( fieldsA, fieldsB )
- seq = range( 0, len( fieldsA ) + len( fieldsB ) )
- fieldsA.extend( fieldsB )
- fieldsA = dict( zip ( seq, fieldsA ) )
- return fieldsA
+ fieldsA = layerA.dataProvider().fields().values()
+ fieldsB = layerB.dataProvider().fields().values()
+ fieldsB = testForUniqueness( fieldsA, fieldsB )
+ seq = range( 0, len( fieldsA ) + len( fieldsB ) )
+ fieldsA.extend( fieldsB )
+ fieldsA = dict( zip ( seq, fieldsA ) )
+ return fieldsA
# Check if two input CRSs are identical
def checkCRSCompatibility( crsA, crsB ):
- if crsA == crsB:
- return True
- else:
- return False
+ if crsA == crsB:
+ return True
+ else:
+ return False
# Convenience function to write vector layer to shapefile
def writeVectorLayerToShape( vlayer, outputPath, encoding ):
- mCodec = QTextCodec.codecForName( QString(encoding).toLocal8Bit().data() )
- if not mCodec:
- return False
- #Here we should check that the output path is valid
- QgsVectorFileWriter.writeAsShapefile( vlayer, outputPath, encoding, vlayer.dataProvider().crs(), False )
- return True
+ mCodec = QTextCodec.codecForName( QString(encoding).toLocal8Bit().data() )
+ if not mCodec:
+ return False
+ #Here we should check that the output path is valid
+ QgsVectorFileWriter.writeAsShapefile( vlayer, outputPath, encoding, vlayer.dataProvider().crs(), False )
+ return True
# For use with memory provider/layer, converts QGis vector type definition to simple string
def getVectorTypeAsString( vlayer ):
- if vlayer.geometryType() == QGis.Polygon:
- return "Polygon"
- elif vlayer.geometryType() == QGis.Line:
- return "LineString"
- elif vlayer.geometryType() == QGis.Point:
- return "Point"
- else:
- return False
+ if vlayer.geometryType() == QGis.Polygon:
+ return "Polygon"
+ elif vlayer.geometryType() == QGis.Line:
+ return "LineString"
+ elif vlayer.geometryType() == QGis.Point:
+ return "Point"
+ else:
+ return False
# Compute area and perimeter of input polygon geometry
def getAreaAndPerimeter( geom ):
- measure = QgsDistanceArea()
- area = measure.measure( geom )
- perim = measurePerimeter( geom, measure )
- return ( area, perim )
+ measure = QgsDistanceArea()
+ area = measure.measure( geom )
+ perim = measurePerimeter( geom, measure )
+ return ( area, perim )
# Compute perimeter of input polygon geometry
def measurePerimeter( geom ):
- value = 0.00
- polygon = geom.asPolygon()
- for line in polygon:
- value += measure.measureLine( line )
- return value
+ value = 0.00
+ polygon = geom.asPolygon()
+ for line in polygon:
+ value += measure.measureLine( line )
+ return value
# Generate list of QgsPoints from input geometry ( can be point, line, or polygon )
def extractPoints( geom ):
- multi_geom = QgsGeometry()
- temp_geom = []
- if geom.type() == 0: # it's a point
- if geom.isMultipart():
- temp_geom = geom.asMultiPoint()
- else:
- temp_geom.append(geom.asPoint())
- if geom.type() == 1: # it's a line
- multi_geom = geom.asMultiPolyline() #multi_geog is a multiline
- for i in multi_geom: #i is a line
- temp_geom.extend( i )
- else:
- temp_geom = geom.asPolyline()
- elif geom.type() == 2: # it's a polygon
- multi_geom = geom.asMultiPolygon() #multi_geom is a multipolygon
- for i in multi_geom: #i is a polygon
- for j in i: #j is a line
- temp_geom.extend( j )
- else:
- multi_geom = geom.asPolygon() #multi_geom is a polygon
- return temp_geom
+ multi_geom = QgsGeometry()
+ temp_geom = []
+ if geom.type() == 0: # it's a point
+ if geom.isMultipart():
+ temp_geom = geom.asMultiPoint()
+ else:
+ temp_geom.append(geom.asPoint())
+ if geom.type() == 1: # it's a line
+ multi_geom = geom.asMultiPolyline() #multi_geog is a multiline
+ for i in multi_geom: #i is a line
+ temp_geom.extend( i )
+ else:
+ temp_geom = geom.asPolyline()
+ elif geom.type() == 2: # it's a polygon
+ multi_geom = geom.asMultiPolygon() #multi_geom is a multipolygon
+ for i in multi_geom: #i is a polygon
+ for j in i: #j is a line
+ temp_geom.extend( j )
+ else:
+ multi_geom = geom.asPolygon() #multi_geom is a polygon
+ return temp_geom
# Check if two input field maps are unique, and resolve name issues if they aren't
def testForUniqueness( fieldList1, fieldList2 ):
- changed = True
- while changed:
- changed = False
- for i in fieldList1:
- for j in fieldList2:
- if j.name() == i.name():
- j = createUniqueFieldName( j )
- changed = True
- return fieldList2
+ changed = True
+ while changed:
+ changed = False
+ for i in fieldList1:
+ for j in fieldList2:
+ if j.name() == i.name():
+ j = createUniqueFieldName( j )
+ changed = True
+ return fieldList2
# Create a unique field name based on input field name
def createUniqueFieldName( field ):
- check = field.name().right( 2 )
- if check.startsWith("_"):
- ( val, test ) = check.right( 1 ).toInt()
- if test:
- if val < 2:
- val = 2
- else:
- val = val + 1
- field.setName( field.name().left( len( field.name() )-1 ) + unicode( val ) )
- else:
- field.setName( field.name() + "_2" )
- else:
- return field
+ check = field.name().right( 2 )
+ if check.startsWith("_"):
+ ( val, test ) = check.right( 1 ).toInt()
+ if test:
+ if val < 2:
+ val = 2
+ else:
+ val = val + 1
+ field.setName( field.name().left( len( field.name() )-1 ) + unicode( val ) )
+ else:
+ field.setName( field.name() + "_2" )
+ else:
+ return field
# Return list of names of all layers in QgsMapLayerRegistry
def getLayerNames( vTypes ):
- layermap = QgsMapLayerRegistry.instance().mapLayers()
- layerlist = []
- if vTypes == "all":
- for name, layer in layermap.iteritems():
- layerlist.append( unicode( layer.name() ) )
- else:
- if layer.type() == QgsMapLayer.VectorLayer:
- if layer.geometryType() in vTypes:
- return layerlist
+ layermap = QgsMapLayerRegistry.instance().mapLayers()
+ layerlist = []
+ if vTypes == "all":
+ for name, layer in layermap.iteritems():
+ layerlist.append( unicode( layer.name() ) )
+ else:
+ if layer.type() == QgsMapLayer.VectorLayer:
+ if layer.geometryType() in vTypes:
+ return layerlist
# Return list of names of all fields from input QgsVectorLayer
def getFieldNames( vlayer ):
- fieldmap = getFieldList( vlayer )
- fieldlist = []
- for name, field in fieldmap.iteritems():
- if not field.name() in fieldlist:
- fieldlist.append( unicode( field.name() ) )
- return fieldlist
+ fieldmap = getFieldList( vlayer )
+ fieldlist = []
+ for name, field in fieldmap.iteritems():
+ if not field.name() in fieldlist:
+ fieldlist.append( unicode( field.name() ) )
+ return fieldlist
# Return QgsVectorLayer from a layer name ( as string )
def getVectorLayerByName( myName ):
- if layer.type() == QgsMapLayer.VectorLayer and layer.name() == myName:
- if layer.isValid():
- return layer
- else:
- return None
+ if layer.type() == QgsMapLayer.VectorLayer and layer.name() == myName:
+ if layer.isValid():
+ return layer
+ else:
+ return None
# Return QgsMapLayer from a layer name ( as string )
def getMapLayerByName( myName ):
- if layer.name() == myName:
- return layer
- else:
- return None
+ if layer.name() == myName:
+ return layer
+ else:
+ return None
# Return the field list of a vector layer
def getFieldList( vlayer ):
- vprovider = vlayer.dataProvider()
- feat = QgsFeature()
- allAttrs = vprovider.attributeIndexes()
- vprovider.select( allAttrs )
- myFields = vprovider.fields()
- return myFields
+ vprovider = vlayer.dataProvider()
+ feat = QgsFeature()
+ allAttrs = vprovider.attributeIndexes()
+ vprovider.select( allAttrs )
+ myFields = vprovider.fields()
+ return myFields
# Convinience function to create a spatial index for input QgsVectorDataProvider
def createIndex( provider ):
- index = QgsSpatialIndex()
- provider.rewind()
- while provider.nextFeature( feat ):
- index.insertFeature( feat )
- return index
+ index = QgsSpatialIndex()
+ provider.rewind()
+ while provider.nextFeature( feat ):
+ index.insertFeature( feat )
+ return index
# Convinience function to add a vector layer to canvas based on input shapefile path ( as string )
-def addShapeToCanvas( shapeFilePath ):
- shapeFilePathList = shapeFilePath.split( "/" )
- layerName = QString( shapeFilePathList[len(shapeFilePathList)-1] )
- if layerName.endsWith( ".shp" ):
- layerName = unicode( layerName ).rstrip( ".shp" )
- vlayer_new = QgsVectorLayer( shapeFilePath, layerName, "ogr" )
+def addShapeToCanvas( shapefile_path ):
+ file_info = QFileInfo( shapefile_path )
+ if file_info.exists():
+ layer_name = file_info.completeBaseName()
+ else:
+ return False
+ vlayer_new = QgsVectorLayer( shapefile_path, layer_name, "ogr" )
+ print layer_name
+ if vlayer_new.isValid():
+ QgsMapLayerRegistry.instance().addMapLayer( vlayer_new )
+ return True
+ else:
+ return False
- if vlayer_new.isValid():
- QgsMapLayerRegistry.instance().addMapLayer(vlayer_new)
- return True
- else:
- return False
# Return all unique values in field based on field index
def getUniqueValues( provider, index ):
- allAttrs = provider.attributeIndexes()
- provider.select( allAttrs )
- f = QgsFeature()
- values = []
- check = []
- while provider.nextFeature( f ):
- if not f.attributeMap()[ index ].toString() in check:
- values.append( f.attributeMap()[ index ] )
- check.append( f.attributeMap()[ index ].toString() )
- return values
+ allAttrs = provider.attributeIndexes()
+ provider.select( allAttrs )
+ f = QgsFeature()
+ values = []
+ check = []
+ while provider.nextFeature( f ):
+ if not f.attributeMap()[ index ].toString() in check:
+ values.append( f.attributeMap()[ index ] )
+ check.append( f.attributeMap()[ index ].toString() )
+ return values
# Generate a save file dialog with a dropdown box for choosing encoding style
def saveDialog( parent ):
- settings = QSettings()
- dirName = settings.value( "/UI/lastShapefileDir" ).toString()
- filtering = QString( "Shapefiles (*.shp)" )
- encode = settings.value( "/UI/encoding" ).toString()
- fileDialog = QgsEncodingFileDialog( parent, "Save output shapefile", dirName, filtering, encode )
- fileDialog.setDefaultSuffix( QString( "shp" ) )
- fileDialog.setFileMode( QFileDialog.AnyFile )
- fileDialog.setAcceptMode( QFileDialog.AcceptSave )
- fileDialog.setConfirmOverwrite( True )
- if not fileDialog.exec_() == QDialog.Accepted:
- return None, None
- files = fileDialog.selectedFiles()
- settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( files.first() ) ).absolutePath() ) )
- return ( unicode( files.first() ), unicode( fileDialog.encoding() ) )
+ settings = QSettings()
+ dirName = settings.value( "/UI/lastShapefileDir" ).toString()
+ filtering = QString( "Shapefiles (*.shp)" )
+ encode = settings.value( "/UI/encoding" ).toString()
+ fileDialog = QgsEncodingFileDialog( parent, "Save output shapefile", dirName, filtering, encode )
+ fileDialog.setDefaultSuffix( QString( "shp" ) )
+ fileDialog.setFileMode( QFileDialog.AnyFile )
+ fileDialog.setAcceptMode( QFileDialog.AcceptSave )
+ fileDialog.setConfirmOverwrite( True )
+ if not fileDialog.exec_() == QDialog.Accepted:
+ return None, None
+ files = fileDialog.selectedFiles()
+ settings.setValue("/UI/lastShapefileDir", QVariant( QFileInfo( unicode( files.first() ) ).absolutePath() ) )
+ return ( unicode( files.first() ), unicode( fileDialog.encoding() ) )
# Return field type from it's name
def getFieldType(vlayer, fieldName):
- fields = vlayer.dataProvider().fields()
- for name, field in fields.iteritems():
- if field.name() == fieldName:
- return field.typeName()
+ fields = vlayer.dataProvider().fields()
+ for name, field in fields.iteritems():
+ if field.name() == fieldName:
+ return field.typeName()
# return the number of unique values in field
def getUniqueValuesCount( vlayer, fieldIndex, useSelection ):
- count = 0
- values = []
- if useSelection:
- selection = vlayer.selectedFeatures()
- for f in selection:
- if f.attributeMap()[ fieldIndex ].toString() not in values:
- values.append( f.attributeMap()[ fieldIndex ].toString() )
- count += 1
- else:
- while vprovider.nextFeature( feat ):
- if feat.attributeMap()[ fieldIndex ].toString() not in values:
- values.append( feat.attributeMap()[ fieldIndex ].toString() )
- count += 1
- return count
+ count = 0
+ values = []
+ if useSelection:
+ selection = vlayer.selectedFeatures()
+ for f in selection:
+ if f.attributeMap()[ fieldIndex ].toString() not in values:
+ values.append( f.attributeMap()[ fieldIndex ].toString() )
+ count += 1
+ else:
+ while vprovider.nextFeature( feat ):
+ if feat.attributeMap()[ fieldIndex ].toString() not in values:
+ values.append( feat.attributeMap()[ fieldIndex ].toString() )
+ count += 1
+ return count
