[QGIS Commit] r13045 - trunk/qgis/src/app
svn_qgis at osgeo.org
Thu Mar 11 05:26:55 EST 2010
Author: mhugent
Date: 2010-03-11 05:26:50 -0500 (Thu, 11 Mar 2010)
New Revision: 13045
trunk/qgis/src/app/main.cpp
Add option to set QSettings path
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2010-03-10 23:58:48 UTC (rev 13044)
+++ trunk/qgis/src/app/main.cpp 2010-03-11 10:26:50 UTC (rev 13045)
@@ -92,6 +92,7 @@
<< "\t[--project projectfile]\tload the given QGIS project\n"
<< "\t[--extent xmin,ymin,xmax,ymax]\tset initial map extent\n"
<< "\t[--nologo]\thide splash screen\n"
+ << "\t[--optionspath path]\tuse the given QSettings path\n"
<< "\t[--help]\t\tthis text\n\n"
<< " FILES:\n"
<< " Files specified on the command line can include rasters,\n"
@@ -303,13 +304,14 @@
{"lang", required_argument, 0, 'l'},
{"project", required_argument, 0, 'p'},
{"extent", required_argument, 0, 'e'},
+ {"optionspath", required_argument, 0, 'o'},
{0, 0, 0, 0}
/* getopt_long stores the option index here. */
int option_index = 0;
- optionChar = getopt_long( argc, argv, "swhlpe",
+ optionChar = getopt_long( argc, argv, "swhlpeo",
long_options, &option_index );
/* Detect the end of the options. */
@@ -356,6 +358,10 @@
myInitialExtent = optarg;
break;
+ case 'o':
+ QSettings::setPath( QSettings::NativeFormat, QSettings::UserScope, optarg );
+ break;
case '?':
usage( argv[0] );
return 2; // XXX need standard exit codes
@@ -420,6 +426,10 @@
myInitialExtent = argv[++i];
+ else if ( i + 1 < argc && ( arg == "--optionspath" || arg == "-o" ) )
+ QSettings::setPath( QSettings::NativeFormat, QSettings::UserScope, argv[++i] );
else
myFileList.append( QDir::convertSeparators( QFileInfo( QFile::decodeName( argv[i] ) ).absoluteFilePath() ) );
