[QGIS Commit] r13049 - trunk/qgis/src/ui
svn_qgis at osgeo.org
Thu Mar 11 16:58:41 EST 2010
Author: borysiasty
Date: 2010-03-11 16:58:41 -0500 (Thu, 11 Mar 2010)
New Revision: 13049
trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui
trunk/qgis/src/ui/qgscomposerbase.ui
trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
Print composer gui cleanups from Milena
Modified: trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui 2010-03-11 17:37:13 UTC (rev 13048)
+++ trunk/qgis/src/ui/qgscomposerarrowwidgetbase.ui 2010-03-11 21:58:41 UTC (rev 13049)
@@ -42,7 +42,7 @@
<item row="1" column="0">
<widget class="QDoubleSpinBox" name="mOutlineWidthSpinBox">
<property name="prefix">
- <string>Outline width </string>
+ <string>Line width </string>
</property>
</widget>
</item>
Modified: trunk/qgis/src/ui/qgscomposerbase.ui
--- trunk/qgis/src/ui/qgscomposerbase.ui 2010-03-11 17:37:13 UTC (rev 13048)
+++ trunk/qgis/src/ui/qgscomposerbase.ui 2010-03-11 21:58:41 UTC (rev 13049)
@@ -6,7 +6,7 @@
<rect>
<x>0</x>
<y>0</y>
- <width>799</width>
+ <width>1145</width>
<height>609</height>
</rect>
</property>
@@ -172,6 +172,7 @@
<addaction name="mActionAddBasicShape"/>
<addaction name="mActionAddArrow"/>
<addaction name="mActionAddTable"/>
+ <addaction name="separator"/>
<addaction name="mActionSelectMoveItem"/>
<addaction name="mActionMoveItemContent"/>
<addaction name="mActionGroupItems"/>
Modified: trunk/qgis/src/ui/qgscomposermapwidgetbase.ui
--- trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2010-03-11 17:37:13 UTC (rev 13048)
+++ trunk/qgis/src/ui/qgscomposermapwidgetbase.ui 2010-03-11 21:58:41 UTC (rev 13049)
@@ -155,6 +155,12 @@
<layout class="QHBoxLayout" name="horizontalLayout_2">
<item>
<widget class="QCheckBox" name="mKeepLayerListCheckBox">
+ <property name="maximumSize">
+ <size>
+ <width>20</width>
+ <height>16777215</height>
+ </size>
+ </property>
<property name="text">
<string/>
</property>
@@ -311,7 +317,7 @@
<property name="geometry">
<rect>
<x>0</x>
- <y>-54</y>
+ <y>0</y>
<width>377</width>
<height>789</height>
</rect>
@@ -417,14 +423,14 @@
</property>
</widget>
</item>
- <item row="19" column="0">
+ <item row="21" column="0">
<widget class="QCheckBox" name="mDrawAnnotationCheckBox">
<string>Draw annotation</string>
</property>
</widget>
</item>
- <item row="20" column="0">
+ <item row="22" column="0">
<widget class="QLabel" name="mAnnotationPositionLabel">
<string>Annotation position</string>
@@ -437,10 +443,10 @@
</property>
</widget>
</item>
- <item row="21" column="0">
+ <item row="23" column="0">
<widget class="QComboBox" name="mAnnotationPositionComboBox"/>
</item>
- <item row="22" column="0">
+ <item row="24" column="0">
<widget class="QLabel" name="mAnnotationDirectionLabel">
<property name="frameShape">
<enum>QFrame::NoFrame</enum>
@@ -456,43 +462,17 @@
</property>
</widget>
</item>
- <item row="23" column="0">
+ <item row="25" column="0">
<widget class="QComboBox" name="mAnnotationDirectionComboBox"/>
</item>
- <item row="30" column="0">
- <widget class="QLabel" name="mLineColorLabel">
- <property name="text">
- <string>Line color</string>
- </property>
- <property name="wordWrap">
- <bool>true</bool>
- </property>
- <property name="buddy">
- <cstring>mLineColorButton</cstring>
- </property>
- </widget>
- </item>
- <item row="31" column="0">
- <widget class="QgsColorButton" name="mLineColorButton">
- <property name="sizePolicy">
- <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
- <horstretch>0</horstretch>
- <verstretch>0</verstretch>
- </sizepolicy>
- </property>
- <string/>
- </property>
- </widget>
- </item>
- <item row="32" column="0">
+ <item row="34" column="0">
<widget class="QPushButton" name="mAnnotationFontButton">
<string>Font...</string>
</property>
</widget>
</item>
- <item row="33" column="0">
+ <item row="35" column="0">
<widget class="QLabel" name="mDistanceToFrameLabel">
<string>Distance to map frame</string>
@@ -505,10 +485,10 @@
</property>
</widget>
</item>
- <item row="34" column="0">
+ <item row="36" column="0">
<widget class="QDoubleSpinBox" name="mDistanceToMapFrameSpinBox"/>
</item>
- <item row="35" column="0">
+ <item row="37" column="0">
<widget class="QLabel" name="mCoordinatePrecisionLabel">
<string>Coordinate precision</string>
@@ -521,7 +501,7 @@
</property>
</widget>
</item>
- <item row="36" column="0">
+ <item row="38" column="0">
<widget class="QSpinBox" name="mCoordinatePrecisionSpinBox"/>
</item>
<item row="15" column="0">
@@ -590,7 +570,7 @@
</property>
</widget>
</item>
- <item row="37" column="0">
+ <item row="39" column="0">
<spacer name="verticalSpacer_2">
<property name="orientation">
<enum>Qt::Vertical</enum>
@@ -603,6 +583,32 @@
</property>
</spacer>
</item>
+ <item row="19" column="0">
+ <widget class="QLabel" name="mLineColorLabel">
+ <property name="text">
+ <string>Line color</string>
+ </property>
+ <property name="wordWrap">
+ <bool>true</bool>
+ </property>
+ <property name="buddy">
+ <cstring>mLineColorButton</cstring>
+ </property>
+ </widget>
+ </item>
+ <item row="20" column="0">
+ <widget class="QgsColorButton" name="mLineColorButton">
+ <property name="sizePolicy">
+ <sizepolicy hsizetype="Preferred" vsizetype="Preferred">
+ <horstretch>0</horstretch>
+ <verstretch>0</verstretch>
+ </sizepolicy>
+ </property>
+ <string/>
+ </property>
+ </widget>
+ </item>
</layout>
</widget>
</item>
@@ -641,10 +647,10 @@
<tabstop>mOffsetYSpinBox</tabstop>
<tabstop>mCrossWidthSpinBox</tabstop>
<tabstop>mLineWidthSpinBox</tabstop>
+ <tabstop>mLineColorButton</tabstop>
<tabstop>mDrawAnnotationCheckBox</tabstop>
<tabstop>mAnnotationPositionComboBox</tabstop>
<tabstop>mAnnotationDirectionComboBox</tabstop>
- <tabstop>mLineColorButton</tabstop>
<tabstop>mAnnotationFontButton</tabstop>
<tabstop>mDistanceToMapFrameSpinBox</tabstop>
<tabstop>mCoordinatePrecisionSpinBox</tabstop>
