[QGIS Commit] r13076 - in trunk/qgis: . src/app
svn_qgis at osgeo.org
Fri Mar 19 07:41:18 EDT 2010
Author: wonder
Date: 2010-03-19 07:41:12 -0400 (Fri, 19 Mar 2010)
New Revision: 13076
trunk/qgis/qgis.1
trunk/qgis/src/app/main.cpp
trunk/qgis/src/app/qgisapp.cpp
trunk/qgis/src/app/qgisapp.h
[FEATURE] Added --noplugins command line options to avoid restoring the plugins. Useful when a plugin misbehaves and causes QGIS to crash during startup.
Modified: trunk/qgis/qgis.1
--- trunk/qgis/qgis.1 2010-03-19 09:32:34 UTC (rev 13075)
+++ trunk/qgis/qgis.1 2010-03-19 11:41:12 UTC (rev 13076)
@@ -1,4 +1,4 @@
-.TH QGIS 1 "April 13, 2008"
+.TH QGIS 1 "March 19, 2010"
.SH NAME
qgis \- Quantum GIS Geographic Information System
.SH SYNOPSIS
@@ -14,6 +14,8 @@
.B " [--extent"
.I xmin,ymin,xmax,ymax]
.br
+.B " [--noplugins]"
+.br
.B " [--help]"
.br
.B " [file]..."
@@ -65,7 +67,11 @@
.B \--extent xmin,ymin,xmax,ymax
Set initial map extent by passing coordinates of that rectangle.
.TP
-.B \--help
+.B \--noplugins
+.br
+Don't restore plugins on startup. Useful if some third-party plugins make QGIS crash during startup.
+.TP
+.B \--help
.br
Display brief usage help.
.TP
Modified: trunk/qgis/src/app/main.cpp
--- trunk/qgis/src/app/main.cpp 2010-03-19 09:32:34 UTC (rev 13075)
+++ trunk/qgis/src/app/main.cpp 2010-03-19 11:41:12 UTC (rev 13076)
@@ -92,6 +92,7 @@
<< "\t[--project projectfile]\tload the given QGIS project\n"
<< "\t[--extent xmin,ymin,xmax,ymax]\tset initial map extent\n"
<< "\t[--nologo]\thide splash screen\n"
+ << "\t[--noplugins]\tdon't restore plugins on startup\n"
<< "\t[--optionspath path]\tuse the given QSettings path\n"
<< "\t[--help]\t\tthis text\n\n"
<< " FILES:\n"
@@ -267,6 +268,7 @@
int mySnapshotHeight = 600;
bool myHideSplash = false;
+ bool myRestorePlugins = true;
// This behaviour will set initial extent of map canvas, but only if
// there are no command line arguments. This gives a usable map
@@ -296,6 +298,7 @@
/* These options set a flag. */
{"help", no_argument, 0, '?'},
{"nologo", no_argument, 0, 'n'},
+ {"noplugins", no_argument, 0, 'P'},
/* These options don't set a flag.
* We distinguish them by their indices. */
{"snapshot", required_argument, 0, 's'},
@@ -354,6 +357,10 @@
myProjectFileName = QDir::convertSeparators( QFileInfo( QFile::decodeName( optarg ) ).absoluteFilePath() );
break;
+ case 'P':
+ myRestorePlugins = false;
+ break;
case 'e':
myInitialExtent = optarg;
break;
@@ -402,6 +409,10 @@
myHideSplash = true;
+ else if ( arg == "--noplugins" || arg == "-P" )
else if ( i + 1 < argc && ( arg == "--snapshot" || arg == "-s" ) )
mySnapshotFileName = QDir::convertSeparators( QFileInfo( QFile::decodeName( argv[++i] ) ).absoluteFilePath() );
@@ -615,7 +626,7 @@
#endif
- QgisApp *qgis = new QgisApp( mypSplash ); // "QgisApp" used to find canonical instance
+ QgisApp *qgis = new QgisApp( mypSplash, myRestorePlugins ); // "QgisApp" used to find canonical instance
qgis->setObjectName( "QgisApp" );
Modified: trunk/qgis/src/app/qgisapp.cpp
--- trunk/qgis/src/app/qgisapp.cpp 2010-03-19 09:32:34 UTC (rev 13075)
+++ trunk/qgis/src/app/qgisapp.cpp 2010-03-19 11:41:12 UTC (rev 13076)
@@ -327,7 +327,7 @@
QgisApp *QgisApp::smInstance = 0;
// constructor starts here
-QgisApp::QgisApp( QSplashScreen *splash, QWidget * parent, Qt::WFlags fl )
+QgisApp::QgisApp( QSplashScreen *splash, bool restorePlugins, QWidget * parent, Qt::WFlags fl )
: QMainWindow( parent, fl ),
mSplash( splash ),
mPythonUtils( NULL )
@@ -425,7 +425,12 @@
mSplash->showMessage( tr( "Restoring loaded plugins" ), Qt::AlignHCenter | Qt::AlignBottom );
qApp->processEvents();
QgsPluginRegistry::instance()->setQgisInterface( mQgisInterface );
- QgsPluginRegistry::instance()->restoreSessionPlugins( QgsApplication::pluginPath() );
+ if ( restorePlugins )
+ // Restoring of plugins can be disabled with --noplugins command line option
+ // because some plugins may cause QGIS to crash during startup
+ QgsPluginRegistry::instance()->restoreSessionPlugins( QgsApplication::pluginPath() );
mSplash->showMessage( tr( "Initializing file filters" ), Qt::AlignHCenter | Qt::AlignBottom );
Modified: trunk/qgis/src/app/qgisapp.h
--- trunk/qgis/src/app/qgisapp.h 2010-03-19 09:32:34 UTC (rev 13075)
+++ trunk/qgis/src/app/qgisapp.h 2010-03-19 11:41:12 UTC (rev 13076)
@@ -81,7 +81,7 @@
Q_OBJECT
public:
//! Constructor
- QgisApp( QSplashScreen *splash, QWidget * parent = 0, Qt::WFlags fl = Qt::Window );
+ QgisApp( QSplashScreen *splash, bool restorePlugins = true, QWidget * parent = 0, Qt::WFlags fl = Qt::Window );
//! Destructor
~QgisApp();
