[QGIS Commit] r13084 - docs/trunk/english_us/user_guide
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 19 09:37:31 EDT 2010
Author: dassau
Date: 2010-03-19 09:37:31 -0400 (Fri, 19 Mar 2010)
New Revision: 13084
   docs/trunk/english_us/user_guide/working_with_vector.tex
more updates
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-19 13:15:39 UTC (rev 13083)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-19 13:37:31 UTC (rev 13084)
@@ -1189,7 +1189,9 @@
 The attribute window will appear, allowing you to enter the information for
 the new feature. Figure \ref{fig:vector_digitising} shows setting attributes
-for a fictitious new river in Alaska.
+for a fictitious new river in Alaska. In the \tab{Digitising} tab under the
+\mainmenuopt{Settings} >\dropmenuopt{Options} menu, you can also activate the
+\checkbox{Suppress attributes pop-up windows after each created feature}.
 \begin{figure}[ht]
    \begin{center}
@@ -1611,9 +1613,10 @@
 For a \textbf{simple search by attributes} on only one column the \button{Look for}
 field can be used. Select the field (column) from which the search should be
-performed from the dropdown menu and hit the \button{Search} button. For more
-complex searches use the Advanced search \button{...}, which will lauch the
-Search Query Builder described in Section \ref{sec:select_by_query}.
+performed from the dropdown menu and hit the \button{Search} button. The number of
+matching rows will appear in the status bar. For more complex searches use
+the Advanced search \button{...}, which will lauch the Search Query Builder
+described in Section \ref{sec:select_by_query}.
 To show selected records only, use the checkbox \checkbox{Show selected records only}. To search selected records only, use the checkbox \checkbox{Search selected records only}. The other buttons at the bottom left of the attribute table window provide following functionality:
More information about the QGIS-commit mailing list
