[QGIS Commit] r13088 - in docs/trunk/english_us/user_guide: . working_with_vector_screenies
svn_qgis at osgeo.org svn_qgis at osgeo.org
Fri Mar 19 12:35:50 EDT 2010
Author: dassau
Date: 2010-03-19 12:35:49 -0400 (Fri, 19 Mar 2010)
New Revision: 13088
Added:
   docs/trunk/english_us/user_guide/working_with_vector_screenies/fieldcalculator.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionCalculateField.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionDeleteAttribute.png
   docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionNewAttribute.png
   docs/trunk/english_us/user_guide/working_with_vector.tex
   docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile
added section about the fieldcalculator
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-19 16:18:22 UTC (rev 13087)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex	2010-03-19 16:35:49 UTC (rev 13088)
@@ -1626,7 +1626,12 @@
 \item \toolbtntwo{mActionInvertSelection}{Invert selection}
 \item \toolbtntwo{mActionCopySelected}{Copy selected rows to clipboard} also with \keystroke{Ctrl-C}
 \item \toolbtntwo{mActionZoomToSelected}{Zoom map to selected rows} also with \keystroke{Ctrl-J}
-\item \toolbtntwo{mActionToggleEditing}{toggle editing mode} to edit single values of attribute table.
+\item \toolbtntwo{mActionToggleEditing}{toggle editing mode} to edit single values
+of attribute table and to enable functionalities described below.
+\item \toolbtntwo{mActionDeleteSelected}{Delete Selected Features}
+\item \toolbtntwo{mActionNewAttribute}{New Column} for PostGIS layers and for OGR layers with GDAL version >= 1.6.
+\item \toolbtntwo{mActionDeleteAttribute}{Delete Column} only for PostGIS layers yet.
+\item \toolbtntwo{mActionCalculateField}{Open field calcultor}
 \end{itemize}
 \begin{Tip}[ht]\caption{\textsc{Manipulating Attribute data}}
@@ -1637,7 +1642,6 @@
 \end{Tip}
 \subsection{Query Builder}\label{sec:query_builder}
 \index{Query Builder}
@@ -1694,11 +1698,7 @@
 \ref{sec:vectorprops} for more information.}
 \end{Tip}
-\subsection{Select by query}\label{sec:select_by_query}
-\index{PostgreSQL!query builder}
-\index{PostGIS!query builder}
-\index{query builder!PostgreSQL}
-\index{query builder!PostGIS}
+\minisec{Select by query}\label{sec:select_by_query}
 With QGIS it is possible also to select features using a similar query builder
 interface to that used in \ref{sec:query_builder}. In the above section
@@ -1713,5 +1713,74 @@
 that allows to define a subset of a table and display it as described in Section
+\subsection{Field Calculator}\label{sec:field_calculator}
+\index{PostgreSQL!field calculator}
+\index{PostGIS!field calculator}
+\index{OGR!field calculator}
+\index{field calculator!PostgreSQL}
+\index{field calculator!PostGIS}
+\index{field calculator!OGR}
+The \toolbtntwo{mActionCalculateField}{Field Calculator} button in the
+attribute table allows to perform calculations on basis of existing
+attribute values or defined functions, e.g to calculate length or area
+of geometry features. The results can be written to a new attribute column
+or it can be used to update values in an already existing column.
+You have to bring the vector layer in editing mode, before you can click on
+the field calculator icon to open the dialog (see Figure
+\ref{fig:field_calculator}). In the dialog you first have to select, whether
+you want to update an existing field, only update selected features or
+create a new attribute field, where the results of the calculation will be added.
+\begin{figure}[ht]
+  \begin{center}
+    \caption{Field Calculator \nixcaption}\label{fig:field_calculator}\smallskip
+    \includegraphics[clip=true, width=11.5cm]{fieldcalculator}
+  \end{center}
+\end{figure}
+If you choose to add a new field, you need to enter a field name, a field type
+(integer, real or string), the total field width, and the field precision.
+For example, if you choose a field width of 10 and a field precision of 3 it
+means you have 6 signs before the dot, then the dot and another 3 signs for the
+precision.
+The \textbf{Fields list} contains all attributes of the attribute table to be
+searched. To add an attribute to the Field calculator expression field, double
+click its name in the Fields list. Generally you can use the various fields,
+values and operators to construct the calculation expression or you can just
+type it into the box.
+The \textbf{Values list} lists the values of an attribute field. To list all
+possible values, select the attribute field in the Fields list and click the
+\button{All} button\index{Field Calculator!getting all values}. To list all
+values of an attribute field that are present in the sample table, select the
+attribute in the Fields list and click the \button{Sample} button\index{Field
+Calcultor!generating sample list}. The procedure is the same as for the Query
+Builder. To add a value to the Field calculator expression box, double click its
+name in the Values list.
+The \textbf{Operators section} contains all usable operators. To add an operator
+to the Field calculator expression box, click the appropriate button. Mathematical
+calculations ( + , - , * \dots), trigonometric functions ( sin, cos, tan, \dots),
+extract geometric information ( length and area ) are available and will be
+extended in future versions.
+A short example illustrates how the field calculator works. We want to calculate
+the length of the 'railroads' layer from the \filename{qgis\_example\_dataset}:
+\begin{enumerate}
+\item Load the Shapefile \filename{railroads.shp} in QGIS and open
+the \dialog{Attribute Table} dialog.
+\item Click on \toolbtntwo{mActionToggleEditing}{Toggle editing mode} and
+open the \toolbtntwo{mActionCalculateField}{Field Calculator} dialog.
+\item Unselect the \checkbox{Update existing field} checkbox to enable the
+new field box.
+\item Add 'length' as output field name, 'real' as output field type and define
+output field width 10 and a precision of 3.
+\item Now double click on Operator 'length' to add it as \$length into the
+field calculator expression box and click \button{Ok}.
+\end{enumerate}
 \index{vector layers|)}
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile
--- docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile	2010-03-19 16:18:22 UTC (rev 13087)
+++ docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile	2010-03-19 16:35:49 UTC (rev 13088)
@@ -29,6 +29,10 @@
     vectorWrapping.eps\
     redo_undo.eps\
     rotatepointsymbol.eps\
+    mActionNewAttribute.eps\
+    mActionDeleteAttribute.eps\
+    mActionCalculateField.eps\
+    fieldcalculator.eps\
 # digitising_attributes09.eps\
 #	newvectorlayer.eps\
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/fieldcalculator.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/fieldcalculator.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionCalculateField.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionCalculateField.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionDeleteAttribute.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionDeleteAttribute.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionNewAttribute.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/mActionNewAttribute.png
More information about the QGIS-commit mailing list
