[QGIS Commit] r13097 - trunk/qgis/python
svn_qgis at osgeo.org
Sat Mar 20 05:23:38 EDT 2010
Author: borysiasty
Date: 2010-03-20 05:23:38 -0400 (Sat, 20 Mar 2010)
New Revision: 13097
trunk/qgis/python/utils.py
new utils.showPluginHelp() method - patch #2562 by ccrook applied
Modified: trunk/qgis/python/utils.py
--- trunk/qgis/python/utils.py 2010-03-20 09:22:07 UTC (rev 13096)
+++ trunk/qgis/python/utils.py 2010-03-20 09:23:38 UTC (rev 13097)
@@ -4,7 +4,7 @@
-from PyQt4.QtCore import QCoreApplication
+from PyQt4.QtCore import QCoreApplication,QLocale
from qgis.core import QGis
import sys
import traceback
@@ -176,7 +176,9 @@
return True
return bool(metadata.canBeUninstalled())
except:
- return False
+ msg = "Error calling "+packageName+".canBeUninstalled"
+ showException(sys.exc_type, sys.exc_value, sys.exc_traceback, msg)
+ return True
def unloadPlugin(packageName):
@@ -240,6 +242,28 @@
startPlugin(packageName)
+def showPluginHelp(packageName=None,filename="index",section=""):
+ try:
+ source = ""
+ if packageName is None:
+ import inspect
+ source = inspect.currentframe().f_back.f_code.co_filename
+ else:
+ source = sys.modules[packageName].__file__
+ except:
+ return
+ path = os.path.dirname(source)
+ locale = str(QLocale().name()).split("_")[0]
+ helpfile = os.path.join(path,filename+"-"+locale+".html")
+ if not os.path.exists(helpfile):
+ helpfile = os.path.join(path,filename+".html")
+ if os.path.exists(helpfile):
+ url = "file://"+helpfile
+ if section != "":
+ url = url + "#" + section
+ iface.openURL(url,False)
# IMPORT wrapper
