[QGIS Commit] r13109 - in docs/trunk/english_us/user_guide: .
working_with_vector_screenies
svn_qgis at osgeo.org
Sat Mar 20 13:50:01 EDT 2010
Author: dassau
Date: 2010-03-20 13:50:00 -0400 (Sat, 20 Mar 2010)
New Revision: 13109
Added:
docs/trunk/english_us/user_guide/working_with_vector_screenies/categorysymbol_ng_line.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/graduatesymbol_ng_line.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_area.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_line.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_point.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/stylemanager.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties1.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties2.png
docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties3.png
docs/trunk/english_us/user_guide/working_with_vector.tex
docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile
added new symbology description
Modified: docs/trunk/english_us/user_guide/working_with_vector.tex
--- docs/trunk/english_us/user_guide/working_with_vector.tex 2010-03-20 14:12:31 UTC (rev 13108)
+++ docs/trunk/english_us/user_guide/working_with_vector.tex 2010-03-20 17:50:00 UTC (rev 13109)
@@ -560,7 +560,7 @@
\begin{figure}[h]
\centering
-\caption{Symbolizing-options \nixcaption}
+\caption{Symbolizing Options \nixcaption}
\subfigure[Single symbol] {\label{subfig:single_symbol}\includegraphics[clip=true, width=0.4\textwidth]{vectorClassifySingle}}\goodgap
\subfigure[Graduated symbol] {\label{subfig:graduated_symbol}\includegraphics[clip=true, width=0.4\textwidth]{vectorClassifyGraduated}}\\
\subfigure[Continous color] {\label{subfig:cont_color}\includegraphics[clip=true, width=0.4\textwidth]{vectorClassifyContinous}}\goodgap
@@ -594,8 +594,6 @@
\end{description}
\end{description}
-%%FIXME Add new symbology minisec
Once you have styled your layer you also could save your layer-style to a
separate file (with \filename{*.qml}-ending).
To do this, use the button \button{Save Style \ldots}. No need to say that
@@ -612,6 +610,202 @@
fig. \ref{fig:vector_symbology}). This is very useful for overlaying several
vector layers.
+\subsubsection{New Generation Symbology}
+In QGIS \CURRENT a new symbology was integrated in parallel with the symbology
+described above. This new generation symbology provides a variety of improvements and
+new features and will replace the current symbology in one of the upcoming releases.
+To switch to the new symbolgy you currently have to click on the \button{new symbology} button in the \tab{General} tab of the \dialog{Layer Properties} dialog.
+\minisec{Understanding the new generation symbology}
+There are three types of symbols: marker symbols (for points), line symbols and
+fill symbols (for polygons). Symbols can consist of one or more symbol layers. It
+is possible to define the color of a symbol and this color is then defined for all
+symbol layers. Some layers may have the color locked - for those the color can not
+be altered. This is useful when you define the color of a multilayer symbol.
+Similarly, it is possible to define the width for line symbols, as well as size and
+angle for marker symbols.
+\minisec{Available symbol layer types}
+\begin{itemize}
+\item \textbf{Simple marker}: Rendering with one of hardcoded markers.
+\item \textbf{Simple line}: Usual rendering of a line (with specified
+width, color and pen style)
+\item \textbf{Simple fill}: Usual rendering of a polygon (with defined
+fill color, fill pattern and outline)
+\item \textbf{SVG marker}: Rendering with a SVG picture
+\item \textbf{Marker line}: A line rendered by repeating a marker symbol
+\end{itemize}
+\minisec{Color ramps}
+Color ramps are used to define a range of colors that can be used during
+the creation of renderers. The symbol's color will be set from the color ramp.
+There are two types of color ramps:
+\begin{itemize}
+\item \textbf{Gradient}: Linear gradient from one color to some other.
+\item \textbf{random}: Randomly generated colors from a specified area of
+color space
+\end{itemize}
+\minisec{Styles}
+A style groups a set of various symbols and color ramps. You can define your
+prefered or frequently used symbols, and can use it without having to recreate
+it everytime. Style items (symbols and color ramps) have always a name by which
+they can be queried from the style. There is one default style in QGIS (modifiable)
+and the user can add further styles.
+\minisec{Renderers}
+The renderer is responsible for drawing a feature together with the correct
+symbol. There are three types of renderers: single symbol, categorized (called
+unique color in the old symbology), and graduated. There is no continuous color
+renderer, because it is in fact only a special case of the graduated renderer.
+The categorized and graduated renderer can be created by specifying a symbol
+and a color ramp - they will set the colors for symbols appropriately.
+\subsubsection{Working with the New Generation Symbology}
+First you have to enable the new generation symbology clicking on the
+\button{new symbology} button in the \tab{General} tab of the
+\dialog{Layer Properties} dialog. The new dialog allows to choose one of the
+three renderers: single symbol, categorized and graduated. Depending on the
+chosen renderer, the symbology tab provides different settings and options, that
+will be described in the following sections.
+\minisec{Single Symbol Renderer}
+The Single Symbol Renderer is used to render all features of the layer using a
+single user-defined symbol. The properties, that can be adjusted in the
+Symbology tab, depend partially on the type of the layer, but all types share
+the following structure. In the top left part of the tab, there is a preview of
+the current symbol to be rendered. In the bottom part of the tab, there is a
+list of symbols already defined for the current style, prepared to be used via
+selecting them from the list. The current symbol can be modified using the
+\button{Properties} button, which opens a \dialog{Symbol Properties} dialog, or
+the \button{Set Color} button, which opens an ordinary \dialog{Color} dialog.
+After having done any needed changes, the symbol can be added to the list of
+current style symbols (using the \button{Add to style} button) and then easily
+be used in the future.
+\begin{figure}[h]
+\centering
+\caption{New Single Symbolizing options \nixcaption}
+ \subfigure[Single symbol point properties] {\label{subfig:singleNG1}\includegraphics[clip=true, width=0.3\textwidth]{singlesymbol_ng_point}}\goodgap
+ \subfigure[Single symbol line properties] {\label{subfig:singleNG2}\includegraphics[clip=true, width=0.3\textwidth]{singlesymbol_ng_line}}\goodgap
+ \subfigure[Single symbol area properties] {\label{subfig:singleNG3}\includegraphics[clip=true, width=0.3\textwidth]{singlesymbol_ng_area}}
+\end{figure}
+\minisec{Categorized Renderer}
+The Categorized Renderer is used to render all features from a layer, using a
+single user-defined symbol, which color reflects the value of a selected
+feature's attribute. The Symbology tab allows you to select:
+\begin{itemize}
+\item The attribute (using the Column listbox)
+\item The symbol (using the Symbol Properties dialog)
+\item The colors (using the Color Ramp listbox)
+\end{itemize}
+For convenience, the list in the bottom part of the tab lists the values of
+all currently selected attributes together, including the symbols that will
+be rendered.
+The example in figure \ref{fig:catsymNG} shows the category rendering dialog
+used for the rivers layer of the qgis sample dataset.
+\begin{figure}[ht]
+ \begin{center}
+ \caption{New Categorized Symbolizing options \nixcaption}\label{fig:catsymNG}\smallskip
+ \includegraphics[clip=true, width=10cm]{categorysymbol_ng_line}
+\end{center}
+\end{figure}
+\minisec{Graduated rendering}
+The Graduated Renderer is used to render all the features from a layer, using
+a single user-defined symbol, whose color reflects the classification of a selected
+feature's attribute to a class.
+Analogue to the categorized rendered, the symbology tab allows you to select:
+\begin{itemize}
+\item The symbol (using the Symbol Properties button)
+\item The colors (using the Color Ramp list)
+\end{itemize}
+Additionally, you can specify the number of classes and also the mode how to
+classify features inside the classes (using the Mode list). The listbox in the
+bottom part of the symbology tab lists the classes together with their ranges,
+labels and symbols that will be rendered.
+The example in figure \ref{fig:gradsymNG} shows the category rendering dialog
+for the rivers layer of the qgis sample dataset.
+\begin{figure}[ht]
+ \begin{center}
+ \caption{New Graduated Symbolizing options \nixcaption}\label{fig:gradsymNG}\smallskip
+ \includegraphics[clip=true, width=10cm]{graduatesymbol_ng_line}
+\end{center}
+\end{figure}
+\minisec{Symbol Properties}
+The symbol properties dialog allows the user to specify different properties of
+the symbol to be rendered. In the top left part of the dialog, you find a preview
+of the current symbol as it will be displayed in the map canvas. Below the preview
+is the list of symbol layers. To start the symbol properties dialog, click the
+\dropmenuopttwo{mActionOptions}{Properties} button in the \tab{General} tab of the
+The control panels allow adding or removing layers, changing the position of layers,
+or locking layers for color changes. In the right part of the dialog, there are
+shown the settings applicable to the single symbol layer selected in the symbol
+layer list. The most important is the 'Symbol Layer Type' combo box, which allows
+you to choose the layer type. The available options are \filename{SimpleLine},
+\filename{SvgMarker} and \filename{SimpleFill}.
+Depending on the chosen value, these settings are available in the right part
+of the dialog:
+\begin{itemize}
+\item \textbf{SimpleLine}: Color, Pen width, Pen style, Offset, Join style and Cap style;
+\item \textbf{SvgMarker}: Size, Angle, Offset X, Offset Y and SVG Image
+\item \textbf{SimpleFill}: Color, Border color, Fill style.
+\end{itemize}
+Example: A picture showing a line symbol composed from three simple lines with different pen widths.
+Example: Symbol properties for a point layer
+Example: Symbol properties filling pattern for a polygon layer
+\begin{figure}[h]
+\centering
+\caption{Defining symbol properties \nixcaption}
+ \subfigure[Line composed from three simple lines] {\label{subfig:symprops1}\includegraphics[clip=true, width=0.3\textwidth]{symbolproperties1}}\goodgap
+ \subfigure[Symbol properties for point layer] {\label{subfig:symprops2}\includegraphics[clip=true, width=0.3\textwidth]{symbolproperties2}}\goodgap
+ \subfigure[Filling pattern for a polygon] {\label{subfig:symprops3}\includegraphics[clip=true, width=0.3\textwidth]{symbolproperties3}}
+\end{figure}
+\subsubsection{Style Manager to manage symbols and color ramps}
+The Style Manger is a small helper application, that lists symbols and color
+ramps available in a style. It also allows you to add and/or remove items. To
+launch the Style Manager, click on \mainmenuopt{Settings} > \dropmenuopt{Style
+Manager} in the mai menu.
+\begin{figure}[ht]
+ \begin{center}
+ \caption{Style Manager to manage symbols and color ramps \nixcaption}\label{fig:stylemanager}\smallskip
+ \includegraphics[clip=true, width=7cm]{stylemanager}
+\end{center}
+\end{figure}
\subsubsection{Labels Tab}
The \tab{Labels} tab allows you to enable labeling features and control a number of
Modified: docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile
--- docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile 2010-03-20 14:12:31 UTC (rev 13108)
+++ docs/trunk/english_us/user_guide/working_with_vector_screenies/Makefile 2010-03-20 17:50:00 UTC (rev 13109)
@@ -33,10 +33,20 @@
mActionDeleteAttribute.eps\
mActionCalculateField.eps\
fieldcalculator.eps\
+ stylemanager.eps\
+ singlesymbol_ng_point.eps\
+ singlesymbol_ng_line.eps\
+ singlesymbol_ng_area.eps\
+ categorysymbol_ng_line.eps\
+ graduatesymbol_ng_line.eps\
+ symbolproperties1.eps\
+ symbolproperties2.eps\
+ symbolproperties3.eps\
# digitising_attributes09.eps\
# newvectorlayer.eps\
# querybuilder.eps\
##### TARGETS #####
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/categorysymbol_ng_line.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/categorysymbol_ng_line.png
___________________________________________________________________
Added: svn:mime-type
+ application/octet-stream
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/graduatesymbol_ng_line.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/graduatesymbol_ng_line.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_area.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_area.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_line.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_line.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_point.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/singlesymbol_ng_point.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/stylemanager.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/stylemanager.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties1.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties1.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties2.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties2.png
Added: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties3.png
Property changes on: docs/trunk/english_us/user_guide/working_with_vector_screenies/symbolproperties3.png
