[QGIS Commit] r13116 - in docs/trunk/english_us/user_guide: . plugins_labeling_images
svn_qgis at osgeo.org svn_qgis at osgeo.org
Sat Mar 20 18:36:31 EDT 2010
Author: dassau
Date: 2010-03-20 18:36:30 -0400 (Sat, 20 Mar 2010)
New Revision: 13116
Added:
   docs/trunk/english_us/user_guide/plugins_labeling_images/label_area.png
   docs/trunk/english_us/user_guide/plugins_labeling_images/label_engine.png
   docs/trunk/english_us/user_guide/plugins_labeling_images/label_line.png
   docs/trunk/english_us/user_guide/plugins_labeling_images/label_points.png
   docs/trunk/english_us/user_guide/plugins_labeling.tex
   docs/trunk/english_us/user_guide/plugins_labeling_images/Makefile
added labeling plugin section
Modified: docs/trunk/english_us/user_guide/plugins_labeling.tex
--- docs/trunk/english_us/user_guide/plugins_labeling.tex	2010-03-20 22:19:18 UTC (rev 13115)
+++ docs/trunk/english_us/user_guide/plugins_labeling.tex	2010-03-20 22:36:30 UTC (rev 13116)
@@ -6,4 +6,75 @@
 % comment out the following line:
 %\updatedisclaimer
-The labeling plugin can
+The \toolbtntwo{labeling}{Labeling} plugin provides smart labeling for vector point,
+line and polygon layers and only requires a few parameters. This plugin will replace
+the current QGIS labeling.
+\begin{enumerate}
+  \item Start QGIS and load a vector point, line or polygon layer.
+  \item Load the labeling plugin in the Plugin Manager (see Section
+  \ref{sec:load_core_plugin}), activate the layer in the legend and click on the
+  \toolbtntwo{labeling}{Labeling} icon which appears in the QGIS toolbar menu.
+\end{enumerate}
+\minisec{Labeling point layers}
+First step is to activate the \checkbox{Label this layer} checkbox and select an attribute
+column to use for labeling. After that you can define the label placement and text style,
+labeling priority, scale-based visibility, if every part of multipart feature is to be
+labeled and if features act as obstacles for labels or not (see Figure \ref{fig:pointlabel}).
+\begin{figure}[ht]
+\begin{center}
+   \caption{Smart labeling of vector point layers \nixcaption}\label{fig:pointlabel}\smallskip
+   \includegraphics[clip=true, width=12cm]{label_points}
+\end{center}
+\end{figure}
+\minisec{Labeling line layers}
+column to use for labeling. After that you can define the label placement, orientation,
+distance to feature, text style, labeling priority, scale-based visibility, if every part
+of a multipart line is to be labeled, if lines shall be merged to avoid duplicate labels
+and if features act as obstacles for labels or not (see Figure \ref{fig:linelabel}).
+\begin{figure}[ht]
+\begin{center}
+   \caption{Smart labeling of vector line layers \nixcaption}\label{fig:linelabel}\smallskip
+   \includegraphics[clip=true, width=12cm]{label_line}
+\end{center}
+\end{figure}
+\minisec{Labeling polygon layers}
+column to use for labeling. After that you can define the label placement, distance and text
+style, labeling priority, scale-based visibility, if every part of multipart feature is to be
+labeled and if features act as obstacles for labels or not (see Figure \ref{fig:arealabel}).
+\begin{figure}[ht]
+\begin{center}
+   \caption{Smart labeling of vector polygon layers \nixcaption}\label{fig:arealabel}\smallskip
+   \includegraphics[clip=true, width=12cm]{label_area}
+\end{center}
+\end{figure}
+\minisec{Change engine settings}
+Additionally you can click the \button{Engine settings} button and select the search method,
+used to find the best label placement. Available is Chain, Popmusic Tabu, Popmusic Chain,
+Popmusic Tabu Chain and FALP.
+\begin{figure}[ht]
+\begin{center}
+   \caption{Dialog to change label engine settings \nixcaption}\label{fig:labelengine}\smallskip
+   \includegraphics[clip=true, width=7cm]{label_engine}
+\end{center}
+\end{figure}
+Furthermore the number of candidates can be defined for point, line and polygon features,
+and you can define whether to show all labels (including colliding labels) and label
+candidates for debugging.
Modified: docs/trunk/english_us/user_guide/plugins_labeling_images/Makefile
--- docs/trunk/english_us/user_guide/plugins_labeling_images/Makefile	2010-03-20 22:19:18 UTC (rev 13115)
+++ docs/trunk/english_us/user_guide/plugins_labeling_images/Makefile	2010-03-20 22:36:30 UTC (rev 13116)
@@ -12,6 +12,10 @@
 #	nextfile.eps
 PNG=labeling.eps\
+	label_area.eps\
+	label_engine.eps\
+	label_line.eps\
+	label_points.eps\
 ##### TARGETS #####
Added: docs/trunk/english_us/user_guide/plugins_labeling_images/label_area.png
(Binary files differ)
Property changes on: docs/trunk/english_us/user_guide/plugins_labeling_images/label_area.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: docs/trunk/english_us/user_guide/plugins_labeling_images/label_engine.png
Property changes on: docs/trunk/english_us/user_guide/plugins_labeling_images/label_engine.png
Added: docs/trunk/english_us/user_guide/plugins_labeling_images/label_line.png
Property changes on: docs/trunk/english_us/user_guide/plugins_labeling_images/label_line.png
Added: docs/trunk/english_us/user_guide/plugins_labeling_images/label_points.png
Property changes on: docs/trunk/english_us/user_guide/plugins_labeling_images/label_points.png
More information about the QGIS-commit mailing list
