[QGIS Commit] r13128 -
docs/trunk/english_us/coding-compilation_guide
svn_qgis at osgeo.org
Sun Mar 21 07:30:14 EDT 2010
Author: dassau
Date: 2010-03-21 07:30:13 -0400 (Sun, 21 Mar 2010)
New Revision: 13128
docs/trunk/english_us/coding-compilation_guide/Makefile
docs/trunk/english_us/coding-compilation_guide/coding.tex
docs/trunk/english_us/coding-compilation_guide/install.tex
docs/trunk/english_us/coding-compilation_guide/qgis_style.sty
docs/trunk/english_us/coding-compilation_guide/title.tex
update coding and compilation guide - also in wiki
Modified: docs/trunk/english_us/coding-compilation_guide/Makefile
--- docs/trunk/english_us/coding-compilation_guide/Makefile 2010-03-21 09:36:18 UTC (rev 13127)
+++ docs/trunk/english_us/coding-compilation_guide/Makefile 2010-03-21 11:30:13 UTC (rev 13128)
@@ -21,8 +21,8 @@
make pics
latex $(FILE)
#bibtex $(FILE)
- bibtex $(FILE)1
- bibtex $(FILE)2
+ #bibtex $(FILE)1
+ #bibtex $(FILE)2
#now loop over Latex files, until stable:
echo Rerun > $(FILE).log
while grep Rerun $(FILE).log >/dev/null 2>&1 ; do latex $(FILE).tex ; done
@@ -30,7 +30,7 @@
text:
latex $(FILE)
- bibtex $(FILE)
+ #bibtex $(FILE)
Modified: docs/trunk/english_us/coding-compilation_guide/coding.tex
--- docs/trunk/english_us/coding-compilation_guide/coding.tex 2010-03-21 09:36:18 UTC (rev 13127)
+++ docs/trunk/english_us/coding-compilation_guide/coding.tex 2010-03-21 11:30:13 UTC (rev 13128)
@@ -8,12 +8,12 @@
The following chapters provide coding information for QGIS Version \CURRENT.
This document corresponds almost to a \LaTeX~ conversion of the CODING.t2t
-file coming with the QGIS sources from November, 27th 2009.
+file coming with the QGIS sources from March, 21th 2010.
These standards should be followed by all QGIS developers.
-\subsection{Classes}
-\subsubsection{Names}
+\subsubsection{Classes}
+\minisec{Names}
Class in QGIS begin with Qgs and are formed using mixed case.
\begin{verbatim}
@@ -23,7 +23,7 @@
QgsRasterLayer
\end{verbatim}
-\subsubsection{Members}
+\minisec{Members}
Class member names begin with a lower case \textit{m} and are formed using mixed
case.
@@ -35,9 +35,9 @@
All class members should be private.
\textbf{Public class members are STRONGLY discouraged}
-\subsubsection{Accessor Functions}
+\minisec{Accessor Functions}
Class member values should be obtained through accesssor functions. The
-function should be named without a \textit{get} prefix. Accessor functions for the
+unction should be named without a \textit{get} prefix. Accessor functions for the
two private members above would be:
\begin{verbatim}
@@ -45,7 +45,7 @@
currentExtent()
\end{verbatim}
-\subsubsection{Functions}
+\minisec{Functions}
Function names begin with a lowercase letter and are formed using mixed case.
The function name should convey something about the purpose of the function.
@@ -54,8 +54,8 @@
setUserOptions()
\end{verbatim}
-\subsection{Qt Designer}
-\subsubsection{Generated Classes}
+\subsubsection{Qt Designer}
+\minisec{Generated Classes}
QGIS classes that are generated from Qt Designer (ui) files should have a
\textit{Base} suffix. This identifies the class as a generated base class.
@@ -64,7 +64,7 @@
QgsPluginMangerBase
QgsUserOptionsBase
\end{verbatim}
-\subsubsection{Dialogs}
+\minisec{Dialogs}
All dialogs should implement the following:
* Tooltip help for all toolbar icons and other relevant widgets
* WhatsThis help for \textbf{all} widgets on the dialog
@@ -72,8 +72,8 @@
that directs the user to the appropriate help page by launching their web
browser
-\subsection{C++ Files}
+\subsubsection{C++ Files}
+\minisec{Names}
C++ implementation and header files should be have a .cpp and .h extension
respectively. Filename should be all lowercase and, in the case of classes,
match the class name.
@@ -89,7 +89,7 @@
and implemented in its own file. This makes it much easier for newcomers to
identify where the code is relating to specific class.
-\subsubsection{Standard Header and License}
+\minisec{Standard Header and License}
Each source file should contain a header section patterned after the following
example:
@@ -110,7 +110,7 @@
\end{verbatim}
-\subsubsection{SVN Keyword}
+\minisec{SVN Keyword}
Each source file should contain the \$Id\$ keyword. This will be expanded by CVS
to contain useful information about the file, revision, last committer, and
date/time of last checkin.
@@ -122,7 +122,7 @@
/* $Id$ */
\end{verbatim}
-\subsection{Variable Names}
+\subsubsection{Variable Names}
Variable names begin with a lower case letter and are formed using mixed case.
\begin{verbatim}
@@ -131,7 +131,7 @@
currentExtent
\end{verbatim}
-\subsection{Enumerated Types}
+\subsubsection{Enumerated Types}
Enumerated types should be named in CamelCase with a leading capital e.g.:
\begin{verbatim}
@@ -147,28 +147,28 @@
Do not use generic type names that will conflict with other types. e.g. use
"UnkownUnit" rather than "Unknown"
-\subsection{Global Constants}
+\subsubsection{Global Constants}
Global constants should be written in upper case underscore separated e.g.:
\begin{verbatim}
const long GEOCRS_ID = 3344;
\end{verbatim}
-\subsection{Editing}
+\subsubsection{Editing}
Any text editor/IDE can be used to edit QGIS code, providing the following
requirements are met.
-\subsubsection{Tabs}
+\minisec{Tabs}
Set your editor to emulate tabs with spaces. Tab spacing should be set to 2
spaces.
-\subsubsection{Indentation}
+\minisec{Indentation}
Source code should be indented to improve readability. There is a .indent.pro
file in the QGIS src directory that contains the switches to be used when
indenting code using the GNU indent program. If you don't use GNU indent, you
should emulate these settings.
-\subsubsection{Braces}
+\minisec{Braces}
Braces should start on the line following the expression:
\begin{verbatim}
@@ -183,7 +183,7 @@
\end{verbatim}
-\subsection{API Compatibility}
+\subsubsection{API Compatibility}
From QGIS 1.0 we will provide a stable, backwards compatible API. This will
provide a stable basis for people to develop against, knowing their code will
work against any of the 1.x QGIS releases (although recompiling may be
@@ -208,11 +208,11 @@
\end{verbatim}
-\subsection{Coding Style}
+\subsubsection{Coding Style}
Here are described some programming hints and tips that will hopefully reduce
errors, development time, and maintenance.
-\subsubsection{Where-ever Possible Generalize Code}
+\minisec{Where-ever Possible Generalize Code}
\begin{verbatim}
If you are cut-n-pasting code, or otherwise writing the same thing more than
once, consider consolidating the code into a single function.
@@ -224,7 +224,7 @@
* make it more difficult for multiple copies to evolve differences over time,
thus making it harder to understand and maintain for others
-\subsubsection{Prefer Having Constants First in Predicates}
+\minisec{Prefer Having Constants First in Predicates}
Prefer to put constants first in predicates.
\begin{verbatim}
@@ -236,7 +236,7 @@
generate an error if you accidentally use "=" instead of "==" for comparisons
since constants inherently cannot be assigned values.
-\subsubsection{Whitespace Can Be Your Friend}
+\minisec{Whitespace Can Be Your Friend}
Adding spaces between operators, statements, and functions makes it easier for
humans to parse code.
@@ -252,7 +252,7 @@
if ( ! a && b )
\end{verbatim}
-\subsubsection{Add Trailing Identifying Comments}
+\minisec{Add Trailing Identifying Comments}
Adding comments at the end of function, struct and class implementations makes
it easier to find them later.
@@ -272,7 +272,7 @@
} // foo::bar()
\end{verbatim}
-\subsubsection{Use Braces Even for Single Line Statements}
+\minisec{Use Braces Even for Single Line Statements}
Using braces for code in if/then blocks or similar code structures even for
single line statements means that adding another statement is less likely to
generate broken code.
@@ -303,33 +303,31 @@
\end{verbatim}
-\subsubsection{Book recommendations}
+\minisec{Book recommendations}
\begin{itemize}
-\item \url{http://www.awprofessional.com/title/0321334876}, Scott Meyers
-\item \url{http://www.awprofessional.com/bookstore/product.asp?isbn=020163371X&rl=1}, Scott Meyers
-\item \url{http://www.awprofessional.com/title/0201749629}, Scott Meyers
-\item \url{http://www.awprofessional.com/title/0201634988}, GoF
+\item \url{Effective C++}{http://www.awprofessional.com/title/0321334876}, Scott Meyers
+\item \url{More Effective C++}{http://www.awprofessional.com/bookstore/product.asp?isbn=020163371X\&rl=1}, Scott Meyers
+\item \url{Effective STL}{http://www.awprofessional.com/title/0201749629}, Scott Meyers
+\item \url{Design Patterns}{http://www.awprofessional.com/title/0201634988}, GoF
\end{itemize}
You should also really read this article from Qt Quarterly on
-\url{http://doc.trolltech.com/qq/qq13-apis.html}
+\htmladdnormallink{http://doc.trolltech.com/qq/qq13-apis.html designing Qt style}{APIs}
-\section{SVN Access}
+\subsection{SVN Access}
This page describes how to get started using the QGIS Subversion repository
-\subsection{Accessing the Repository}
+\subsubsection{Accessing the Repository}
To check out QGIS HEAD:
\begin{verbatim}
svn --username [your user name] co https://svn.osgeo.org/qgis/trunk/qgis
\end{verbatim}
-\subsection{Anonymous Access}
+\subsubsection{Anonymous Access}
You can use the following commands to perform an anonymous checkout from the
QGIS Subversion repository. Note we recommend checking out the trunk (unless
-you are a developer or really HAVE to have the latest changes and dont mind
+you are a developer or really HAVE to have the latest changes and don't mind
lots of crashing!).
You must have a subversion client installed prior to checking out the code. See
@@ -359,7 +357,7 @@
See the INSTALL file in the source tree for specific instructions on building
development versions.
-\subsection{QGIS documentation sources}
+\subsubsection{QGIS documentation sources}
If you're interested in checking out Quantum GIS documentation sources:
\begin{verbatim}
@@ -368,16 +366,16 @@
You can also take a look at DocumentationWritersCorner for more information.
-\subsection{SVN Documentation}
+\subsubsection{SVN Documentation}
The repository is organized as follows:
-\url{http://wiki.qgis.org/images/repo.png}
+\htmladdnormallink{http://wiki.qgis.org/images/repo.png}{http://wiki.qgis.org/images/repo.png}
-See the Subversion book \url{http://svnbook.red-bean.com} for information on becoming
+See the Subversion book \htmladdnormallink{http://svnbook.red-bean.com}{http://svnbook.red-bean.com} for information on becoming
a SVN master.
-\subsection{Development in branches}
-\subsubsection{Purpose}
+\subsubsection{Development in branches}
+\minisec{Purpose}
The complexity of the QGIS source code has increased considerably during the
last years. Therefore it is hard to anticipate the side effects that the
addition of a feature will have. In the past, the QGIS project had very long
@@ -388,7 +386,7 @@
This section describes the procedure for branching and merging in the QGIS
project.
-\subsubsection{Procedure}
+\minisec{Procedure}
\begin{itemize}
\item \textbf{Initial announcement on mailing list:}
Before starting, make an announcement on the developer mailing list to see if
@@ -396,15 +394,19 @@
technical advisor of the project steering committee (PSC). If the new feature
requires any changes to the QGIS architecture, a request for comment (RFC) is
needed.
\item \textbf{Create a branch:}
Create a new svn branch for the development of the new feature (see
UsingSubversion for the svn syntax). Now you can start developing.
\item \textbf{Merge from trunk regularly:}
It is recommended to merge the changes in trunk to the branch on a regular
basis. This makes it easier to merge the branch back to trunk later.
\item \textbf{Documentation on wiki:}
It is also recommended to document the intended changes and the current status
of the work on a wiki page.
\item \textbf{Testing before merging back to trunk:}
When you are finished with the new feature and happy with the stability, make
an announcement on the developer list. Before merging back, the changes will
@@ -412,10 +414,11 @@
Windows) will be generated to also involve non-developers. In trac, a new
Component will be opened to file tickets against. Once there are no remaining
issues left, the technical advisor of the PSC merges the changes into trunk.
\end{itemize}
-\subsubsection{Creating a branch}
+\minisec{Creating a branch}
We prefer that new feature developments happen out of trunk so that trunk
remains in a stable state. To create a branch use the following command:
@@ -425,7 +428,7 @@
svn commit -m "New feature branch"
\end{verbatim}
-\subsubsection{Merge regularly from trunk to branch}
+\minisec{Merge regularly from trunk to branch}
When working in a branch you should regularly merge trunk into it so that your
branch does not diverge more than necessary. In the top level dir of your
branch, first type \texttt{`svn info`} to determine the revision numbers of your
@@ -435,15 +438,15 @@
timlinux at timlinux-desktop:~/dev/cpp/qgis_raster_transparency_branch$ svn info
Caminho: .
URL: https://svn.osgeo.org/qgis/branches/raster_transparency_branch
-Raiz do Repositorio: https://svn.osgeo.org/qgis
-UUID do repositorio: c8812cc2-4d05-0410-92ff-de0c093fc19c
-Revisao: 6546
-Tipo de No: diretorio
+Raiz do Repositrio: https://svn.osgeo.org/qgis
+UUID do repositrio: c8812cc2-4d05-0410-92ff-de0c093fc19c
+Reviso: 6546
+Tipo de N: diretrio
Agendado: normal
-Autor da Ultima Mudanca: timlinux
-Revisao da Ultima Mudanca: 6495
-Data da Ultima Mudanca: 2007-02-02 09:29:47 -0200 (Sex, 02 Fev 2007)
-Propriedades da Ultima Mudanca: 2007-01-09 11:32:55 -0200 (Ter, 09 Jan 2007)
+Autor da ltima Mudana: timlinux
+Reviso da ltima Mudana: 6495
+Data da ltima Mudana: 2007-02-02 09:29:47 -0200 (Sex, 02 Fev 2007)
+Propriedades da ltima Mudana: 2007-01-09 11:32:55 -0200 (Ter, 09 Jan 2007)
\end{verbatim}
The second revision number shows the revision number of the start revision of
@@ -462,19 +465,19 @@
svn commit -m "Merged upstream changes from trunk to my branch"
\end{verbatim}
-\subsection{Submitting Patches}
+\subsubsection{Submitting Patches}
There are a few guidelines that will help you to get your patches into QGIS
easily, and help us deal with the patches that are sent to use easily.
-\subsubsection{Patch file naming}
+\minisec{Patch file naming}
If the patch is a fix for a specific bug, please name the file with the bug
number in it e.g. \textbf{bug777fix.diff}, and attach it to the original bug report
-in trac (\url{https://trac.osgeo.org/qgis/}).
+in trac (\htmladdnormallink{https://trac.osgeo.org/qgis/}{https://trac.osgeo.org/qgis/}).
If the bug is an enhancement or new feature, its usually a good idea to create
-a ticket in trac (\url{https://trac.osgeo.org/qgis/}) first and then attach you
+a ticket in trac (\htmladdnormallink{https://trac.osgeo.org/qgis/}{https://trac.osgeo.org/qgis/}) first and then attach you
-\subsubsection{Create your patch in the top level QGIS source dir}
+\minisec{Create your patch in the top level QGIS source dir}
This makes it easier for us to apply the patches since we don't need to
navigate to a specific place in the source tree to apply the patch. Also when I
receive patches I usually evaluate them using kompare, and having the patch
@@ -487,7 +490,7 @@
svn diff src/ui/somefile.ui src/app/somefile2.cpp > bug872fix.diff
\end{verbatim}
-\subsubsection{Including non version controlled files in your patch}
+\minisec{Including non version controlled files in your patch}
If your improvements include new files that don't yet exist in the repository,
you should indicate to svn that they need to be added before generating your
patch e.g.
@@ -498,21 +501,21 @@
svn diff > bug7887fix.diff
\end{verbatim}
-\subsubsection{Getting your patch noticed}
+\minisec{Getting your patch noticed}
QGIS developers are busy folk. We do scan the incoming patches on bug reports
but sometimes we miss things. Don't be offended or alarmed. Try to identify a
developer to help you - using the ["Project Organigram"] and contact them
-asking them if they can look at your patch. If you dont get any response, you
+asking them if they can look at your patch. If you don't get any response, you
can escalate your query to one of the Project Steering Committee members
(contact details also available on the ["Project Organigram"]).
-\subsubsection{Due Diligence}
+\minisec{Due Diligence}
QGIS is licensed under the GPL. You should make every effort to ensure you only
submit patches which are unencumbered by conflicting intellectual property
rights. Also do not submit code that you are not happy to have made available
under the GPL.
-\subsection{Obtaining SVN Write Access}
+\subsubsection{Obtaining SVN Write Access}
Write access to QGIS source tree is by invitation. Typically when a person
submits several (there is no fixed number here) substantial patches that
demonstrate basic competance and understanding of C++ and QGIS coding
@@ -525,7 +528,7 @@
substantial patches that demonstrate their understanding of modifying the code
base without breaking things, etc.
-\subsubsection{Procedure once you have access}
+\minisec{Procedure once you have access}
Checkout the sources:
\begin{verbatim}
@@ -574,7 +577,7 @@
\end{verbatim}
Your editor (as defined in \$EDITOR environment variable) will appear and you
-should make a comment at the top of the file (above the area that says 'dont
+should make a comment at the top of the file (above the area that says 'don't
change this'. Put a descriptive comment and rather do several small commits if
the changes across a number of files are unrelated. Conversely we prefer you to
group related changes into a single commit.
@@ -584,14 +587,14 @@
trac account.
-\section{Unit Testing}
+\subsection{Unit Testing}
As of November 2007 we require all new features going into trunk to be
accompanied with a unit test. Initially we have limited this requirement to
\textbf{qgis\_core}, and we will extend this requirement to other parts of the code base
once people are familiar with the procedures for unit testing explained in the
sections that follow.
-\subsection{The QGIS testing framework - an overview}
+\subsubsection{The QGIS testing framework - an overview}
Unit testing is carried out using a combination of QTestLib (the Qt testing
library) and CTest (a framework for compiling and running tests as part of the
CMake build process). Lets take an overview of the process before I delve into
@@ -642,7 +645,7 @@
already done much of the configuration for you in CMake and other places in the
source tree so all you need to do are the easy bits - writing unit tests!
-\subsection{Creating a unit test}
+\subsubsection{Creating a unit test}
Creating a unit test is easy - typically you will do this by just creating a
single .cpp file (not .h file is used) and implement all your test methods as
public methods that return void. I'll use a simple test class for
@@ -773,7 +776,7 @@
regression test along with the bug fix. Now if anybody breakes this in the
source code again in the future, we can immediatly identify that the code has
regressed. Better yet before committing any changes in the future, running our
-tests will ensure our changes dont have unexpected side effects - like breaking
+tests will ensure our changes don't have unexpected side effects - like breaking
existing functionality.
There is one more benifit to regression tests - they can save you time. If you
@@ -834,14 +837,14 @@
#endif
//create some objects that will be used in all tests...
- std::cout << "Prefix PATH: " << \
- QgsApplication::prefixPath().toLocal8Bit().data() << std::endl;
- std::cout << "Plugin PATH: " << \
- QgsApplication::pluginPath().toLocal8Bit().data() << std::endl;
- std::cout << "PkgData PATH: " << \
- QgsApplication::pkgDataPath().toLocal8Bit().data() << std::endl;
- std::cout << "User DB PATH: " << \
- QgsApplication::qgisUserDbFilePath().toLocal8Bit().data() << std::endl;
+ std::cout << "Prefix PATH: " << QgsApplication::prefixPath().toLocal8Bit().data()
+ << std::endl;
+ std::cout << "Plugin PATH: " << QgsApplication::pluginPath().toLocal8Bit().data()
+ << std::endl;
+ std::cout << "PkgData PATH: " << QgsApplication::pkgDataPath().toLocal8Bit().data()
+ << std::endl;
+ std::cout << "User DB PATH: " << QgsApplication::qgisUserDbFilePath().toLocal8Bit().data()
+ << std::endl;
//create a raster layer that will be used in all tests...
QString myFileName (TEST_DATA_DIR); //defined in CmakeLists.txt
@@ -938,7 +941,7 @@
line is the include for the MOC generated sources. You should replace
'testqgsrasterlayer' with the name of your class in lower case.
-\subsection{Adding your unit test to CMakeLists.txt}
+\subsubsection{Adding your unit test to CMakeLists.txt}
Adding your unit test to the build system is simply a matter of editing the
CMakeLists.txt in the test directory, cloning one of the existing test blocks,
and then replacing your test class name into it. For example:
@@ -948,7 +951,7 @@
ADD_QGIS_TEST(rasterlayertest testqgsrasterlayer.cpp)
\end{verbatim}
-\subsection{The ADD\_QGIS\_TEST macro explained}
+\subsubsection{The ADD\_QGIS\_TEST macro explained}
I'll run through these lines briefly to explain what they do, but if you are
not interested, just do the step explained in the above section and section.
@@ -1061,7 +1064,7 @@
suite of tests and you want to run each executeable in turn, and better yet
integrate running tests into the build process, the \textbf{CTest} is what we use.
-\subsection{Building your unit test}
+\subsubsection{Building your unit test}
To build the unit test you need only to make sure that ENABLE\_TESTS=true in the
cmake configuration. There are two ways to do this:
@@ -1071,7 +1074,7 @@
Other than that, just build QGIS as per normal and the tests should build too.
-\subsection{Run your tests}
+\subsubsection{Run your tests}
The simplest way to run the tests is as part of your normal build process:
\begin{verbatim}
@@ -1125,8 +1128,8 @@
User DB PATH: /Users/tim/.qgis/qgis.db
QDEBUG : TestQgsApplication::checkTheme() Checking if a theme icon exists:
- /Users/tim/dev/cpp/qgis/build/tests/src/core/\
- ..//share/qgis/themes/default//mIconProjectionDisabled.png
+ /Users/tim/dev/cpp/qgis/build/tests/src/core/../ \
+ /share/qgis/themes/default//mIconProjectionDisabled.png
FAIL! : TestQgsApplication::checkTheme() '!myPixmap.isNull()' returned FALSE. ()
Loc: [/Users/tim/dev/cpp/qgis/tests/src/core/testqgsapplication.cpp(59)]
PASS : TestQgsApplication::cleanupTestCase()
@@ -1150,7 +1153,8 @@
works in a truly platform way. I will update this document as things
progress.
-\section{HIG (Human Interface Guidelines)}
+\subsection{HIG (Human Interface Guidelines)}
In order for all graphical user interface elements to appear consistant and to
all the user to instinctively use dialogs, it is important that the following
guidelines are followed in layout and design of GUIs.
@@ -1165,8 +1169,8 @@
capital letter, and all remaing words written with lower case first letters
\item Do not end labels for widgets or group boxes with a colon:
Adding a colon causes visual noise and does not impart additional meaning,
- so dont use them. An exception to this rule is when you have two labels next
- to each other e.g.: Label1 \url{Plugin}{Path:} Label2 [/path/to/plugins]
+ so don't use them. An exception to this rule is when you have two labels next
+ to each other e.g.: Label1 \htmladdnormallink{Plugin}{Path:} Label2 [/path/to/plugins]
\item Keep harmful actions away from harmless ones:
If you have actions for 'delete', 'remove' etc, try to impose adequate space
between the harmful action and innocuous actions so that the users is less
@@ -1176,3 +1180,5 @@
buttons is consistent with the operating system / locale / desktop
environment that the user is using.
\end{enumerate}
Modified: docs/trunk/english_us/coding-compilation_guide/install.tex
--- docs/trunk/english_us/coding-compilation_guide/install.tex 2010-03-21 09:36:18 UTC (rev 13127)
+++ docs/trunk/english_us/coding-compilation_guide/install.tex 2010-03-21 11:30:13 UTC (rev 13128)
@@ -13,61 +13,52 @@
A current version is also available at the wiki, see:
\url{http://www.qgis.org/wiki/Installation_Guide}
-\section{General Build Notes}
+\subsection{General Build Notes}
Since version 0.8.1 QGIS no longer uses the autotools for building. QGIS, like a
-number of major projects (eg. KDE 4.0), now uses CMake (\url {http://www.cmake.org}{http://www.cmake.org})
+number of major projects (eg. KDE 4.0), now uses CMake (\htmladdnormallink{http://www.cmake.org}{http://www.cmake.org})
for building from source. The configure script in this directory simply checks
for the existence of cmake and provides some clues to build QGIS.
-For complete information, see the wiki at:
-\url{http://wiki.qgis.org/qgiswiki/Building\_with\_CMake}
+\subsubsection{An overview of the dependencies required for building}
+'''Required build deps:'''
+* CMake $>$= 2.4.3
+* Flex, Bison
-\subsection{An overview of the dependencies required for building}
-\textbf{Required build deps:}
-\begin{itemize}
-\item CMake $>$= 2.4.3
-\item Flex, Bison
-\end{itemize}
+'''Required runtime deps:'''
+* Qt $>$= 4.3.0
+* Proj $>$= 4.4.x
+* GEOS $>$= 3.0
+* Sqlite3 $>$= 3.0.0
+* GDAL/OGR $>$= 1.4.x
-\textbf{Required runtime deps:}
-\begin{itemize}
-\item Qt $>$= 4.3.0
-\item Proj $>$= ? (known to work with 4.4.x)
-\item GEOS $>$= 2.2 (3.0 is supported, maybe 2.1.x works too)
-\item Sqlite3 $>$= ? (probably 3.0.0)
-\item GDAL/OGR $>$= 1.4.x
-\end{itemize}
+'''Optional dependencies:'''
+* for GRASS plugin - GRASS $>$= 6.0.0 (libraries compiled with exceptions support)
+* for georeferencer - GSL $>$= 1.8
+* for postgis support and SPIT plugin - PostgreSQL $>$= 8.0.x
+* for gps plugin - expat $>$= 1.95
+* for mapserver export and PyQGIS - Python $>$= 2.3 (2.5+ preferred)
+* for PyQGIS - SIP $>$= 4.8, PyQt $>$= must match Qt version
+* for GPS tracking - Qwt $>$= 5.0
-\textbf{Optional dependencies:}
-\begin{itemize}
-\item for GRASS plugin - GRASS $>$= 6.0.0
-\item for georeferencer - GSL $>$= ? (works with 1.8)
-\item for postgis support and SPIT plugin - PostgreSQL $>$= 8.0.x
-\item for gps plugin - expat $>$= ? (1.95 is OK)
-\item for mapserver export and PyQGIS - Python $>$= 2.3 (2.5+ preferred)
-\item for PyQGIS - SIP $>$= 4.5, PyQt $>$= must match Qt version
-\end{itemize}
+'''Recommended runtime deps:'''
+* for gps plugin - gpsbabel
-\textbf{Recommended runtime deps:}
-\begin{itemize}
-\item for gps plugin - gpsbabel
-\end{itemize}
-\section{Building under windows using msys}
+\subsection{Building under windows using msys}
\textbf{Note:} For a detailed account of building all the dependencies yourself you
can visit Marco Pasetti's website here:
-\url{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}
+\htmladdnormallink{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}{http://www.webalice.it/marco.pasetti/qgis+grass/BuildFromSource.html}
Read on to use the simplified approach with pre-built libraries...
-\subsection{MSYS:}
+\subsubsection{MSYS:}
MSYS provides a unix style build environment under windows. We have created a
zip archive that contains just about all dependencies.
Get this:
-\url {http://download.osgeo.org/qgis/win32/msys.zip}
+\htmladdnormallink{http://download.osgeo.org/qgis/win32/msys.zip}{http://download.osgeo.org/qgis/win32/msys.zip}
and unpack to c:$\backslash$msys
@@ -75,11 +66,11 @@
our pre-made one, detailed instructions are provided elsewhere in this
document.
-\subsection{Qt4.3}
+\subsubsection{Qt4.3}
Download qt4.3 opensource precompiled edition exe and install (including the
download and install of mingw) from here:
-\url{http://qt.nokia.com/downloads}
+\htmladdnormallink{http://qt.nokia.com/downloads}{http://qt.nokia.com/downloads}
When the installer will ask for MinGW, you don't need to download and install
it, just point the installer to c:$\backslash$msys$\backslash$mingw
@@ -108,33 +99,33 @@
c:\Qt\4.3.0 make
\end{verbatim}
-\subsection{Flex and Bison}
-\textbf{Note}: I think this section can be removed as it should be installed int the
+\subsubsection{Flex and Bison}
+*** Note I think this section can be removed as it should be installed int the
msys image already. TS
Get Flex
-\url{http://sourceforge.net/project/showfiles.php?group\_id=23617&package\_id=16424}
+\htmladdnormallink{http://sourceforge.net/project/showfiles.php?group\_id=23617\&package\_id=16424}{http://sourceforge.net/project/showfiles.php?group\_id=23617\&package\_id=16424}
(the zip bin) and extract it into c:$\backslash$msys$\backslash$mingw$\backslash$bin
-\subsection{Python stuff: (optional)}
+\subsubsection{Python stuff: (optional)}
Follow this section in case you would like to use Python bindings for QGIS. To
be able to compile bindings, you need to compile SIP and PyQt4 from sources as
their installer doesn't include some development files which are necessary.
-\subsubsection{Download and install Python - use Windows installer}
+\minisec{Download and install Python - use Windows installer}
(It doesn't matter to what folder you'll install it)
-\url{http://python.org/download/}
+\htmladdnormallink{http://python.org/download/}{http://python.org/download/}
-\subsubsection{Download SIP and PyQt4 sources}
-\url{http://www.riverbankcomputing.com/software/sip/download} \\
-\url{http://www.riverbankcomputing.com/software/pyqt/download}
+\minisec{Download SIP and PyQt4 sources}
+\htmladdnormallink{http://www.riverbankcomputing.com/software/sip/download}{http://www.riverbankcomputing.com/software/sip/download}
+\htmladdnormallink{http://www.riverbankcomputing.com/software/pyqt/download}{http://www.riverbankcomputing.com/software/pyqt/download}
Extract each of the above zip files in a temporary directory. Make sure
to get versions that match your current Qt installed version.
-\subsubsection{Compile SIP}
+\minisec{Compile SIP}
\begin{verbatim}
c:\Qt\4.3.0\bin\qtvars.bat
python configure.py -p win32-g++
@@ -142,7 +133,7 @@
make install
\end{verbatim}
-\subsubsection{Compile PyQt}
+\minisec{Compile PyQt}
\begin{verbatim}
python configure.py
@@ -150,22 +141,22 @@
make install
\end{verbatim}
-\subsubsection{Final python notes}
-\textbf{Note}: You can delete the directories with unpacked SIP and PyQt4 sources after a
+\minisec{Final python notes}
+/!$\backslash$ You can delete the directories with unpacked SIP and PyQt4 sources after a
successfull install, they're not needed anymore.
-\subsection{Subversion:}
+\subsubsection{Subversion:}
In order to check out QGIS sources from the repository, you need Subversion
client. This installer should work fine:
-\url{http://subversion.tigris.org/files/documents/15/36797/svn-1.4.3-setup.exe}
+\htmladdnormallink{http://subversion.tigris.org/files/documents/15/36797/svn-1.4.3-setup.exe}{http://subversion.tigris.org/files/documents/15/36797/svn-1.4.3-setup.exe}
-\subsection{CMake:}
+\subsubsection{CMake:}
CMake is build system used by Quantum GIS. Download it from here:
-\url{http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe}
+\htmladdnormallink{http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe}{http://www.cmake.org/files/v2.4/cmake-2.4.6-win32-x86.exe}
-\subsection{QGIS:}
+\subsubsection{QGIS:}
Start a cmd.exe window ( Start -$>$ Run -$>$ cmd.exe ) Create development
directory and move into it
@@ -185,7 +176,7 @@
svn co https://svn.osgeo.org/qgis/branches/Release-0_8_0 qgis0.8
\end{verbatim}
-\subsection{Compiling:}
+\subsubsection{Compiling:}
As a background read the generic building with CMake notes at the end of
this document.
@@ -206,12 +197,12 @@
cd build
\end{verbatim}
-\subsection{Configuration}
+\subsubsection{Configuration}
\begin{verbatim}
cmakesetup ..
\end{verbatim}
-\textbf{Note}: NOTE: You must include the '..' above.
+/!$\backslash$ NOTE: You must include the '..' above.
Click 'Configure' button. When asked, you should choose 'MinGW Makefiles'
as generator.
@@ -228,18 +219,18 @@
When configuration is done, click 'OK' to exit the setup utility.
-\subsection{Compilation and installation}
+\subsubsection{Compilation and installation}
\begin{verbatim}
make make install
\end{verbatim}
-\subsection{Run qgis.exe from the directory where it's installed (CMAKE\_INSTALL\_PREFIX)}
+\minisec{Run qgis.exe from the directory where it's installed (CMAKE\_INSTALL\_PREFIX)}
Make sure to copy all .dll:s needed to the same directory as the qgis.exe
binary is installed to, if not already done so, otherwise QGIS will complain
about missing libraries when started.
The best way to do this is to download both the QGIS current release installer
-package from \url{http://qgis.org/uploadfiles/testbuilds/} and install it. Now copy
+package from \htmladdnormallink{http://qgis.org/uploadfiles/testbuilds/}{http://qgis.org/uploadfiles/testbuilds/} and install it. Now copy
the installation dir from C:$\backslash$Program Files$\backslash$Quantum GIS into c:$\backslash$Program
Files$\backslash$qgis-0.8.1 (or whatever the current version is. The name should strictly
match the version no.) After making this copy you can uninstall the release
@@ -251,32 +242,34 @@
c:$\backslash$msys$\backslash$local$\backslash$bin and c:$\backslash$msys$\backslash$local$\backslash$lib directories, so the DLLs will be
used from that place.
-\subsection{Create the installation package: (optional)}
-Downlad and install NSIS from (\url{http://nsis.sourceforge.net/Main\_Page})
+\subsubsection{Create the installation package: (optional)}
+Downlad and install NSIS from (\htmladdnormallink{http://nsis.sourceforge.net/Main\_Page}{http://nsis.sourceforge.net/Main\_Page})
Now using windows explorer, enter the win\_build directory in your QGIS source
tree. Read the READMEfile there and follow the instructions. Next right click
on qgis.nsi and choose the option 'Compile NSIS Script'.
-\section{Building on Mac OSX using frameworks and cmake (QGIS $>$ 0.8)}
+\subsection{Building on Mac OSX using frameworks and cmake or Xcode}
In this approach I will try to avoid as much as possible building dependencies
from source and rather use frameworks wherever possible.
-Included are a few notes for building on Mac OS X 10.5 (\underline{Leopard}) and 10.6
-(\underline{Snow Leopard}).
+The base system here is Mac OS X 10.4 (\underline{Tiger}) and below. Included are a few notes
+for building on Mac OS X 10.5 (\underline{Leopard}) and 10.6 (\underline{Snow Leopard}).
\underline{Snow Leopard note:} A cmake/qt/sip bug currently exists where a 32-bit
cmake build fails to provide python bindings. This means that python plugin support
is currently lacking for 32-bit builds using cmake in Snow Leopard. See the Xcode
build method to if you require python support.
-\subsection{Install XCODE}
-I recommend to get the latest xcode dmg from the Apple XDC Web site. Install
-XCODE after the \~{}1gb download is complete.
+\subsubsection{Install Xcode}
+I recommend to get the latest Xcode dmg from the Apple XDC Web site
+(http:/developer.apple.com). The Mac system install disks come with a copy of
+Xcode, but it's likely out of date.
+Install Xcode after the \~{}1gb download is complete.
-\textbf{Note}: Note: It may be that you need to create some symlinks after installing
-the XCODE SDK (in particular if you are using XCODE 2.5 on tiger):
+/!$\backslash$ Note: It may be that you need to create some symlinks after installing
+Xcode (in particular if you are using Xcode 2.5 on Tiger):
\begin{verbatim}
cd /Developer/SDKs/MacOSX10.4u.sdk/usr/
@@ -284,14 +277,13 @@
sudo ln -s /usr/local/ local
\end{verbatim}
-\subsection{Install Qt4 from .dmg}
+\subsubsection{Install Qt4 from .dmg}
You need a minimum of Qt-4.3.0. I suggest getting the latest.
\underline{Snow Leopard note:} If you are building on Snow Leopard, you will need to
decide between 32-bit support in the older, Qt Carbon branch, or 64-bit
support in the Qt Cocoa branch. Appropriate installers are available for both
-as of Qt-4.5.2, and the release candidate of Qt-4.6.0-cocoa works fairly well
-with Qgis as tested with nightly snapshots of sip and pyqt.
+as of Qt-4.5.2. Qt 4.6+ is recommended for Cocoa.
\begin{verbatim}
@@ -303,7 +295,10 @@
Once downloaded open the dmg and run the installer. Note you need admin
privileges to install.
-\underline{Qt 4.4+ note:} Starting in Qt 4.4 (?) libQtCLucene was added, and in 4.5 libQtUiTools was added, both in /usr/lib. When using a system SDK (which will happen in the Xcode build), these libraries will not be found. To fix this problem, add symlinks to /usr/local:
+\underline{Qt 4.4+ note:} Starting in Qt 4.4 (?) libQtCLucene was added, and in 4.5
+libQtUiTools was added, both in /usr/lib. When using a system SDK (which will
+happen in the Xcode build), these libraries will not be found. To fix this problem,
+add symlinks to /usr/local:
\begin{verbatim}
sudo ln -s /usr/lib/libQtUiTools.a /usr/local/lib/
@@ -312,11 +307,12 @@
These should then be found automatically on Leopard and above. Earlier systems
may need some help by adding '-L/usr/local/lib' to CMAKE\_SHARED\_LINKER\_FLAGS,
-CMAKE\_MODULE\_LINKER\_FLAGS and CMAKE\_EXE\_LINKER\_FLAGS in the cmake build, or
-adding '/usr/local/lib' to LIBRARY\_SEARCH\_PATHS in the Xcode build.
+CMAKE\_MODULE\_LINKER\_FLAGS and CMAKE\_EXE\_LINKER\_FLAGS in the cmake build.
-\subsection{Install development frameworks for QGIS dependencies}
-Download William Kyngesburye's excellent GDAL Complete package that includes PROJ, GEOS, GDAL, SQLite3, and image libraries, as frameworks.
+\subsubsection{Install development frameworks for QGIS dependencies}
+Download William Kyngesburye's excellent GDAL Complete package that includes
+PROJ, GEOS, GDAL, SQLite3, and image libraries, as frameworks. There is also
+a GSL framework.
\begin{verbatim}
http://www.kyngchaos.com/wiki/software:frameworks
@@ -339,7 +335,7 @@
http://www.kyngchaos.com/wiki/software:grass
\end{verbatim}
-\subsubsection{Additional Dependencies : General compatibility note}
+\minisec{Additional Dependencies : General compatibility note}
There are some additional dependencies that, at the time of writing, are not
provided as frameworks or installers so we will need to build these from source.
If you are wanting to build Qgis as a 64-bit application, you will need to
@@ -348,30 +344,7 @@
default system architecture, which is 64-bit, according to instructions for
individual dependency packages.
-\subsubsection{Additional Dependencies : GSL}
-Retrieve the current version of the Gnu Scientific Library from:
-\begin{verbatim}
-ftp://ftp.gnu.org/gnu/gsl/
-\end{verbatim}
-Then extract it and build it to a prefix of /usr/local. Double-click the source
-tarball to unpack it, then, in Terminal.app, cd to the source folder and:
-\begin{verbatim}
-./configure
-make
-sudo make install
-\end{verbatim}
-\underline{Snow Leopard note:} Snow Leopard compiles 64bit by default.
-For explicit 32-bit support in gsl, substitute the standard configure line with:
-\begin{verbatim}
-./configure CFLAGS="-Os -arch i386"
-\end{verbatim}
-\subsubsection{Additional Dependencies : Expat}
+\minisec{Additional Dependencies : Expat}
\underline{Snow Leopard note:} Snow Leopard includes a usable expat, so this step is
not necessary on Snow Leopard.
@@ -395,10 +368,10 @@
./configure CFLAGS="-Os -arch x86_64"
\end{verbatim}
-\subsubsection{Additional Dependencies : Python}
+\minisec{Additional Dependencies : Python}
\underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard include a usable
Python 2.5 and 2.6, respectively. So there is no need to install Python on
-Leopard and Snow Leopard You can still install Python from python.org if preferred.
+Leopard and Snow Leopard. You can still install Python from python.org if preferred.
Make sure you install at least the latest Python 2.5 from
@@ -408,7 +381,7 @@
Python 3 is a major change, and may have compatibility issues, so try it at your own risk.
-\subsubsection{Additional Dependencies : SIP}
+\minisec{Additional Dependencies : SIP}
Retrieve the python bindings toolkit SIP from
\begin{verbatim}
@@ -443,18 +416,18 @@
'arch' command, 'python' does not). If you are using 32-bit Qt (Qt Carbon):
\begin{verbatim}
-python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin \
+python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin
-e /usr/local/include -v /usr/local/share/sip --arch=i386
\end{verbatim}
For 64-bit Qt (Qt Cocoa), use this configure line:
\begin{verbatim}
-e /usr/local/include -v /usr/local/share/sip --arch=x86_64
\end{verbatim}
-\subsubsection{Additional Dependencies : PyQt}
+\minisec{Additional Dependencies : PyQt}
Retrieve the python bindings toolkit for Qt from
\begin{verbatim}
@@ -468,6 +441,17 @@
export QTDIR=/Developer/Applications/Qt
python configure.py
yes
+\end{verbatim}
+There is a problem with the configuration that needs to be fixed now (it affect PyQwt compilation later). Edit pyqtconfig.py and change the qt\_dir line to:
+\begin{verbatim}
+ 'qt_dir': '/usr',
+\end{verbatim}
+Then continue with compilation and installation:
+\begin{verbatim}
make
sudo make install
\end{verbatim}
@@ -495,18 +479,69 @@
\begin{verbatim}
-python2.6 configure.py -d /Library/Python/2.6/site-packages \
--b /usr/local/bin --use-arch i386
+python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch i386
\end{verbatim}
\begin{verbatim}
--b /usr/local/bin --use-arch x86_64
+python2.6 configure.py -d /Library/Python/2.6/site-packages -b /usr/local/bin --use-arch x86_64
\end{verbatim}
-\subsubsection{Additional Dependencies : Bison}
+\minisec{Additional Dependencies : Qwt/PyQwt}
+The GPS tracking feature uses Qwt. Some popular 3rd-party plugins use PyQwt.
+You can take care of both with the PyQwt source from:
+\begin{verbatim}
+http://pyqwt.sourceforge.net/
+\end{verbatim}
+Double-click the tarball to unpack it.
+Now, first edit qwtconfig.pri in the qwt-5.2 subdir and change some settings so
+you don't get a bloated debug static library (too bad they are configurable from
+qmake). Scroll down to the 'release/debug mode' block. Edit the last 'CONFIG +='
+line, within an 'else' block, and change 'debug' to 'release'. Also uncomment
+(remove \# prefix) the line 'CONFIG += QwtDll'.
+Save and close.
+Now, cd into the qwt-5.2 subdir in a Terminal. Type these commands to build and install:
+\begin{verbatim}
+qmake -spec macx-g++
+make
+sudo make install
+\end{verbatim}
+The Qwt shared library is now installed in /usr/local/qwt-5.x.x[-svn] (x.x is the
+minor.point version, and it may be an SVN version). Remember this for QGIS and PyQwt configuration.
+Now for PyQwt. Still in the Terminal:
+\begin{verbatim}
+cd ../configure
+python configure.py --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
+--extra-lib-dirs=/usr/local/qwt-5.2.1-svn/lib --extra-libs=qwt
+make
+sudo make install
+\end{verbatim}
+Make sure to use the qwt install path from the Qwt build above.
+\underline{Snow Leopard note}
+If using Qt Carbon, you need to specify which architectures to build, otherwise
+it will default to a combination that does not work (ie x86\_64 for a Carbon Qt).
+This is not needed for Qt Cocoa. Configure as follows:
+\begin{verbatim}
+python configure.py --extra-cflags="-arch i386" --extra-cxxflags="-arch i386" \
+--extra-lflags="-arch i386" --extra-include-dirs=/usr/local/qwt-5.2.1-svn/include \
+\end{verbatim}
+\minisec{Additional Dependencies : Bison}
\underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard include Bison 2.3, so this step can be skipped on Leopard and Snow Leopard.
The version of bison available by default on Mac OS X 10.4 and older is too old so you need to
@@ -516,7 +551,7 @@
ftp.gnu.org/gnu/bison/
\end{verbatim}
-Now build and install it to a prefix of /usr/local. Double-click the source
+Now build and install it to a prefix of /usr/local.\&\#65533; Double-click the source
tarball to unpack it, then cd to the source folder and:
\begin{verbatim}
@@ -525,7 +560,7 @@
sudo make install
\end{verbatim}
-\subsection{Install CMAKE for OSX}
+\subsubsection{Install CMake for OSX}
Get the latest source release from here:
\begin{verbatim}
@@ -543,11 +578,11 @@
sudo make install
\end{verbatim}
-\subsection{Install subversion for OSX}
+\subsubsection{Install subversion for OSX}
\underline{Leopard and Snow Leopard note:} Leopard and Snow Leopard (Xcode 3+)
include SVN, so this step can be skipped on Leopard and Snow Leopard.
-The [\url{http://sourceforge.net/projects/macsvn/MacSVN}] project has a downloadable
+The [\htmladdnormallink{http://sourceforge.net/projects/macsvn/MacSVN}{http://sourceforge.net/projects/macsvn/MacSVN}] project has a downloadable
build of svn. If you are a GUI inclined person you may want to grab their gui
client too. Get the command line client here:
@@ -558,7 +593,7 @@
Once downloaded open the zip file and run the installer.
You also need to install BerkleyDB available from the same
-\url {http://sourceforge.net/projects/macsvn/}{website}. At the time of writing the
+\htmladdnormallink{http://sourceforge.net/projects/macsvn/}{website}. At the time of writing the
file was here:
\begin{verbatim}
@@ -586,7 +621,7 @@
Now close and reopen your shell to get the updated vars.
-\subsection{Check out QGIS from SVN}
+\subsubsection{Check out QGIS from SVN}
Now we are going to check out the sources for QGIS. First we will create a
directory for working in (or some folder of your choice):
@@ -624,14 +659,14 @@
I suggest you press 'p' to accept the key permanently.
-\subsection{Configure the build}
-There are 2 different methods to build QGIS: the traditional Cmake method,
+\subsubsection{Configure the build}
+There are 2 different methods to build QGIS: the traditional CMake method,
and the new Xcode project (starting with QGIS 1.1). The Xcode project has
-additional bundling steps, though some optional Qgis features must be explicitly
-stated in a user configuration file. The Cmake build handles optional features,
+additional bundling steps, though some optional QGIS features must be explicitly
+stated in a user configuration file. The CMake build handles optional features,
and some bundling steps are available with scripts in the mac directory.
-\subsubsection{Configure the Cmake build}
+\minisec{Configure the CMake build}
CMake supports out of source build so we will create a 'build' dir for the
build process. OS X uses \$\{HOME\}/Applications as a standard user app folder (it gives it the system app folder icon).
If you have the correct permissions you may want to build
@@ -709,7 +744,7 @@
\end{verbatim}
-\subsubsection{Configure the Xcode build}
+\minisec{Configure the Xcode build}
In the mac/xcode folder in the source, duplicate the 'qgis\_user-template.xcconfig'
file and name it 'qgis\_user.xcconfig'. A default build will use the KyngChaos
frameworks, Postgres, GRASS 6.4, the python.org Python 2.5 (for Tiger)
@@ -722,8 +757,8 @@
other dependency libraries to create a self-contained package. The KyngChaos
frameworks and GRASS application are not bundled.
-\subsection{Building}
-\subsubsection{Building with Cmake}
+\subsubsection{Building}
+\minisec{Building with Cmake}
Now we can start the build process:
\begin{verbatim}
@@ -742,7 +777,7 @@
sudo make install
\end{verbatim}
-\subsubsection{Building with Xcode}
+\minisec{Building with Xcode}
Open the Xcode project file in the mac/xcode directory. Select 'Release' build
configuration and select the 'Full Qgis' target, then build. If you use ccache,
there have been compilation problems reported, so it is suggested that you disable
@@ -759,8 +794,8 @@
qgis\_user.xcconfig. Copy this to whereever you like.
-\section{Building on GNU/Linux}
-\subsection{Building QGIS with Qt4.x}
+\subsection{Building on GNU/Linux}
+\subsubsection{Building QGIS with Qt4.x}
\textbf{Requires:} Ubuntu Hardy / Debian derived distro
These notes are current for Ubuntu 7.10 - other versions and Debian derived
@@ -777,7 +812,7 @@
in use for a while, you may need to just skip those steps which are irrelevant
to you.
-\subsection{Prepare apt}
+\subsubsection{Prepare apt}
The packages qgis depends on to build are available in the "universe" component
of Ubuntu. This is not activated by default, so you need to activate it:
@@ -793,14 +828,14 @@
sudo apt-get update
\end{verbatim}
-\subsection{Install Qt4}
+\subsubsection{Install Qt4}
\begin{verbatim}
sudo apt-get install libqt4-core libqt4-debug \
libqt4-dev libqt4-gui libqt4-qt3support libqt4-sql lsb-qt4 qt4-designer \
qt4-dev-tools qt4-doc qt4-qtconfig uim-qt gcc libapt-pkg-perl resolvconf
\end{verbatim}
-\textbf{Note}: \textbf{*A Special Note:*} If you are following this set of instructions on
+/!$\backslash$ \textbf{*A Special Note:*} If you are following this set of instructions on
a system where you already have Qt3 development tools installed, there will
be a conflict between Qt3 tools and Qt4 tools. For example, qmake will
point to the Qt3 version not the Qt4. Ubuntu Qt4 and Qt3 packages are
@@ -836,7 +871,7 @@
Use the simple command line dialog that appears after running each of the
above commands to select the Qt4 version of the relevant applications.
-\subsection{Install additional software dependencies required by QGIS}
+\subsubsection{Install additional software dependencies required by QGIS}
\begin{verbatim}
sudo apt-get install gdal-bin libgdal1-dev libgeos-dev proj \
libgdal-doc libhdf4g-dev libhdf4g-run python-dev \
@@ -845,9 +880,9 @@
python-qt4 python-qt4-dev python-sip4 sip4 python-sip4-dev
\end{verbatim}
-\textbf{Note}: Debian users should use libgdal-dev above rather
+/!$\backslash$ Debian users should use libgdal-dev above rather
-\textbf{Note}: \textbf{*Note:*} For python language bindings SIP $>$= 4.5 and PyQt4 $>$= 4.1 is required! Some stable GNU/Linux
+/!$\backslash$ \textbf{*Note:*} For python language bindings SIP $>$= 4.5 and PyQt4 $>$= 4.1 is required! Some stable GNU/Linux
distributions (e.g. Debian or SuSE) only provide SIP $<$ 4.5 and PyQt4 $<$ 4.1. To include support for python
language bindings you may need to build and install those packages from source.
@@ -857,19 +892,17 @@
sudo apt-get install cmake
\end{verbatim}
-\subsection{GRASS Specific Steps}
-\textbf{Note}: \textbf{*Note:*} If you don't need to build with GRASS support, you can
+\subsubsection{GRASS Specific Steps}
+/!$\backslash$ \textbf{*Note:*} If you don't need to build with GRASS support, you can
skip this section.
Now you can install grass from dapper:
\begin{verbatim}
-sudo apt-get install grass libgrass-dev libgdal1-1.4.0-grass
+sudo apt-get install grass libgrass-dev
\end{verbatim}
-\textbf{Note}: You may need to explicitly state your grass version e.g. libgdal1-1.3.2-grass
-\subsection{Setup ccache (Optional)}
+\subsubsection{Setup ccache (Optional)}
You should also setup ccache to speed up compile times:
\begin{verbatim}
@@ -878,7 +911,7 @@
sudo ln -s /usr/bin/ccache g++
\end{verbatim}
-\subsection{Prepare your development environment}
+\subsubsection{Prepare your development environment}
As a convention I do all my development work in \$HOME/dev/$<$language$>$, so in
this case we will create a work environment for C++ development work like
this:
@@ -890,7 +923,7 @@
This directory path will be assumed for all instructions that follow.
-\subsection{Check out the QGIS Source Code}
+\subsubsection{Check out the QGIS Source Code}
There are two ways the source can be checked out. Use the anonymous method
if you do not have edit privaleges for the QGIS source repository, or use
the developer checkout if you have permissions to commit source code
@@ -926,8 +959,8 @@
accept (t)emporarily or accept (p)ermanently?
\end{verbatim}
-\subsection{Starting the compile}
-\textbf{Note}: \textbf{*Note:*} The next section describes howto build debian packages
+\subsubsection{Starting the compile}
+/!$\backslash$ \textbf{*Note:*} The next section describes howto build debian packages
I compile my development version of QGIS into my \~{}/apps directory to avoid
conflicts with Ubuntu packages that may be under /usr. This way for example
@@ -967,7 +1000,7 @@
It may take a little while to build depending on your platform.
-\subsection{Building Debian packages}
+\subsubsection{Building Debian packages}
Instead of creating a personal installation as in the previous step you can
also create debian package. This is done from the qgis root directory, where
you'll find a debian directory.
@@ -984,10 +1017,10 @@
dpkg-buildpackage -us -uc -b
\end{verbatim}
-\textbf{Note}: If \texttt{dpkg-buildpackage} complains about unmet build dependencies
+/!$\backslash$ \textbf{*Note:*} If \texttt{dpkg-buildpackage} complains about unmet build dependencies
you can install them using \texttt{apt-get} and re-run the command.
-\textbf{Note}: If you have \texttt{libqgis1-dev} installed, you need to remove it first
+/!$\backslash$ \textbf{*Note:*} If you have \texttt{libqgis1-dev} installed, you need to remove it first
using \texttt{dpkg -r libqgis1-dev}. Otherwise \texttt{dpkg-buildpackage} will complain about a
build conflict.
@@ -1003,7 +1036,7 @@
../python-qgis_1.0preview16_amd64.deb
\end{verbatim}
-\subsection{Running QGIS}
+\subsubsection{Running QGIS}
Now you can try to run QGIS:
\begin{verbatim}
@@ -1013,13 +1046,13 @@
If all has worked properly the QGIS application should start up and appear
on your screen.
-\subsection{A practical case: Building QGIS and GRASS from source on Ubuntu with ECW and MrSID formats support}
+\subsubsection{A practical case: Building QGIS and GRASS from source on Ubuntu with ECW and MrSID formats support}
The following procedure has been tested on Ubuntu 8.04, 8.10 and 9.04 32bit. If you want
to use different versions of the software (gdal, grass, qgis), just make the
necessary adjustments to the following code. This guide assumes that you don't have
installed any previous version of gdal, grass and qgis.
-\subsubsection{Step 1: install base packages}
+\minisec{Step 1: install base packages}
First you need to install the necessary packages required to download the source
code and compile it. Open the terminal and issue the following command:
@@ -1027,8 +1060,8 @@
sudo apt-get install build-essential g++ subversion
\end{verbatim}
-\subsubsection{Step 2: compile and install the ecw libraries}
-Go to the ERDAS web site \url{http://www.erdas.com/} and follow the links
+\minisec{Step 2: compile and install the ecw libraries}
+Go to the ERDAS web site \htmladdnormallink{http://www.erdas.com/}{http://www.erdas.com/} and follow the links
"'''products --$>$ ECW JPEG2000 Codec SDK --$>$ downloads'''"
then download the "'''Image Compression SDK Source Code 3.3'''" (you'll need to make a registration
and accept a license).
@@ -1065,15 +1098,15 @@
cd ..
\end{verbatim}
-\subsubsection{Step 3: download the MrSID binaries}
-Go to the LIZARDTECH web site \url{http://www.lizardtech.com/} and follow the links
+\minisec{Step 3: download the MrSID binaries}
+Go to the LIZARDTECH web site \htmladdnormallink{http://www.lizardtech.com/}{http://www.lizardtech.com/} and follow the links
"'''download --$>$ Developer SDKs'''",
then download the "'''GeoExpress SDK for Linux (x86) - gcc 4.1 32-bit'''"
(you'll need to make a registration and accept a license).
Uncompress the downloaded file. The resulting directory name should be similar to "Geo\_DSDK-7.0.0.2167"
-\subsubsection{Step 4: compile and install the gdal libraries}
+\minisec{Step 4: compile and install the gdal libraries}
Download the latest gdal source code
\begin{verbatim}
@@ -1147,35 +1180,36 @@
cd ..
\end{verbatim}
-\subsubsection{Step 5: compile and install GRASS}
+\minisec{Step 5: compile and install GRASS}
Before downloading and compile GRASS source code you need to install a few
other libraries and programs. We can do this trough apt
\begin{verbatim}
sudo apt-get install flex bison libreadline5-dev libncurses5-dev lesstif2-dev \
-debhelper dpatch libtiff4-dev \
-tcl8.4-dev tk8.4-dev fftw-dev xlibmesa-gl-dev libfreetype6-dev autoconf2.13 \
-autotools-dev libgdal1-dev proj libjpeg62-dev libpng12-dev libpq-dev unixodbc-dev \
-doxygen fakeroot cmake python-dev python-qt4-common python-qt4-dev python-sip4 \
-python2.5-dev sip4 libglew1.5-dev libxmu6 libqt4-dev libgsl0-dev python-qt4 swig \
-python-wxversion python-wxgtk2.8 libwxgtk2.8-0 libwxbase2.8-0 tcl8.4-dev \
-tk8.4-dev tk8.4 libfftw3-dev libfftw3-3
+debhelper dpatch libtiff4-dev tcl8.4-dev tk8.4-dev fftw-dev xlibmesa-gl-dev \
+libfreetype6-dev autoconf2.13 autotools-dev libgdal1-dev proj libjpeg62-dev \
+libpng12-dev libpq-dev unixodbc-dev doxygen fakeroot cmake python-dev \
+python-qt4-common python-qt4-dev python-sip4 python2.5-dev sip4 libglew1.5-dev libxmu6 \
+libqt4-dev libgsl0-dev python-qt4 swig python-wxversion python-wxgtk2.8 \
+libwxgtk2.8-0 libwxbase2.8-0 tcl8.4-dev tk8.4-dev tk8.4 libfftw3-dev libfftw3-3
\end{verbatim}
At this point we can get the GRASS source code: you may want to download it
trough svn or maybe you want just to download the latest available source code arquive.
-For example the GRASS 6.4rc5 is available at \url{http://grass.itc.it/grass64/source/grass-6.4.0RC5.tar.gz}
+For example the GRASS 6.4rc4 is available at \htmladdnormallink{http://grass.itc.it/grass64/source/grass-6.4.0RC4.tar.gz}{http://grass.itc.it/grass64/source/grass-6.4.0RC4.tar.gz}
Uncompress the arquive, enter the newly created folder and run configure with a few specific parameters
\begin{verbatim}
-./configure --with-tcltk-includes=/usr/include/tcl8.4 \
+CFLAGS="-fexceptions" ./configure --with-tcltk-includes=/usr/include/tcl8.4 \
--with-proj-share=/usr/share/proj --with-gdal=/usr/local/bin/gdal-config \
--with-python=/usr/bin/python2.5-config
\end{verbatim}
-then as usual (it will take a while)
+The additional gcc option -fexceptions is necessary to enable exceptions support in GRASS libraries. It is currently the only way to avoid QGIS crashes if a fatal error happens in GRASS library. See also \htmladdnormallink{http://trac.osgeo.org/grass/ticket/869}{http://trac.osgeo.org/grass/ticket/869}
+Then as usual (it will take a while)
\begin{verbatim}
make
\end{verbatim}
@@ -1199,67 +1233,12 @@
grass64 -wxpython
\end{verbatim}
-\subsubsection{Step 6: compile and install the GDAL-GRASS libraries}
-Create a plain text file named "grass.conf" inside the folder "/etc/ld.so.conf.d"
-\begin{verbatim}
-sudo gedit /etc/ld.so.conf.d/grass.conf
-\end{verbatim}
-and add the following line
-\begin{verbatim}
-/usr/local/grass-6.4.0RC4/lib/
-\end{verbatim}
-save and exit.
-Download the latest version of the gdal-grass library (gdal-grass-1.4.3.tar.gz) from
-\url{http://download.osgeo.org/gdal/}
-uncompress the arquive and enter the newly created folder
-\begin{verbatim}
-cd /gdal-grass-1.4.3
-\end{verbatim}
-run configure
-\begin{verbatim}
-./configure --with-grass=/usr/local/grass-6.4.0RC4
-\end{verbatim}
-then as usual
-\begin{verbatim}
-make
-\end{verbatim}
-and
-\begin{verbatim}
-sudo make install
-\end{verbatim}
-and finish the process by creating the necessary links to the most recent shared libraries
-\begin{verbatim}
-sudo ldconfig
-\end{verbatim}
-leave the folder
-\begin{verbatim}
-cd ..
-\end{verbatim}
-\subsubsection{Step 6: compile and install QGIS}
+\minisec{Step 6: compile and install QGIS}
As for GRASS you can obtain the QGIS source code from different sources,
for instance from svn or just by downloading one of the source code arquives available
-at \url {http://www.qgis.org/download/sources.html}{http://www.qgis.org/download/sources.html}
+at \htmladdnormallink{http://www.qgis.org/download/sources.html}{http://www.qgis.org/download/sources.html}
-For example download the QGIS 1.1.0 source code here \\
-\url{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}
+For example download the QGIS 1.1.0 source code here \htmladdnormallink{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}{http://download.osgeo.org/qgis/src/qgis\_1.1.0.tar.gz}
@@ -1308,54 +1287,54 @@
\end{verbatim}
-\section{Creation of MSYS environment for compilation of Quantum GIS}
-\subsection{Initial setup}
-\subsubsection{MSYS}
+\subsection{Creation of MSYS environment for compilation of Quantum GIS}
+\subsubsection{Initial setup}
+\minisec{MSYS}
This is the environment that supplies many utilities from UNIX world in Windows and is needed
by many dependencies to be able to compile.
Download from here:
\begin{quotation}
-\url{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}
+\htmladdnormallink{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MSYS-1.0.11-2004.04.30-1.exe}
\end{quotation}
Install to \texttt{c:$\backslash$msys}
All stuff we're going to compile is going to get to this directory (resp. its subdirs).
-\subsubsection{MinGW}
+\minisec{MinGW}
Download from here:
\begin{quotation}
-\url{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}
+\htmladdnormallink{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}{http://puzzle.dl.sourceforge.net/sourceforge/mingw/MinGW-5.1.3.exe}
\end{quotation}
Install to \texttt{c:$\backslash$msys$\backslash$mingw}
It suffices to download and install only \texttt{g++} and \texttt{mingw-make} components.
-\subsubsection{Flex and Bison}
+\minisec{Flex and Bison}
Flex and Bison are tools for generation of parsers, they're needed for GRASS and also QGIS compilation.
Download the following packages:
\begin{quotation}
-\url{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}
+\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}{http://gnuwin32.sourceforge.net/downlinks/flex-bin-zip.php}
\end{quotation}
\begin{quotation}
-\url{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}
+\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}{http://gnuwin32.sourceforge.net/downlinks/bison-bin-zip.php}
\end{quotation}
\begin{quotation}
-\url{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}
+\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}{http://gnuwin32.sourceforge.net/downlinks/bison-dep-zip.php}
\end{quotation}
Unpack them all to \texttt{c:$\backslash$msys$\backslash$local}
-\subsection{Installing dependencies}
-\subsubsection{Getting ready}
+\subsubsection{Installing dependencies}
+\minisec{Getting ready}
Paul Kelly did a great job and prepared a package of precompiled libraries for GRASS.
The package currently includes:
@@ -1373,104 +1352,22 @@
It's available for download here:
\begin{quotation}
-\url{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}
+\htmladdnormallink{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}{http://www.stjohnspoint.co.uk/grass/wingrass-extralibs.tar.gz}
\end{quotation}
Moreover he also left the notes how to compile it (for those interested):
\begin{quotation}
-\url{http://www.stjohnspoint.co.uk/grass/README.extralibs}
+\htmladdnormallink{http://www.stjohnspoint.co.uk/grass/README.extralibs}{http://www.stjohnspoint.co.uk/grass/README.extralibs}
\end{quotation}
Unpack the whole package to \texttt{c:$\backslash$msys$\backslash$local}
-\subsubsection{GDAL level one}
-Since Quantum GIS needs GDAL with GRASS support, we need to compile GDAL
-from source - Paul Kelly's package doesn't include GRASS support in GDAL.
-The idea is following:
-\begin{enumerate}
-\item compile GDAL without GRASS
-\item compile GRASS
-\item compile GDAL with GRASS
-\end{enumerate}
-So, start with downloading GDAL sources:
- \begin{quotation}
-\url{http://download.osgeo.org/gdal/gdal141.zip}
- \end{quotation}
-Unpack it to some directory, preferably \texttt{c:$\backslash$msys$\backslash$local$\backslash$src}.
-Start MSYS console, go to gdal-1.4.1 directory and run the commands below.
-You can put them all to a script, e.g. build-gdal.sh and run them at once.
-The recipe is taken from Paul Kelly's instructions - basically they
-just make sure that the library will be created as DLL and the utility
-programs will be dynamically linked to it...
-\begin{verbatim}
-CFLAGS="-O2 -s" CXXFLAGS="-O2 -s" LDFLAGS=-s ./configure --without-libtool \
---prefix=/usr/local --enable-shared --disable-static --with-libz=/usr/local \
---with-png=/usr/local
-make
-make install
-rm /usr/local/lib/libgdal.a
-g++ -s -shared -o ./libgdal.dll -L/usr/local/lib -lz -lpng ./frmts/o/*.o \
-./gcore/*.o ./port/*.o ./alg/*.o ./ogr/ogrsf_frmts/o/*.o \
-./ogr/ogrgeometryfactory.o ./ogr/ogrpoint.o ./ogr/ogrcurve.o \
-./ogr/ogrlinestring.o ./ogr/ogrlinearring.o ./ogr/ogrpolygon.o \
-./ogr/ogrutils.o ./ogr/ogrgeometry.o ./ogr/ogrgeometrycollection.o \
-./ogr/ogrmultipolygon.o ./ogr/ogrsurface.o ./ogr/ogrmultipoint.o \
-./ogr/ogrmultilinestring.o ./ogr/ogr_api.o ./ogr/ogrfeature.o \
-./ogr/ogrfeaturedefn.o ./ogr/ogrfeaturequery.o ./ogr/ogrfeaturestyle.o \
-./ogr/ogrfielddefn.o ./ogr/ogrspatialreference.o ./ogr/ogr_srsnode.o \
-./ogr/ogr_srs_proj4.o ./ogr/ogr_fromepsg.o ./ogr/ogrct.o ./ogr/ogr_opt.o \
-./ogr/ogr_srs_esri.o ./ogr/ogr_srs_pci.o ./ogr/ogr_srs_usgs.o \
-./ogr/ogr_srs_dict.o ./ogr/ogr_srs_panorama.o ./ogr/swq.o \
-./ogr/ogr_srs_validate.o ./ogr/ogr_srs_xml.o ./ogr/ograssemblepolygon.o \
-./ogr/ogr2gmlgeometry.o ./ogr/gml2ogrgeometry.o
-install libgdal.dll /usr/local/lib
-cd ogr
-g++ -s ogrinfo.o -o ogrinfo.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s ogr2ogr.o -o ogr2ogr.exe -lgdal -L/usr/local/lib -lpng -lz -lgdal
-g++ -s ogrtindex.o -o ogrtindex.exe -lgdal -L/usr/local/lib -lpng -lz -lgdal
-install ogrinfo.exe ogr2ogr.exe ogrtindex.exe /usr/local/bin
-cd ../apps
-g++ -s gdalinfo.o -o gdalinfo.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdal_translate.o -o gdal_translate.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdaladdo.o -o gdaladdo.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdalwarp.o -o gdalwarp.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdal_contour.o -o gdal_contour.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdaltindex.o -o gdaltindex.exe -L/usr/local/lib -lpng -lz -lgdal
-g++ -s gdal_rasterize.o -o gdal_rasterize.exe -L/usr/local/lib -lpng -lz -lgdal
-install gdalinfo.exe gdal_translate.exe gdaladdo.exe gdalwarp.exe \
-gdal_contour.exe gdaltindex.exe gdal_rasterize.exe /usr/local/bin
-\end{verbatim}
-Finally, manually edit \texttt{gdal-config} in \texttt{c:$\backslash$msys$\backslash$local$\backslash$bin} to replace the static library reference with -lgdal:
-\begin{verbatim}
-CONFIG_LIBS="-L/usr/local/lib -lpng -lz -lgdal"
-\end{verbatim}
-GDAL build procedure can be greatly simplified to use libtool with a libtool line patch:
-configure gdal as below:
-./configure --with-ngpython --with-xerces=/local/ --with-jasper=/local/ --with-grass=/local/grass-6.3.cvs/ --with-pg=/local/pgsql/bin/pg\_config.exe
-Then fix libtool with:
-mv libtool libtool.orig
-cat libtool.orig $|$ sed 's/max\_cmd\_len=8192/max\_cmd\_len=32768/g' $>$ libtool
-Libtool on windows assumes a line length limit of 8192 for some reason and tries to page the linking and fails miserably. This is a work around.
-Make and make install should be hassle free after this.
-\subsubsection{GRASS}
+\minisec{GRASS}
Grab sources from CVS or use a weekly snapshot, see:
\begin{quotation}
-\url{http://grass.itc.it/devel/cvs.php}
+\htmladdnormallink{http://grass.itc.it/devel/cvs.php}{http://grass.itc.it/devel/cvs.php}
\end{quotation}
In MSYS console go to the directory where you've unpacked or checked out sources
@@ -1495,43 +1392,15 @@
By the way, these pages might be useful:
\begin{itemize}
-\item \url{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}
-\item \url{http://geni.ath.cx/grass.html}
+\item \htmladdnormallink{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}{http://grass.gdf-hannover.de/wiki/WinGRASS\_Current\_Status}
+\item \htmladdnormallink{http://geni.ath.cx/grass.html}{http://geni.ath.cx/grass.html}
\end{itemize}
-\subsubsection{GDAL level two}
-At this stage, we'll use GDAL sources we've used before, only the compilation will be a bit different.
-But first in order to be able to compile GDAL sources with current GRASS CVS, you need to patch them, here's what you need to change:
- \begin{quotation}
-\url{http://trac.osgeo.org/gdal/attachment/ticket/1587/plugin\_patch\_grass63.diff}
- \end{quotation}
-(you can patch it by hand or use patch.exe in \texttt{c:$\backslash$msys$\backslash$bin})
-Now in MSYS console go to the GDAL sources directory and run the same commands as in level one, only with these differences:
-\begin{enumerate}
-\item when running \texttt{./configure} add this argument: \texttt{--with-grass=/usr/local/grass-6.3.cvs}
-\item when calling \texttt{g++} on line 5 (which creates libgdal.dll), add these arguments: \texttt{-L/usr/local/grass-6.3.cvs/lib -lgrass\_vect -lgrass\_dig2 -lgrass\_dgl -lgrass\_rtree -lgrass\_linkm -lgrass\_dbmiclient -lgrass\_dbmibase -lgrass\_I -lgrass\_gproj -lgrass\_vask -lgrass\_gmath -lgrass\_gis -lgrass\_datetime}
-\end{enumerate}
-Then again, edit \texttt{gdal-config} and change line with CONFIG\_LIBS
-\begin{verbatim}
-CONFIG_LIBS="-L/usr/local/lib -lpng -L/usr/local/grass-6.3.cvs/lib -lgrass_vect \
--lgrass_dig2 -lgrass_dgl -lgrass_rtree -lgrass_linkm -lgrass_dbmiclient \
--lgrass_dbmibase -lgrass_I -lgrass_gproj -lgrass_vask -lgrass_gmath -lgrass_gis \
--lgrass_datetime -lz -L/usr/local/lib -lgdal"
-\end{verbatim}
-Now, GDAL should be able to work also with GRASS raster layers.
-\subsubsection{GEOS}
+\minisec{GEOS}
Download the sources:
\begin{quotation}
-\url{http://geos.refractions.net/geos-2.2.3.tar.bz2}
+\htmladdnormallink{http://geos.refractions.net/geos-2.2.3.tar.bz2}{http://geos.refractions.net/geos-2.2.3.tar.bz2}
\end{quotation}
Unpack to e.g. \texttt{c:$\backslash$msys$\backslash$local$\backslash$src}
@@ -1556,13 +1425,13 @@
make install
\end{verbatim}
-\subsubsection{SQLITE}
+\minisec{SQLITE}
You can use precompiled DLL, no need to compile from source:
Download this archive:
\begin{quotation}
-\url{http://www.sqlite.org/sqlitedll-3\_3\_17.zip}
+\htmladdnormallink{http://www.sqlite.org/sqlitedll-3\_3\_17.zip}{http://www.sqlite.org/sqlitedll-3\_3\_17.zip}
\end{quotation}
and copy sqlite3.dll from it to \texttt{c:$\backslash$msys$\backslash$local$\backslash$lib}
@@ -1570,16 +1439,16 @@
Then download this archive:
\begin{quotation}
-\url{http://www.sqlite.org/sqlite-source-3\_3\_17.zip}
+\htmladdnormallink{http://www.sqlite.org/sqlite-source-3\_3\_17.zip}{http://www.sqlite.org/sqlite-source-3\_3\_17.zip}
\end{quotation}
and copy sqlite3.h to \texttt{c:$\backslash$msys$\backslash$local$\backslash$include}
-\subsubsection{GSL}
+\minisec{GSL}
Download sources:
\begin{quotation}
-\url{ftp://ftp.gnu.org/gnu/gsl/gsl-1.9.tar.gz}
+\htmladdnormallink{ftp://ftp.gnu.org/gnu/gsl/gsl-1.9.tar.gz}{ftp://ftp.gnu.org/gnu/gsl/gsl-1.9.tar.gz}
\end{quotation}
Unpack to \texttt{c:$\backslash$msys$\backslash$local$\backslash$src}
@@ -1592,11 +1461,11 @@
make install
\end{verbatim}
-\subsubsection{EXPAT}
+\minisec{EXPAT}
Download sources:
\begin{quotation}
-\url{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}
+\htmladdnormallink{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}{http://dfn.dl.sourceforge.net/sourceforge/expat/expat-2.0.0.tar.gz}
\end{quotation}
@@ -1609,35 +1478,35 @@
make install
\end{verbatim}
-\subsubsection{POSTGRES}
+\minisec{POSTGRES}
We're going to use precompiled binaries. Use the link below for download:
-\begin{quotation}
+ \begin{quotation}
\url{http://wwwmaster.postgresql.org/download/}
-\end{quotation}
+ \end{quotation}
copy contents of pgsql directory from the archive to \texttt{c:$\backslash$msys$\backslash$local}
-\subsection{Cleanup}
+\subsubsection{Cleanup}
We're done with preparation of MSYS environment. Now you can delete all stuff in \texttt{c:$\backslash$msys$\backslash$local$\backslash$src} - it takes quite a lot
of space and it's not necessary at all.
-\section{Building with MS Visual Studio}
-\textbf{Note}: This section describes a process where you build all dependencies yourself. See the section
+\subsection{Building with MS Visual Studio}
+/!$\backslash$ This section describes a process where you build all dependencies yourself. See the section
after this for a simpler procedure where we have all the dependencies you need pre-packaged
and we focus just on getting Visual Studio Express set up and building QGIS.
Note that this does not currently include GRASS or Python plugins.
-\subsection{Setup Visual Studio}
+\subsubsection{Setup Visual Studio}
This section describes the setup required to allow Visual Studio to be used to build QGIS.
-\subsubsection{Express Edition}
+\minisec{Express Edition}
The free Express Edition lacks the platform SDK which contains headers and so on that are needed when building QGIS. The platform SDK can be installed as described here:
\begin{quotation}
-\url{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}
+\htmladdnormallink{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}{http://msdn.microsoft.com/vstudio/express/visualc/usingpsdk/}
\end{quotation}
Once this is done, you will need to edit the $<$vsinstalldir$>$$\backslash$Common7$\backslash$Tools$\backslash$vsvars file as follows:
@@ -1647,35 +1516,35 @@
This will add more headers to the system INCLUDE path. Note that this will only work when you use the Visual Studio command prompt when building. Most of the dependencies will be built with this.
You will also need to perform the edits described here to remove the need for a library that Visual Studio Express lacks:
-\begin{quotation}
-\url{http://www.codeproject.com/wtl/WTLExpress.asp}
-\end{quotation}
+ \begin{quotation}
+\htmladdnormallink{http://www.codeproject.com/wtl/WTLExpress.asp}{http://www.codeproject.com/wtl/WTLExpress.asp}
+ \end{quotation}
-\subsubsection{All Editions}
+\minisec{All Editions}
You will need stdint.h and unistd.h. unistd.h comes with GnuWin32 version of flex \& bison binaries (see later). stdint.h can be found here:
-\begin{quotation}
-\url{http://www.azillionmonkeys.com/qed/pstdint.h}
-\end{quotation}
+ \begin{quotation}
+\htmladdnormallink{http://www.azillionmonkeys.com/qed/pstdint.h}{http://www.azillionmonkeys.com/qed/pstdint.h}.
+ \end{quotation}
Copy both of these to $<$vsinstalldir$>$$\backslash$VC$\backslash$include.
-\subsection{Download/Install Dependencies}
+\subsubsection{Download/Install Dependencies}
This section describes the downloading and installation of the various QGIS dependencies.
Download the following packages and run the installers:
\begin{quotation}
-\url{http://gnuwin32.sourceforge.net/downlinks/flex.php}
+\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/flex.php}{http://gnuwin32.sourceforge.net/downlinks/flex.php}
\end{quotation}
\begin{quotation}
-\url{http://gnuwin32.sourceforge.net/downlinks/bison.php}
+\htmladdnormallink{http://gnuwin32.sourceforge.net/downlinks/bison.php}{http://gnuwin32.sourceforge.net/downlinks/bison.php}
\end{quotation}
-\subsubsection{To include PostgreSQL support in Qt}
+\minisec{To include PostgreSQL support in Qt}
If you want to build Qt with PostgreSQL support you need to download
PostgreSQL, install it and create a library you can later link with Qt.
@@ -1717,18 +1586,18 @@
That's almost it. You only need to the include and lib path to INCLUDE and LIB
in vcvars.bat respectively.
-\subsubsection{Qt}
+\minisec{Qt}
Build Qt following the instructions here:
\begin{quotation}
-\url{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}
+\htmladdnormallink{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}{http://wiki.qgis.org/qgiswiki/Building\_QT\_4\_with\_Visual\_C\%2B\%2B\_2005}
\end{quotation}
-\subsubsection{Proj.4}
+\minisec{Proj.4}
Get proj.4 source from here:
\begin{quotation}
-\url{http://proj.maptools.org/}
+\htmladdnormallink{http://proj.maptools.org/}{http://proj.maptools.org/}
\end{quotation}
Using the Visual Studio command prompt (ensures the environment is setup properly), run the following in the src directory:
@@ -1753,16 +1622,16 @@
This can also be added to a batch file.
+\minisec{GSL}
Get gsl source from here:
\begin{quotation}
-\url{http://david.geldreich.free.fr/downloads/gsl-1.9-windows-sources.zip}
+\htmladdnormallink{http://david.geldreich.free.fr/downloads/gsl-1.9-windows-sources.zip}{http://david.geldreich.free.fr/downloads/gsl-1.9-windows-sources.zip}
\end{quotation}
Build using the gsl.sln file
-Get geos from svn (svn checkout \url{http://svn.refractions.net/geos/trunk} geos).
+\minisec{GEOS}
+Get geos from svn (svn checkout \htmladdnormallink{http://svn.refractions.net/geos/trunk}{http://svn.refractions.net/geos/trunk} geos).
Edit geos$\backslash$source$\backslash$makefile.vc as follows:
Uncomment lines 333 and 334 to allow the copying of version.h.vc to version.h.
@@ -1794,8 +1663,8 @@
-\subsubsection{GDAL}
-Get gdal from svn (svn checkout \url{https://svn.osgeo.org/gdal/branches/1.4/gdal} gdal).
+\minisec{GDAL}
+Get gdal from svn (svn checkout \htmladdnormallink{https://svn.osgeo.org/gdal/branches/1.4/gdal}{https://svn.osgeo.org/gdal/branches/1.4/gdal} gdal).
Edit nmake.opt to suit, it's pretty well commented.
@@ -1811,38 +1680,38 @@
nmake -f makefile.vc devinstall
\end{verbatim}
-\subsubsection{PostGIS}
+\minisec{PostGIS}
Get PostGIS and the Windows version of PostgreSQL from here:
\begin{quotation}
-\url{http://postgis.refractions.net/download/}
+\htmladdnormallink{http://postgis.refractions.net/download/}{http://postgis.refractions.net/download/}
\end{quotation}
Note the warning about not installing the version of PostGIS that comes with the PostgreSQL installer. Simply run the installers.
-\subsubsection{Expat}
+\minisec{Expat}
Get expat from here:
\begin{quotation}
-\url{http://sourceforge.net/project/showfiles.php?group\_id=10127}
+\htmladdnormallink{http://sourceforge.net/project/showfiles.php?group\_id=10127}{http://sourceforge.net/project/showfiles.php?group\_id=10127}
\end{quotation}
You'll need expat-win32bin-2.0.1.exe.
Simply run the executable to install expat.
-\subsubsection{CMake}
+\minisec{CMake}
Get CMake from here:
\begin{quotation}
-\url{http://www.cmake.org/HTML/Download.html}
+\htmladdnormallink{http://www.cmake.org/HTML/Download.html}{http://www.cmake.org/HTML/Download.html}
\end{quotation}
You'll need cmake-$<$version$>$-win32-x86.exe. Simply run this to install CMake.
-\subsection{Building QGIS with CMAKE}
-Get QGIS source from svn (svn co \url{https://svn.osgeo.org/qgis/trunk/qgis} qgis).
+\subsubsection{Building QGIS with CMAKE}
+Get QGIS source from svn (svn co \htmladdnormallink{https://svn.osgeo.org/qgis/trunk/qgis}{https://svn.osgeo.org/qgis/trunk/qgis} qgis).
Create a 'Build' directory in the top level QGIS directory. This will be where all the build output will be generated.
-Run Start--$>$All Programs--$>$CMake--$>$CMake.
+Run Start out{$>$All Programs}$>$CMake--$>$CMake.
In the 'Where is the source code:' box, browse to the top level QGIS directory.
@@ -1865,16 +1734,13 @@
You will also either need to add all the dependency dlls to the QGIS install directory or add their respective directories to your PATH.
-\section{Building under Windows using MSVC Express}
-\textbf{Note}: Note: Building under MSVC is still a work in progress. In particular the
-following dont work yet: python, grass, postgis connections.
-\textbf{Note}: This section of the document is in draft form and is not ready to be used
+\subsection{Building under Windows using MSVC Express}
+/!$\backslash$ This section of the document is in draft form and is not ready to be used
yet.
Tim Sutton, 2007
-\subsection{System preparation}
+\subsubsection{System preparation}
I started with a clean XP install with Service Pack 2 and all patches applied.
I have already compiled all the dependencies you need for gdal, expat etc,
so this tutorial wont cover compiling those from source too. Since compiling
@@ -1894,7 +1760,7 @@
* Compile QGIS
* Create setup.exe installer for QGIS
-\subsection{Install the libraries archive}
+\subsubsection{Install the libraries archive}
Half of the point of this section of the MSVC setup procedure is to make
things as simple as possible for you. To that end I have prepared an
archive that includes all dependencies needed to build QGIS except Qt
@@ -1917,17 +1783,17 @@
c:\dev\cpp\qgislibs-release
\end{verbatim}
-\textbf{Note}: Note that you are not obliged to use this directory layout, but you
+/!$\backslash$ Note that you are not obliged to use this directory layout, but you
should adjust any instructions that follow if you plan to do things
differently.
-\subsection{Install Visual Studio Express 2005}
+\subsubsection{Install Visual Studio Express 2005}
First thing we need to get is MSVC Express from here:
-\url{http://msdn2.microsoft.com/en-us/express/aa975050.aspx}
+\htmladdnormallink{http://msdn2.microsoft.com/en-us/express/aa975050.aspx}{http://msdn2.microsoft.com/en-us/express/aa975050.aspx}
-The page is really confusing so dont feel bad if you cant actually find the
-download at first! There are six coloured blocks on the page for the various
+The page is really confusing so don't feel bad if you cant actually find the
+download at first! There are six colored blocks on the page for the various
studio family members (vb / c\# / j\# etc). Simply choose your language under
the 'select your language' combo under the yellow C++ block, and your download
will begin. Under internet explorer I had to disable popup blocking for the
@@ -1936,7 +1802,7 @@
Once the setup commences you will be prompted with various options. Here is what
I chose :
- * Send useage information to Microsoft (No)
+ * Send usage information to Microsoft (No)
* Install options:
* Graphical IDE (Yes)
* Microsoft MSDN Express Edition (No)
@@ -1946,10 +1812,10 @@
It will need to download around 90mb of installation files and reports
that the install will consume 554mb of disk space.
-\subsection{Install Microsoft Platform SDK2}
+\subsubsection{Install Microsoft Platform SDK2}
Go to this page:
-\url{http://msdn2.microsoft.com/en-us/express/aa700755.aspx}
+\htmladdnormallink{http://msdn2.microsoft.com/en-us/express/aa700755.aspx}{http://msdn2.microsoft.com/en-us/express/aa700755.aspx}
Start by using the link provided on the above page to download and install the
platform SDK2.
@@ -2017,9 +1883,9 @@
Debuggin Tools for Windows (Yes)
\end{verbatim}
-\textbf{Note}: Note that you can always come back later to add extra bits if you like.
+/!$\backslash$ Note that you can always come back later to add extra bits if you like.
-\textbf{Note}: Note that installing the SDK requires validation with the
+/!$\backslash$ Note that installing the SDK requires validation with the
Microsoft Genuine Advantage application. Some people have a philosophical
objection to installing this software on their computers. If you are one
of them you should probably consider using the MINGW build instructions
@@ -2079,7 +1945,7 @@
The notes go on to show how to build a mswin32 application which you can try if you like -
I'm not going to recover that here.
-\subsection{Edit your vsvars}
+\subsubsection{Edit your vsvars}
Backup your vsvars32.bat file in
\begin{verbatim}
@@ -2104,27 +1970,24 @@
@rem
@set DevEnvDir=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE
- at set PATH=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE;\
-C:\Program Files\Microsoft Visual Studio 8\VC\BIN;\
-C:\Program Files\Microsoft Visual Studio 8\Common7\Tools;\
-C:\Program Files\Microsoft Visual Studio 8\SDK\v2.0\bin;\
-C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;\
-C:\Program Files\Microsoft Visual Studio 8\VC\VCPackages;%PATH%
+ at set PATH=C:\Program Files\Microsoft Visual Studio 8\Common7\IDE;C:\Program \
+Files\Microsoft Visual Studio 8\VC\BIN;C:\Program Files\Microsoft Visual \
+Studio 8\Common7\Tools;C:\Program Files\Microsoft Visual Studio \
+8\SDK\v2.0\bin;C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727;C:\Program \
+Files\Microsoft Visual Studio 8\VC\VCPackages;%PATH%
@rem added by Tim
- at set PATH=C:\Program Files\Microsoft Platform SDK for Windows \
-Server 2003 R2\Bin;%PATH%
+ at set PATH=C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\Bin;%PATH%
@set INCLUDE=C:\Program Files\Microsoft Visual Studio 8\VC\INCLUDE;%INCLUDE%
@rem added by Tim
- at set INCLUDE=C:\Program Files\Microsoft Platform SDK for Windows \
-Server 2003 R2\Include;%INCLUDE%
-Server 2003 R2\Include\mfc;%INCLUDE%
+ at set INCLUDE=C:\Program Files\Microsoft Platform SDK for Windows Server \
+2003 R2\Include;%INCLUDE%
+2003 R2\Include\mfc;%INCLUDE%
@set INCLUDE=%INCLUDE%;C:\dev\cpp\qgislibs-release\include\postgresql
- at set LIB=C:\Program Files\Microsoft Visual Studio 8\VC\LIB;\
-C:\Program Files\Microsoft Visual Studio 8\SDK\v2.0\lib;%LIB%
+ at set LIB=C:\Program Files\Microsoft Visual Studio 8\VC\LIB;C:\Program \
+Files\Microsoft Visual Studio 8\SDK\v2.0\lib;%LIB%
@rem added by Tim
- at set LIB=C:\Program Files\Microsoft Platform SDK for Windows \
-Server 2003 R2\Lib;%LIB%
+ at set LIB=C:\Program Files\Microsoft Platform SDK for Windows Server 2003 R2\Lib;%LIB%
@set LIB=%LIB%;C:\dev\cpp\qgislibs-release\lib
@set LIBPATH=C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
@@ -2142,9 +2005,9 @@
\end{verbatim}
-\subsection{Environment Variables}
+\subsubsection{Environment Variables}
Right click on 'My computer' then select the 'Advanced' tab. Click environment variables and
-create or augment the following '''System''' variables (if they dont already exist):
+create or augment the following '''System''' variables (if they don't already exist):
\begin{verbatim}
Variable Name: Value:
@@ -2173,7 +2036,7 @@
SVN_SSH "C:\\Program Files\\PuTTY\\plink.exe"
\end{verbatim}
-\subsection{Building Qt4.3.2}
+\subsubsection{Building Qt4.3.2}
You need a minimum of Qt 4.3.2 here since this is the first version to officially
support building the open source version of Qt for windows under MSVC.
@@ -2189,7 +2052,7 @@
c:\Qt\4.x.x\
\end{verbatim}
-\subsubsection{Compile Qt}
+\minisec{Compile Qt}
Open the Visual Studio C++ command line and cd to c:$\backslash$Qt$\backslash$4.x.x where you
extracted the source and enter:
@@ -2202,12 +2065,12 @@
Add -qt-sql-odbc -qt-sql-psql to the configure line if your want odbc and
PostgreSQL support build into Qt.
-\textbf{Note}: Note: For me in some cases I got a build error on qscreenshot.pro. If you
+/!$\backslash$ Note: For me in some cases I got a build error on qscreenshot.pro. If you
are only interested in having the libraries needed for building Qt apps, you
can probably ignore that. Just check in c:$\backslash$Qt$\backslash$4.3.2$\backslash$bin to check all dlls and
helper apps (assistant etc) have been made.
-\subsubsection{Configure Visual C++ to use Qt}
+\minisec{Configure Visual C++ to use Qt}
After building configure the Visual Studio Express IDE to use Qt:
1) open Visual Studio Express IDE
@@ -2255,11 +2118,11 @@
feel free to add some - I just needed QString and took the first hit in google
I could find.
-\subsection{Install Python}
-Download \url{http://python.org/ftp/python/2.5.1/python-2.5.1.msi} and install it.
+\subsubsection{Install Python}
+Download \htmladdnormallink{http://python.org/ftp/python/2.5.1/python-2.5.1.msi}{http://python.org/ftp/python/2.5.1/python-2.5.1.msi} and install it.
-\subsection{Install SIP}
-Download \url{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip} and extract it
+\subsubsection{Install SIP}
+Download \htmladdnormallink{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip}{http://www.riverbankcomputing.com/Downloads/sip4/sip-4.7.1.zip} and extract it
into your c:$\backslash$dev$\backslash$cpp directory.
From a Visual C++ command line cd to the directory where you extract SIP and run:
@@ -2269,8 +2132,8 @@
nmake install
\end{verbatim}
-\subsection{Install PyQt4}
-Download \url{http://www.riverbankcomputing.com/Downloads/PyQt4/GPL/PyQt-win-gpl-4.3.1.zip} and extract it
+\subsubsection{Install PyQt4}
+Download \htmladdnormallink{http://www.riverbankcomputing.com/Downloads/PyQt4/GPL/PyQt-win-gpl-4.3.1.zip}{http://www.riverbankcomputing.com/Downloads/PyQt4/GPL/PyQt-win-gpl-4.3.1.zip} and extract it
From a Visual C++ command line cd to the directory where you extracted PyQt4 and run:
@@ -2280,7 +2143,7 @@
nmake install
\end{verbatim}
-\subsection{Install CMake}
+\subsubsection{Install CMake}
Download and install cmake 2.4.7 or better, making sure to enable the
option
@@ -2288,12 +2151,12 @@
Update path for all users
\end{verbatim}
-\subsection{Install Subversion}
+\subsubsection{Install Subversion}
You '''must''' install the command line version if you want the CMake svn scripts to work.
Its a bit tricky to find the correct version on the subversion download site as they have
som misleadingly named similar downloads. Easiest is to just get this file:
-\url{http://subversion.tigris.org/downloads/1.4.5-win32/apache-2.2/svn-win32-1.4.5.zip}
+\htmladdnormallink{http://subversion.tigris.org/downloads/1.4.5-win32/apache-2.2/svn-win32-1.4.5.zip}{http://subversion.tigris.org/downloads/1.4.5-win32/apache-2.2/svn-win32-1.4.5.zip}
Extract the zip file to
@@ -2309,7 +2172,7 @@
To your path.
-\subsection{Initial SVN Check out}
+\subsubsection{Initial SVN Check out}
Open a cmd.exe window and do:
\begin{verbatim}
@@ -2336,7 +2199,7 @@
Press 'p' to accept and the svn checkout will commence.
-\subsection{Create Makefiles using cmakesetup.exe}
+\subsubsection{Create Makefiles using cmakesetup.exe}
I wont be giving a detailed description of the build process, because
the process is explained in the first section (where you manually build
all dependencies) of the windows build notes in this document. Just skip
@@ -2376,7 +2239,9 @@
Once the build completes right click on INSTALL in the solution browser and
choose build. This will by default install qgis into c:$\backslash$program files$\backslash$qgisX.X.X.
-\subsection{Running and packaging}
+\subsubsection{Running and packaging}
To run QGIS you need to at the minimum copy the dlls from c:$\backslash$dev$\backslash$cpp$\backslash$qgislibs-release$\backslash$bin
into the c:$\backslash$program files$\backslash$qgisX.X.X directory.
Modified: docs/trunk/english_us/coding-compilation_guide/qgis_style.sty
--- docs/trunk/english_us/coding-compilation_guide/qgis_style.sty 2010-03-21 09:36:18 UTC (rev 13127)
+++ docs/trunk/english_us/coding-compilation_guide/qgis_style.sty 2010-03-21 11:30:13 UTC (rev 13128)
@@ -173,8 +173,8 @@
\usepackage{xspace}
%Macros QGIS Versions
-\def\CURRENT{1.3\xspace}
-\def\OLD{1.2\xspace}
+\def\CURRENT{1.4\xspace}
+\def\OLD{1.3\xspace}
\def\VERYOLD{1.0\xspace}
% add disclaimer about the revision status of a section
Modified: docs/trunk/english_us/coding-compilation_guide/title.tex
--- docs/trunk/english_us/coding-compilation_guide/title.tex 2010-03-21 09:36:18 UTC (rev 13127)
+++ docs/trunk/english_us/coding-compilation_guide/title.tex 2010-03-21 11:30:13 UTC (rev 13128)
@@ -15,7 +15,7 @@
\Large{Coding and Compilation Guide} \\
\vspace{0.5cm}
%\includegraphics[clip=true, scale=0.4]{splash}
-\Large{Version ~\CURRENT \textsl{'Mimas'}}
+\Large{Version ~\CURRENT \textsl{'Enceladus'}}
\end{center}
\end{titlepage}
