[QGIS Commit] r13154 - in trunk/qgis/src: app/composer core/composer
svn_qgis at osgeo.org
Wed Mar 24 12:37:41 EDT 2010
Author: mhugent
Date: 2010-03-24 12:37:40 -0400 (Wed, 24 Mar 2010)
New Revision: 13154
trunk/qgis/src/app/composer/qgscomposer.cpp
trunk/qgis/src/core/composer/qgscomposermap.cpp
trunk/qgis/src/core/composer/qgscomposermap.h
Code for drawing items in composer map. Not yet enabled
Modified: trunk/qgis/src/app/composer/qgscomposer.cpp
--- trunk/qgis/src/app/composer/qgscomposer.cpp 2010-03-24 15:46:13 UTC (rev 13153)
+++ trunk/qgis/src/app/composer/qgscomposer.cpp 2010-03-24 16:37:40 UTC (rev 13154)
@@ -1315,6 +1315,7 @@
return;
+ map->setMapCanvas( mapCanvas() ); //set canvas to composer map to have the possibility to draw canvas items
QgsComposerMapWidget* mapWidget = new QgsComposerMapWidget( map );
connect( this, SIGNAL( zoomLevelChanged() ), map, SLOT( renderModeUpdateCachedImage() ) );
mItemWidgetMap.insert( map, mapWidget );
Modified: trunk/qgis/src/core/composer/qgscomposermap.cpp
--- trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-03-24 15:46:13 UTC (rev 13153)
+++ trunk/qgis/src/core/composer/qgscomposermap.cpp 2010-03-24 16:37:40 UTC (rev 13154)
@@ -34,6 +34,7 @@
#include "qgslabelattributes.h"
#include <QGraphicsScene>
+#include <QGraphicsView>
#include <QPainter>
#include <QSettings>
#include <iostream>
@@ -42,7 +43,7 @@
QgsComposerMap::QgsComposerMap( QgsComposition *composition, int x, int y, int width, int height )
: QgsComposerItem( x, y, width, height, composition ), mKeepLayerSet( false ), mGridEnabled( false ), mGridStyle( Solid ), \
mGridIntervalX( 0.0 ), mGridIntervalY( 0.0 ), mGridOffsetX( 0.0 ), mGridOffsetY( 0.0 ), mGridAnnotationPrecision( 3 ), mShowGridAnnotation( false ), \
- mGridAnnotationPosition( OutsideMapFrame ), mAnnotationFrameDistance( 1.0 ), mGridAnnotationDirection( Horizontal ), mCrossLength( 3 )
+ mGridAnnotationPosition( OutsideMapFrame ), mAnnotationFrameDistance( 1.0 ), mGridAnnotationDirection( Horizontal ), mCrossLength( 3 ), mMapCanvas( 0 )
mComposition = composition;
mId = mComposition->composerMapItems().size();
@@ -73,7 +74,7 @@
QgsComposerMap::QgsComposerMap( QgsComposition *composition )
: QgsComposerItem( 0, 0, 10, 10, composition ), mKeepLayerSet( false ), mGridEnabled( false ), mGridStyle( Solid ), \
//Offset
mXOffset = 0.0;
@@ -257,14 +258,19 @@
double yTopLeftShift = ( mExtent.yMaximum() - rotationPoint.y() ) * mapUnitsToMM();
painter->save();
- //painter->scale( scale, scale );
painter->translate( mXOffset, mYOffset );
painter->translate( xTopLeftShift, yTopLeftShift );
painter->rotate( mRotation );
painter->translate( xShiftMM, -yShiftMM );
painter->drawImage( 0, 0, mCacheImage );
+ //restore rotation
painter->restore();
+ //draw canvas items
+ //drawCanvasItems( painter, itemStyle );
else if ( mComposition->plotStyle() == QgsComposition::Print ||
mComposition->plotStyle() == QgsComposition::Postscript )
@@ -300,8 +306,13 @@
draw( painter, requestRectangle, theSize, 25.4 ); //scene coordinates seem to be in mm
painter->restore();
mDrawing = false;
@@ -1388,3 +1399,93 @@
return Bottom;
+void QgsComposerMap::drawCanvasItems( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle )
+ if ( !mMapCanvas )
+ return;
+ QList<QGraphicsItem*> itemList = mMapCanvas->items();
+ int nItems = itemList.size();
+ QList<QGraphicsItem*>::iterator itemIt = itemList.begin();
+ for ( ; itemIt != itemList.end(); ++itemIt )
+ //don't draw mapcanvasmap (has z value -10)
+ if ( !( *itemIt ) || ( *itemIt )->zValue() == -10 )
+ continue;
+ drawCanvasItem( *itemIt, painter, itemStyle );
+void QgsComposerMap::drawCanvasItem( QGraphicsItem* item, QPainter* painter, const QStyleOptionGraphicsItem* itemStyle )
+ if ( !item || !mMapCanvas || !mMapRenderer )
+ return;
+ painter->save();
+ //only for debugging
+ double itemPosX = item->scenePos().x();
+ double itemPosY = item->scenePos().y();
+ double cWidth = mMapCanvas->width();
+ double cHeight = mMapCanvas->height();
+ QgsRectangle rendererExtent = mMapRenderer->extent();
+ QgsRectangle composerMapExtent = mExtent;
+ //determine scale factor according to graphics view dpi
+ double scaleFactor = 1.0 / mMapCanvas->logicalDpiX() * 25.4;
+ double itemX, itemY;
+ QGraphicsItem* parent = item->parentItem();
+ if ( !parent )
+ QPointF mapPos = composerMapPosForItem( item );
+ itemX = mapPos.x();
+ itemY = mapPos.y();
+ else //place item relative to the parent item
+ QPointF itemScenePos = item->scenePos();
+ QPointF parentScenePos = parent->scenePos();
+ QPointF mapPos = composerMapPosForItem( parent );
+ itemX = mapPos.x() + ( itemScenePos.x() - parentScenePos.x() ) * scaleFactor;
+ itemY = mapPos.y() + ( itemScenePos.y() - parentScenePos.y() ) * scaleFactor;
+ painter->translate( itemX, itemY );
+ painter->scale( scaleFactor, scaleFactor );
+ item->paint( painter, itemStyle, 0 );
+ painter->restore();
+QPointF QgsComposerMap::composerMapPosForItem( const QGraphicsItem* item ) const
+ return QPointF( 0, 0 );
+ if ( mExtent.height() <= 0 || mExtent.width() <= 0 || mMapCanvas->width() <= 0 || mMapCanvas->height() <= 0 )
+ double mapX = item->scenePos().x() / mMapCanvas->width() * mMapRenderer->extent().width() + mMapRenderer->extent().xMinimum();
+ double mapY = mMapRenderer->extent().yMaximum() - item->scenePos().y() / mMapCanvas->height() * mMapRenderer->extent().height();
+ double itemX = rect().width() * ( mapX - mExtent.xMinimum() ) / mExtent.width();
+ double itemY = rect().height() * ( mExtent.yMaximum() - mapY ) / mExtent.height();
+ return QPointF( itemX, itemY );
Modified: trunk/qgis/src/core/composer/qgscomposermap.h
--- trunk/qgis/src/core/composer/qgscomposermap.h 2010-03-24 15:46:13 UTC (rev 13153)
+++ trunk/qgis/src/core/composer/qgscomposermap.h 2010-03-24 16:37:40 UTC (rev 13154)
@@ -27,6 +27,7 @@
class QgsMapToPixel;
class QDomNode;
class QDomDocument;
+class QGraphicsView;
class QPainter;
/** \ingroup MapComposer
@@ -245,6 +246,9 @@
void setMapRotation( double r );
+ /**Sets canvas pointer (necessary to query and draw map canvas items)*/
+ void setMapCanvas( QGraphicsView* canvas ) { mMapCanvas = canvas; }
public slots:
/**Called if map canvas has changed*/
@@ -341,6 +345,7 @@
QRectF mCurrentRectangle;
/**The length of the cross sides for mGridStyle Cross*/
double mCrossLength;
+ QGraphicsView* mMapCanvas;
/**Draws the map grid*/
void drawGrid( QPainter* p );
@@ -381,6 +386,10 @@
QPointF mapToItemCoords( const QPointF& mapCoords ) const;
/**Returns the item border of a point (in item coordinates)*/
Border borderForLineCoord( const QPointF& p ) const;
+ void drawCanvasItems( QPainter* painter, const QStyleOptionGraphicsItem* itemStyle );
+ void drawCanvasItem( QGraphicsItem* item, QPainter* painter, const QStyleOptionGraphicsItem* itemStyle );
+ QPointF composerMapPosForItem( const QGraphicsItem* item ) const;
#endif
